查看: 2838|回复: 0
[LV工具模块] LabVIEW 2011SP1 Mobile Module Win32Eng LabVIEW移动模块2011SP1版下载
    9 小时前
    发表于 2020-11-9 23:23:57 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2011SP1
    文件大小: 423189088 字节 (403.58 MB)
    修改日期: 2012-01-14 05:02
    MD5: d7f49f9cc96faad9158433cf1a1aeaed(可秒传)
    SHA1: fd3957516d2eefa248ca86a99ea108a9f6e9fae5
    SHA256: dfb5ab80d2877b73eec9424e64ae2034a284976bd195f7b655e0e483e50e8182
    CRC32: 1f246a7d
    Mobile2011SP1.txt (573 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2011 Mobile Module Readme
    Version 11.0
    June 2011
    This file contains important last-minute information about the LabVIEW 2011 Mobile Module, including installation issues.
    Installing the Mobile Module
    Resources
    Important Information
    Important Note to Customers
    National Instruments is discontinuing production and support for the Mobile Module. LabVIEW 2011 Mobile Module is the final version. For existing users of the Mobile Module, National Instruments will continue to offer extended support for this module according to the guidelines found in the NI LabVIEW Lifecycle Policy.
    The Mobile Module has the following system requirements:
    • LabVIEW 2011 Base, Full, or Professional Development System (32-bit)
    • 2.5 GB available disk space
    • A Mobile device running Windows Mobile 5.0, Windows Mobile 6.0, or Pocket PC 2003
      Note  Refer to the KnowledgeBase at ni.com for more information about additional software requirements and supported devices for Windows Mobile and Pocket PC.
    The Mobile Module supports the following operating systems:
    • Windows 7 (32-bit)
    • Windows Vista (32-bit)
    • Windows XP Service Pack 2 or later (32-bit)
    The Mobile Module does not support Windows NT/Me/98/95/2000, Windows Server non-R2 editions, or the Windows Server 2008 R2 edition.
    You can install all of your LabVIEW products—including the Mobile Module—using the LabVIEW 2011 Platform DVDs. You can find installation instructions for the Mobile Module along with activation instructions in the following locations:
    • LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    Additional Installation Information
    This section contains information that you might find helpful as you install the Mobile Module.
    • The Mobile Module runs in evaluation mode if you do not activate it. In evaluation mode, you can create VIs, but any Mobile applications you build run only for five minutes. You have the option of activating the Mobile Module during the installation process. You also can use the NI License Manager, available by selecting Start»All Programs»National Instruments»NI License Manager, to activate National Instruments products. Refer to the National Instruments License Manager Help, available by selecting Help»Contents in the NI License Manager, for more information about activating NI products.
    • The Mobile Module includes Microsoft tools, such as Microsoft ActiveSync on Windows XP. Some of these Microsoft tools might interfere with any existing installations of Visual Studio, Windows Embedded, or Windows CE toolkits.
    • (Windows XP) The Mobile Module installs ActiveSync 4.2 if you do not already have ActiveSync 4.2 or later installed. The Mobile Module works with ActiveSync 4.2 or later.
    • (Windows Vista/7) You must install Windows Mobile Device Center to use the Mobile Module. Refer to the Microsoft Web site at www.microsoft.com to download Windows Mobile Device Center.
    • (Windows Vista/7) If you are using the LabVIEW Mobile Module on Windows Vista or Windows 7 operating systems, you need to install Virtual PC 2007 to debug your application on the emulator. Refer to the Microsoft Web site at www.microsoft.com to download Virtual PC 2007.
    • You might need to install the additional tools, such as NI-DAQmxBase, PNG image support, Shared Variable support, WIDCOMM Bluetooth DLLs, LabVIEW SMS client, NI-VISA, or Windows Mobile Emulators to use the Mobile Module. Refer to the Installing Additional Tools section of the Getting Started with the LabVIEW Mobile Module manual for more information about additional tools.
      Note  The LabVIEW 2011 Mobile Module includes a new version of the LabVIEW Short Message Service (SMS) Client. Mobile applications built in LabVIEW 2010 Module Module and earlier are not compatible with this new version of the SMS Client. You must install and run the LabVIEW SMS Client, which is located in labview\PDA\Utilities\SMS\device\Setup.exe, on the host computer to receive SMS messages.
    Uninstalling the Mobile Module
    If you uninstall the Mobile Module, you also must uninstall the following:
    • (Windows XP) Microsoft ActiveSync
    • (Windows Vista/7) Windows Mobile Device Center
    • Microsoft Device Emulator version 1.0 – ENU
    • Microsoft Visual C++ 2005 Redistributable
    Using Microsoft Silverlight
    Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2011 Mobile Module.
    Refer to the National Instruments Web site for an up-to-date list of fixed issues in the LabVIEW 2011 Mobile Module.
    Resources
    LabVIEW includes extensive online and PDF documentation for new and experienced LabVIEW users. Refer to the Related Documentation section in the Getting Started with the NI LabVIEW Mobile Module manual for more information about LabVIEW documentation. Visit the National Instruments Web site at ni.com for software drivers and updates, a searchable KnowledgeBase, product manuals, step-by-step troubleshooting wizards, thousands of example programs, tutorials, application notes, instrument drivers, and so on.
    GMT+8, 2025-12-8 18:28
