LabVIEW 2011 PID and Fuzzy Logic Toolkit Win32Eng LabVIEW PID和模糊逻辑工具包2011版下载
2011
文件大小: 63965792 字节 (61.00 MB)
修改日期: 2011-07-09 01:21
MD5: 7a1bb2e7cbf63185a24fab4b38e45978(重复下载一致)
SHA1: 2044744c54efd3a38452031f3e333e08f30e5f21
SHA256: b345c48e698358f331c7e00ca550496cf2d2ea2f1b14cba73f07434288ccce88
CRC32: 179d74f2
PID FLT2011.txt
(584 Bytes, 下载次数: 1, 售价: 10 圆)
LabVIEW 2011 PID and Fuzzy Logic Toolkit ReadmeVersion 11.0.0 June 2011 This file contains the following information about the LabVIEW 2011 PID and Fuzzy Logic Toolkit. System Requirements Version 2011 Features and Changes Installation/Upgrading Instructions Accessing the Help Finding Examples Known Issues Bug Fixes System RequirementsThe computer you are using must meet the following minimum system requirements to run the PID and Fuzzy Logic Toolkit: - LabVIEW 2011 Full or Professional Development System (32-bit)
Supported Operating SystemsYou can run the LabVIEW PID and Fuzzy Logic Toolkit installer on the following operating systems: - Windows 7 (32-bit and 64-bit)
- Windows Vista (32-bit and 64-bit)
- Windows XP Service Pack 2 or later (32-bit)
- Windows Server 2003 R2 (32-bit)
- Windows Server 2008 R2 (64-bit)
The LabVIEW PID and Fuzzy Logic Toolkit installer does not support Windows XP SP1 or earlier/2000/NT/Me/98/95 or the Windows Server non-R2 editions. Version 2011 Features and ChangesThe LabVIEW 2011 PID and Fuzzy Logic Toolkit incorporates the following new features and changes. Autotuning EnhancementsThe LabVIEW 2011 PID and Fuzzy Logic Toolkit includes enhanced autotuning functionality provided by several new VIs. These enhancements enable you to configure autotuning programmatically without using the Autotuning Wizard, use autotuning in RT and FPGA applications, directly control temperature systems, and design autotuning solutions based on Cohen-Coon and Chien-Hrones-Reswick tuning methods. These updates include the following new VIs: - PID Advanced Autotuning
- PID Online Autotuning
- PID Autotuning Design
- PID Autotuning (Temperature)
Refer to the Autotuning PID Controllers book, located under Toolkits» PID and Fuzzy Logic Toolkit» PID Control in the LabVIEW Help, for more information. New VIsThe LabVIEW 2011 PID and Fuzzy Logic Toolkit includes the following new VIs: - PID Structure Conversion—Converts a PID controller or controllers in Academic, Parallel, or Series form into the form (Academic) and PID gains units that the PID VIs expect.
Updated VIThe LabVIEW 2011 PID and Fuzzy Logic Toolkit includes the following updated VI: - PID Advanced—The PID Advanced VI includes the following new inputs that provide additional configuration options for PID controllers you implement with this VI:
- gamma—Specifies an amount by which to weight the error applied to derivative action.
- alpha—Specifies the derivative filter time constant
Refer to the PID VIs book, located under Toolkits» PID and Fuzzy Logic Toolkit» PID and Fuzzy Logic Toolkit VIs in the LabVIEW Help for more information about these new and updated VIs. Notice of Upcoming ChangesThe Advanced VIs were deprecated in the LabVIEW 8.2 PID Control Toolkit. The LabVIEW PID and Fuzzy Logic Toolkit still supports applications that use these VIs. However, note that a future version of the PID and Fuzzy Logic Toolkit might no longer support these VIs. National Instruments strongly recommends that you use the LabVIEW Control Design and Simulation Module to replace the functionality of these VIs. Refer to the National Instruments Web site at ni.com for more information about the Control Design and Simulation Module. Installation/Upgrading InstructionsYou can install all of your LabVIEW products—including the LabVIEW PID and Fuzzy Logic Toolkit—using the LabVIEW 2011 Platform DVDs. You can find installation instructions for the PID and Fuzzy Logic Toolkit along with activation instructions in the following locations: - LabVIEW Release Notes, which are available in your LabVIEW software kit.
- LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site. Note: If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product. Accessing the HelpThe PID and Fuzzy Logic Toolkit Help contains conceptual, how-to, and reference information about the PID and Fuzzy Logic Toolkit. Complete the following steps to access this help file. - Launch LabVIEW.
- Select Help»LabVIEW Help to launch the LabVIEW Help.
- Click the Contents tab.
- Navigate to the Toolkits» PID and Fuzzy Logic Toolkit top-level topic.
Finding ExamplesRefer to the labview\examples\control directory for example VIs that demonstrate common tasks using the PID and Fuzzy Logic Toolkit. You also can access these VIs by selecting Help»Find Examples from the pull-down menu and selecting Toolkits and Modules» PID Control in the NI Example Finder window. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. Known IssuesYou can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2011 PID and Fuzzy Logic Toolkit. Bug FixesThe following items are the IDs and titles of a subset of issues fixed between the LabVIEW 2010 PID and Fuzzy Logic Toolkit and the LabVIEW 2011 PID and Fuzzy Logic Toolkit. This is not an exhaustive list of issues fixed in the current version of the PID and Fuzzy Logic Toolkit. If you have a CAR ID, you can search this list to validate the issue has been fixed. | ID | Fixed Issue | | 287441 | Fuzzy System Designer needs keyboard shortcuts in run-time menu |
Important InformationCopyright © 2011 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. Trademarks LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents. |
