查看: 3578|回复: 0
[LV工具模块] LabVIEW 2012 PID and Fuzzy Logic Toolkit Win32Eng LabVIEW PID和模糊逻辑工具包2012版下载
    昨天 15:52
  • 签到天数: 3749 天
    连续签到: 76 天
    发表于 2020-11-9 23:44:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2012
    文件大小: 64457352 字节 (61.47 MB)
    修改日期: 2012-06-15 22:16
    MD5: b4d9ebc07c65603b3b96f2abf1ed8ae9(重复下载一致)
    SHA1: eeaf7b2b630c5ec0904b724c79883301aca0a2a7
    SHA256: 985c9901595fc6a0029b8efaa3cb4351b8445e054dcd839704ea1905ff93596c
    CRC32: e0ed126c
    PID FLT2012.txt (584 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2012 PID and Fuzzy Logic Toolkit Readme
    Version 12.0.0
    June 2012
    This file contains important information about the LabVIEW 2012 PID and Fuzzy Logic Toolkit, including installation instructions, behavior changes, and known issues.
    Installation/Upgrading Instructions
    Version 2012 Change
    In addition to the system requirements for the LabVIEW Development System, the PID and Fuzzy Logic Toolkit has the following requirements:
    • LabVIEW 2012 Full or Professional Development System (32-bit)
    • At least 75 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2012.
    You can install all of your LabVIEW products—including the PID and Fuzzy Logic Toolkit—using the LabVIEW 2012 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    Version 2012 Change
    In the PID and Fuzzy Logic Toolkit 2011 and earlier, the PID Structure Conversion VI converts controllers in Parallel form to Academic form using the following transformation for the integral value: Td = K * Kd. In the PID and Fuzzy Logic Toolkit 2012, the PID Structure Conversion VI converts the integral value using the following transformation: Td = Kd / K.
    To continue using the behavior from the previous versions, use the VI located at \examples\control\PID\subVIs\Convert PID Parameters.vi.
    Refer to the the Toolkits» PID and Fuzzy Logic Toolkit» PID Control» PID Algorithms» PID Topologies topic on the Contents tab of the LabVIEW Help for more information about different forms of PID controllers.
    Notice of Upcoming Changes
    The Advanced VIs were deprecated in the LabVIEW 8.2 PID Control Toolkit. The LabVIEW PID and Fuzzy Logic Toolkit still supports applications that use these VIs. However, note that a future version of the PID and Fuzzy Logic Toolkit might no longer support these VIs. National Instruments strongly recommends that you use the LabVIEW Control Design and Simulation Module to replace the functionality of these VIs. Refer to the National Instruments website at ni.com for more information about the Control Design and Simulation Module.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the LabVIEW 2012 PID and Fuzzy Logic Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2012 PID and Fuzzy Logic Toolkit. This is not an exhaustive list of issues fixed in the current version of the PID and Fuzzy Logic Toolkit. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    177698Center of Sums, Center of Maximum, Mean of Maximum may give NaN result
    The PID and Fuzzy Logic Toolkit Help contains conceptual, how-to, and reference information about the PID and Fuzzy Logic Toolkit. Complete the following steps to access this help file.
    • Launch LabVIEW.
    • Select Help»LabVIEW Help to launch the LabVIEW Help.
    • Click the Contents tab.
    • Navigate to the Toolkits» PID and Fuzzy Logic Toolkit top-level topic.
    Refer to the labview\examples\control directory for example VIs that demonstrate common tasks using the PID and Fuzzy Logic Toolkit. You also can access these VIs by selecting Help»Find Examples from the pull-down menu and selecting Toolkits and Modules» PID and Fuzzy Logic Control in the NI Example Finder window. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Important Information
    © 2009–2012 National Instruments. All rights reserved.
    GMT+8, 2025-12-22 20:05
