LabVIEWӾ
 һ
 עԱ
б
鿴: 2762|ظ: 0
[LVģ] LabVIEW 2011 Real-Time Execution Trace Toolkit Win32Eng LabVIEWʵʱϵͳִиģRETT2011
  • TAÿ
    4 Сʱǰ
  • ǩ: 3733
    ǩ: 60
    2020-11-10 23:20:55 | ʾȫ¥ |Ķģʽ ԣ㶫ʡݸ ͨ
    ע½ɲ鿴ʹͼԼ
    Ҫ ¼ ſػ鿴û˺ţעԱ
    Windowsϵͳ£LinuxMACϵͳ˽NIĸģ顢߰ʹNI֤ģ󲿷ֵĶʹNI Lincense ActivatorNIкSerial NumberɼNI License ActivatorLabVIEW/VBAI/VDM/VASģ鹤߰ƽ⹤߲ް汾http://visionbbs.com/thread-490-1-1.html
    Ӿ̳ĸNIԴӾصģʹ⣬󲿷ֵĶʹãṩԴṩ֧֡ԴصַһͬʱṩNIٷͰٶ̵ĵַijЩ߰NIַʧЧûNIַֻʹðٶ̵ַٶ̵ַʧЧڣϵ̳ͷ¡NIķʱٶȺ׳ɰװʱִ޷װɺ󣬶ԴУ(NIһṩMD5SHA256)֤ٷӾ̳ṩУͶԱȣһ¾Ϳ԰װ粻һ£ҪءӾ̳ϴԴ϶صԴ2019صԴNIȷУͶԱȹ֤ȷԴϴٶ̡У͹صַļHashFHashļУ֤ļȷ֤MD5ֵ㡢SHA1ֵ㡢SHA256ֵ㡢CRC32ֵhttp://visionbbs.com/thread-26524-1-1.html
    National Instruments Real-Time Execution Traceִи٣߰ڷ͵LabVIEW Real-TimeLabWindows/CVI Real-TimeնӦóĶʱԡ ù߰ڲ񲢲鿴ִиټ¼ִиټ¼һʱʾVIͲϵͳ̡߳
    2011
    ļС: 137579104 ֽ (131.21 MB)
    ޸: 2011-06-29 05:10
    MD5: 31904ec8fd47f41286b1529d70e20ba8ظһ£
    SHA1: 50ec56aa733f2993c125b9c2e920975a0c5537d3
    SHA256: bceaf389982f3c6c5606f13de1f3d648cd22e6121edeee47a15a52a968cfc754
    CRC32: 0a383d68
    ٶ̺NIٷصַ
    RETT2011.txt (580 Bytes, ش: 0, ۼ: 10 Բ)
    Real-Time Execution Trace Toolkit 2.0 Readme
    August 2007
    LabVIEW Real-Time Module or LabWindowsTM/CVITM Real-Time Module
    Complete the following steps to install the Real-Time Execution Trace Toolkit. Installing the Real-Time Execution Trace Toolkit 2.0 removes any existing previous versions of the LabVIEW Execution Trace Toolkit.
    • Insert the CD that contains the Real-Time Execution Trace Toolkit.
    • Run the setup.exe program.
    Accessing the Help from LabVIEW
    Refer to the LabVIEW Help, accessible by selecting Help»Search the LabVIEW Help from the pull-down menu in LabVIEW, for information about the Execution Trace Toolkit VIs.
    Accessing the Help from LabWindows/CVI
    Refer to the LabWindows/CVI Help, accessible by selecting Help»Contents in LabWindows/CVI, for information about using the Real-Time Execution Trace Toolkit in LabWindows/CVI.
    Finding Examples in LabVIEW
    LabVIEW examples for the Real-Time Execution Trace Toolkit are located in the labview\examples\tracetool\ folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find example VIs using the NI Example Finder. Select Help»Find Examples to launch the NI Example Finder. You also can click the arrow on the Open button on the LabVIEW dialog box and select Examples from the shortcut menu to launch the NI Example Finder.
    Use the Browse or Search page of the NI Example Finder to find an example VI. In the Browse page, the Real-Time Execution Trace Toolkit examples are located in the Toolkits and Modules»Execution Trace Toolkit folder.
    Finding Examples in LabWindows/CVI
    You can find example programs using the NI Example Finder. Select Help»Find Examples in LabWindows/CVI to launch the NI Example Finder.
    The Real-Time Execution Trace Toolkit 2.0 includes the following known issues at the time of release.
    • Events near the end of the trace may not be visible until zoomed in.
    The Execution Trace Toolkit 2.0 includes the following bug fixes.
    Bug IDFixed Issue
    3QJDKD1RTimed Loops did not report correct priorities.
    © 2005C2007 National Instruments Corporation. All rights reserved.
    National Instruments, NI, ni.com, LabVIEW, LabVIEW Real-Time Module, LabWindows/CVI Real-Time Module, and Real-Time Execution Trace Toolkit are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    The mark LabWindows is used under a license from Microsoft Corporation.
    ظ
    ʹõ ٱ
    б
    LabVIEW HALCONͼŽ̳̣24.09
    ʯλӾLabVIEW VisionͼPDF+Ƶ̳11ȫ
    LabVIEW Visionʵ2020-2024̳-NI Visionкʹ÷ܣNI VISION2020VDM21/22/23/24
    QQ|LabVIEWӾ |վͼ
    GMT+8, 2025-12-5 12:47
    ٻظ ض б
