查看: 3314|回复: 0
[LV工具模块] LabVIEW 2010 System Identification Toolkit Win32Eng LabVIEW系统辨识工具包2010版下载
    1 小时前
    发表于 2020-11-10 23:34:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    System Identification(系统识别)工具包可用于为现实设备建立数学模型。 该工具包中包含数据预处理、模型估计、分析和验证工具。 通过选择参数、非参数、递归、部分已知等模型估计方法,可识别表述现实设备特性的系统模型。 将识别出的系统模型与Control Design and Simulation模块以及Real-Time模块整合在一起,可完成控制设计的整个过程。
    2010
    文件大小: 103574112 字节 (98.78 MB)
    修改日期: 2010-06-23 15:21
    MD5: 4e772a17b5c0c042c2ca500abe331a15(重复下载一致)
    SHA1: e55330eb61336e62cd124f31b5718ffdcb08b1ee
    SHA256: 3a27b596a1a63e08c42a3c637353d3061f59e9a5779ab77d4a11e92954711d00
    CRC32: cdce37a9
    百度和NI官方下载地址:
    SYSID2010.txt (593 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2010 System Identification Toolkit Readme
    Version 10.0.0
    June 2010
    This file contains information to introduce you to the LabVIEW 2010 System Identification Toolkit. This file also provides you with help resources you can use while working with this toolkit. The file contains the following information that you need to understand.
    New Features and Changes
    The System Identification Toolkit provides an assistant and a library of VIs for developing models of a system based on a large set of raw data. Both tools enable you to complete the entire system identification process, from analyzing the raw data to validating the identified model.
    Refer to the LabVIEW System Identification Assistant Readme, accessible by opening the Readme_SIAssit.html file in the Readme directory of LabVIEW Platform DVD 1, for instructions of installing the System Identification Assistant.
    The following list contains the new features and changes of the System Identification Toolkit.
    • This version supports estimating transfer function models with step response signals. Estimate transfer function models with step response signals in either of the following methods:
      • Use the Step Response (WDT) instance VI and the Step Response (Array) instance VI of the SI Estimate Transfer Function Model VI.
      • Use the SI Transfer Function Estimation Express VI and configure the Signal type and Settings options of this Express VI.
    • This version improves the performance and determinism of the Recursive Model Estimation VIs.
    • This version includes the following new example VIs:
      • Belt-driven Motion System (Frequency Domain)—Refer to the Belt-driven Motion System (Frequency Domain) VI in the Toolkits and Modules»System Identification»Industry Applications»Mechanical Systems folder in the NI Example Finder for this example VI.
      • Belt-driven Motion System (Greybox)—Refer to the Belt-driven Motion System (Greybox) VI in the Toolkits and Modules»System Identification»Industry Applications»Mechanical Systems folder in the NI Example Finder for this example VI.
      • Belt-driven Motion System (User Defined)—Refer to the Belt-driven Motion System (User Defined) VI in the Toolkits and Modules»System Identification»Industry Applications»Mechanical Systems folder in the NI Example Finder for this example VI.
      • Quadruple Tank System—Refer to the Quadruple Tank System VI in the Toolkits and Modules»System Identification»Industry Applications» Process Industry Systems folder in the NI Example Finder for this example VI.
    • This version includes the following changed VIs:
      • SI Convert to Models of CDT—This VI moves from the Model Conversion palette to the System Identification palette.
      • SI Estimate FRF—This VI includes the coherence output to return the coherence and the frequency scale of the frequency response function (FRF).
      • Polynomial Model Estimation VIs—All Polynomial Model Estimation VIs move to the Parametric Model Estimation palette. The original Polynomial Model Estimation palette is deprecated.
    The computer you are using must meet the following minimum system requirements to run the System Identification Toolkit:
    • Supported operating systems:
      • Windows XP (32-bit)
    • 600 MB free disk space
    • LabVIEW 2010 Full or Professional Development System
    Note: The System Identification Toolkit does not support Windows 2000/NT/Me/98/95 or the Windows Server non-R2 editions.
    You can install all of your LabVIEW products—including the System Identification Toolkit—using the LabVIEW 2010 Platform DVDs. You can find installation instructions for the System Identification Toolkit along with activation instructions in the following locations:
    • LabVIEW 2010 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2010 Platform DVDs, refer to the National Instruments Web site.
    The System Identification Toolkit installer contains both the System Identification Assistant and the System Identification VIs. You must have LabVIEW SignalExpress installed to install the System Identification Assistant.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW, for conceptual information about using the System Identification Toolkit and information about the System Identification VIs.
    Refer to the LabVIEW System Identification Toolkit Algorithm References manual, accessible by opening the SIreference.pdf file in the labview\manuals directory, for information about algorithms implemented in the System Identification Toolkit and their corresponding references.
    You can access the examples for the System Identification Toolkit by selecting Help»Find Examples to display the NI Example Finder and then navigating to the Toolkits and Modules»System Identification folder. You also can click the Find Examples link in the Examples section of the Getting Started window to display the NI Example Finder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the System Identification Toolkit in the labview\examples\System Identification directory.
    Refer to the National Instruments Web site and enter the Info Code SYSID for more examples of using the System Identification Toolkit.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the System Identification Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2010 System Identification Toolkit. This is not an exhaustive list of issues fixed in the current version of the System Identification Toolkit.
    173602Incorrect example folder path in the Getting Started with the System Identification Assistant help
    177418Model Simulation VI cannot give correct result if transfer function only contains noise model
    191791Incorrect path in Example Load Model from File.vi in LabVIEW
    191797LabVIEW crashes when opening example Feedback Detection.vi
    201204The pole-zero cancellation tolerance for SI Discrete to Continuous Conversion VI Not Used In Calculations
    204236Cannot select 0 for the numerator order in the SI Transfer Function Estimation Express VI
    © 2010 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-12-8 11:02
