查看: 2977|回复: 0
[LV工具模块] LabVIEW 2011 System Identification Toolkit Win32Eng LabVIEW系统辨识工具包2011版下载
    1 小时前
    发表于 2020-11-10 23:37:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    System Identification(系统识别)工具包可用于为现实设备建立数学模型。 该工具包中包含数据预处理、模型估计、分析和验证工具。 通过选择参数、非参数、递归、部分已知等模型估计方法,可识别表述现实设备特性的系统模型。 将识别出的系统模型与Control Design and Simulation模块以及Real-Time模块整合在一起,可完成控制设计的整个过程。
    2011
    文件大小: 117103200 字节 (111.68 MB)
    修改日期: 2011-07-14 23:25
    MD5: 067a484f7268f703f382bf7c812b7851(重复下载一致)
    SHA1: 2ed53a28e77b7090c9c5db88841e8afd8b976539
    SHA256: d8a229682365d52e648767abd642399e28b66ac31f9d695e01cd96eaddbae3bc
    CRC32: e8636a0e
    百度和NI官方下载地址:
    SYSID2011.txt (588 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2011 System Identification Toolkit Readme
    Version 11.0.0
    June 2011
    This file contains information to introduce you to the LabVIEW 2011 System Identification Toolkit. This file also provides you with help resources you can use while working with this toolkit. The file contains the following information that you need to understand.
    New Features and Changes
    The LabVIEW 2011 System Identification Toolkit is the upgrade version of the LabVIEW 2010 System Identification Toolkit. The System Identification Toolkit provides an assistant and a library of VIs for developing models of a system based on a large set of raw data. Both tools enable you to complete the entire system identification process, from analyzing the raw data to validating the identified model.
    Refer to the LabVIEW System Identification Assistant Readme, accessible by opening the readme_SIAssit.html file in the Readme directory of LabVIEW Platform DVD 1, for instructions of installing the System Identification Assistant.
    • The LabVIEW 2011 System Identification Toolkit symbolic parser only supports all elements that the LabVIEW Mathematics VIs support. The following VIs are affected:
      • SI Create Partially Known State-Space Model VI
      Applications created with previous versions of the System Identification Toolkit that use unsupported elements might not be compatible with this release.
    Refer to the LabVIEW Help for more information about supported elements and exceptions.
    The computer you are using must meet the following minimum system requirements to run the System Identification Toolkit:
    • 600 MB free disk space
    • LabVIEW 2011 Full or Professional Development System (32-bit)
    You can run the System Identification Toolkit on the following operating systems:
    • Windows XP Service Pack 2 or later
    Note: The System Identification Toolkit does not support Windows 2000/NT/Me/98/95 or the Windows Server non-R2 editions.
    You can install all of your LabVIEW products—including the System Identification Toolkit—using the LabVIEW 2011 Platform DVDs. You can find installation instructions for the System Identification Toolkit along with activation instructions in the following locations:
    • LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    The System Identification Toolkit installer contains both the System Identification Assistant and the System Identification VIs. You must have LabVIEW SignalExpress installed to install the System Identification Assistant.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW, for conceptual information about using the System Identification Toolkit and information about the System Identification VIs.
    Refer to the LabVIEW System Identification Toolkit Algorithm References manual, accessible by opening the SIreference.pdf file in the labview\manuals directory, for information about algorithms implemented in the System Identification Toolkit and their corresponding references.
    You can access the examples for the System Identification Toolkit by selecting Help»Find Examples to display the NI Example Finder and then navigating to the Toolkits and Modules»System Identification folder. You also can click the Find Examples link in the Examples section of the Getting Started window to display the NI Example Finder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the System Identification Toolkit in the labview\examples\System Identification directory.
    Refer to the National Instruments Web site and enter the Info Code SYSID for more examples of using the System Identification Toolkit.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the System Identification Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2011 System Identification Toolkit. If you have a bug ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the System Identification Toolkit.
    Bug IDFixed Issue
    249413System Identification Toolkit does not support "a" as a symbolic variable
    GMT+8, 2025-12-8 11:02
