查看: 3134|回复: 0
[LV工具模块] LabVIEW 2012 System Identification Toolkit Win32Eng LabVIEW系统辨识工具包2012版下载
    1 小时前
    发表于 2020-11-10 23:39:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    System Identification(系统识别)工具包可用于为现实设备建立数学模型。 该工具包中包含数据预处理、模型估计、分析和验证工具。 通过选择参数、非参数、递归、部分已知等模型估计方法,可识别表述现实设备特性的系统模型。 将识别出的系统模型与Control Design and Simulation模块以及Real-Time模块整合在一起,可完成控制设计的整个过程。
    2012
    文件大小: 118616064 字节 (113.12 MB)
    修改日期: 2012-06-20 04:48
    MD5: 1f84a96cf013fe7af1f986e1016239dc(重复下载一致)
    SHA1: ec1a6441f7d0dbbde1bf63c39bd60c32d8bd46b4
    SHA256: 4329f95fb6866ea6263a37df49df8a64a488337ce68bfe635436c3e65ca0d7d2
    CRC32: ae816345
    百度和NI官方下载地址:
    SYSID2012.txt (590 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2012 System Identification Toolkit Readme
    Version 12.0.0
    June 2012
    This file contains information to introduce you to the LabVIEW 2012 System Identification Toolkit. This file also provides you with help resources you can use while working with this toolkit. The file contains the following information that you need to understand.
    The LabVIEW 2012 System Identification Toolkit is the upgrade version of the LabVIEW 2011 System Identification Toolkit. The System Identification Toolkit provides an assistant and a library of VIs for developing models of a system based on a large set of raw data. Both tools enable you to complete the entire system identification process, from analyzing the raw data to validating the identified model.
    Refer to the LabVIEW System Identification Assistant Readme, accessible by opening the readme_SIAssit.html file in the Readme directory of LabVIEW Platform DVD 1, for instructions of installing the System Identification Assistant.
    In addition to the system requirements for the LabVIEW Development System, the System Identification Toolkit has the following requirements:
    • LabVIEW 2012 Full or Professional Development System (32-bit)
    • At least 600 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2012.
    You can install all of your LabVIEW products—including the System Identification Toolkit—using the LabVIEW 2012 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website at ni.com.
    Note:  If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    The System Identification Toolkit installer contains both the System Identification Assistant and the System Identification VIs. You must have LabVIEW SignalExpress installed to install the System Identification Assistant.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the System Identification Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the System Identification Toolkit. This is not an exhaustive list of issues fixed in the current version of the System Identification Toolkit. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    294984System Identification Toolkit returns non-sensible error on input sizes being different
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the System Identification Toolkit.
    Refer to the LabVIEW System Identification Toolkit Algorithm References manual, accessible by opening the SIreference.pdf file in the labview\manuals directory, for information about algorithms implemented in the System Identification Toolkit and their corresponding references.
    You can access the examples for the System Identification Toolkit by selecting Help»Find Examples to display the NI Example Finder and then navigating to the Toolkits and Modules»System Identification folder. You also can click the Find Examples link in the Examples section of the Getting Started window to display the NI Example Finder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the System Identification Toolkit in the labview\examples\System Identification directory.
    © 2012 National Instruments. All rights reserved.
    GMT+8, 2025-12-8 11:02
