查看: 3274|回复: 3
[LV工具模块] LabVIEW 2013 System Identification Toolkit Win32Eng LabVIEW系统辨识工具包2013版下载
  • 签到天数: 3810 天
    发表于 2020-11-10 23:41:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    System Identification(系统识别)工具包可用于为现实设备建立数学模型。 该工具包中包含数据预处理、模型估计、分析和验证工具。 通过选择参数、非参数、递归、部分已知等模型估计方法,可识别表述现实设备特性的系统模型。 将识别出的系统模型与Control Design and Simulation模块以及Real-Time模块整合在一起,可完成控制设计的整个过程。
    2013
    文件大小: 143233824 字节 (136.60 MB)
    修改日期: 2013-06-28 23:01
    MD5: bcb8fdc116edd38126f1af7dbe05c1e4(重复下载一致)
    SHA1: 1bb27a136f24223bfaedbcc23147fc1228cf4645
    SHA256: a25dc39ddf0d77cd0b32550e893cb73e0f38d414d25b5224c2ae0afec7c127d3
    CRC32: a0728491
    百度和NI官方下载地址:
    SYSID2013.txt (592 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2013 System Identification Toolkit Readme
    Version 13.0.0
    June 2013
    This file contains information to introduce you to the LabVIEW 2013 System Identification Toolkit. This file also provides you with help resources you can use while working with this toolkit. The file contains the following information that you need to understand.
    NI Software Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    The System Identification Toolkit 2013 updates the System Identification Toolkit 2012 to support LabVIEW 2013. This is a maintenance release. The System Identification Toolkit provides an assistant and a library of VIs for developing models of a system based on a large set of raw data. Both tools enable you to complete the entire system identification process, from analyzing the raw data to validating the identified model.
    Refer to the System Identification Assistant Readme, accessible by opening the readme_SIAssit.html file in the Readme directory of LabVIEW Platform DVD 1, for instructions of installing the System Identification Assistant.
    In addition to the system requirements for the LabVIEW Development System, the System Identification Toolkit has the following requirements:
    • LabVIEW 2013 Full or Professional Development System (32-bit)
    • At least 600 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2013.
    You can install all of your LabVIEW products—including the System Identification Toolkit—using the LabVIEW 2013 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    Note:  If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    The System Identification Toolkit installer contains both the System Identification Assistant and the System Identification VIs. You must have NI SignalExpress installed to install the System Identification Assistant.
    System Identification Toolkit Updates and Notifications
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the System Identification Toolkit.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the System Identification Toolkit.
    Refer to the LabVIEW System Identification Toolkit Algorithm References manual, accessible by opening the SIreference.pdf file in the labview\manuals directory, for information about algorithms implemented in the System Identification Toolkit and their corresponding references.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»System Identification folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the System Identification Toolkit in the labview\examples\System Identification directory.
    Using NI Launcher
    Finding All Programs
    NI System Identification Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments System Identification Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of System Identification Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI LabWindows/CVIcvi_lifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2004–2013 National Instruments. All rights reserved.
    发表于 2022-1-22 15:14:39 | 显示全部楼层 来自:浙江省杭州市 电信
    有 LabVIEW 2013 System Identification Toolkit   64位版本的吗?或任何版本的64位版?
  • 签到天数: 1 天
    发表于 2025-12-16 13:07:27 | 显示全部楼层 来自:广东省深圳市 电信
    为什么后面的labview版本没有这个辨识包了呢?2025版本的labview能用这个包吗?还是必须要用2013版的labview?
  • 签到天数: 3810 天
     楼主| 发表于 2025-12-16 16:31:09 | 显示全部楼层 来自:广东省东莞市 联通
    xiangyuan_122 发表于 2025-12-16 13:07
    为什么后面的labview版本没有这个辨识包了呢?2025版本的labview能用这个包吗?还是必须要用2013版的labvie ...
    仅支持32位LV2013,可能是没有什么人用吧。就没有更新了。或者是集成到其他工具包中去了,那就要自己去找找相关说明。
    GMT+8, 2026-2-27 11:58
