查看: 3762|回复: 5
[驱动] 菲力尔FLIR-灰点Point Grey工业相机Linux Ubuntu18.04系统驱动Spinnaker-2.2.0.48-amd64/arm64
    昨天 08:22
  • 签到天数: 3723 天
    连续签到: 50 天
    发表于 2020-11-12 09:54:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    文件版本:
    spinnaker-2.2.0.48-Ubuntu18.04-amd64-pkg.tar
    spinnaker-2.2.0.48-Ubuntu18.04-arm64-pkg.tar
    百度网盘下载地址:
    链接:
    提取码: qs3q
    Spinnaker SDK – 2.2.0.48
    - CHANGE LIST (list of updates with this version):
    Enhancements:
    - Initial support for Ubuntu Focal (20.04)
    - Improve 'Incomplete Buffer Warning' with more actionable message
    - Improve experience on finding out why there are missing packets (SpinView_WPF)
    - Add disable Auto Gain and Auto WB to SpinView optimize FPS button
    - Add warning/note to Trigger example related to triggering faster than frame time
    - SpinView_Qt - Port over Windows Camera Auto IP
    Resolved Issues:
    - Fix multiple issues introduced with 2.1 release when using Gige cameras in Windows 7
    - Bash profile has incorrect line ending
    - Fix disabling of GEV enumeration
    - Debug Symbols loaded in Example .sln Files (for .exe files)
    - SpinView_WPF buffer nodes do not update when streaming
    - Spinnaker Documentations shortcut does not open the C/C++ pdf on Linux
    - Unavailable Files in Examples_vs2015 Solution
    - SpinView_Qt does not link to Spinnaker documentation on Linux
    - Some paths lost in PATH after installing Spinnaker 2.2.x
    - GigE camera window in SpinView would close randomly while streaming with a split view of U3V and GigE at max resolution
    - Resetting Application Settings does not set rendering back to CPU
    - Lossless Compression - Unable to decompress images with chunk data enabLED
    - UnregisterEventHandler failing with error "No event is registered"
    - No Command Nodes Available in VisionPro Cognex
    - USB3 camera segfaults in linux when being accessed in multiple applications
    - SpinView 2.0.0.146 histogram not working with BFLY-PGE-13E4C bayer pixel formats
    - EnumerateGEVInterfaces shortcuts do not work unless run as admin
    - Spinview 2.0.0.146 display pane will reset when startup everytime.
    - Interfaces appear and disappear from the Interface list on some PCs
    - Streaming images are not displayed after re-arranging image display panes in SpinView_Qt
    - endacquisition freezes with image callback registered (Windows)
    - EnumerationEvents_(C ,CSharp, VB, Python) Doesn't Show GigE Interface Arrival/Removals Correctly
    - SpinView_WPF log viewer match whole words search is not case sensitive
    - GigE camera won't initialize after firmware update in SpinView_WPF
    - After power cycling a GigE camera in SpinView_WPF, device list does not update on its own
    - SpinView_WPF throws 4 errors when displaying node information with no increments
    - macos installer pyspin3.6 package packs in pyspin2.7
    - 32bit SpinnakerDirectShow_v140.dll not packaged in 64bit Spinnaker installer
    发表于 2021-5-13 09:18:36 | 显示全部楼层 来自:江苏省南京市鼓楼区 电信
  • 签到天数: 1 天
    发表于 2021-6-28 14:41:31 | 显示全部楼层 来自:北京市 联通
  • 签到天数: 2 天
    发表于 2021-7-5 14:23:14 | 显示全部楼层 来自:湖北省武汉市 联通
    发表于 2022-3-1 18:50:35 | 显示全部楼层 来自:河南省洛阳市偃师市 联通
    发表于 2023-2-27 12:54:30 | 显示全部楼层 来自:北京市海淀区 联通
    GMT+8, 2025-11-26 03:01
