查看: 2449|回复: 0
[NI驱动程序] NI-Industrial Communications for DNP3 14.0.1 Win32/64Eng NI DNP3工业通信软件14.0.1
    昨天 10:50
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2020-11-12 23:18:23 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for DNP3 driver是一组用来创建DNP3分站或主站应用程序的LabVIEW函数集。
    NI-Industrial Communications for DNP3(分布式网络协议)驱动程序支持以太网和串行通信、文件传输以及主站和分站之间的时间同步。这些LabVIEW函数可帮助您在Windows计算机上进行编程,并部署到PXI控制器或现场应用所需的CompactRIO单板控制器。借助该驱动,用户还可使用每个分站的多个通信通道以及每个通道的多个会话(逻辑设备)。
    14.0.1
    文件大小: 134332808 字节 (128.11 MB)
    修改日期: 2019-10-31 07:39
    MD5: 104cd560ea468eb637a8d9bcd359f35b
    SHA1: 8709f3a7b25ff620280e8cb49b88f5a5397d0440
    SHA256: 97ff9a10b20c8d12f883466f9623308372f8671b40007099a66a8701ffe746a9
    CRC32: 9f4629d8
    DNP3 14.0.1.txt (632 Bytes, 下载次数: 0, 售价: 10 元)
    NI-Industrial Communications for DNP3 14.0.1 Readme
    December 2017
    This file contains important information about the NI-Industrial Communications for DNP3 software, including system requirements, installation instructions, and new features and changes.
    New Features and Changes
    Driver Version Naming Changes
    The NI-Industrial Communications for DNP3 software contains an extensive library of VIs and properties in LabVIEW for you to program applications for your DNP3 devices.
    System RequirementsNI Hardware Support
    The following list indicates the NI hardware products supported by the VIs in NI-Industrial Communications for DNP3:
    • CompactRIO controllers with real-time OS
    • PXI/PXI Express controllers with real-time OS
    • PXI Express controllers with Windows OS
    • Industrial controllers with real-time OS
    The following table lists the NI application software supported by NI-Industrial Communications for DNP3.
    NI Application SoftwareVersions Supported by NI-Industrial Communications for DNP3
    NI LabVIEW2011 (32-bit), 2012 (32-bit), 2013 (32-bit), 2014 (32-bit), 2015 (32-bit), 2016 (32-bit), 2017 (32-bit)
    NI LabVIEW Real-Time Module2011, 2012, 2013, 2014, 2015, 2016, 2017
    Note  You can install NI-Industrial Communications for DNP3 with only one version of LabVIEW on a computer. If you want to install NI-Industrial Communications for DNP3 with another supported version of LabVIEW on the same computer, you must uninstall existing NI-Industrial Communications for DNP3 and then install it under the target version of LabVIEW.
    Note  Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW.
    Before installing the NI-Industrial Communications for DNP3 software, log on as Administrator or as a user with Administrator privileges. The NI-Industrial Communications for DNP3 software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Double-click the setup.exe file in the root directory of the NI-Industrial Communications for DNP3 installer and follow the instructions on the screen to install NI-Industrial Communications for DNP3. After you complete installing NI-Industrial Communications for DNP3, you can program DNP3 applications and deploy them on targets.
    Note  Refer to the Activation Instructions folder in the root directory of the NI-Industrial Communications for DNP3 installer for instructions about how to activate the NI-Industrial Communications for DNP3 software.
    NI-Industrial Communications for DNP3 14.0.1 contains the following new features and changes:
    • Added support for targets running NI Linux Real-Time (64-bit)—IC-3120/3121/3171/3172/3173
    NI-Industrial Communications for DNP3 versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: NI-Industrial Communications for DNP3 14.0. For example, NI-Industrial Communications for DNP3 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-Industrial Communications for DNP3 2.1. The first version released under the new numbering scheme is NI-Industrial Communications for DNP3 14.0.
    Refer to the NI-Industrial Communications for DNP3 API for LabVIEW Help, accessible from Help»NI-Industrial Communications for DNP3 in LabVIEW, for information about NI-Industrial Communications for DNP3.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Hardware Input and Output»NI-Industrial Communications»DNP3 folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for NI-Industrial Communications for DNP3 in the labview\examples\DNP3 directory.
    Using NI Launcher
    Finding All Programs
    © 2010–2017 National Instruments. All rights reserved.
    374796B-01
    GMT+8, 2025-7-26 05:56
