查看: 3011|回复: 0
[NI软件产品] NI-Industrial Communications for Ethernet/IP 14.0 Win32/64Eng NI以太网/IP 工业通信软件14.0下载
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-11-12 23:51:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for Ethernet/IP使LabVIEW系统能够作为以太网/IP网络上的以太网/IP Class 1适配器设备进行通信。
    NI-Industrial Communications for Ethernet/IP是一款应用软件,为您使用CompactRIO控制器、CompactRIO单板控制器、PXI控制器、紧凑型视觉系统、智能相机、工业控制器或独立CompactDAQ系统提供了所需的支持。它包含丰富的LabVIEW VI和属性库,助您快速为兼容的以太网/IP硬件设备创建自定义的以太网/IP应用程序。该软件具有显式消息传递和I/O数据通信机制。这些机制提供与各种可编程逻辑控制器(PLC)和以太网/IP I/O设备的通信和数据共享。
    14.0
    文件大小: 168575776 字节 (160.77 MB)
    修改日期: 2014-08-06 13:18
    MD5: 88687a5e47c58fd1570f51209fb35845
    SHA1: b87f5d0c17739a61be8ce29c053eae2216b67c9d
    SHA256: 0d2e0251aaf7b4d5575f9ffd30bdbc62958e50863a08ce26dc695959d8c7c894
    CRC32: a281ad30
    IndComEIP14.0.txt (634 Bytes, 下载次数: 1, 售价: 10 圆)
    NI-Industrial Communications for EtherNet/IP 14.0 Readme
    Version 14.0
    June 2014
    This file contains important information about NI-Industrial Communications for EtherNet/IP, including supported NI application software and NI hardware, installation instructions, and new features.
    NI Hardware Support
    New Features and Changes
    EtherNet/IP 14.0
    EtherNet/IP 1.3
    EtherNet/IP 1.2.1
    EtherNet/IP 1.2
    EtherNet/IP 1.1
    Driver Version Naming Changes
    NI-Industrial Communications for EtherNet/IP contains an extensive library of VIs and properties in LabVIEW to program your customized EtherNet/IP applications for your devices.
    In addition to the system requirements for the LabVIEW Development System, NI-Industrial Communications for EtherNet/IP has the following requirements:
    • LabVIEW Base Development System
    • LabVIEW Real-Time Module (required only if you run NI-Industrial Communications for EtherNet/IP on NI RT targets)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for the version of LabVIEW that you run NI-Industrial Communications for EtherNet/IP on.
    The following table lists the NI application software versions, including service packs, supported by NI-Industrial Communications for EtherNet/IP. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    NI Application SoftwareVersions Supported by NI-Industrial Communications for EtherNet/IP
    NI LabVIEW2011, 2012, 2013, 2014
    NI LabVIEW Real-Time Module2011, 2012, 2013, 2014
    NI Hardware Support
    NI-Industrial Communications for EtherNet/IP supports the following NI hardware products:
    • NI PXI
    • NI CompactRIO
    • NI Single-Board RIO
    • NI stand-alone CompactDAQ
    • NI industrial controllers
    • NI Smart Cameras
    • NI Compact Vision System
    • NI Embedded Vision System
    Before installing NI-Industrial Communications for EtherNet/IP, log on as Administrator or as a user with Administrator privileges. NI-Industrial Communications for EtherNet/IP setup program must have Administrator privileges because the program modifies the configuration registry of your system.
    Double-click the setup.exe file in the root directory of the NI-Industrial Communications for EtherNet/IP installer and follow the instructions on the screen to install NI-Industrial Communications for EtherNet/IP on the host.
    Use Measurement & Automation Explorer (NI MAX) to install NI-Industrial Communications for EtherNet/IP on NI RT targets.
    New Features and ChangesEtherNet/IP 14.0
    • Added support for NI stand-alone CompactDAQ modules
    • Added support for LabVIEW 2014 (32-bit and 64-bit)
    EtherNet/IP 1.3
    • Added support for NI cRIO-9068
    • Added support for LabVIEW 2013 (32-bit and 64-bit)
    EtherNet/IP 1.2.1
    • Added support for NI License Manager
    • Added support for LabVIEW 2012 (32-bit and 64-bit)
    • Resolved a problem that EtherNet/IP can not be included in the installer created using Application Builder
    EtherNet/IP 1.2
    • Added support for LabVIEW 2011 (64-bit)
    • Resolved a stability issue seen only in LabVIEW RT 2009
    • Resolved a problem that ethernetIPInterface.dll is not exported when building an EIP Windows application
    EtherNet/IP 1.1
    • First official release to support EtherNet/IP
    • Added example VIs to show how to use the VI APIs for creating EtherNet/IP applications
    • Added more LabVIEW error codes to better diagnose problems
    NI-Industrial Communications for EtherNet/IP versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: NI-Industrial Communications for EtherNet/IP 14.0. For example, NI-Industrial Communications for EtherNet/IP 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-Industrial Communications for EtherNet/IP 1.3. The first version released under the new numbering scheme is NI-Industrial Communications for EtherNet/IP 14.0.
    Refer to the NI-Industrial Communications for EtherNet/IP Help, accessible from Help»NI-Industrial Communications for EtherNet/IP in LabVIEW, for information about NI-Industrial Communications for EtherNet/IP.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Hardware Input and Output»NI-Industrial Communications»EtherNet/IP folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for NI-Industrial Communications for EtherNet/IP in the labview\examples\ethernetip directory.
    When you install National Instruments software on Microsoft Windows 8.x, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, NI MAX, and NI Launcher.
    Using NI Launcher
    Finding All Programs
    NI-Industrial Communications for EtherNet/IP Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-Industrial Communications for EtherNet/IP will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-Industrial Communications for EtherNet/IP that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2010–2014 National Instruments. All rights reserved.
    GMT+8, 2025-10-30 02:20
