NI-Industrial Communications for Ethernet/IP 17.0 Win32/64Eng NI以太网/IP 工业通信软件17.0下载
NI-Industrial Communications for Ethernet/IP使LabVIEW系统能够作为以太网/IP网络上的以太网/IP Class 1适配器设备进行通信。
NI-Industrial Communications for Ethernet/IP是一款应用软件,为您使用CompactRIO控制器、CompactRIO单板控制器、PXI控制器、紧凑型视觉系统、智能相机、工业控制器或独立CompactDAQ系统提供了所需的支持。它包含丰富的LabVIEW VI和属性库,助您快速为兼容的以太网/IP硬件设备创建自定义的以太网/IP应用程序。该软件具有显式消息传递和I/O数据通信机制。这些机制提供与各种可编程逻辑控制器(PLC)和以太网/IP I/O设备的通信和数据共享。
17.0
文件大小: 238928776 字节 (227.86 MB)
修改日期: 2017-04-13 13:05
MD5: 1e6187b2cd22a7eaaefea141af40e0aa
SHA1: 83ea83827252ef2a32966b805c3b7dc2b02b1de6
SHA256: 3a32c3455c91684ce2aa108be34c1535e31da69ae7df0bba90a36d522285dd91
CRC32: 0fec350f
IndComEIP17.0.txt
(634 Bytes, 下载次数: 0, 售价: 10 圆)
NI-Industrial Communications for EtherNet/IP 17.0 ReadmeMarch 2017 This file contains important information about NI-Industrial Communications for EtherNet/IP, including supported application software and hardware, installation instructions, and new features. Overview System Requirements Supported Operating Systems Application Software Support Hardware Support Installation Instructions Product Security and Critical Updates New Features Accessing the Help Finding Examples Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 Legal Information OverviewNI-Industrial Communications for EtherNet/IP contains an extensive library of VIs and properties in LabVIEW to program your customized EtherNet/IP applications for your devices. System RequirementsIn addition to the system requirements for the LabVIEW Development System, NI-Industrial Communications for EtherNet/IP has the following requirements: - LabVIEW Base Development System
- LabVIEW Real-Time Module (required only if you run NI-Industrial Communications for EtherNet/IP on RT targets)
Refer to the LabVIEW Readme for additional system requirements and supported operating systems for the version of LabVIEW that you run NI-Industrial Communications for EtherNet/IP on. Supported Operating SystemsNI-Industrial Communications for EtherNet/IP supports the following operating systems: - Windows 10/8.11/7 SP12
- Windows Server 2012 R2 (64-bit)1
- Windows Server 2008 R2 SP1 (64-bit)2
Note In 2016 NI-Industrial Communications for EtherNet/IP dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-Industrial Communications for EtherNet/IP 17.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Industrial Communications for EtherNet/IP 17.0 to an unsupported OS. Additionally, after installing NI-Industrial Communications for EtherNet/IP 17.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?. Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/info and enter the Info Code PAESupport. 1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update. Application Software SupportThe following table lists the application software versions, including service packs, supported by NI-Industrial Communications for EtherNet/IP. If you are not using NI application software, refer to Microsoft Visual Studio Support. | Application Software | Versions Supported by NI-Industrial Communications for EtherNet/IP | | LabVIEW | 2014, 2015, 2016, 2017 | | LabVIEW Real-Time Module | 2014, 2015, 2016, 2017 | Hardware SupportNI-Industrial Communications for EtherNet/IP supports the following NI hardware products: - CompactRIO
- Compact Vision System
- Embedded Vision System
- Industrial Controllers
- NI PXI
- NI PXIe
- Single-Board RIO
- Smart Cameras
- Stand-Alone CompactDAQ
Installation InstructionsBefore installing NI-Industrial Communications for EtherNet/IP, log on as Administrator or as a user with Administrator privileges. The NI-Industrial Communications for EtherNet/IP setup program must have Administrator privileges because the program modifies the configuration registry of your system. Double-click the setup.exe file in the root directory of the NI-Industrial Communications for EtherNet/IP installer and follow the instructions on the screen to install NI-Industrial Communications for EtherNet/IP on the host. Use NI Measurement & Automation Explorer (MAX) to install NI-Industrial Communications for EtherNet/IP on RT targets. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. New FeaturesEtherNet/IP 17.0- Added support for LabVIEW 2017
EtherNet/IP 16.0- Added support for NI cRIO-9032/9035 (Sync)/9037/9039 (Sync)
- Added support for LabVIEW 2016
EtherNet/IP 15.0- Added support for NI cRIO-9035/9036/9039/9063/9064/9065
- Added support for NI sbRIO-9607/9627/9637
- Added support for LabVIEW 2015
EtherNet/IP 14.0- Added support for stand-alone CompactDAQ modules
- Added support for LabVIEW 2014
EtherNet/IP 1.3- Added support for NI cRIO-9068
- Added support for LabVIEW 2013
EtherNet/IP 1.2.1- Added support for NI License Manager
- Added support for LabVIEW 2012
- Resolved a problem that EtherNet/IP cannot be included in the installer created using Application Builder
EtherNet/IP 1.2- Added support for LabVIEW 2011 (64-bit)
- Resolved a stability issue seen only in the LabVIEW 2009 Real-Time Module
- Resolved a problem that ethernetIPInterface.dll is not exported when building an EtherNet/IP Windows application
EtherNet/IP 1.1- First official release to support the EtherNet/IP protocol
- Added example VIs to show how to use the VI APIs for creating EtherNet/IP applications
- Added more LabVIEW error codes to better diagnose problems
Accessing the HelpRefer to the NI-Industrial Communications for EtherNet/IP Help, accessible from Help»NI-Industrial Communications for EtherNet/IP in LabVIEW, for information about NI-Industrial Communications for EtherNet/IP. Finding ExamplesSelect Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Hardware Input and Output»NI-Industrial Communications»EtherNet/IP folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. You also can find the examples for NI-Industrial Communications for EtherNet/IP in the labview\examples\ethernetip directory. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
- To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, How Can I Determine the Type and Version of My NI Installer?.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, NI Measurement & Automation Explorer (MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. Legal InformationCopyright © 2010–2017 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 374775D-01 |
