查看: 4034|回复: 0
[NI软件产品] NI-Industrial Communications for Ethernet/IP 18.0 Win32/64Eng NI以太网/IP 工业通信软件18.0下载
    昨天 10:50
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2020-11-13 00:00:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for Ethernet/IP使LabVIEW系统能够作为以太网/IP网络上的以太网/IP Class 1适配器设备进行通信。
    NI-Industrial Communications for Ethernet/IP是一款应用软件,为您使用CompactRIO控制器、CompactRIO单板控制器、PXI控制器、紧凑型视觉系统、智能相机、工业控制器或独立CompactDAQ系统提供了所需的支持。它包含丰富的LabVIEW VI和属性库,助您快速为兼容的以太网/IP硬件设备创建自定义的以太网/IP应用程序。该软件具有显式消息传递和I/O数据通信机制。这些机制提供与各种可编程逻辑控制器(PLC)和以太网/IP I/O设备的通信和数据共享。
    18.0
    文件大小: 243506056 字节 (232.23 MB)
    修改日期: 2018-05-17 00:59
    MD5: 053c8749da3fa980fdc0b3cc96478cd4
    SHA1: fe50dd3a437339b1dd8f0de00286dfc9270efad8
    SHA256: 1d6f722019618100173e54adb193d1671cce59f92cd7798a97cf608843b9a2db
    CRC32: 14e357e2
    IndComEIP18.0.txt (634 Bytes, 下载次数: 6, 售价: 10 元)
    NI-Industrial Communications for EtherNet/IP 18.0 Readme
    March 2018
    This file contains important information about NI-Industrial Communications for EtherNet/IP, including supported application software and hardware, installation instructions, and new features.
    Hardware Support
    NI-Industrial Communications for EtherNet/IP contains an extensive library of VIs and properties in LabVIEW to program your customized EtherNet/IP applications for your devices.
    In addition to the system requirements for the LabVIEW Development System, NI-Industrial Communications for EtherNet/IP has the following requirements:
    • LabVIEW Base Development System
    • LabVIEW Real-Time Module (required only if you run NI-Industrial Communications for EtherNet/IP on RT targets)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for the version of LabVIEW that you run NI-Industrial Communications for EtherNet/IP on.
    NI-Industrial Communications for EtherNet/IP supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016 NI-Industrial Communications for EtherNet/IP dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-Industrial Communications for EtherNet/IP 18.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Industrial Communications for EtherNet/IP 18.0 to an unsupported OS. Additionally, after installing NI-Industrial Communications for EtherNet/IP 18.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    The following table lists the application software versions, including service packs, supported by NI-Industrial Communications for EtherNet/IP. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-Industrial Communications for EtherNet/IP
    LabVIEW2015, 2016, 2017, 2018
    LabVIEW Real-Time Module2015, 2016, 2017, 2018
    Hardware Support
    NI-Industrial Communications for EtherNet/IP supports the following NI hardware products:
    • CompactRIO
    • Compact Vision System
    • Embedded Vision System
    • Industrial Controllers
    • NI PXI
    • NI PXIe
    • Single-Board RIO
    • Smart Cameras
    • Stand-Alone CompactDAQ
    Before installing NI-Industrial Communications for EtherNet/IP, log on as Administrator or as a user with Administrator privileges. The NI-Industrial Communications for EtherNet/IP setup program must have Administrator privileges because the program modifies the configuration registry of your system.
    Double-click the setup.exe file in the root directory of the NI-Industrial Communications for EtherNet/IP installer and follow the instructions on the screen to install NI-Industrial Communications for EtherNet/IP on the host.
    Use NI Measurement & Automation Explorer (MAX) to install NI-Industrial Communications for EtherNet/IP on RT targets.
    New FeaturesEtherNet/IP 18.0
    • Added support for LabVIEW 2018
    EtherNet/IP 17.0
    • Added support for LabVIEW 2017
    EtherNet/IP 16.0
    • Added support for cRIO-9032/9035 (Sync)/9037/9039 (Sync)
    • Added support for LabVIEW 2016
    EtherNet/IP 15.0
    • Added support for cRIO-9035/9036/9039/9063/9064/9065
    • Added support for sbRIO-9607/9627/9637
    • Added support for LabVIEW 2015
    EtherNet/IP 14.0
    • Added support for stand-alone CompactDAQ modules
    • Added support for LabVIEW 2014
    EtherNet/IP 1.3
    • Added support for cRIO-9068
    • Added support for LabVIEW 2013
    EtherNet/IP 1.2.1
    • Added support for NI License Manager
    • Added support for LabVIEW 2012
    • Resolved a problem that EtherNet/IP cannot be included in the installer created using Application Builder
    EtherNet/IP 1.2
    • Added support for LabVIEW 2011 (64-bit)
    • Resolved a stability issue seen only in the LabVIEW 2009 Real-Time Module
    • Resolved a problem that ethernetIPInterface.dll is not exported when building an EtherNet/IP Windows application
    EtherNet/IP 1.1
    • First official release to support the EtherNet/IP protocol
    • Added example VIs to show how to use the VI APIs for creating EtherNet/IP applications
    • Added more LabVIEW error codes to better diagnose problems
    Refer to the NI-Industrial Communications for EtherNet/IP Help, accessible from Help»NI-Industrial Communications for EtherNet/IP in LabVIEW, for information about NI-Industrial Communications for EtherNet/IP.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Hardware Input and Output»NI-Industrial Communications»EtherNet/IP folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for NI-Industrial Communications for EtherNet/IP in the labview\examples\ethernetip directory.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, NI Measurement & Automation Explorer (MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    © 2010–2018 National Instruments. All rights reserved.
    374775F-01
    GMT+8, 2025-7-26 07:29
