查看: 4791|回复: 0
[NI软件产品] NI-Industrial Communications for Ethernet/IP 19.0 Win32/64Eng NI以太网/IP 工业通信软件19.0下载
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-11-13 00:03:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for Ethernet/IP使LabVIEW系统能够作为以太网/IP网络上的以太网/IP Class 1适配器设备进行通信。
    NI-Industrial Communications for Ethernet/IP是一款应用软件,为您使用CompactRIO控制器、CompactRIO单板控制器、PXI控制器、紧凑型视觉系统、智能相机、工业控制器或独立CompactDAQ系统提供了所需的支持。它包含丰富的LabVIEW VI和属性库,助您快速为兼容的以太网/IP硬件设备创建自定义的以太网/IP应用程序。该软件具有显式消息传递和I/O数据通信机制。这些机制提供与各种可编程逻辑控制器(PLC)和以太网/IP I/O设备的通信和数据共享。
    19.0
    文件大小: 398571520 字节 (380.11 MB)
    修改日期: 2019-05-14 03:18
    MD5: 789d1e44d66e5c6319aa8ab72c08d0a3
    SHA1: 43e7150529e829d1f770d6819008e5e8d77c9743
    SHA256: c2b06390c05a968fde7dc7114240d48b86146c477295bdd3f07b8379ffdd1b8b
    CRC32: 1a3036f1
    IndComEIP19.0.txt (627 Bytes, 下载次数: 6, 售价: 10 圆)
    NI-Industrial Communications for EtherNet/IP 19.0 Readme
    March 2019
    This file contains important information about NI-Industrial Communications for EtherNet/IP, including supported application software and hardware, installation instructions, and new features.
    Hardware Support
    NI-Industrial Communications for EtherNet/IP Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    NI-Industrial Communications for EtherNet/IP contains an extensive library of VIs and properties in LabVIEW to program your customized EtherNet/IP applications for your devices.
    In addition to the system requirements for the LabVIEW Development System, NI-Industrial Communications for EtherNet/IP has the following requirements:
    • LabVIEW Base Development System
    • LabVIEW Real-Time Module (required only if you run NI-Industrial Communications for EtherNet/IP on RT targets)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for the version of LabVIEW that you run NI-Industrial Communications for EtherNet/IP on.
    NI-Industrial Communications for EtherNet/IP supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  Refer to NI-Industrial Communications for EtherNet/IP Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  In 2016 NI-Industrial Communications for EtherNet/IP dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-Industrial Communications for EtherNet/IP 19.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Industrial Communications for EtherNet/IP 19.0 to an unsupported OS. Additionally, after installing NI-Industrial Communications for EtherNet/IP 19.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    The following table lists the application software versions, including service packs, supported by NI-Industrial Communications for EtherNet/IP. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-Industrial Communications for EtherNet/IP
    LabVIEW2016, 2017, 2018, 2019
    LabVIEW Real-Time Module2016, 2017, 2018, 2019
    Hardware Support
    NI-Industrial Communications for EtherNet/IP supports the following NI hardware products:
    • CompactRIO
    • Compact Vision System
    • Embedded Vision System
    • Industrial Controllers
    • PXI
    • PXIe
    • Single-Board RIO
    • Smart Cameras
    • Stand-Alone CompactDAQ
    Note  NI-Industrial Communications for EtherNet/IP 19.0 does not support PXI or PXIe devices with NI Linux Real-Time.
    Use NI Measurement & Automation Explorer (MAX) to install NI-Industrial Communications for EtherNet/IP on RT targets.
    New FeaturesEtherNet/IP 19.0
    • Added support for LabVIEW 2019.
    • Added support for cRIO-9055/9058.
    EtherNet/IP 18.0
    • Added support for LabVIEW 2018.
    EtherNet/IP 17.0
    • Added support for LabVIEW 2017.
    EtherNet/IP 16.0
    • Added support for cRIO-9032/9035 (Sync)/9037/9039 (Sync).
    • Added support for LabVIEW 2016.
    EtherNet/IP 15.0
    • Added support for cRIO-9035/9036/9039/9063/9064/9065.
    • Added support for sbRIO-9607/9627/9637.
    EtherNet/IP 14.0
    • Added support for stand-alone CompactDAQ modules.
    • Added support for LabVIEW 2014.
    EtherNet/IP 1.3
    • Added support for cRIO-9068.
    • Added support for LabVIEW 2013.
    EtherNet/IP 1.2.1
    • Added support for NI License Manager.
    • Added support for LabVIEW 2012.
    • Resolved a problem that EtherNet/IP cannot be included in the installer created using Application Builder
    EtherNet/IP 1.2
    • Added support for LabVIEW 2011 (64-bit).
    • Resolved a stability issue seen only in the LabVIEW 2009 Real-Time Module.
    • Resolved a problem that ethernetIPInterface.dll is not exported when building an EtherNet/IP Windows application.
    EtherNet/IP 1.1
    • First official release to support the EtherNet/IP protocol.
    • Added example VIs to show how to use the VI APIs for creating EtherNet/IP applications.
    • Added more LabVIEW error codes to better diagnose problems.
    Refer to the NI-Industrial Communications for EtherNet/IP Help, accessible from Help»NI-Industrial Communications for EtherNet/IP in LabVIEW, for information about NI-Industrial Communications for EtherNet/IP.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Hardware Input and Output»NI-Industrial Communications»EtherNet/IP folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for NI-Industrial Communications for EtherNet/IP in the labview\examples\ethernetip directory.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, NI Measurement & Automation Explorer (MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    NI-Industrial Communications for EtherNet/IP will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2010–2019 National Instruments. All rights reserved.
    374775G-01
    GMT+8, 2025-10-30 02:18
