查看: 3284|回复: 0
[NI软件产品] NI-Industrial Communications for EtherCAT 2.7 Win32/64Eng 以太网控制自动化技术工业通信软件2.7版下载
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-11-13 23:03:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for EtherCAT提供了EtherCAT主站支持,以支持NI控制器硬件上的确定性I/O。
    NI-Industrial Communications for EtherCAT为用户使用CompactRIO控制器、PXI控制器或工业控制器提供支持。使用此软件,您可以通过使用基于EtherCAT总线的CompactRIO机箱或使用远程I/O硬件来扩展I/O。NI建议结合经过充分测试和验证的NI EtherCAT产品使用此驱动软件。
    2.7
    文件大小: 316352800 字节 (301.70 MB)
    修改日期: 2014-04-29 23:18
    MD5: daa4b976a6e2db7d42b412bbfb4cf066
    SHA1: e70a6bd2358c2a5da69c6e2a74a064e74e4053d0
    SHA256: 0bae3bff23cf48822afca792c781f0e9c811dbab6845e5c2ed3ade167dc72d0b
    CRC32: 181b5e37
    NIIndComECAT2.7.txt (644 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for EtherCAT 2.7 Readme
    January 2014
    This file contains last-minute information about the NI-Industrial Communications for EtherCAT software.
    Revision History
    Supported Platforms
    NI Software Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    Revision HistoryVersion 2.7
    Added support to import device profiles to the real-time targets. Complete the following steps to import the profiles.
    • Right-click the EtherCAT master item and select Utilities»Import Device Profiles to display the Import Device Profile dialog box.
    • Select the Import to the real-time target checkbox when you want to import the profiles to the real-time target.
    • Click the file browse button to select the device profiles that you want to import. In the Found device profiles section, the Device Filenames column displays the file that you want to import. The following table lists the results, the profile types, and detailed information of each result.
      ResultProfile TypeDescription
      SucceededSlave or Module DeviceYou import the profile successfully.
      CancelledSlave or Module DeviceYou do not log in before accessing the remote target.
      No supported protocol installedSlave or Module DeviceThe real-time target does not have the protocol to transfer files. Use Measurement & Automation Explorer (MAX) to install WebDAV or FTP protocol to the real-time target.
      Failed to import the device profileSlave or Module DeviceYou modified the device profile hierarchy or the profiles corrupted. Make sure that you keep the profile hierarchy and the profile is intact.
      Module profile is not referenced by any slave profilesModule DeviceYou cannot import a module device profile that no slave device profile references to. Make sure that you select a folder that contains the module device profile and the related slave device profile.
      Failed to transfer device profiles to the real-time targetSlave or Module DeviceThe connection between the host and the remote real-time target is broken.
    Version 2.6
    • Added support for cRIO-9068.
    • Added support for new C Series modules, such as NI 9381 and NI 9482.
    Version 2.5
    • Added support for more than eight modules on third-party modular slave devices.
    • Added support for 4-port slave devices when DC is not enabled.
    Version 2.4
    • Added support for sending and receiving raw PDO data.
    • Added support for monitoring slave device states.
    Version 2.3
    • Fixed a latency issue caused by using fiberoptic converters in an EtherCAT network.
    • Added support for third-party C Series modules in the NI 9144 FPGA mode.
    • Added support for using Remote Programmatic API with the LabVIEW Run-Time Engine.
    • Extended the maximum scan period to 1 second.
    Version 2.2
    • Added support for cable redundancy.
    • Added support for Modular Device Profiles.
    • Added support for NI cRIO-908x Controller Series.
    Version 2.1
    • Improved the performance of User-defined Variables.
    Version 2.0
    • Added support for Programmatic Configuration.
    • Added support for synchronization among multiple NI EtherCAT masters.
    • Added support for PXIe-8133 and Real-Time Desktop target.
    • Added support for NI 9214 C Series module.
    Version 1.2
    • Added support for cRIO-9023, NI 9792 and EVS-146x Series.
    • Added support for new C Series modules.
    Version 1.1
    • Added LabVIEW FPGA Module support for the NI 9144.
    • Added support for Industrial Controller and cRIO-9024.
    • Added support for new C Series modules (including the NI 951x Motion modules).
    Version 1.0.2
    • Fixed incorrect installer dependency.
    Version 1.0.1
    • Added support for cRIO-9022.
    Version 1.0
    • Initial support for NI-Industrial Communications for EtherCAT.
    Supported PlatformsSupported Hardware
    This version of the NI-Industrial Communications for EtherCAT software supports the following National Instruments hardware products with the LabVIEW Real-Time Module:
    • NI CompactRIO real-time controller
      • NI cRIO-9022
      • NI cRIO-9023
      • NI cRIO-9024
      • NI cRIO-9025
      • NI cRIO-9068
      • NI cRIO-9074
      • NI cRIO-9081
      • NI cRIO-9082
      • NI 9792
    • Embedded real-time controllers with the NI PXI-8231, PXI-8232, or PXI-8234 Ethernet interface
      • All real-time embedded PXI controllers
    • Embedded real-time controllers with two built-in Ethernet adapters
      • PXI-8109
      • PXI-8115
      • PXIe-8115
      • PXIe-8133
      • PXIe-8135
      • NI 3100 Industrial Controller
      • NI 3110 Industrial Controller
    • Real-Time Desktop target with any of the following Ethernet interfaces
      • NI PCIe-8231
      • NI PCI-8232
      • NI PCIe-8235
    • Embedded Vision System
      • EVS-1463
      • EVS-1463 RT
      • EVS-1464
      • EVS-1464 RT
    • Rack-Mount 1U Controllers
      • NI RMC-8354
      • NI RMC-8355
    Software Requirements
    In addition to the system requirements for the LabVIEW Development System, the NI-Industrial Communications for EtherCAT software has the following requirements:
    • LabVIEW 2010 or later
    • LabVIEW 2010 Real-Time Module or later
    • NI-RIO 13.1
    Notes:
    • To use NI 9144 in FPGA Mode, you must have the LabVIEW 2010 FPGA Module or later installed on the host computer, or access to a compiled bitfile you can download to the FPGA of NI 9144.
    • The LabVIEW 2010 NI SoftMotion Module or later must be installed for the NI 951x Series drive interface modules to work on EtherCAT.
    Before installing the NI-Industrial Communications for EtherCAT software, log on as Administrator or as a user with Administrator privileges. The NI-Industrial Communications for EtherCAT software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-Industrial Communications for EtherCAT software.
    • Insert the NI-Industrial Communications for EtherCAT software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-Industrial Communications for EtherCAT software CD.
    • The installation wizard guides you through the necessary steps to install the NI-Industrial Communications for EtherCAT software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking the Cancel button.
    • When the installation is complete, click the Finish button.
    Visit ni.com/security for security information about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments.
    Refer to the NI-Industrial Communications for EtherCAT Help, accessible by selecting Help»NI-Industrial Communications for EtherCAT from the pull-down menu in LabVIEW, or available by selecting Start»All Programs»National Instruments»NI-Industrial Communications for EtherCAT»NI-Industrial Communications for EtherCAT Help or (Windows 8) by clicking NI Launcher and selecting NI-Industrial Communications for EtherCAT»NI-Industrial Communications for EtherCAT Help in the window that appears, for information about using the NI-Industrial Communications for EtherCAT software.
    LabVIEW examples for the NI-IndCom for EtherCAT software are in the labview\examples\indcomecat folder. You can modify an example VI to fit an application or copy an example and paste the example to a VI you create.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the NI-Industrial Communications for EtherCAT.
    Using NI Launcher
    Finding All Programs
    NI-Industrial Communications for EtherCAT Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-Industrial Communications for EtherCAT will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-Industrial Communications for EtherCAT that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2008–2014 National Instruments. All rights reserved.
    Credits
    This product includes components that use the Expat XML Parser. In regards to the Expat XML Parser, the following notice applies:
    Copyright © 1998, 1999, 2000 Thai Open Source Software Center Ltd and Clark Cooper. Copyright © 2001, 2002, 2003, 2004, 2005, 2006 Expat maintainers.
    Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    GMT+8, 2025-10-30 02:15
