查看: 2195|回复: 0
[MVTEC] MVTEC Halcon 20.05.0.1 Progress Deep Learning Core Win32/Win64 HALCON深度学习内核20.05.0.1 32位/64位Windows版
    昨天 08:45
  • 签到天数: 3641 天
    发表于 2020-11-14 11:35:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    HALCON 20.05.0.1 Deep Learning Core - Additional Core Functionality Required for Deep Learning (x86sse2-win32 / x64-win64), Add-on to Full/Runtime Version:
    文件名: halcon-20.05.0.1-windows-deep-learning-core.exe
    文件大小: 1023390920 字节 (975.98 MB)
    修改日期: 2020-11-05 13:29
    版本: 20.5.0.1
    MD5: 50eb0a9e1dfa71bc7f4e89197f321264
    SHA1: 8528e0a0d981fbb6f85fba2100ff5158673365f2
    SHA256: eddefed461422bcb3ba315a77fb7f8ef8fe77afa14df605b93ad3cbd8756be1a
    CRC32: f7167444
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    百度网盘下载地址:
    链接:
    提取码: idhc
    Release Notes for HALCON 20.05.0.1 Progress
    Hotfix for HALCON 20.05.0.0 Progress
    This document provides the release notes for MVTec HALCON 20.05.0.1 Progress, as released in July 2020, which is a Hotfix for HALCON 20.05.0.0 Progress. For general information like licensing or supported operating systems, see the release notes of HALCON 20.05.0.0 Progress.
    Contents
    Detailed Description of Changes in HALCON 20.05.0.1 Progress (Hotfix)
    Deep Learning
    Matching
    Licensing
    Release Notes of Previous HALCON Versions
    The changes in HALCON 20.05.0.1 Progress are described with respect to HALCON 20.05.0.0 Progress.
    Deep Learning
    If the system parameter "cudnn_deterministic" was specified as "true" and the model parameter "optimize_for_inference" was also "true", the training of this deep learning model did not use the corresponding deterministic cuDNN backward algorithm for convolution layers as required. Hence, the training of such a model was most likely not deterministic on a GPU. This problem has been fixed.
    Matching
    find_shape_model, find_shape_models, find_scaled_shape_model, find_scaled_shape_models, find_aniso_shape_model, find_aniso_shape_models, and find_shape_model_3d did not abort in a timeout error in rare cases where the operator was parallelized and a timeout was set. This problem has been fixed.
    Licensing
    When using a license bound to a dongle, HDevelop could periodically fail to communicate with the dongle and complain about a licensing error in response. This problem has been fixed.
    GMT+8, 2025-9-4 04:27
