查看: 3286|回复: 0
[NI驱动程序] NI-USRP 15.0 Driver Win32/64Eng NI通用软件无线电外设仪器驱动程序15.0下载
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-11-16 23:01:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI USRP
    NI-USRP支持使用NI通用软件无线电外设(USRP)收发仪和LabVIEW可重配置I/O (RIO) USRP设备的客户。
    NI-USRP是一个NI仪器驱动程序,可同时支持软件无线电(SDR)设备和可重配置SDR设备。如果要配置设备,可使用NI-USRP仪器驱动程序中包含的NI-USRP API或USRP RIO仪器设计库(IDL)。NI-USRP可帮助您使用NI SDR硬件创建发射(Tx)和接收(Rx)应用。
    15.0
    文件大小: 1619880541 字节 (1.51 GB)
    修改日期: 2019-06-25 02:58
    MD5: b842431ed82fa2560f403bc70bb179ba(官方正确)
    SHA1: 0518ac5fb89e8a7845743a5b39da399ac263392c
    SHA256: 879e3a7ce857c43c05590a43b0699bc3f01429e5df5ab4fbdc8340955b4a88ce
    CRC32: 6cde1b9c
    USRP15.0.txt (557 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-USRP 15.0 Readme
    October 2015
    Thank you for using NI-USRP. This file contains important information about NI-USRP and is organized into the following sections:
    Accessing VIs and Sample Project
    Accessing Examples
    Driver Version Naming Changes
    Uninstalling/Modifying NI-USRP
    NI-USRP 15.0 adds support for LabVIEW 2015 (32- and 64-bit).
    NI-USRP 14.5.1 adds support for several bug fixes.
    NI-USRP 14.5 includes the following new features:
    • Support for NI USRP-294x 120 MHz and NI USRP-295x 120 MHz devices
    NI-USRP 14.1 includes the following new features:
    • Support for NI USRP-2900 and NI USRP-2901 hardware with LabVIEW Communications System Design software
    NI-USRP 14.0 adds support for LabVIEW 2014 (32- and 64-bit).
    The following hardware products are supported under Windows 10 (32-bit and 64-bit* versions), Windows 8.1 (32-bit and 64-bit* versions)/7 (32-bit and 64-bit* versions)/Vista (32-bit and 64-bit* versions)/XP operating systems.
    • NI USRP-2900†
    • NI USRP-2901†
    • NI USRP-2920
    • NI USRP-2921
    • NI USRP-2922
    • NI USRP-2930
    • NI USRP-2932
    • NI USRP-2940R 40 MHz
    • NI USRP-2942R 40 MHz
    • NI USRP-2943R 40 MHz
    • NI USRP-2950R 40 MHz
    • NI USRP-2952R 40 MHz
    • NI USRP-2953R 40 MHz
    • NI USRP-2940R 120 MHz
    • NI USRP-2942R 120 MHz
    • NI USRP-2943R 120 MHz
    • NI USRP-2950R 120 MHz
    • NI USRP-2952R 120 MHz
    • NI USRP-2953R 120 MHz
    • Ettus Research USRP2**
    • Ettus Research N200**
    • Ettus Research N210**
    • Ettus Research X300**
    • Ettus Research X310**
    * These software versions run within the 32-bit emulation layer, Windows on Windows (WOW64), or in a native 64-bit process.
    † These devices are supported only in LabVIEW Communications System Design software.
    ** The NI-USRP instrument driver supports WBX, SBX, XCVR2450, LFTX, LFRX, BasicTX, and BasicRX daughterboards on this device. Other daughterboards may also be compatible, but they have not been tested.
    Device-specific information about these modules is included in the NI-USRP Help.
    NI-USRP 15.0 supports the following operating systems:
    • Windows XP Service Pack 3 (SP3)(32-bit)
    Minimum System Requirements
    • RAM—1 GB
    • Gigabit Ethernet interface
    • Windows 10/8.1/7/Vista/XP SP3, with all available critical updates and service packs
    Recommended System
    • Processor—Intel i7 or equivalent
    • RAM—2 GB
    • Dedicated gigabit Ethernet interface for each device
    Note  You should install ADEs, such as NI LabVIEW or LabVIEW Communications System Design software, before installing NI-USRP 15.0. To add support for ADEs installed after installing NI-USRP, modify your NI-USRP installation or launch the NI-USRP installer again.
    • NI LabVIEW 2012, 2013, 2014, 2015
    • LabVIEW Communications System Design software 1.0, 1.1
      • Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit)/Vista (32-bit)/Windows XP: Program Files\National Instruments\
      • Windows 10 (32-bit)/8.1 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\National Instruments\
      • Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit)/Vista (32-bit)/Windows XP: Windows\System32
      • Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit)/Vista (64-bit): Windows\syswow64
      • Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\National Instruments\
      • Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit)/Vista (64-bit): Windows\system32
    ItemInstalled Location
    NI-USRP\NI-USRP\
    NI-USRP Utilities\NI-USRP\utilities\
    NI-USRP Examples\LabVIEW\examples\instr\niUSRP\
    NI-USRP Header files\Shared\ExternalCompilerSupport\C\include
    NI-USRP Import Library files\Shared\ExternalCompilerSupport\C\lib32\msvc
    NI-USRP DLL\niusrp.dll
    NI UHD DLL\niuhd.dll
    NI USRP-RIO DLL\niusrprio.dll
    NI USRP-RIO RPC\niusrpriorpc.exe
    NI-USRP USB Monitor\niusrpmonitor.exe
    NI-USRP Firmware and FPGA images\NI-USRP\images\
    Note  The NI Example Finder does not include NI-USRP examples.
    Additional File Locations for Windows (64-bit)
    NI-USRP\NI-USRP\
    NI-USRP Examples (NI LabVIEW 2014 only)\LabVIEW 2014\examples\instr\niUSRP\
    Documentation for NI-USRP is located at Start»All Programs»National Instruments»NI-USRP»Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-USRP HelpHTML/Windows HelpThe primary document for most NI-USRP products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI USRP
    • Hardware device overviews
    • Information about how to get started with application development
    • A complete programming reference for all NI-USRP VIs
    NI USRP-29xx Getting Started GuidePrinted and PDFContains software and hardware installation, Measurement & Automation Explorer (MAX) configuration, signal connection, and troubleshooting information for your NI 292x/293x/294x/295x device.
    NI USRP-2900/2901 Getting Started GuidePrinted and PDFContains software and hardware installation, signal connection, and troubleshooting information for your NI 2900 or NI 2901 device.
    SpecificationsPDFLists technical specifications for your device.
    NI-USRP 15.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Documentation for LabVIEW Communications System Design software is located online at http://www.ni.com/documentation/en/labview-comms/latest/manual/labview-comms-manual/ and includes the following information:
    • An introduction to LabVIEW Comms
    • A complete programming reference for all NI-USRP nodes
    To access the LabVIEW sample project from the Create Project dialog, select Sample Projects in the left pane and navigate to the Simple NI-USRP Streaming project.
    NI–USRP palette VIs are available from the Functions»Instrument I/O»Instrument Drivers»NI-USRP palette.
    Accessing Examples
    NI-USRP includes several example applications for LabVIEW. These examples serve as interactive tools, programming models, and as building blocks in your own applications. NI-USRP includes examples for getting started and other software-defined radio (SDR) functionality. You can access the NI-USRP examples from the following locations:
    • From the Start menu at Start»All Programs»National Instruments»NI-USRP»Examples.
    • From the LabVIEW Functions palette at Instrument I/O»Instrument Drivers»NI-USRP»Examples.
    You can access additional examples from the Code Sharing Community at ni.com/usrp.
    NI-USRP versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-USRP 15.0 is the version released with LabVIEW 2015 SP1. The last version released under the old numbering scheme is NI-USRP 1.3. The first version released under the new numbering scheme is NI-USRP 14.0.
    • Click Change/Remove.
    • Select NI-USRP 15.0 from the dialog box that appears.
    For Windows 8.1, complete the following steps:
    • Go to the desktop.
    • Select the Charms Bar.
    • Select Settings.
    • Click Control Panel.
    As part of the NI-USRP 15.0 installation, the following software is installed. To completely remove the NI-USRP 15.0 installation from your system, you must also remove all of the following packages:
    • NI LabVIEW Modulation Toolkit 4.4
    • NI LabVIEW MathScript RT Module (depending on distribution)
    • NI LabVIEW Digital Filter Design Toolkit (depending on distribution)
    • NI-RIO 15.0
    • NI Measurement & Automation Explorer 15.0
    Ethernet Support on NI 294x/295x Devices
    NI 294x/295x devices support both 1G Ethernet and 10G Ethernet using the connectors on the device back panel. With the default FPGA image, port 0 is designated for 1G, and port 1 is designated for 10G.
    You can access the software and documentation known issues list online. Refer to the NI-USRP 15.0 Known Issues at ni.com and enter the Info Code exwey5 for an up-to-date list of known issues in NI-USRP 15.0.
    The following items are changes in NI-USRP 14.5.1 from NI-USRP 14.5.0.
    546871Fixed an issue that caused the Reference Clock PLL in FPGA to fail to lock to the internal source.
    545660Fixed an issue that caused the signal to degrade after you install the NI-USRP 14.5.0 driver.
    The following items are changes in NI-USRP 14.5 from NI-USRP 14.1.
    506448Fixed an issue that caused multiple Rx channels to fail to align when you use USRP RIO and NI-USRP VIs.
    494912Fixed an issue that caused NI-USRP not to accept RIO aliases for USRP devices that use PCI Express.
    492685Fixed an issue that caused the niUSRP Open Rx Session VI to take a long time to execute after you run the niUSRP Open Tx Session VI followed by the niUSRP Configure Signal VI.
    492219Fixed an issue that caused a Tx underflow error when you start Rx after Tx.
    489197Fixed an issue that caused an LO locking error on channel 1 when you query an attribute from the NI-USRP driver before you configure any parameters.
    470359Fixed an issue that caused bad or empty GPS NMEA strings to return when queries are made in a random wait iterative fashion.
    456805Fixed an issue that caused the niUSRP Get Time VI to return a value of 1 instead of 0 in the fractional seconds output.
    311843Fixed an issue that caused the NI 2920 and NI 2921 devices to coerce the carrier frequency incorrectly.
    The following items are changes in NI-USRP 14.1 from NI-USRP 14.0.
    510807Fixed an issue that caused NI-USRP to hang if an empty array was passed to the niUSRP Write Tx Data (poly) VI.
    The following items are changes in NI-USRP 14.0 from NI-USRP 1.3.
    488044Fixed an issue that caused clocks derived from the Data Clock to result in invalid data due to the Data Clock changing rate. Refer to KB 6OBBPOR4 on ni.com.
    484898Fixed an issue that caused incorrect reference level settings when you configure the Rx reference level on NI 294x/295x devices.
    465859Fixed an issue that caused errors when you configure two sessions in LabVIEW to the same device in parallel fashion.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Finding All Programs
    NI-USRP Drops Support for Microsoft Windows Vista and Windows XP in 2016
    National Instruments NI-USRP will drop support for Microsoft Windows Vista and Windows XP as of July 1, 2016. Versions of NI-USRP that ship after July 1, 2016 will not install or run on Windows Vista, or Windows XP. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2011–2015 National Instruments. All rights reserved.
    374760E-01
    GMT+8, 2025-11-19 10:41
