NI-USRP 15.5 Driver Win32/64Eng NI通用软件无线电外设仪器驱动程序15.5下载
NI USRP
NI-USRP支持使用NI通用软件无线电外设(USRP)收发仪和LabVIEW可重配置I/O (RIO) USRP设备的客户。
NI-USRP是一个NI仪器驱动程序,可同时支持软件无线电(SDR)设备和可重配置SDR设备。如果要配置设备,可使用NI-USRP仪器驱动程序中包含的NI-USRP API或USRP RIO仪器设计库(IDL)。NI-USRP可帮助您使用NI SDR硬件创建发射(Tx)和接收(Rx)应用。
15.5
文件大小: 1755706672 字节 (1.64 GB)
修改日期: 2019-06-25 02:58
MD5: 5114766ffd9250cf767e0c45833074af(官方正确)
SHA1: 0a10fdbafd8b16e5599471c16c8131c2d85c2a53
SHA256: 9e4e0bb5d89dcc7f7d8bb85545f46f3126820e7ad5c4e611611f078bc1323fba
CRC32: fb4be06f
USRP15.5.txt
(559 Bytes, 下载次数: 0, 售价: 10 圆)
NI-USRP 15.5 ReadmeJuly 2016
Thank you for using NI-USRP. This file contains important information about NI-USRP and is organized into the following sections:
New Features Supported Hardware System Requirements Installed Software, Documentation, and Examples Documentation Accessing VIs and Functions Finding Examples and Sample Projects Product Security and Critical Updates Driver Version Naming Changes Uninstalling/Modifying NI-USRP Known Issues Bug Fixes Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 NI Software Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 Legal Information New FeaturesNI-USRP 15.5 includes the following new features:
- Support for NI USRP-2944R and NI USRP-2954R devices
NI-USRP 15.1 adds support for LabVIEW Communications 2.0.
NI-USRP 15.0 adds support for LabVIEW 2015 (32- and 64-bit).
NI-USRP 14.5.1 adds support for several bug fixes.
NI-USRP 14.5 includes the following new features:
- Support for NI USRP-294x 120 MHz and NI USRP-295x 120 MHz devices
NI-USRP 14.1 includes the following new features:
- Support for NI USRP-2900 and NI USRP-2901 hardware with LabVIEW Communications System Design software
NI-USRP 14.0 adds support for LabVIEW 2014 (32- and 64-bit).
Supported HardwareThe following hardware products are supported under Windows 10 (32-bit and 64-bit*), Windows 8.1 (32-bit and 64-bit*)/7 (32-bit and 64-bit*)/Vista (32-bit and 64-bit*)/XP operating systems.
- NI USRP-2900†
- NI USRP-2901†
- NI USRP-2920
- NI USRP-2921
- NI USRP-2922
- NI USRP-2930
- NI USRP-2932
- NI USRP-2940R 40 MHz
- NI USRP-2940R 120 MHz
- NI USRP-2942R 40 MHz
- NI USRP-2942R 120 MHz
- NI USRP-2943R 40 MHz
- NI USRP-2943R 120 MHz
- NI USRP-2944R
- NI USRP-2950R 40 MHz
- NI USRP-2950R 120 MHz
- NI USRP-2952R 40 MHz
- NI USRP-2952R 120 MHz
- NI USRP-2953R 40 MHz
- NI USRP-2953R 120 MHz
- NI USRP-2954R
- Ettus Research USRP2**
- Ettus Research N200**
- Ettus Research N210**
- Ettus Research X300**
- Ettus Research X310**
* These software versions run within the 32-bit emulation layer, Windows on Windows (WOW64), or in a native 64-bit process.
† These devices are supported only in LabVIEW Communications System Design software.
** The NI-USRP instrument driver supports UBX, CBX, CBX-120, WBX, WBX-120, SBX, SBX-120, and XCVR2450 daughterboards. Other daughterboards may also be compatible, but they have not been tested.
Device-specific information about these modules is included in the NI-USRP Help.
System RequirementsSupported Operating SystemsNI-USRP 15.5 supports the following operating systems:
- Windows 10 (32-bit and 64-bit)
- Windows 8.1 (32-bit and 64-bit)
- Windows 7 (32-bit and 64-bit)
- Windows Vista (32-bit and 64-bit)
- Windows XP Service Pack 3 (32-bit)
Minimum System Requirements- Processor—Pentium 4 or equivalent
- RAM—2 GB
- Microsoft Internet Explorer 5.5 or later
- A screen resolution of 1,024 x 768 with 256 colors
- Windows 10/8.1/7/Vista/XP SP3, with all available critical updates and service packs
Device | Minimum System Requirements | | NI USRP-290x | USB 2.0 or higher | | NI USRP-292x/293x | Gigabit Ethernet | | NI USRP-294x/295x | PCI/MXI Express x4 or Gigabit Ethernet |
Recommended System- Processor—Intel i7 or equivalent
- RAM—4 GB
- Windows 10/8.1/7, with all available critical updates and service packs
Device | Recommend System | | NI USRP-290x | USB 3.0 or higher | | NI USRP-292x/293x | Gigabit Ethernet | | NI USRP-294x/295x | PCI/MXI Express x4 or Gigabit Ethernet |
Application Development Environments (ADEs)Note You should install ADEs, such as NI LabVIEW or LabVIEW Communications System Design software, before installing NI-USRP 15.5. To add support for ADEs installed after installing NI-USRP, modify your NI-USRP installation or launch the NI-USRP installer again.
- NI LabVIEW 2012, 2013, 2014, or 2015
- LabVIEW Communications System Design Suite 2.0
Installed Software, Documentation, and ExamplesInstalled Software- is an alias for the following National Instruments file folder location:
- Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit)/Vista (32-bit)/Windows XP: Program Files\National Instruments\
- Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\National Instruments\
- is an alias for the following file folder location:
- Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit)/Vista (32-bit)/Windows XP: Windows\System32
- Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit)/Vista (64-bit): Windows\syswow64
- Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\National Instruments\
- Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit)/Vista (64-bit): Windows\system32
File LocationsItem | Installed Location | | NI-USRP | \NI-USRP\ | | NI-USRP Utilities | \NI-USRP\utilities\ | | NI-USRP Examples | \LabVIEW\examples\instr\niUSRP\ | | NI-USRP Header files | \Shared\ExternalCompilerSupport\C\include | | NI-USRP Import Library files | \Shared\ExternalCompilerSupport\C\lib32\msvc | | NI-USRP DLL | \niusrp.dll | | NI-USRP 2 DLL | \niusrp2.dll | | NI UHD DLL | \niuhd.dll | | NI UHD 2 DLL | \niuhd2.dll | | NI-USRP RIO DLL | \niusrprio.dll | | NI-USRP RIO RPC | \niusrpriorpc.exe | | NI-USRP USB Monitor | \niusrpmonitor.exe | | NI-USRP Firmware and FPGA images | \NI-USRP\images\ |
Additional File Locations for Windows (64-bit)Item | Installed Location | | NI-USRP | \NI-USRP\ | | NI-USRP Header files | \Shared\ExternalCompilerSupport\C\include | | NI-USRP Import Library files | \Shared\ExternalCompilerSupport\C\lib64\msvc | | NI-USRP DLL | \niusrp.dll | | NI-USRP 2 DLL | \niusrp2.dll | | NI UHD DLL | \niuhd.dll | | NI UHD 2 DLL | \niuhd2.dll | | NI-USRP RIO DLL | \niusrprio.dll | | NI-USRP Examples (NI LabVIEW 2015 only) | \LabVIEW 2015\examples\instr\niUSRP\ |
DocumentationDocumentation for NI-USRP is located at Start»All Programs»National Instruments»NI-USRP»Documentation. The documentation set is composed of the following documents.
Document | Format | Description | | NI-USRP Help | HTML/Windows Help | The primary document for most NI-USRP products. The help is an HTML version of a traditional user manual that includes the following information:- An introduction to NI USRP
- Hardware device information
- How to get started with application development
- A complete reference for all NI-USRP programming functions and VIs
| | NI USRP-292x Getting Started Guide | Printed and PDF | Contains software and hardware installation, NI MAX configuration, signal connection, and troubleshooting information for your USRP-292x device. | | NI USRP-293x Getting Started Guide | Printed and PDF | Contains software and hardware installation, NI MAX configuration, signal connection, and troubleshooting information for your USRP-293x device. | | NI USRP-294x Getting Started Guide | Printed and PDF | Contains software and hardware installation, NI MAX configuration, signal connection, and troubleshooting information for your USRP-294x device. | | NI USRP-295x Getting Started Guide | Printed and PDF | Contains software and hardware installation, NI MAX configuration, signal connection, and troubleshooting information for your USRP-295x device. | | NI USRP-2900/2901 Getting Started Guide | Printed and PDF | Contains software and hardware installation, signal connection, and troubleshooting information for your USRP-2900 or USRP-2901 device. | | Specifications for your device | PDF | Lists technical specifications for your device. | | NI-USRP 15.5 Readme | HTML (this document) | Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices. |
To access the LabVIEW Communications System Design Suite 2.0 Manual, visit ni.com/info and enter the Info Code exudg7. This manual includes the following information:
- An introduction to LabVIEW Comms
- Hardware device overviews
- Information about how to get started with application development
- A complete programming reference for all NI-USRP nodes
Note To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/reader.
Accessing VIs and FunctionsNI–USRP palette VIs are available from the Functions»Instrument I/O»Instrument Drivers»NI-USRP palette.
USRP RIO palette VIs are available from the Functions»Instrument I/O»Instrument Drivers»USRP RIO palette.
Finding Examples and Sample ProjectsNI-USRP includes several example applications for LabVIEW. These examples serve as interactive tools, programming models, and as building blocks in your own applications. NI-USRP includes examples for getting started and other software-defined radio (SDR) functionality. You can access the NI-USRP examples from the following locations:
- From the Start menu at Start»All Programs»National Instruments»NI-USRP»Examples.
- From the LabVIEW Functions palette at Instrument I/O»Instrument Drivers»NI-USRP»Examples.
Note The NI Example Finder does not include NI-USRP examples.
USRP RIO includes several sample projects for LabVIEW. These sample projects serve as starting points to build a USRP RIO streaming application. To access the LabVIEW sample project from the Create Project dialog, select Sample Projects in the left pane and navigate to the Simple NI-USRP Streaming project.
You can access additional examples from the Code Sharing Community at ni.com/usrp.
Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments.
Driver Version Naming ChangesNI-USRP versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-USRP 15.0 is the version released with LabVIEW 2015. The last version released under the old numbering scheme is NI-USRP 1.3. The first version released under the new numbering scheme is NI-USRP 14.0.
Uninstalling/Modifying NI-USRPFor Windows XP, complete the following steps:
- Launch the Control Panel by selecting Start»Control Panel.
- Double-click Add or Remove Programs.
- Select National Instruments Software.
- Click Change/Remove.
- Select NI-USRP 15.5 from the dialog box that appears.
- Click Remove to uninstall the product; click Modify to change the components that are installed.
- Double-click Programs and Features.
- Click the Uninstall/Change button.
- Right-click on the Start button.
- Select Control Panel.
- Select Programs» Programs and Features.
- Click the Uninstall button.
As part of the NI-USRP 15.5 installation, the following software is installed. To completely remove the NI-USRP 15.5 installation from your system, you must also remove all of the following packages:
- NI-RIO 15.1
- NI Measurement & Automation Explorer 15.0
Caution Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
Note Do not attempt to uninstall by manually deleting files.
Ethernet Support on USRP-294x/295x DevicesUSRP-294x/295x devices support both 1G Ethernet and 10G Ethernet using the connectors on the device back panel. With the default FPGA image, port 0 is designated for 1G, and port 1 is designated for 10G.
Note The FPGA cannot be modified when the USRP-294x/295x device is connected through Ethernet.
Known IssuesYou can access the software and documentation known issues list online. Refer to the NI-USRP 15.5 Known Issues at ni.com/info and enter the Info Code ex63uj for an up-to-date list of known issues in NI-USRP 15.5.
Bug FixesThe following items are changes in NI-USRP 15.5 from NI-USRP 15.1.
ID | Fixed Issue | | 544731 | Fixed an issue that caused Rx/Tx samples to be misaligned by 5 ns when synchronizing using the external PPS on an USRP-294x/295x device. | | 519793 | Fixed an issue that caused two channel acquisitions (Rx) on a single USRP-2901 device to fail to align. | | 486961 | Fixed an issue that caused the niUSRP Find Devices VI to occasionally return incorrect information when a session is open to a USRP device. | | 466351 | Fixed an issue that caused "A stream command was issued in the past" or "Packet had timestamp that was late (or too early)" errors to occur with MIMO synchronization. |
There are no changes in NI-USRP 15.1 from NI-USRP 15.0.
The following items are changes in NI-USRP 15.0 from NI-USRP 14.5.1.
ID | Fixed Issue | | 544473 | Fixed an issue that caused the niUSRP Configure Frequency Shift VI to incorrectly negate the Tx shift when the scope was "all". |
The following items are changes in NI-USRP 14.5.1 from NI-USRP 14.5.
ID | Fixed Issue | | 546871 | Fixed an issue that caused the Reference Clock PLL in the FPGA to fail to lock to the internal source. | | 545660 | Fixed an issue that caused the signal to degrade after you install NI-USRP 14.5. |
The following items are changes in NI-USRP 14.5 from NI-USRP 14.1.
ID | Fixed Issue | | 528168 | Fixed an issue that caused channels to fail to align during a two-channel Rx using the USRP-2900 or USRP-2901. | | 506448 | Fixed an issue that caused multiple Rx channels to fail to align when you use USRP RIO and NI-USRP VIs. | | 494912 | Fixed an issue that caused NI-USRP not to accept RIO aliases for USRP devices that use PCI Express. | | 492685 | Fixed an issue that caused the niUSRP Open Rx Session VI to take a long time to execute after you run the niUSRP Open Tx Session VI followed by the niUSRP Configure Signal VI. | | 492219 | Fixed an issue that caused a Tx underflow error when you start Rx after Tx. | | 489197 | Fixed an issue that caused an LO locking error on channel 1 when you query an attribute from the NI-USRP driver before you configure any parameters. | | 470359 | Fixed an issue that caused bad or empty GPS NMEA strings to return when queries are made in a random wait iterative fashion. | | 456805 | Fixed an issue that caused the niUSRP Get Time VI to return a value of 1 instead of 0 in the fractional seconds output. | | 311843 | Fixed an issue that caused the USRP-2920 and USRP-2921 devices to coerce the carrier frequency incorrectly. |
The following items are changes in NI-USRP 14.1 from NI-USRP 14.0.
ID | Fixed Issue | | 510807 | Fixed an issue that caused NI-USRP to hang if an empty array was passed to the niUSRP Write Tx Data (poly) VI. | | 489197 | Fixed an issue that caused a LO locking error to occur on channel one on your USRP-294x/295x devices. |
The following items are changes in NI-USRP 14.0 from NI-USRP 1.3.
ID | Fixed Issue | | 488044 | Fixed an issue that caused clocks derived from the Data Clock to result in invalid data due to the Data Clock changing rate. Refer to KB 6OBBPOR4 on ni.com. | | 484898 | Fixed an issue that caused incorrect reference level settings when you configure the Rx reference level on USRP-294x/295x devices. | | 465859 | Fixed an issue that caused errors when you configure two sessions in LabVIEW to the same device in parallel fashion. | Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software.
- For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, Automating the Installation of a Suited Installer.
- To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, How Can I Determine the Type and Version of My National Instruments Installer?.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10.
Using NI Software with Microsoft Windows 8.1When you install National Instruments software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
NI-USRP Extends Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003Although most National Instruments software products will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016, NI-USRP will provide extended support until August 1, 2016. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
| Product | Info Code | | NI LabVIEW | lifecycle | | NI LabWindows™/CVI™ | cvi_lifecycle | | NI Measurement Studio | mstudiolifecycle | | NI TestStand | tslcp | | NI DIAdem | ddlcp | | NI SignalExpress | selcp | | NI VeriStand | nivslifecycle |
Legal InformationCopyright
© 2011–2016 National Instruments. All rights reserved.
- Notices are located in the \_Legal Information and directories.
374760G-01 |
