查看: 3118|回复: 0
[NI驱动程序] NI-USRP 16.1 Driver Win32/64Eng NI通用软件无线电外设仪器驱动程序16.1下载
    昨天 09:09
  • 签到天数: 3782 天
    连续签到: 33 天
    发表于 2020-11-16 23:08:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI USRP
    NI-USRP支持使用NI通用软件无线电外设(USRP)收发仪和LabVIEW可重配置I/O (RIO) USRP设备的客户。
    NI-USRP是一个NI仪器驱动程序,可同时支持软件无线电(SDR)设备和可重配置SDR设备。如果要配置设备,可使用NI-USRP仪器驱动程序中包含的NI-USRP API或USRP RIO仪器设计库(IDL)。NI-USRP可帮助您使用NI SDR硬件创建发射(Tx)和接收(Rx)应用。
    16.1
    文件大小: 2701061781 字节 (2.52 GB)
    修改日期: 2017-02-10 02:16
    MD5: 490fbd69829c09efd4e2bb923e644f04(官方正确)
    SHA1: ecebbd15aa1a7e8994d644aee370da92689fb612
    SHA256: d84906d26150770b0a77da3f8f76966e83e5af1e302e49c1f946eb167e7f9f47
    CRC32: f3aee9e0
    USRP16.1.txt (561 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-USRP 16.1 Readme
    February 2017
    This file contains important information about NI-USRP and is organized into the following sections:
    Accessing VIs and Functions
    Finding Examples and Sample Projects
    Driver Version Naming Changes
    Uninstalling/Modifying NI-USRP
    Ethernet Support on USRP RIO Devices
    NI-USRP 16.1 includes the following new features:
    • Support for USRP-2945 and USRP-2955 devices with LabVIEW 2016
    • Support for USRP-2900 and USRP-2901 devices with LabVIEW 2016
    NI-USRP 16.0 adds support for LabVIEW 2016 (32- and 64-bit).
    NI-USRP 15.5 includes the following new features:
    • Support for USRP-2944 and USRP-2954 devices
    NI-USRP 15.1 adds support for LabVIEW Communications 2.0.
    NI-USRP 15.0 adds support for LabVIEW 2015 (32- and 64-bit).
    NI-USRP 14.5.1 adds support for several bug fixes.
    NI-USRP 14.5 includes the following new features:
    • Support for USRP-2940/2942/2943 120 MHz and USRP-2950/2952/2953 120 MHz devices
    NI-USRP 14.1 includes the following new features:
    • Support for USRP-2900 and USRP-2901 hardware with LabVIEW Communications System Design Software
    NI-USRP 14.0 adds support for LabVIEW 2014 (32- and 64-bit).
    The following list shows which hardware products are supported in the NI-USRP instrument driver. The following hardware products are supported in all operating systems listed in the Supported Operating Systems section.
    • USRP-2900
    • USRP-2901
    • USRP-2920
    • USRP-2921
    • USRP-2922
    • USRP-2930
    • USRP-2932
    • USRP-2940 40 MHz
    • USRP-2940 120 MHz
    • USRP-2942 40 MHz
    • USRP-2942 120 MHz
    • USRP-2943 40 MHz
    • USRP-2943 120 MHz
    • USRP-2944
    • USRP-2945†
    • USRP-2950 40 MHz
    • USRP-2950 120 MHz
    • USRP-2952 40 MHz
    • USRP-2952 120 MHz
    • USRP-2953 40 MHz
    • USRP-2953 120 MHz
    • USRP-2954
    • USRP-2955†
    • Ettus Research USRP2**
    • Ettus Research N200**
    • Ettus Research N210**
    • Ettus Research X300**
    • Ettus Research X310**
    * These software versions run within the 32-bit emulation layer, Windows on Windows (WOW64), or in a native 64-bit process.
    † These devices are supported only in LabVIEW 2016.
    ** The NI-USRP instrument driver supports TwinRX, UBX, CBX, CBX-120, WBX, WBX-120, SBX, SBX-120, and XCVR2450 daughterboards. Other daughterboards may also be compatible, but they have not been tested.
    Device-specific information about these modules is included in the NI-USRP Help.
    • Windows Embedded Standard 7 SP12 (32-bit and 64-bit)
    Note  NI-USRP 16.1 and later does not support Windows Server non-R2 editions.
    Minimum Requirements
    • Connector—USB 2.0 or higher (USRP-2900/2901), Gigabit Ethernet (USRP-2920/2921/2922/2930/2932/2940/2942/2943/2944/2945/2950/2952/2953/2954/2955), or PCI/MXI Express x4 (USRP-2940/2942/2943/2944/2945/2950/2952/2953/2954/2955)
    Note  You should install ADEs, such as LabVIEW or LabVIEW Communications, before installing NI-USRP 16.1. To add support for ADEs installed after installing NI-USRP, modify your NI-USRP installation or launch the NI-USRP installer again.
    ADE
    Supported Devices
    LabVIEW 2013 SP1, 2014 SP1, 2015 SP1, or 2016All devices
    LabVIEW Communications System Design Software 2.0USRP-2900/2901/2920/2921/2922/2930/2932
    LabVIEW Communications System Design Suite 2.0USRP-2940/2942/2943/2944/2950/2952/2953/2954
    • is an alias for the following file folder location: (64-bit) Windows\system32
    Item
    Installed Location
    NI-USRP\NI-USRP\
    NI-USRP Utilities\NI-USRP\utilities\
    NI-USRP Examples\LabVIEW\examples\instr\niUSRP\
    NI-USRP Header files\Shared\ExternalCompilerSupport\C\include
    NI-USRP Import Library files\Shared\ExternalCompilerSupport\C\lib32\msvc
    NI-USRP DLL\niusrp.dll
    NI-USRP 2 DLL\niusrp2.dll
    NI UHD DLL\niuhd.dll
    NI UHD 2 DLL\niuhd2.dll
    NI-USRP RIO DLL\niusrprio.dll
    NI-USRP RIO RPC\niusrpriorpc.exe
    NI-USRP USB Monitor\niusrpmonitor.exe
    NI-USRP Firmware and FPGA images\NI-USRP\images\
    Additional File Locations for Windows (64-bit)
    Item
    Installed Location
    NI-USRP\NI-USRP\
    NI-USRP Import Library files\Shared\ExternalCompilerSupport\C\lib64\msvc
    NI-USRP Examples (LabVIEW 2016 only)\LabVIEW 2016\examples\instr.lib\niUSRP\
    Documentation for NI-USRP is located at Start»All Programs»National Instruments»NI-USRP»Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-USRP HelpHTML/Windows HelpThe primary document for most NI-USRP products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI USRP
    • Hardware device information
    • A complete reference for all NI-USRP programming functions and VIs
    USRP-2900/2901 Getting Started GuidePrinted and PDFContains software and hardware installation, signal connection, and troubleshooting information for your USRP-2900/2901 device.
    NI USRP-292x Getting Started GuidePrinted and PDFContains software and hardware installation, signal connection, and troubleshooting information for your USRP-2920/2921/2922 device.
    NI USRP-293x Getting Started GuidePrinted and PDFContains software and hardware installation, signal connection, and troubleshooting information for your USRP-2930/2932 device.
    USRP-2940/2942/2943/2944/2945 Getting Started GuidePrinted and PDFContains software and hardware installation, signal connection, and troubleshooting information for your USRP-2940/2942/2943/2944/2945 device.
    USRP-2950/2952/2953/2954/2955 Getting Started GuidePrinted and PDFContains software and hardware installation, signal connection, and troubleshooting information for your USRP-2950/2952/2953/2954/2955 device.
    NI-USRP 16.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    To access the LabVIEW Communications System Design Suite 2.0 Manual, visit ni.com/info and enter the Info Code commsmanual. This manual includes the following information:
    • An introduction to LabVIEW Comms
    • Hardware device overviews
    • Information about how to get started with application development
    • A complete programming reference for all NI-USRP nodes
    NI–USRP palette VIs are available from the Functions»Instrument I/O»Instrument Drivers»NI-USRP palette.
    USRP RIO palette VIs are available from the Functions»Instrument I/O»Instrument Drivers»USRP RIO palette.
    NI-USRP includes several example applications for LabVIEW. These examples serve as interactive tools, programming models, and as building blocks in your own applications. NI-USRP includes examples for getting started and other software-defined radio (SDR) functionality. You can access the NI-USRP examples from the following locations:
    • From the Start menu at Start»All Programs»National Instruments»NI-USRP»Examples.
    • From the LabVIEW Functions palette at Instrument I/O»Instrument Drivers»NI-USRP»Examples.
    Note  The NI Example Finder does not include NI-USRP examples.
    USRP RIO includes several sample projects for LabVIEW. These sample projects serve as starting points to build a USRP RIO streaming application. To access the LabVIEW sample project from the Create Project dialog, select Sample Projects in the left pane and navigate to the NI-USRP Simple Streaming project.
    You can access additional examples from the Code Sharing Community at ni.com/usrp.
    NI-USRP 16.1 Does Not Support Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    As of August 2016, NI-USRP does not support Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-USRP 16.1 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-USRP 16.1 to an unsupported OS. Additionally, after installing NI-USRP 16.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-USRP versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: . For example, NI-USRP 16.0 is the version released with LabVIEW 2016. The last version released under the old numbering scheme is NI-USRP 1.3. The first version released under the new numbering scheme is NI-USRP 14.0.
    • Select NI-USRP 16.1 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI-USRP 16.1 installation, the following software is installed. To completely remove the NI-USRP 16.1 installation from your system, you must also remove all of the following packages:
    • NI-RIO 16.0
    • NI Measurement & Automation Explorer 16.0
    USRP RIO devices support both 1G Ethernet and 10G Ethernet using the connectors on the device back panel. With the default FPGA image, port 0 is designated for 1G, and port 1 is designated for 10G.
    Note  The FPGA cannot be modified when the USRP RIO device is connected through Ethernet.
    You can access the software and documentation known issues list online. Refer to the NI-USRP 16.1 Known Issues at ni.com/info and enter the Info Code exidx4 for an up-to-date list of known issues in NI-USRP 16.1.
    The following items are changes in NI-USRP 16.1 from NI-USRP 16.0.
    ID
    Fixed Issue
    597196Fixed an issue that caused errors to appear when launching the NI-USRP Configuration Utility from LabVIEW Communications 2.0.
    494050Fixed an issue that caused the USRP-2950/2952/2953/2954 devices not to set the GPS time by default.
    There are no changes in NI-USRP 16.0 from NI-USRP 15.5.
    The following items are changes in NI-USRP 15.5 from NI-USRP 15.1.
    ID
    Fixed Issue
    544731Fixed an issue that caused Rx/Tx samples to be misaligned by 5 ns when synchronizing using the external PPS on a USRP RIO device.
    519793Fixed an issue that caused two channel acquisitions (Rx) on a single USRP-2901 device to fail to align.
    486961Fixed an issue that caused the niUSRP Find Devices VI to occasionally return incorrect information when a session is open to a USRP device.
    466351Fixed an issue that caused "A stream command was issued in the past" or "Packet had timestamp that was late (or too early)" errors to occur with MIMO synchronization.
    There are no changes in NI-USRP 15.1 from NI-USRP 15.0.
    The following items are changes in NI-USRP 15.0 from NI-USRP 14.5.1.
    ID
    Fixed Issue
    544473Fixed an issue that caused the niUSRP Configure Frequency Shift VI to incorrectly negate the Tx shift when the scope was "all".
    The following items are changes in NI-USRP 14.5.1 from NI-USRP 14.5.
    ID
    Fixed Issue
    546871Fixed an issue that caused the Reference Clock PLL in the FPGA to fail to lock to the internal source.
    545660Fixed an issue that caused the signal to degrade after you install NI-USRP 14.5.
    The following items are changes in NI-USRP 14.5 from NI-USRP 14.1.
    ID
    Fixed Issue
    528168Fixed an issue that caused channels to fail to align during a two-channel Rx using the USRP-2900 or USRP-2901.
    506448Fixed an issue that caused multiple Rx channels to fail to align when you use USRP RIO and NI-USRP VIs.
    494912Fixed an issue that caused NI-USRP not to accept RIO aliases for USRP devices that use PCI Express.
    492685Fixed an issue that caused the niUSRP Open Rx Session VI to take a long time to execute after you run the niUSRP Open Tx Session VI followed by the niUSRP Configure Signal VI.
    492219Fixed an issue that caused a Tx underflow error when you start Rx after Tx.
    489197Fixed an issue that caused an LO locking error on channel 1 when you query an attribute from the NI-USRP driver before you configure any parameters.
    470359Fixed an issue that caused bad or empty GPS NMEA strings to return when queries are made in a random wait iterative fashion.
    456805Fixed an issue that caused the niUSRP Get Time VI to return a value of 1 instead of 0 in the fractional seconds output.
    311843Fixed an issue that caused the USRP-2920 and USRP-2921 devices to coerce the carrier frequency incorrectly.
    The following items are changes in NI-USRP 14.1 from NI-USRP 14.0.
    ID
    Fixed Issue
    510807Fixed an issue that caused NI-USRP to hang if an empty array was passed to the niUSRP Write Tx Data (poly) VI.
    489197Fixed an issue that caused a LO locking error to occur on channel one on your USRP RIO devices.
    The following items are changes in NI-USRP 14.0 from NI-USRP 1.3.
    ID
    Fixed Issue
    488044Fixed an issue that caused clocks derived from the Data Clock to result in invalid data due to the Data Clock changing rate. Refer to KB 6OBBPOR4 on ni.com.
    484898Fixed an issue that caused incorrect reference level settings when you configure the Rx reference level on USRP RIO devices.
    465859Fixed an issue that caused errors when you configure two sessions in LabVIEW to the same device in parallel fashion.
    When you install National Instruments software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    © 2011–2017 National Instruments. All rights reserved.
    374760J-01
    GMT+8, 2026-1-25 05:36
