查看: 3207|回复: 0
[NI驱动程序] NI-USRP 17.2 Driver Win32/64Eng NI通用软件无线电外设仪器驱动程序17.2下载
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-11-16 23:15:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI USRP
    NI-USRP支持使用NI通用软件无线电外设(USRP)收发仪和LabVIEW可重配置I/O (RIO) USRP设备的客户。
    NI-USRP是一个NI仪器驱动程序,可同时支持软件无线电(SDR)设备和可重配置SDR设备。如果要配置设备,可使用NI-USRP仪器驱动程序中包含的NI-USRP API或USRP RIO仪器设计库(IDL)。NI-USRP可帮助您使用NI SDR硬件创建发射(Tx)和接收(Rx)应用。
    17.2
    文件大小: 3228101888 字节 (3.01 GB)
    修改日期: 2018-05-18 01:51
    版本: 18.1.0.0
    MD5: a8d34302042356cd26cf04715a8b160e(官方正确)
    SHA1: ec23771d4db52ae53cc52fd37f04dd7257e001f4
    SHA256: 75a9a2bb7283d356a1ba2bf488ae572e93a9791fa7bdeabc64c5e930015f81c2
    CRC32: 8c6b1d4b
    USRP17.2.txt (583 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-USRP 17.2 Readme
    April 2018
    This file contains important information about NI-USRP, including installation instructions, new features, a partial list of bugs fixed for NI-USRP 17.2, and known issues.
    Accessing VIs and Functions
    Finding Examples and Sample Projects
    Ethernet Support on USRP RIO Devices
    This software installation provides support for customers using software defined radio (USRP) devices and software defined radio reconfigurable (USRP RIO) devices, as specified in the Supported Hardware section. To program your USRP or USRP RIO device, use the NI-USRP API or USRP RIO Instrument Design Library (IDL) included in the NI-USRP instrument driver.
    The getting started guide for your device provides information about how to install, configure, test, and begin using a USRP or USRP RIO device.
    NI-USRP 17.2 adds support for the USRP-2974 device with LabVIEW Communications System Design Suite 2.0.
    NI-USRP 17.1 adds support for several bug fixes.
    NI-USRP 17.0 adds support for LabVIEW 2017 (32- and 64-bit).
    NI-USRP 16.1 includes the following new features:
    • Support for USRP-2945 and USRP-2955 devices with LabVIEW 2016
    • Support for USRP-2900 and USRP-2901 devices with LabVIEW 2016
    NI-USRP 16.0 adds support for LabVIEW 2016 (32- and 64-bit).
    NI-USRP 15.5 includes the following new features:
    • Support for USRP-2944 and USRP-2954 devices
    NI-USRP 15.1 adds support for LabVIEW Communications 2.0.
    NI-USRP 15.0 adds support for LabVIEW 2015 (32- and 64-bit).
    The following hardware products are supported in all operating systems listed in the Supported Operating Systems section. Refer to the Application Software Support section for information regarding supported application software versions.
    • USRP-2900
    • USRP-2901
    • USRP-2920
    • USRP-2921
    • USRP-2922
    • USRP-2930
    • USRP-2932
    • USRP-2940 40 MHz
    • USRP-2940 120 MHz
    • USRP-2942 40 MHz
    • USRP-2942 120 MHz
    • USRP-2943 40 MHz
    • USRP-2943 120 MHz
    • USRP-2944
    • USRP-2945
    • USRP-2950 40 MHz
    • USRP-2950 120 MHz
    • USRP-2952 40 MHz
    • USRP-2952 120 MHz
    • USRP-2953 40 MHz
    • USRP-2953 120 MHz
    • USRP-2954
    • USRP-2955
    • USRP-2974
    • Ettus Research USRP2*
    • Ettus Research N200*
    • Ettus Research N210*
    • Ettus Research X300*
    • Ettus Research X310*
    *The NI-USRP instrument driver supports TwinRX, UBX, CBX, CBX-120, WBX, WBX-120, SBX, SBX-120, XCVR2450
    daughterboards. Other daughterboards may also be compatible, but they have not been tested.
    Device-specific information about these modules is included in the NI-USRP Help.
    NI-USRP 17.2 has the following requirements:
    • Connector
      • USB 2.0 or higher (USRP-2900/2901)
      • Gigabit Ethernet (USRP-2920/2921/2922/2930/2932/2940/2942/2943/2944/2945/2950/2952/2953/2954/2955/2974)
      • PCI/MXI Express x4 (USRP-2940/2942/2943/2944/2945/2950/2952/2953/2954/2955)
    NI-USRP 17.2 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  NI-USRP 17.2 does not support Windows Server non-R2 editions.
    Note  In 2016, NI-USRP dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-USRP 17.2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-USRP 17.2 to an unsupported OS. Additionally, after installing NI-USRP 17.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-USRP 17.2 supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabVIEW Communications System Design Software, or LabVIEW Communications System Design Suite, before installing NI-USRP. To add support for application software installed after installing NI-USRP, modify your NI-USRP installation or launch the NI-USRP installer again.
    Device
    LabVIEW 2014 SP1, 2015 SP1, 2016, or 2017
    LabVIEW Communications System Design Software 2.0
    USRP-2900/2901YesYesYes
    USRP-2920/2921/2922YesYesYes
    USRP-2930/2932YesYesYes
    USRP-2940/2942/2943/2944YesNoYes
    USRP-2950/2952/2953/2954YesNoYes
    USRP-2945/2955Yes†NoNo
    USRP-2974NoNoYes
    † The USRP-2945/2955 devices are supported only in LabVIEW 2016 and LabVIEW 2017.
    Note  NI-USRP is not supported in LabVIEW NXG 1.0 or later.
    • is an alias for the following file folder location: (64-bit) Windows\system32
    Item
    Installed Location
    NI-USRP\NI-USRP\
    NI-USRP Utilities\NI-USRP\utilities\
    NI-USRP Examples\LabVIEW\examples\instr\niUSRP\
    NI-USRP Header files\Shared\ExternalCompilerSupport\C\include
    NI-USRP Import Library files\Shared\ExternalCompilerSupport\C\lib32\msvc
    NI-USRP DLL\niusrp.dll
    NI-USRP 2 DLL\niusrp2.dll
    NI UHD DLL\niuhd.dll
    NI UHD 2 DLL\niuhd2.dll
    NI-USRP RIO DLL\niusrprio.dll
    NI-USRP RIO RPC\niusrpriorpc.exe
    NI-USRP USB Monitor\niusrpmonitor.exe
    NI-USRP Firmware and FPGA images\NI-USRP\images\
    Additional File Locations for Windows (64-bit)
    Item
    Installed Location
    NI-USRP\NI-USRP\
    NI-USRP Import Library files\Shared\ExternalCompilerSupport\C\lib64\msvc
    NI-USRP Examples\LabVIEW\examples\instr.lib\niUSRP\
    Documentation for NI-USRP is located at Start»All Programs»National Instruments»NI-USRP»Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-USRP HelpHTML/Windows HelpThe primary document for most NI-USRP products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI USRP
    • Hardware device information
    • A complete reference for all NI-USRP programming functions and VIs
    Getting Started Guide for your devicePrinted and PDFContains software and hardware installation, configuration, signal connection, and troubleshooting information for your device.
    NI-USRP 17.2 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    To access the LabVIEW Communications System Design Suite 2.0 Manual, visit ni.com/info and enter the Info Code commsmanual. This manual includes the following information:
    • An introduction to LabVIEW Comms
    • Hardware device overviews
    • Information about how to get started with application development
    • A complete programming reference for all NI-USRP nodes
    NI–USRP palette VIs are available from the Functions»Instrument I/O»Instrument Drivers»NI-USRP palette.
    USRP RIO palette VIs are available from the Functions»Instrument I/O»Instrument Drivers»USRP RIO palette.
    NI-USRP includes several example applications for LabVIEW. These examples serve as interactive tools, programming models, and as building blocks in your own applications. NI-USRP includes examples for getting started and other software-defined radio (SDR) functionality. You can access the NI-USRP examples from the following locations:
    • From the Start menu at Start»All Programs»National Instruments»NI-USRP»Examples.
    • From the LabVIEW Functions palette at Instrument I/O»Instrument Drivers»NI-USRP»Examples.
    Note  The NI Example Finder does not include NI-USRP examples.
    USRP RIO includes several sample projects for LabVIEW. These sample projects serve as starting points to build a USRP RIO streaming application. To access the LabVIEW sample project from the Create Project dialog, select Sample Projects in the left pane and navigate to the NI-USRP Simple Streaming project.
    You can access additional examples from the Code Sharing Community at ni.com/usrp.
    USRP RIO devices support both 1G Ethernet and 10G Ethernet using the connectors on the device back panel. With the default FPGA image, port 0 is designated for 1G, and port 1 is designated for 10G.
    The USRP-2974 is only supported through Ethernet using 1 GbE through RJ45 and 10 GbE through SFP+ connections.
    Note  The FPGA cannot be modified when the USRP RIO device is connected through Ethernet.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-USRP 17.2.
    There are no changes in NI-USRP 17.2 from NI-USRP 17.1.
    The following items are changes in NI-USRP 17.1 from NI-USRP 17.0.
    ID
    Fixed Issue
    679121Fixed an issue that caused digital data values in the NI-USRP Simple Streaming with USRP-2945/2955 Sample Project to be scaled to half of the correct value.
    681935Fixed an issue that caused aliases to appear in the data path after the frequency shift occurred on the FPGA.
    The following items are changes in NI-USRP 17.0 from NI-USRP 16.1.
    ID
    Fixed Issue
    641880Fixed an issue that caused the RF frequency to be inaccurate due to LO sharing when using the USRP-2945/2955 and the USRP RIO sample project.
    624459Fixed an issue that caused the building of a bitfile to fail using DRAM in LabVIEW Communications 2.0 after installing NI-USRP.
    617872Fixed an issue that caused the streaming performance of USRP RIO devices to degrade when connected over PCIe and using NI-USRP API.
    The following items are changes in NI-USRP 16.1 from NI-USRP 16.0.
    ID
    Fixed Issue
    597196Fixed an issue that caused errors to appear when launching the NI-USRP Configuration Utility from LabVIEW Communications 2.0.
    494050Fixed an issue that caused the USRP-2950/2952/2953/2954 devices not to set the GPS time by default.
    There are no changes in NI-USRP 16.0 from NI-USRP 15.5.
    The following items are changes in NI-USRP 15.5 from NI-USRP 15.1.
    ID
    Fixed Issue
    544731Fixed an issue that caused Rx/Tx samples to be misaligned by 5 ns when synchronizing using the external PPS on a USRP RIO device.
    519793Fixed an issue that caused two channel acquisitions (Rx) on a single USRP-2901 device to fail to align.
    486961Fixed an issue that caused the niUSRP Find Devices VI to occasionally return incorrect information when a session is open to a USRP device.
    466351Fixed an issue that caused "A stream command was issued in the past" or "Packet had timestamp that was late (or too early)" errors to occur with MIMO synchronization.
    There are no changes in NI-USRP 15.1 from NI-USRP 15.0.
    The following items are changes in NI-USRP 15.0 from NI-USRP 14.5.1.
    ID
    Fixed Issue
    544473Fixed an issue that caused the niUSRP Configure Frequency Shift VI to incorrectly negate the Tx shift when the scope was "all".
    © 2011–2018 National Instruments. All rights reserved.
    374760M-01
    GMT+8, 2025-11-19 10:41
