查看: 3130|回复: 0
[NI软件产品] NI Package Builder 19.0 Win32/64Eng NI安装包生成器NIPB19.0
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2020-11-18 22:57:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI Package Builder可帮助您管理和生成自己的NI软件包、软件包安装程序和订阅源。
    NI Package Builder是一个用于分发软件的实用程序。您可以使用它来管理和生成多个软件包和订阅源,然后使用Package Manager或SystemLink软件进行分发。您还可以生成和分发独立的软件包安装程序。此外,您可以将多个NI产品安装程序捆绑到自定义安装文件中。
    19.0
    文件大小: 540379136 字节 (515.35 MB)
    修改日期: 2019-05-15 05:17
    MD5: a00082ebacdb8a12c1e408de8c860b4c(官方正确)
    SHA1: 3ae52320034443e8e64bc0406be535637120167a
    SHA256: 8c71e06005db9f9010399cd180a89db7a7e7514856d2bb44cc58f4ad433a6007
    CRC32: 58006586
    NIPB19.0.txt (639 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Package Builder 19.0.1 Readme
    May 2019
    This file contains important information about NI Package Builder, including installation instructions, features, and known issues.
    Features
    NI Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Use NI Package Builder to set up, create, and publish complex package-based deployments.
    NI Package Builder 19.0.1 has the following recommended requirements:
    • Intel i5 or equivalent
    • At least 130 MB of disk space
    • 4 GB RAM
    NI Package Builder 19.0.1 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  Refer to NI Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    NI Package Builder 19.0.1 supports the following application software versions, including service packs.
    Versions Supported by Package Builder 19.0.1
    Integration Support
    Package Builder Can Deploy
    NI TestStand™
    2019 and later
    2017 and later
    2016 SP1 and later
    2018 and later
    LabVIEW NXG1
    N/A
    2.0 and later
    LabWindows™/CVI™ 1
    N/A
    2019 and later
    Measurement Studio1
    N/A
    2019 and later
    1 NI Package Builder can create and deploy package-based installers for these products; however, NI Package Builder does not perform any discovery, custom staging, or automatic selection of package dependencies for these products' deployment files.
    NI automates Package Builder installation using NI Package Manager. If you do not already have NI software installed, NI Package Builder installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • The installation of NI Package Builder installs both a 32-bit and a 64-bit version of NI Package Builder. If you will be deploying NI TestStand files, you should choose the version of NI Package Builder that is the same bitness as you use for NI TestStand.
    Features
    NI Package Builder helps you perform the following tasks:
    • Configuring and creating packages, including defining the dependencies between packages;
    • Creating local repositories that contain one or more top-level packages including any package dependencies and a feed that lists the collection of packages and their location;
    • Creating package installers that contain one or more top-level packages including any package dependencies; and
    • Bundling multiple NI product installers into a package installer.
    NI plans to continuously develop and release new features in NI Package Builder to address known limitations. Refer to the NI Package Builder Help for more information about known limitations. Look for updates to NI Package Builder in NI Package Manager.
    You can access the software and documentation known issues list online. Visit ni.com/info and enter the Info Code NIPBKnownIssues for an up-to-date list of known issues in NI Package Builder 19.0.1.
    Refer to the NI Package Builder Help, accessible from the Package Builder toolbar, for information about Package Builder.
    NI will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2019 National Instruments. All rights reserved.
    377980A-01
    GMT+8, 2025-12-5 13:25
