查看: 5831|回复: 1
[LV工具模块] NI Automotive Diagnostic Command Set Toolkit 18.0 Full Win32/64Eng 汽车诊断命令集工具包ADCS18.0完整版下载
    昨天 08:40
  • 签到天数: 3765 天
    连续签到: 16 天
    发表于 2020-11-19 22:55:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    汽车诊断命令集工具包Automotive Diagnostic Command Set Toolkit
    汽车诊断命令集工具包为ECU生产测试设计和开发汽车诊断应用程序。
    汽车诊断命令集(ADCS)工具包是LabVIEW、LabWindows/CVI和Microsoft Visual Studio的软件附件。该附件适用于一系列汽车诊断应用,通常包括读取和写入参数、访问故障诊断代码(DTC)、闪存ECU固件以及启动ECU诊断测试模式。借助ADCS工具包,您可以开发单个应用程序,并根据需要随时进行部署,而无需额外部署或runtime许可证。该附件与许多NI汽车接口设备兼容,可简化各种便携式和车载诊断应用的开发,并提供对UDS、OBD、WWH-OBD等协议的支持。LabWindows标志经Microsoft公司授权使用。Windows是Microsoft公司在美国和其他国家的注册商标。
    18.0
    文件大小: 459499748 字节 (438.21 MB)
    修改日期: 2019-06-25 02:42
    MD5: 35a1ef62da4a4f879c0af947a8e5d27e(官方正确)
    SHA1: aa6c7d5be0a1163585304fdf70b60734c4030897
    SHA256: 0907f546c04659a137f82f199f7230abd902e5bb2af9099eecbc9ad319e948f4
    CRC32: 52a0149e
    ADCS18.0.txt (600 Bytes, 下载次数: 16, 售价: 10 圆)
    Automotive Diagnostic Command Set 18.0 Readme
    June 2018
    This file contains important information about the Automotive Diagnostic Command Set software for Windows and LabVIEW Real-Time (RT), including installation instructions, new features, and known issues for Automotive Diagnostic Command Set 18.0.
    Supported Software and Hardware
    ECU Simulator
    Additional Programming Topics
    Using NI-XNET with the Automotive Diagnostic Command Set
    The Automotive Diagnostic Command Set software supports Windows 10/8.11/7 SP12.
    Note  In 2016 National Instruments dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. Automotive Diagnostic Command Set 18.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use Automotive Diagnostic Command Set 18.0 to an unsupported OS. Additionally, after installing this version of Automotive Diagnostic Command Set, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    This version of Automotive Diagnostic Command Set software supports the following development environments, including service packs.
    Application SoftwareVersions Supported by Automotive Diagnostic Command Set 18.0
    LabVIEW2015, 2016, 2017, and 2018
    LabVIEW Real-Time (ETS)2015, 2016, 2017, and 2018
    LabWindows™/CVI™2012 and later
    Microsoft Visual C/C++2008 and later
    Note  The Automotive Diagnostic Command Set software does not support LabWindows™/CVI™ Real-Time Module.
    Supported Software and HardwareThe Automotive Diagnostic Command Set software supports the following software and hardware:
    • NI-CAN software version 15.0 or later
    • NI-CAN hardware supported by NI-CAN 15.0
    • NI-XNET software version 15.0 or later
    • NI-XNET CAN and LIN hardware supported by NI-XNET 15.0 or later
    • CompactRIO and R-Series hardware using NI 9852/9853 two-port CAN modules for NI CompactRIO (we recommend using NI 986x on NI CompactRIO instead of NI 985x)
    Note  The Automotive Diagnostic Command Set software supports only National Instruments CAN and LIN hardware products.
    For information about software for CAN products from other vendors, refer to the documentation you received with those products.
    Before installing the Automotive Diagnostic Command Set software, log on as Administrator or as a user with Administrator privileges. The Automotive Diagnostic Command Set software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the Automotive Diagnostic Command Set software.
    • Insert the Automotive Diagnostic Command Set software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your Automotive Diagnostic Command Set software CD.
    • The installation wizard guides you through the necessary steps to install the Automotive Diagnostic Command Set software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
    ECU Simulator
    The Automotive Diagnostic Command Set software provides an ECU simulation for CAN and LIN. All examples of the Automotive Diagnostic Command Set are preconfigured to communicate with the ECU simulation.
    LabVIEW users can find the ECU simulator under National Instruments\LabVIEW\examples\Automotive Diagnostic Command Set\Diagnostic Demo ECU.llb.
    Microsoft Visual C/C++ users can find the ECU simulator under \Users\Public\Documents\National Instruments\Automotive Diagnostic Command Set\Examples\MS Visual C\Diagnostic Demo ECU.
    New Features and Changes as Compared to Automotive Diagnostic Command Set 15.0
    The Automotive Diagnostic Command Set 18.0 release adds the following features:
    • Added support for LabVIEW 2016, LabVIEW 2017, and LabVIEW 2018.
    • Added support for ISO CAN FD.
    • Added support for Diagnostic over IP over non-Primary NICs.
    • Added support for LIN sleep for UDS.
    • Removed support for LabVIEW 2012, LabVIEW 2013, and LabVIEW 2014.
    Removed support for LabWindows™/CVI™ 2010 and earlier versions.New Features and Changes as Compared to Automotive Diagnostic Command Set 14.0
    The Automotive Diagnostic Command Set 15.0 release adds the following features:
    • Removed support for LabVIEW 2011.
    • Added support for 64-bit LabVIEW and C/C++.
    • Added support for CompactRIO Real-Time Controllers supported by NI-XNET 15.0 (NI cRIO-9081, NI cRIO-9082, NI cRIO-903x).
    New Features and Changes as Compared to Automotive Diagnostic Command Set 1.2
    The Automotive Diagnostic Command Set 14.0 release adds the following features:
    • Added support for LabVIEW 2014.
    • Removed support for LabVIEW 2010.
    • Added support for WWH-OBD (World-Wide-Harmonized On-Board Diagnostics) based on ISO 27145.
    • Added the new Get Time Stamp function to measure timestamp information of the first/last send/received frame of the ISO TP for CAN and LIN.
    • Added support for NI cRIO-9068 Controller (based on NI Linux Real-Time OS).
    The Automotive Diagnostic Command Set software installs the necessary C/C++ support files in the following locations:
    • The typical path to the C examples folder is \Users\Public\Documents\National Instruments\Automotive Diagnostic Command Set\Examples\MS Visual C.
    • The header file for Visual C/C++ 2008 and 2015 is in the Program Files\National Instruments\Shared\ExternalCompilerSupport\C\include folder.
    • The library file is in the Program Files\National Instruments\Shared\ExternalCompilerSupport\C\lib32\msvc folder.
    Using the VW Transport protocol with NI-XNET:
    • If you are using the VW Transport Protocol on NI-XNET hardware, we suggest using the Frame Stream Input and Output Mode. Example: CAN1@ni_genie_nixnet uses CAN interface 1 on NI-XNET with Frame Stream Mode.
    The following items are the IDs and titles of a subset of issues fixed between Automotive Diagnostic Command Set 18.0 and Automotive Diagnostic Command Set 15.0. This is not an exhaustive list of issues fixed in the current version of the Automotive Diagnostic Command Set. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    Bug IDFixed Issue
    514438Automotive Diagnostic Command Set 15.0 does not support any NI CompactRIO RT Controller running the NI Linux Real-Time Operating System (such as an NI cRIO-9068 or NI cRIO-903x) if you are using an NI 985x C Series module.
    556023LIN Fails to recognize a negative response wait message (ack 0x78).
    563610Timeout RspPending property produces error -8009 when used with LIN.
    590466Setting STmin property to 0xF1 to 0x F9 range does not properly space consecutive frames.
    594837String to call Bitfile on "Open Diagnostic.vi" is case sensitive for the file extension.
    616125Automotive Diagnostic Command Set 15.0 cannot be used on Linux Real-Time targets if Automotive Diagnostic Command Set 15.0 and ECU Measurement and Calibration Toolkit 15.0 being installed on the host computer.
    673998Significant delay in back-to-back frame transfer (flash application) for the ISO TP transport protocol when upgrading from ADCS 1.2 to 15.0.
    681350OBD Request Supported PIDs.vi does not return PIDs above x20 under certain conditions.
    The Automotive Diagnostic Command Set Help is the primary reference document for Automotive Diagnostic Command Set. This manual includes an introduction to diagnostic protocols. It also includes information about how to get started with application development and a complete reference for all Automotive Diagnostic Command Set functions.
    To open the Automotive Diagnostic Command Set Help, go to: Programs»National Instruments»Automotive Diagnostic Command Set»Documentation.
    If you are using NI hardware that is supported by NI-XNET, it is recommended that you use NI-XNET 18.0 with Automotive Diagnostic Command Set 18.0.
    CAN FD support with the Automotive Diagnostic Command Set
    CAN FD features are only supported with NI-XNET version 17.0.1 or later.
    NI does not recommend cRIO-901x and cRIO-902x targets for CAN FD.
    Recommended Maximum Message Length for CAN FD
    NI recommends the following maximum message length for CAN FD based on the system RAM size.
    System RAM SizeMaximum Message Length
    ≤512 MB8 MB
    512 MB – 3.5 GB64 MB
    >3.5 GB256 MB
    © 2009–2018 National Instruments. All rights reserved.
    375413C-01
    发表于 2022-6-28 14:40:39 | 显示全部楼层 来自:上海市 电信
    GMT+8, 2026-1-8 06:01
