查看: 5146|回复: 0
[LV工具模块] NI Automotive Diagnostic Command Set Toolkit 20.0 Win32/64Eng 汽车诊断命令集工具包ADCS20.0
    昨天 08:40
  • 签到天数: 3765 天
    连续签到: 16 天
    发表于 2020-11-19 23:09:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    汽车诊断命令集工具包Automotive Diagnostic Command Set Toolkit
    汽车诊断命令集工具包为ECU生产测试设计和开发汽车诊断应用程序。
    汽车诊断命令集(ADCS)工具包是LabVIEW、LabWindows/CVI和Microsoft Visual Studio的软件附件。该附件适用于一系列汽车诊断应用,通常包括读取和写入参数、访问故障诊断代码(DTC)、闪存ECU固件以及启动ECU诊断测试模式。借助ADCS工具包,您可以开发单个应用程序,并根据需要随时进行部署,而无需额外部署或runtime许可证。该附件与许多NI汽车接口设备兼容,可简化各种便携式和车载诊断应用的开发,并提供对UDS、OBD、WWH-OBD等协议的支持。LabWindows标志经Microsoft公司授权使用。Windows是Microsoft公司在美国和其他国家的注册商标。
    20.0
    文件大小: 1026041856 字节 (978.51 MB)
    修改日期: 2020-05-12 01:18
    MD5: 40e4f02d3f706b59d5e7e1b98d95077c(官方正确)
    SHA1: 346d1be9d2d2548ea5da7a06a5986435ed25f41e
    SHA256: c7eed585097da888b8c09073ba9ac476501c2545dc49479017058d088664cbab
    CRC32: c7e6084b
    ADCS20.0.txt (630 Bytes, 下载次数: 6, 售价: 10 圆)
    Automotive Diagnostic Command Set Toolkit 20.0 Readme
    April 2020
    This file contains important information about the Automotive Diagnostic Command Set software for Windows and LabVIEW Real-Time (RT), including installation instructions, new features, and known issues for Automotive Diagnostic Command Set 20.0.
    Supported Software and Hardware
    ECU Simulator
    Additional Programming Topics and Known Issues
    Using NI-XNET with the Automotive Diagnostic Command Set
    Automotive Diagnostic Command Set 20.0 supports the following operating systems:
    • Windows Server 2008 R2 SP11 (64-bit, not supported on Server Core Role)
    Note  In 2016 National Instruments dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. Automotive Diagnostic Command Set Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use Automotive Diagnostic Command Set Toolkit to an unsupported OS. Additionally, after installing this version of Automotive Diagnostic Command Set Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support, refer to KB 79UC78LS, NI Installer Fails on Windows XP/Vista and Windows Server 2003.
    Note  Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To understand how this might affect your system and what actions you might need to take, refer to NI Software Fails When Physical Address Extension is Enabled.
    This version of Automotive Diagnostic Command Set software supports the following development environments, including service packs.
    Application SoftwareVersions Supported by Automotive Diagnostic Command Set 20.0
    LabVIEW2017, 2018, 2019, 2020
    LabVIEW Real-Time Module2017, 2018, 2019, and 2020
    LabWindows™/CVI™2015 and later
    Microsoft Visual C/C++2008 and later
    Note  The Automotive Diagnostic Command Set software does not support LabWindows™/CVI™ Real-Time Module.
    The Automotive Diagnostic Command Set software supports the following software and hardware:
    • NI-CAN software version 17.0 or later
    • NI-CAN hardware supported by NI-CAN 17.0
    • NI-XNET software version 17.0 or later
    • NI-XNET CAN and LIN hardware supported by NI-XNET 17.0 or later
    • NI-XNET Automotive Ethernet hardware supported by NI-XNET 19.0 or later
    • CompactRIO and R-Series hardware using NI 9852/9853 two-port CAN modules for NI CompactRIO (we recommend using NI 986x on NI CompactRIO instead of NI 985x)
    Note  The Automotive Diagnostic Command Set software supports only National Instruments Automotive Ethernet, CAN, and LIN hardware products. For information about software for Automotive Ethernet, CAN, and LIN hardware products from other vendors, refer to the documentation you received with those products.
    Before installing the Automotive Diagnostic Command Set software, log on as Administrator or as a user with Administrator privileges. The Automotive Diagnostic Command Set software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the Automotive Diagnostic Command Set software.
    • If applicable, install an application development environment (ADE), such as LabVIEW, LabWindows/CVI, or Microsoft Visual Studio.
    • Use NI Package Manager to install the Automotive Diagnostic Command Set Toolkit and Runtime, or download and install the software from NI Software Product Downloads.
    Note  To download NI Package Manager, visit ni.com/info and enter the Info Code NIPMDownload. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    ECU Simulator
    The Automotive Diagnostic Command Set Toolkit software provides an ECU simulation for CAN, Ethernet, and LIN. All examples of the Automotive Diagnostic Command Set are preconfigured to communicate with the ECU simulator.
    LabVIEW users can find the ECU simulator under \\examples\Automotive Diagnostic Command Set\ADCS Demo ECUs.llb.
    Microsoft Visual C/C++ and LabWindows/CVI users can find the ECU simulators in the following paths:
    • \Users\Public\Documents\National Instruments\Automotive Diagnostic Command Set\Examples\MS Visual C\ADCS Demo ECU CAN Ethernet
    • \Users\Public\Documents\National Instruments\Automotive Diagnostic Command Set\Examples\MS Visual C\ADCS Demo ECU LIN
    New Features and Changes as Compared to Automotive Diagnostic Command Set 19.0
    The Automotive Diagnostic Command Set 20.0 release adds the following features:
    • Added support for LabVIEW 2020.
    • Added support for the PXIe-8522 4-Port, 1000BASE-T1 PXI Automotive Ethernet Interface Module.
    • Added support for the PXIe-8523 4-Port, 100/1000BASE-T1 PXI Automotive Ethernet Interface Module.
    • Removed support for LabVIEW 2016.
    • Removed support for NI-CAN 16.0.
    • Removed support for NI-XNET 16.0.
    • Removed support for NI cRIO-901x.
    • Removed support for NI cRIO-902x.
    • Removed support for NI cRIO-907x.
    • Removed support for NI cRIO-908x.
    • Removed support for NI cRIO-913x.
    New Features and Changes as Compared to Automotive Diagnostic Command Set 18.5
    The Automotive Diagnostic Command Set 19.0 release adds the following features:
    • Added support for LabVIEW 2019.
    • Added support for LabVIEW Linux PXI RT.
    • Added support for LabWindows™/CVI™ 2019.
    • Added 0xFF flag for DoIP broadcast messages.
    • Added support for session-based properties.
    • Added support for the PXIe-8521 4-port, 100BASE-T1 PXI Automotive Ethernet Interface Module.
    • Added support for installation through NI Package Manager.
    • Removed support for LabVIEW 2015.
    • Removed support for LabWindows™/CVI™ 2012 and 2013 (without SP1).
    • Removed support for NI-CAN 15.0.
    • Removed support for NI-XNET 15.0.
    New Features and Changes as Compared to Automotive Diagnostic Command Set 18.0
    The Automotive Diagnostic Command Set 18.5 release adds the following features:
    • Added support for LabVIEW 2018 SP1.
    • Added support for Diagnostic over IP 2012 Protocol Version.
    • Added support for Tester Present Auto Timing.
    • Added support for ECU Determined CAN I/O Mode. CAN I/O mode can be set to ECU Determined to use ECUs with CAN 2.0 or CAN FD.
    • Added Response Plausibility Check property. Defines whether the first byte of the diagnostic response is checked to contain the + 0x40 offset (positive response) or whether the first byte is 0x7F (negative response).
    New Features and Changes as Compared to Automotive Diagnostic Command Set 15.0
    The Automotive Diagnostic Command Set 18.0 release adds the following features:
    • Added support for LabVIEW 2016, LabVIEW 2017, and LabVIEW 2018.
    • Added support for ISO CAN FD.
    • Added support for Diagnostic over IP over non-primary NICs.
    • Added support for LIN sleep for UDS.
    • Removed support for LabVIEW 2012, LabVIEW 2013, and LabVIEW 2014.
    • Removed support for LabWindows™/CVI™ 2010 and earlier versions.
    New Features and Changes as Compared to Automotive Diagnostic Command Set 14.0
    The Automotive Diagnostic Command Set 15.0 release adds the following features:
    • Removed support for LabVIEW 2011.
    • Added support for 64-bit LabVIEW and C/C++.
    • Added support for CompactRIO Real-Time Controllers supported by NI-XNET 15.0 (NI cRIO-9081, NI cRIO-9082, NI cRIO-903x).
    New Features and Changes as Compared to Automotive Diagnostic Command Set 1.2
    The Automotive Diagnostic Command Set 14.0 release adds the following features:
    • Added support for LabVIEW 2014.
    • Removed support for LabVIEW 2010.
    • Added support for WWH-OBD (World-Wide-Harmonized On-Board Diagnostics) based on ISO 27145.
    • Added Get Time Stamp function to measure timestamp information of the first/last sent/received frame of the ISO TP for CAN and LIN.
    • Added support for NI cRIO-9068 Controller (based on NI Linux Real-Time OS).
    The Automotive Diagnostic Command Set software installs the necessary C/C++ support files in the following locations:
    • The path to the C examples folder is \Users\Public\Documents\National Instruments\Automotive Diagnostic Command Set\Examples\MS Visual C.
    • The header file for Visual C/C++ 2008 and 2015 is in the Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\include folder.
    • The library file for 32-bit applications is in the Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\lib32\msvc folder.
    • The library file for 64-bit applications is in the Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\lib64\msvc folder.
    Using the VW Transport protocol with NI-XNET:
    • If you are using the VW Transport Protocol on NI-XNET hardware, we suggest using the Frame Stream Input and Output Mode. Example: CAN1@ni_genie_nixnet uses CAN interface 1 on NI-XNET with Frame Stream Mode.
    Automotive Diagnostic Command Set 20.0 has fixed parameter lists and calling conventions of a subset of functions introduced with Automotive Diagnostic Command Set 19.0. Requires recompiling all C/C++/CVI applications built with Automotive Diagnostic Command Set 19.0 and using one of the following functions:
    • ndDoIPSendVehicleIdentReqEIDAllVersions
    • ndDoIPSendVehicleIdentRequestAllVersions
    • ndDoIPSendVehicleIdentReqVINAllVersions
    • ndDoIPGetEntitiesAllVersions
    • ndDoIPConnectVersion
    The following items are the IDs and titles of a subset of issues fixed in the Automotive Diagnostic Command Set. This is not an exhaustive list of issues fixed in the current version of the Automotive Diagnostic Command Set. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    Bug IDSummary
    528621Description is missing for Error Code -8305
    945583DoIP Activate Routing function modifies the DoIP Target Address when using a DoIP gateway
    986887Memory leak occurs when an ADCS service function is called in C API; running multiple concurrent diagnostic sessions is unreliable
    Refer to the Automotive Diagnostic Command Set Toolkit Help, accessible from Start»National Instruments»ADCS Documentation, for more information about Automotive Diagnostic Command Set Toolkit.
    The Automotive Diagnostic Command Set Help is the primary reference document for Automotive Diagnostic Command Set. This manual includes an introduction to diagnostic protocols. It also includes information about how to get started with application development and a complete reference for all Automotive Diagnostic Command Set functions.
    If you are using NI hardware that is supported by NI-XNET, it is recommended that you use the latest supported version of NI-XNET with Automotive Diagnostic Command Set.
    CAN FD support with the Automotive Diagnostic Command Set
    CAN FD features are only supported with NI-XNET version 17.0.1 or later.
    Recommended Maximum Message Length for CAN FD
    NI recommends the following maximum message length for CAN FD based on the system RAM size.
    System RAM SizeMaximum Message Length
    ≤512 MB8 MB
    512 MB – 3.5 GB64 MB
    >3.5 GB256 MB
    © 2009–2020 National Instruments. All rights reserved.
    375413F-01
    GMT+8, 2026-1-8 06:00
