查看: 3375|回复: 0
[RTE运行引擎] NI ECU Measurement and Calibration Toolkit 18.0 Runitme Win32/64Eng NI电子控制单元测量和校准工具包ECUMC18.0运行版下载
    10 小时前
    发表于 2020-11-22 23:03:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    ECU测量和校准工具包
    ECU测量和校准(ECUMC)工具包用于为电子控制单元(ECU)设计和验证提供测量和校准。
    ECU测量和校准工具包是LabVIEW、LabWindows/CVI和Microsoft C/C ++编程环境的软件附件。该软件支持通用测量和校准协议(Universal Measurement and Calibration Protocol,XCP)及CAN校准协议(CAN Calibration Protocol,CCP),提供了许多高级且易用的函数。这些协议可让用户可根据ASAM (.A2L)数据库文件的定义,读写内部ECU变量及特性。通过(.A2L)数据库文件,工具包自动应用所有换算信息并以工程单位返回数据,便于简单地分析、演示及记录。此外,该工具包还提供了常见应用的示例,例如使用一维到三维用户界面来测量ECU变量或控制ECU特性。LabWindows标志经Microsoft公司授权使用。Windows是Microsoft公司在美国和其他国家的注册商标。
    18.0RT(直接从15.0升级为18.0版本,中间没有16/17版)
    文件大小: 65049474 字节 (62.04 MB)
    修改日期: 2019-06-25 02:42
    MD5: 5b21bdd86e6bd6a2d85f50ac327f32ed(官方正确)
    SHA1: 3c89fcf4974b41ba1183c5eedcda95f8640bbdbf
    SHA256: 4a1b750bd858ae0ac975d0077f9736b51f733eeaca7df1ac51015a79e72a07fc
    CRC32: 678f7351
    ECUMC18.0RT.txt (629 Bytes, 下载次数: 3, 售价: 5 圆)
    ECU Measurement and Calibration Toolkit 18.0 Readme
    June 2018
    This file contains information about the ECU Measurement and Calibration Toolkit software.
    Supported Software and Hardware
    ECU Simulator
    Using LabVIEW Real-Time (RT)
    Additional Programming Topics and Known Issues
    Additional Topics and Known Issues for use of XCP/CCP Custom Device for NI VeriStand
    Using NI-XNET with the ECU Measurement and Calibration Toolkit
    The ECU Measurement and Calibration Toolkit provides full-featured APIs, plus tools for configuration and analysis within NI MAX. The ECU Measurement and Calibration APIs enable you to develop applications that are customized to your test and simulation requirements.
    The ECU Measurement and Calibration Toolkit software supports Windows 10/8.11/7 SP12.
    Note  In 2016 National Instruments dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. ECU Measurement and Calibration Toolkit 18.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use ECU Measurement and Calibration Toolkit 18.0 to an unsupported OS. Additionally, after installing ECU Measurement and Calibration Toolkit 18.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support, refer to KB 79UC78LS, Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?.
    This version of the ECU Measurement and Calibration Toolkit supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by ECU Measurement and Calibration Toolkit 18.0
    LabVIEW2015, 2016, 2017, 2018
    LabVIEW Real-Time (RT)2015, 2016, 2017, 2018
    LabWindows™/CVI™2012 and later
    NI VeriStand2015, 2016, 2017
    Microsoft Visual C/C++2008 and later
    Note  The ECU Measurement and Calibration Toolkit software does not support LabWindows™/CVI™ Real-Time Module.
    This version of the ECU Measurement and Calibration Toolkit software supports the following software and hardware:
    • NI-CAN software version 15.0 or newer
    • NI-CAN hardware supported by NI-CAN 15.0
    • NI-XNET software version 15.0 or newer
    • NI-XNET CAN hardware supported by NI-XNET 15.0 or newer
    • CompactRIO and R-Series hardware using NI 9852/9853 two-port CAN modules for NI CompactRIO (we recommend using NI 986x on NI CompactRIO instead of NI 985x)
    Note  The ECU Measurement and Calibration Toolkit software supports only National Instruments CAN hardware products.
    For information about software for CAN products from other vendors, refer to the documentation you received with those products.
    Before installing the ECU Measurement and Calibration Toolkit software, log on as Administrator or as a user with Administrator privileges. The ECU Measurement and Calibration Toolkit software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the ECU M&C Toolkit software:
    • Insert the ECU Measurement and Calibration Toolkit software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your ECU Measurement and Calibration Toolkit software CD.
    • The installation wizard guides you through the necessary steps to install the ECU Measurement and Calibration Toolkit software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
    ECU Simulator
    The ECU Measurement and Calibration Toolkit software simulates two types of ECUs. All ECU Measurement and Calibration Toolkit examples are preconfigured to communicate with the CCP Test ECU simulation using the ASAM 2MC CCPECU.A2L file.
    Most of the examples can be used with the XCP Test ECU simulation. In that case, please, use the XCPECU.A2L file and the related protocol tokens "XCP:CAN", "XCP:UDP", or "XCP:TCP".
    LabVIEW users using CCP can find the ECU simulator, seed-key DLL, and corresponding A2L file at \\Examples\ECUMC.
    LabVIEW users using XCP can find the ECU simulator, seed-key DLL, and corresponding A2L file at \\Examples\ECUMC.
    MS VC users using CCP can find the ECU simulator, seed-key DLL, and corresponding A2L file at \Users\Public\Documents\National Instruments\ECU Measurement and Calibration Toolkit\Examples\MS Visual C\CCPECU.
    MS VC users using XCP can find the ECU simulator, seed-key DLL, and corresponding A2L file at \Users\Public\Documents\National Instruments\ECU Measurement and Calibration Toolkit\Examples\MS Visual C\XCPECU.
    To use the ECU Measurement and Calibration Toolkit on a LabVIEW RT system, you must download your ASAM 2MC database (*.A2L) file to the RT target. The LabVIEW Real-Time Engine running on a PXI or CompactRIO system supports a File Transfer Protocol (FTP) server. You can access the LabVIEW RT target FTP server using any standard FTP utility for transferring files to and from the hard drive. For further information about how to download your A2L file to the RT target, refer to LabVIEW Real-Time (RT) Configuration in the ECU Measurement and Calibration Toolkit Help.
    New Features Compared to ECU Measurement and Calibration Toolkit 15.0
    The ECU Measurement and Calibration Toolkit 18.0 release adds the following features:
    • Added support for LabVIEW 2016, LabVIEW 2017, and LabVIEW 2018.
    • Added support for NI VeriStand 2016 and 2017.
    • Added support for ISO CAN FD.
    • Added support for Measurement Split Allowed.
    • Removed support for LabVIEW 2012, LabVIEW 2013, and LabVIEW 2014.
    • Removed support for NI VeriStand 2012, VeriStand 2013, and VeriStand 2014.
    • Removed support for LabWindows™/CVI™ 2010 and earlier versions.
    New Features Compared to ECU Measurement and Calibration Toolkit 14.0
    The ECU Measurement and Calibration Toolkit 15.0 release adds the following features:
    • Added support for NI VeriStand 2014 and 2015.
    • Removed support for LabVIEW 2011.
    • Added support for CompactRIO Real-Time Controllers supported by NI-XNET 15.0 (NI cRIO-9081, NI cRIO-9082, NI cRIO-903x).
    • Added support for cDAQ Controllers supported by NI-XNET 14.5 (NI cDAQ-9135).
    • Added XCP STIM Mode into NI VeriStand Custom Device 2013, 2014 and 2015 at asynchronous level.
    • Added Waveform Mode support for XCP ECUs not sending XCP Timestamps to ECU Measurement and Calibration Toolkit.
    • Added Synchronous start of multiple DAQ or STIM tasks to the ECU Measurement and Calibration Toolkit API; this feature is also available within the CCP/XCP VeriStand Custom Device 2013, 2014 and 2015.
    New Features Compared to ECU Measurement and Calibration Toolkit 2.3.1
    The ECU Measurement and Calibration Toolkit 14.0 release adds the following features:
    • Added support for NI VeriStand 2013.
    • Added support for LabVIEW 2014.
    • Removed support for LabVIEW 2010.
    • Added 64-bit user mode support for LabVIEW 2011-2014 64-bit versions.
    • Enhanced selection possibilities of Calibration Pages.
    • Added selection of Calibration Pages for NI VeriStand 2013 Custom Device.
    • Added Remote Seedkey configuration by ECU Measurement and Calibration API and NI VeriStand 2013 Custom Device.
    • Added support for NI cRIO-9068 Controller (based on NI Linux Real-Time OS).
    ECU Measurement and Calibration Toolkit 18.0 supports CCP Version 2.1.
    ECU Measurement and Calibration Toolkit 18.0 does support symbolic conversion tables for reading only. Refer to mcDoubleToText for further information.
    NI-I/O Trace monitors function calls to the ECU Measurement and Calibration Toolkit API. This tool helps in debugging programming problems in the application. To launch this tool, open Tools in MAX, and select NI-I/O Trace. If more than one National Instruments driver is installed on your computer, you can specify which APIs to trace at any time. By default, all installed APIs are enabled. To select the APIs to trace, select Tools»Options, select the View Selections tab, and select the APIs under Installed API Choices.
    The following LabVIEW example VIs do not run under LabVIEW Real-Time and LabVIEW Base Development System:
    • Edit a characteristic.vi
    • Measurement and Calibration Application.vi
    To make these examples run, remove the subVI call from 3DDisplayWrapper.vi in MCCharacteristicsEditors.llb.
    If you are using an NI USB-8473 or NI USB-8473s, the ECU Measurement and Calibration Toolkit is based internally on the NI-CAN Frame API. For this reason, the following properties are not available for the GetProperty function:
    • CRO Task (mcPropCRODAQ_DTO_Task)
    • DTO Task (mcPropDAQ_DTO_Task)
    • SamplesPending (mcPropDAQ_SamplesPending)
    The LabVIEW project examples for CompactRIO and R-Series are configured for use with NI 985x C-Series only.
    The ECU Measurement and Calibration ECU Simulator (DemoECU) is not supported under CompactRIO.
    The Basic Examples and some advanced examples are not supported under cRIO using XCP/TCP and XCP/UDP. To use those examples, you need to modify the communication parameters like the IP Address.
    The behavior of mcDAQListInitialize has changed. It will now return an error (NoMoreDAQLists) if the requested DAQ list cannot be assigned. Before, ECU MC would try to assign a different DAQ list automatically, but this was considered inadequate as the new DAQ list might have different properties than the requested one and thus cause undesired behavior.
    Additional Topics and Known Issues for XCP/CCP Custom Device for NI VeriStand
    ECU Measurement and Calibration Toolkit 18.0 supports NI VeriStand 2015, 2016 and 2017.
    Refer to the XCP/CCP Custom Device online help for information about using the NI XCP/CCP Custom device with VeriStand.
    Upgrade Note: If you are upgrading your XCP/CCP Custom Device from the already-installed National Instruments Developer Zone download, you need to clear the XCP/CCP controls from the NI VeriStand project temporary screen files directory. VeriStand projects created with an older VeriStand version must be converted to the new version by loading the project in System Explorer and saving it. When loading an older project into a newer VeriStand revision, a message shows up informing about missing Driver VI files. This message can be ignored and skipped.
    Upgrading Existing VeriStand System Definitions from a Previous Custom Device Version: You must migrate system definitions created with an earlier version of the XCP/CCP custom device to the current version before you can use them. Therefore, open and save the system definition file in the System Explorer.
    The CCP/XCP on CAN communication introduces higher busloads on the CAN network: If you are using CCP or XCP on CAN, the NI VeriStand Custom Device can add flexible configurations for reading and writing Characteristics and Measurements from the ECU. It is allowed running multiple Characteristic as well as Measurement read or write tasks in parallel. If you set up such a complex system, every task introduces some amount of busload onto the CAN network, because those CCP/XCP commands are based on a handshake protocol. If you run the CCP/XCP on CAN a protocol to its limits, the introduced busload on the CAN network increases significantly, and the ECU may not respond in the predefined time anymore. The reason is that there may not be enough free network bandwidth. In such cases, we recommended analyzing the CAN busload on the CAN network and trying to keep CAN traffic below values of 60% to 70%, to keep the network in an operable state. A typical indicator of running into such CCP/XCP on CAN protocol limits is a timeout error when executing a Characteristic/Measurement read or write operation. Therefore, we recommend checking the XCP/CCP Custom Device error status variable, whether the error 0xFFFB67FE "A timeout occurred waiting for a response from the ECU" occurs.
    The following items are a subset of issues fixed in ECU Measurement and Calibration Toolkit. If you have a CAR ID, you can search to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the ECU Measurement and Calibration Toolkit.
    Issues fixed between ECU Measurement and Calibration Toolkit 15.0 and ECU Measurement and Calibration Toolkit 18.0.
    Bug IDFixed Issue
    533852XCP and CCP Trace will show incorrect byte length of message.
    580435"MC DAQ Read.vi" returns stale data warning 301005 even when fresh data has been received.
    580437"MC DAQ Read.vi" reports error when NumberOfSamplesToRead = 0, preventing "MC DAQ Start Stop.vi" from being called implicitly
    641455"MC Read NChan NSamp Time Dbl.vi" does not read configured number of channels - XCP on Ethernet.
    643072NChan NSamp Time-Value XY Array missing occasional frames.
    657509Custom device, default value for Connect not behaving as documented
    659618Custom device shows incorrect connection status when "Enable Measurement" channel is set to false.
    The ECU Measurement and Calibration Toolkit Help is the primary reference document for this product. The help includes an introduction to the CAN Calibration Protocol (CCP) and Measurement and Calibration Protocol (XCP). It also explains how to get started with application development and includes a complete reference for all ECU Measurement and Calibration Toolkit functions.
    To open the ECU Measurement and Calibration Toolkit Help, go to: Program Files (x86)»National Instruments»ECU Measurement and Calibration Toolkit»Documentation.
    If you are using NI hardware that is supported by NI-XNET, it is recommended that you use NI-XNET 18.0 with ECU Measurement and Calibration Toolkit 18.0.
    CAN FD support with the ECU Measurement and Calibration Toolkit
    CAN FD features are only supported with NI-XNET version 17.0.1 or later.
    NI does not recommend cRIO-901x and cRIO-902x targets for CAN FD.
    Custom baud rate for CAN in NI VeriStand is only supported with NI-XNET version 18.0 or later.
    © 2009–2018 National Instruments. All rights reserved.
    377542A-01
    GMT+8, 2025-12-8 19:19
