查看: 3592|回复: 0
[LV工具模块] NI ECU Measurement and Calibration Toolkit 20.0 Win32/64Eng NI电子控制单元测量和校准工具包ECUMC20.0下载
    昨天 08:10
  • 签到天数: 3731 天
    发表于 2020-11-22 23:14:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    ECU测量和校准工具包
    ECU测量和校准(ECUMC)工具包用于为电子控制单元(ECU)设计和验证提供测量和校准。
    ECU测量和校准工具包是LabVIEW、LabWindows/CVI和Microsoft C/C ++编程环境的软件附件。该软件支持通用测量和校准协议(Universal Measurement and Calibration Protocol,XCP)及CAN校准协议(CAN Calibration Protocol,CCP),提供了许多高级且易用的函数。这些协议可让用户可根据ASAM (.A2L)数据库文件的定义,读写内部ECU变量及特性。通过(.A2L)数据库文件,工具包自动应用所有换算信息并以工程单位返回数据,便于简单地分析、演示及记录。此外,该工具包还提供了常见应用的示例,例如使用一维到三维用户界面来测量ECU变量或控制ECU特性。LabWindows标志经Microsoft公司授权使用。Windows是Microsoft公司在美国和其他国家的注册商标。
    20.0
    文件名: ECU Measurement and Calibration Toolkit\ni-ecumc_20.0.0_offline.iso
    文件大小: 1082214400 字节 (1.01 GB)
    修改日期: 2020-05-12 01:19
    MD5: ae4b1ffe96232c428d6e32bae382d322(官方正确)
    SHA1: 4160eac180b9be809251eccc36774049b4186a53
    SHA256: c319e24a7f84f492432339e20d2baef16dd03ab7898627917194a32743662683
    CRC32: fb019966
    ECUMC20.0.txt (639 Bytes, 下载次数: 4, 售价: 5 圆)
    ECU Measurement and Calibration Toolkit 20.0 Readme
    April 2020
    This file contains information about the ECU Measurement and Calibration Toolkit software.
    Supported Software and Hardware
    ECU Simulator
    Using LabVIEW Real-Time (RT)
    Additional Programming Topics and Known Issues
    Additional Topics and Known Issues for use of XCP/CCP Custom Device for NI VeriStand
    ECUMC Toolkit Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Using NI-XNET with the ECU Measurement and Calibration Toolkit
    The ECU Measurement and Calibration Toolkit provides full-featured APIs, plus tools for configuration and analysis. The ECU Measurement and Calibration APIs enable you to develop applications that are customized to your test and simulation requirements.
    ECU Measurement and Calibration Toolkit 20.0 supports the following operating systems:
    • Windows Server 2008 R2 SP11 (64-bit, not supported on Server Core Role)
    Note  In 2016 National Instruments dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. ECU Measurement and Calibration Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use ECU Measurement and Calibration Toolkit to an unsupported OS. Additionally, after installing this version of ECU Measurement and Calibration Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support, refer to KB 79UC78LS, NI Installer Fails on Windows XP/Vista and Windows Server 2003.
    Note  Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To understand how this might affect your system and what actions you might need to take, refer to NI Software Fails When Physical Address Extension is Enabled.
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, please visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, please visit ni.com/r/b7g5wi.
    This version of the ECU Measurement and Calibration Toolkit supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by ECU Measurement and Calibration Toolkit 20.0
    LabVIEW2017, 2018, 2019, and 2020
    LabVIEW Real-Time Module2017, 2018, 2019, and 2020
    LabWindows™/CVI™2015 and later
    NI VeriStand2017, 2018, 2019, and 2020
    Microsoft Visual C/C++2008 and later
    Note  The ECU Measurement and Calibration Toolkit software does not support LabWindows™/CVI™ Real-Time Module.
    This version of the ECU Measurement and Calibration Toolkit software supports the following software and hardware:
    • NI-CAN software version 17.0 or later
    • NI-CAN hardware supported by NI-CAN 17.0
    • NI-XNET software version 17.0 or later
    • NI-XNET CAN hardware supported by NI-XNET 17.0 and later
    • NI-XNET Automotive Ethernet hardware supported by NI-XNET 19.0 and later
    • CompactRIO and R-Series hardware using NI 9852/9853 two-port CAN modules for NI CompactRIO (we recommend using NI 986x on NI CompactRIO instead of NI 985x)
    Note  The ECU Measurement and Calibration Toolkit software supports only National Instruments Automotive Ethernet and CAN hardware products. For information about software for Automotive Ethernet and CAN hardware products from other vendors, refer to the documentation you received with those products.
    Before installing the ECU Measurement and Calibration Toolkit software, log on as Administrator or as a user with Administrator privileges. The ECU Measurement and Calibration Toolkit software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the ECU Measurement and Calibration Toolkit software.
    • If applicable, install an application development environment (ADE), such as LabVIEW, LabWindows/CVI, or Microsoft Visual Studio.
    • Use NI Package Manager to install the ECU Measurement and Calibration Toolkit and Runtime, or download and install the software from NI Software Product Downloads.
    Note  To download NI Package Manager, visit ni.com/info and enter the Info Code NIPMDownload. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    MSVC and LabWindows/CVI users should always install the MSVC Support feature. This feature installs the CCP and XCP Demo ECUs, which may be helpful if you are running ECU MC MSVC and LabWindows/CVI examples.
    ECU Simulator
    The ECU Measurement and Calibration Toolkit software simulates ECU communication using two calibration protocols: XCP and CCP.
    All of the ECU Measurement and Calibration Toolkit examples are preconfigured to communicate with the NI ECUMC Demo ECU XCP simulation using an ASAM 2MC file, XcpECU.a2l. Many of the examples can be used with the NI ECUMC Demo ECU CCP simulation. To use an example with the ECU CCP simulation, use the CCPECU.A2L file and the related protocol token, CCP:CANx.
    LabVIEW users can find the ECU simulators, seed-key DLLs, and corresponding A2L files in the following path: \\examples\ECUMC\
    Note that the XCPECU.llb library file contains the ECUMC Demo ECU XCP VI; the CCPECU.llb library file contains the ECUMC Demo ECU CCP VI.
    Microsoft Visual C/C++ and LabWindows/CVI users can find the ECUMC Demo ECU simulators (only 32-bit), seed-key DLLs, and corresponding A2L files in the following paths:
    • \ECU Measurement and Calibration Toolkit\ECUMC Demo ECU XCP
    • \ECU Measurement and Calibration Toolkit\ECUMC Demo ECU CCP
    LabWindows/CVI users may refer to copies of the A2L files and seed-key DLLs provided within the CVI examples folder.
    To use the ECU Measurement and Calibration Toolkit on a LabVIEW RT system, you must download your ASAM 2MC database (*.A2L) file to the RT target. The LabVIEW Real-Time Engine running on a PXI or CompactRIO system supports a File Transfer Protocol (FTP) server. You can access the LabVIEW RT target FTP server using any standard FTP utility for transferring files to and from the hard drive. For further information about how to download your A2L file to the RT target, refer to LabVIEW Real-Time (RT) Configuration in the ECU Measurement and Calibration Toolkit Help.
    New Features Compared to ECU Measurement and Calibration Toolkit 19.5
    The ECU Measurement and Calibration Toolkit 20.0 release adds the following features:
    • Added support for LabVIEW 2020.
    • Added support for VeriStand 2020.
    • Removed support for LabVIEW 2016.
    • Removed support for NI-CAN 16.0.
    • Removed support for NI-XNET 16.0.
    • Removed support for NI cRIO-901x.
    • Removed support for NI cRIO-902x.
    • Removed support for NI cRIO-907x.
    • Removed support for NI cRIO-908x.
    • Removed support for NI cRIO-913x.
    New Features Compared to ECU Measurement and Calibration Toolkit 19.0
    The ECU Measurement and Calibration Toolkit 19.5 release adds the following features:
    • Added support for LabVIEW 2019 SP1.
    • Added support for VeriStand 2019.
    • Added support for PXIe-8522 4-port, 1000BASE-T1 Automotive Ethernet Interface.
    • Added support for PXIe-8523 4-port, 100/1000BASE-T1 Automotive Ethernet Interface.
    New Features Compared to ECU Measurement and Calibration Toolkit 18.5
    The ECU Measurement and Calibration Toolkit 19.0 release adds the following features:
    • Added support for LabVIEW 2019.
    • Added support for LabVIEW Linux PXI RT.
    • Added support for LabWindows™/CVI™ 2019.
    • Added the ability to select non-primary NICs.
    • Added support for XCPplus protocol.
    • Added support for the PXIe-8521 4-port, 100BASE-T1 PXI Automotive Ethernet Interface Module.
    • Added support for installation through NI Package Manager.
    • Removed support for LabVIEW 2015.
    • Removed support for LabWindows™/CVI™ 2012 and 2013 (without SP1).
    • Removed support for VeriStand 2015.
    • Removed support for NI-CAN 15.0.
    • Removed support for NI-XNET 15.0.
    New Features Compared to ECU Measurement and Calibration Toolkit 18.0
    The ECU Measurement and Calibration Toolkit 18.5 release adds the following features:
    • Added support for LabVIEW 2018 SP1.
    • Added support for NI VeriStand 2018 and 2018 SP1.
    • Added support for ECU Determined CAN I/O Mode​. The CAN I/O Mode can be set to "ECU Determined" to use XCP ECUs with CAN 2.0 or CAN FD.
    • Added support for Selectable Timing Source for XCP​. This allows synchronization of time with either the ECU, CAN (DAQ), or host.
    • Added support for 64-bit integer. The 64-bit integer characteristic and measurement can be handled without precision loss.
    • Added support for String characteristics. Improves the handling of ASCII characteristics.
    • Added IP Source Port property. The new property XCP IP Source Port enables defining the source port (XCP master port) when Ethernet protocol is used. API only, not supported in NI VeriStand.
    ECU Measurement and Calibration Toolkit supports CCP Version 2.1.
    ECU Measurement and Calibration Toolkit does support symbolic conversion tables for reading only. Refer to documentation for mcDoubleToText for further information.
    NI I/O Trace monitors function calls to the ECU Measurement and Calibration Toolkit API. This tool helps in debugging programming problems in the application. To launch this tool, from within MAX click Tools and select NI I/O Trace. If more than one National Instruments driver is installed on your computer, you can specify which APIs to trace at any time. By default, all installed APIs are enabled. To specify APIs to trace, select Tools»Options, click the View Selections tab, and select the APIs under Installed API Choices.
    The following LabVIEW examples do not run in LabVIEW Real-Time and LabVIEW Base Development System environments:
    • Edit a characteristic.vi
    • Measurement and Calibration Application.vi
    To enable these examples to run, remove the subVI call to 3DDisplayWrapper.vi in MCCharacteristicsEditors.llb. This bypasses the 3D display capability, making the editor fully functional.
    If you are using a USB-8473 or USB-8473S device, the ECU Measurement and Calibration Toolkit is based internally on the NI-CAN Frame API. For this reason, the following properties are not available for the GetProperty function:
    • CRO Task (mcPropCRODAQ_DTO_Task)
    • DTO Task (mcPropDAQ_DTO_Task)
    • SamplesPending (mcPropDAQ_SamplesPending)
    The LabVIEW project examples for CompactRIO and R-Series are configured for use with NI 985x C-Series devices only.
    The ECU Measurement and Calibration ECU Simulators (ECU MC Demo ECU XCP or CCP) are not supported under CompactRIO.
    The examples in the ECUMC_Basic library, and some examples in ECUMC_Advanced are not supported under cRIO using XCP/TCP and XCP/UDP. To use these examples, you need to modify communication parameters, such as the IP Address.
    The behavior of mcDAQListInitialize has changed. It now returns an error (NoMoreDAQLists) if the requested DAQ list cannot be assigned. Prior to this change, ECUMC attempted to automatically assign a different DAQ list, but the new DAQ list might have different properties than the requested one and thus cause undesired behavior.
    The DAQ:XCP:Meas Split Allowed property was moved to ECU:XCP:Meas Split Allowed in the Set Property and Get Property VIs. Existing VIs that use this property will continue to work without any changes.
    XCP supports only DAQ that has a CAN identifier of DTO_ID.
    The following ASAM MCD-2MC (A2L) database features are not supported:
    • Formulas in ASAM MCD-2MC version 1.6 or later. Often used formulas such as linear scaling are not affected.
    • MATRIX_DIM keyword defining multi-dimensional measurements.
    • MATRIX_DIM keyword defining characteristics with more than 2 dimensions.
    • MATRIX_DIM keyword in ASAM MCD-2MC version 1.7 or later.
    Additional Topics and Known Issues for XCP/CCP Custom Device for NI VeriStand
    Refer to the XCP or CCP Master NI VeriStand Custom Device Help for information about using the NI XCP/CCP custom device with VeriStand.
    Upgrade Note: To use a VeriStand project created with a previous version of VeriStand, you must migrate the project to your current version. To migrate, use System Explorer to open the project file, and the save the file from the current version of VeriStand. When you load an older project into a newer version of VeriStand, the program displays a message about missing Driver VI files. You can safely ignore this message.
    Upgrading Existing VeriStand System Definitions from a Previous Custom Device Version: To use an XCP/CCP custom device in a System Definition from a previous version of VeriStand, you must migrate the System Definition file to your current version. Note that you must clear the XCP/CCP controls from the NI VeriStand project temporary screen files (.nivsscr or .nivsscreen) directory. To migrate, use System Explorer to open the System Definition file (.nivssdf), and then save the file from the current version of VeriStand.
    CCP/XCP on CAN communication introduces higher busloads on the CAN network: The CAN Calibration Protocol (CCP) is used for communication with CAN interfaces such as ECUs. Like CCP, the Universal Measurement and Calibration Protocol (XCP) is a networking protocol used for connecting calibration systems to ECUs. While CCP is restricted to the CAN bus, XCP supports several transport layers, including CAN (XCP on CAN) and Ethernet (XCP on Ethernet). Using NI VeriStand, you can create or use existing custom devices, which enable you to simulate ECU validation and testing. In particular, VeriStand custom devices add flexible configurations for exchanging Characteristics and Measurements data with an ECU; and multiple Characteristics and Measurements read or write tasks can be run in parallel.
    If you are using CCP or XCP on CAN, there are certain factors that potentially can have adverse effects on network speed and bandwidth. CCP/XCP commands are based on a handshake protocol, which involves two-way communication (read/write). On complex systems, each task (e.g., get measurements, read and write characteristics) increases the bus load on the network. Running the CCP/XCP on CAN protocol at its maximum capacity also increases the bus load on the CAN network significantly, and ECU response time can become too slow. It is recommended that you analyze the traffic load on the CAN network and try to keep CAN traffic below 60% to 70% to maintain an operable state on the network.
    A typical indication that CCP/XCP on CAN protocol has reached a maximum limit is a timeout error occurring when a Characteristic/Measurement read or write operation is executed. To determine whether a timeout error has occurred, check whether the custom device has reported one of the following error codes:
    • 0xFFFB67FE (-301058) "A timeout occurred waiting for a response from the ECU."
    • 0xFFFB67D8 (-301096) "CCP/XCP error: A timeout occurred while waiting for a response from a slave device."
    The following items are a subset of issues fixed in ECU Measurement and Calibration Toolkit. If you have a Bug ID, you can search to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the ECU Measurement and Calibration Toolkit.
    Bug IDSummary
    896103ECUMC does not return an error when the response to GET_DAQ_LIST_INFO command is less than the required 6 bytes
    898117GetProperty(Event Channels) function returns a random value if the name input is an empty string
    902352Internal calculation of timestamp may be inaccurate for specific ECU timestamp settings
    903056XCP and CCP call the GET_DAQ_LIST_INFO command unnecessarily
    903211DAQ List Initialize function does not verify that measurements are provided
    Refer to the ECU Measurement and Calibration Toolkit Help, accessible from Start»National Instruments»ECUMC Documentation, for more information about ECU Measurement and Calibration Toolkit.
    The ECU Measurement and Calibration Toolkit Help is the primary reference document for this product. The help includes an introduction to the CAN Calibration Protocol (CCP) and Measurement and Calibration Protocol (XCP). It also explains how to get started with application development and includes a complete reference for all ECU Measurement and Calibration Toolkit functions.
    ECU Measurement and Calibration Toolkit will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    If you are using NI hardware that is supported by NI-XNET, it is recommended that you use NI-XNET 19.5 or later with ECU Measurement and Calibration Toolkit.
    CAN FD support with the ECU Measurement and Calibration Toolkit
    CAN FD features are only supported with NI-XNET version 17.0.1 or later.
    Custom baud rate for CAN in NI VeriStand is only supported with NI-XNET version 18.0 or later.
    © 2009–2020 National Instruments. All rights reserved.
    377542E-01
    GMT+8, 2025-12-4 08:07
