查看: 2731|回复: 0
[NI驱动程序] NI-TimeSync 16.0 Win32/64Eng NI时间同步驱动程序16.0版下载
  • 签到天数: 3538 天
    连续签到: 8 天
    发表于 2020-11-25 23:59:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-TimeSync
    NI-TimeSync可帮助安装、配置和监控嵌入式PXI目标上的同步。
    NI-TimeSync是一款驱动软件,可与PXI系统中的模块进行通信和同步。此软件可搭配PXI同步模块使用,用于对运行LabVIEW Real-Time模块的PXI控制器进行同步。该软件可以使用LabVIEW Real-Time模块的日期和时间对PXI控制器进行同步,同时包含基于与系统时间交互的API。此外,NI-TimeSync还提供LabVIEW范例,说明如何使用同步的绝对时间来协调多个实时目标或PXI机箱。NI-TimeSync支持通用和实时操作系统,包括Windows、Windows Server、NI Linux Real-Time、VxWorks和PharLap ETS。注册商标Linux的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux注册商标在全球范围内的所有权。
    16.0
    文件大小: 462982696 字节 (441.53 MB)
    修改日期: 2016-07-12 04:20
    MD5: f7524561205be21d1e133f36dbe5fa34
    SHA1: e380eac17698a5c9bdc73835fabdf90d5dec70c1
    SHA256: 1d596a69effe8ca18c12bd0d4866341b6940ba6a8f49f5320fc5fac3e3c8daa3
    CRC32: 7a8ecb0a
    NITS16.0.txt (563 Bytes, 下载次数: 0, 售价: 10 元)
    NI-TimeSync 16.0 Readme
    June 2016
    NI-TimeSync 16.0 supports the following operating systems:
    • Windows 7 x86, x64
    • Windows 8.1 x86, x64
    • Windows Server 2008 R2 (x64) 1, 3
    • Windows Server 2012 R2 (x64) 1, 3
    • NI Real-Time VxWorks
    • NI Real-Time Phar Lap ETS
    • NI Linux Real-Time4, 5
    1 System Configuration does not support non-R2 versions of Windows Server.
    2 Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the Info Code PAESupport.
    3 Support for Windows Server 2008 R2 and Windows Server 2012 R2 requires disabling Internet Explorer Enhanced Security Configuration (IE ESC). To learn how this affects your use of Windows Server 2008 R2 and Windows Server 2012 R2 and what actions you must take, visit ni.com/info and enter the Info Code MAXSupportIEESC.
    4 ARM-based targets running NI Linux Real-Time are slave only by default. For more information about this issue, visit ni.com/info and enter the Info Code ARMTargetSlaveOnly.
    5 The LabVIEW API installed with NI-TimeSync is not supported on NI Linux Real-Time targets.
    The following table lists the application software versions, including service packs, supported by NI-TimeSync.
    Application SoftwareVersions Supported by NI-TimeSync
    LabVIEW2013, 2014, 2015, 2016
    LabVIEW Real-Time Module2013, 2014, 2015, 2016
    NI-TimeSync Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003 in 2016
    With this release, NI-TimeSync drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-TimeSync 16.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-TimeSync 16.0 to an unsupported OS. Additionally, after installing NI-TimeSync 16.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    You can access the software and documentation known issues list online. For a list of known issues with NI-TimeSync 16.0, visit ni.com/info and enter the Info Code NITimeSync160KnownIssues.
    For a list of bug fixes for NI-TimeSync, visit ni.com/info and enter the Info Code NITimeSyncFixList.
    • For more information on silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
    ©2009-2016 National Instruments. All rights reserved.
    • Review \_Legal Information\_Legal Information.txt for information on including legal information in installers built with NI products.
    374886D-01
    GMT+8, 2025-5-14 06:45
