查看: 3453|回复: 0
[NI驱动程序] NI-TimeSync 17.1 Win32/64Eng NI时间同步驱动程序17.1版下载
  • 签到天数: 3538 天
    连续签到: 8 天
    发表于 2020-11-26 00:04:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-TimeSync
    NI-TimeSync可帮助安装、配置和监控嵌入式PXI目标上的同步。
    NI-TimeSync是一款驱动软件,可与PXI系统中的模块进行通信和同步。此软件可搭配PXI同步模块使用,用于对运行LabVIEW Real-Time模块的PXI控制器进行同步。该软件可以使用LabVIEW Real-Time模块的日期和时间对PXI控制器进行同步,同时包含基于与系统时间交互的API。此外,NI-TimeSync还提供LabVIEW范例,说明如何使用同步的绝对时间来协调多个实时目标或PXI机箱。NI-TimeSync支持通用和实时操作系统,包括Windows、Windows Server、NI Linux Real-Time、VxWorks和PharLap ETS。注册商标Linux的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux注册商标在全球范围内的所有权。
    17.1
    文件大小: 479281104 字节 (457.08 MB)
    修改日期: 2017-07-05 22:05
    MD5: bdc67bc892a8bb7adc3fee53d50c01ca
    SHA1: f09edb95e802ac86fdcc64fa3eed988921a944a5
    SHA256: 09b4f8cce5c36a42bbadf5eac47abe6fea225fb54206f93e08a594e4d462a44a
    CRC32: 89f6a3b2
    NITS17.1.txt (567 Bytes, 下载次数: 0, 售价: 10 元)
    NI-TimeSync 17.1 Readme
    July 2017
    NI-TimeSync is a coordinated set of synchronization protocols that can be used to synchronize time between multiple systems.
    NI-TimeSync 17.1 supports the following operating systems:
    • Windows 10 x86, x64
    • Windows 8.11 x86, x64
    • Windows 7 SP12 x86, x64
    • Windows Server 2012 R2 (x64) 1, 3, 4
    • Windows Server 2008 R2 (x64) 2, 3, 4
    • NI Real-Time VxWorks
    • NI Real-Time Phar Lap ETS
    • NI Linux Real-Time5, 6
    Note  In 2016 NI-TimeSync dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-TimeSync will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-TimeSync to an unsupported OS. Additionally, after installing NI-TimeSync, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    1NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    3 System Configuration does not support non-R2 versions of Windows Server.
    4 Support for Windows Server 2008 R2 and Windows Server 2012 R2 requires disabling Internet Explorer Enhanced Security Configuration (IE ESC). To learn how this affects your use of Windows Server 2008 R2 and Windows Server 2012 R2 and what actions you must take, visit ni.com/info and enter the Info Code MAXSupportIEESC.
    5 IEEE 1588-2008 protocol instances on ARM-based targets running NI Linux Real-Time are configured to be "slave only" by default. For more information about this issue, visit ni.com/info and enter the Info Code ARMTargetSlaveOnly.
    6 The LabVIEW API installed with NI-TimeSync is not supported on NI Linux Real-Time targets.
    NI-TimeSync 17.1 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by NI-TimeSync
    LabVIEW2014, 2015, 2016, 2017
    LabVIEW Real-Time Module2014, 2015, 2016, 2017
    You can access the software and documentation known issues list online. For a list of known issues with NI-TimeSync 17.1, visit ni.com/info and enter the Info Code NITimeSync171KnownIssues.
    For a list of bug fixes for NI-TimeSync, visit ni.com/info and enter the Info Code NITimeSyncFixList.
    • For more information on silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
    ©2009-2017 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help�Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents.
    374886G-01
    GMT+8, 2025-5-14 07:11
