查看: 3620|回复: 0
[LabWindows] LabWindows/CVI 8.5.1 Runtime Win32Eng LabWindows/CVI8.5.1运行版下载
    发表于 2020-12-8 23:19:24 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    8.5.1RT
    文件大小: 48791820 字节 (46.53 MB)
    修改日期: 2019-06-25 03:00
    MD5: 7e54f8b468163edcf88f023813260c4a(官方正确)
    SHA1: a889436ea09524f914f702c5a193b53fec277ad5
    SHA256: 7f5fa37c7c6fedb45286148a43b38d263df9b7370746361352c9484e0fc335b6
    CRC32: 27d24572
    百度和NI官方下载地址:
    CVI8.5.1RT.txt (613 Bytes, 下载次数: 1, 售价: 5 圆)
    LabWindows/CVI for Windows Vista/XP/2000, Version 8.5.1Readme File
    This file contains installation information, programming considerations, and changes that are too recent to be included in the LabWindows/CVI Help. Refer to the LabWindows/CVI Release Notes for more information about new features.
    Contents
    Minimum System Requirements
    Installing LabWindows/CVI
    Activating LabWindows/CVI
    After Installation
    To run LabWindows/CVI 8.5.1, you must have the following items:
    • Personal computer using a Pentium 1GHz or higher microprocessor
    • Windows Vista/XP/2000 Service Pack 3 or later
    • Minimum of 128 MB of RAM, 512 MB recommended
    • 200 MB free hard disk space
    • Microsoft-compatible mouse
    National Instruments recommends that you install the complete LabWindows/CVI program to take full advantage of all LabWindows/CVI 8.5.1 functionality. If you choose to install with options, select the options you want and follow the on-screen directions. If necessary, you can run the setup program again to install or remove additional files.
    Before Installation
    • If you install the LabWindows/CVI Real-Time Module and device drivers with LabWindows/CVI 8.5.1, you must install these products in the following order:
      • LabWindows/CVI 8.5.1
      • Device driver software from the NI Device Drivers CD set
      If you are installing the LabWindows/CVI Real-Time Module, do not install the device driver software when you are prompted to do so during the LabWindows/CVI 8.5.1 installation. Instead, install the device driver software when you are prompted during the LabWindows/CVI Real-Time Module installation.
    • When you install LabWindows/CVI, your user account must have administrator privileges.
    • You must explicitly select the Win32 SDK feature of the LabWindows/CVI installer to install the complete Windows SDK from the LabWindows/CVI Full Development System (FDS). Some Windows SDK header and import library files are included when you install the LabWindows/CVI Base Package. The Windows SDK help file is available only with the LabWindows/CVI FDS.
    • The LabWindows/CVI installation includes the LabWindows/CVI 8.5.1 Run-Time Engine. This version overwrites previous versions of the run-time engine. After you install LabWindows/CVI 8.5.1, executables and DLLs created with previous versions of LabWindows/CVI automatically use the new LabWindows/CVI 8.5.1 Run-Time Engine.
    • The IVI Installer Creator and IVI Specific Driver Test Suite items are selected by default in the installer feature tree only if the IVI Compliance Package is installed. You can select these items if the IVI Compliance Package is not installed, but you must then install the IVI Compliance Package, which you can download from ni.com.
    Running the Installation
    Complete the following steps to install LabWindows/CVI 8.5.1:
    Note  If you already have a different version of LabWindows/CVI installed on your computer, be sure to install version 8.5.1 in a different directory or uninstall the other version before installing LabWindows/CVI 8.5.1.
    • Insert the LabWindows/CVI CD into the CD drive. If the CD does not run automatically, open Windows Explorer, right-click the CD drive icon, and select AutoPlay.
    • On installation startup, the National Instruments LabWindows/CVI screen appears. Click Install LabWindows/CVI.
    • In the User Information panel, enter your name and organization. Select one of the following options:
      If you choose to enter a serial number, enter the serial number found on your Certificate of Ownership card. LabWindows/CVI uses this serial number when you run the NI Activation Wizard.
    Complete the following steps to activate LabWindows/CVI.
    • Select the Automatically activate through a secure Internet connection option and click Next. Your computer must be connected to the Internet for this option to work. If you do not have Internet access on your computer, refer to the LabWindows/CVI Release Notes.
    • The Serial Number option is populated with the number you entered during installation. Click Next.
    • Fill in the necessary information and click Next.
    • Check the option if you would like to receive a confirmation email of your activation and click Next.
    • After a brief moment, you should receive a message indicating whether LabWindows/CVI has been activated or not. Enter or verify your serial number. Click Next.
    • When you successfully activate LabWindows/CVI, click Finish. LabWindows/CVI will then display a window indicating when this license will expire.
    For more information about activation, refer to the LabWindows/CVI Release Notes.
    After Installation
    • Installing LabWindows/CVI in a New Directory—If you installed driver or toolkit software for a previous version of LabWindows/CVI and you install LabWindows/CVI 8.5.1 in a new directory, you must uninstall and reinstall the LabWindows/CVI portion of the driver or toolkit software.
    • New Location for Example Programs—You can find example programs in the following location on Windows Vista: \Users\Public\Documents\National Instruments\CVI85\samples. On Windows 2000/XP, example programs are located in the following location: \Documents and Settings\All Users\Documents\National Instruments\CVI85\samples. You can find a link to these locations from the previously used location (\Program Files\National Instruments\CVI85\samples).
    • New Location for Project and File Templates—Save user-defined project and file templates in the LabWindows/CVI public documents directory (\Documents and Settings\All Users\Documents\National Instruments\CVI on Windows XP/2000 and \Users\Public\Documents\National Instruments\CVI on Windows Vista). LabWindows/CVI no longer searches the previous locations, \Documents and Settings\All Users\Application Data\CVI and \Documents and Settings\\Application Data\CVI, for project and file templates.
    • Flushing Internal Buffers in a Network Variable Write Operation—This version of LabWindows/CVI introduces a new attribute, CNVFlushOnWriteAttribute, which specifies whether to flush all internal buffers in a network variable write operation. Flushing internal buffers improves network variable performance. This attribute is TRUE by default. Existing programs that you open with LabWindows/CVI 8.5.1 take advantage of the improved performance by flushing internal buffers.
      Flushing on write may cause lower throughput in some high bandwidth conditions, in which case you can set CNVFlushOnWriteAttribute to 0 (FALSE). In high bandwidth conditions, National Instruments recommends using the CNVBufferedWriter connection.
    • Flushing Internal Buffers in a Network Variable Read Operation—During a read operation, the Network Variable Library flushes all network variable connections in your program, including data in writer connections, for better performance.
    • Debugging Executables on Windows Vista—On Windows Vista, executables that contain setup, install, or update as part of their name automatically require administrator privileges. If you run these executables as stand-alone from a user-level account, Windows will prompt you for an administrator password. However, LabWindows/CVI cannot debug these applications from a user-level account. When you try to run them, LabWindows/CVI displays a Could not run executable notification. NI recommends that you rename your executable so that it does not contain those words in its name.
    • Performing DAQmx USB Buffered Operations on Windows Vista—On Windows Vista x64 Edition, running a program that uses NI-DAQmx 8.5 and terminating the program while it is performing DAQmx USB buffered operations can cause the machine to reboot or to display a Windows kernel bugcheck.
      The following may cause a process to terminate unexpectedly:
      • Selecting the End Process option in the Task Manager to kill the process.
      • Using a utility such as pskill to request process termination.
      • Shutting down the computer from the command line using shutdown -r -t 0 while the task is still running.
      • The process encountering an access violation, breakpoint, or other unhandled exception.
      • Attempting to log off, restart, or shutdown and clicking Cancel when the process prompts you to quit or cancel.
      • Choosing to stop the process from the LabWindows/CVI debugger while it is running or suspended.
    • Using Functions Requiring the Low-Level Driver—The LabWindows/CVI low-level driver is not supported on Windows Vista x64 Edition. The following functions are affected: inp, inpd, inpw, MapPhysicalMemory, outp, outpd, outpw, ReadFromPhysicalMemory, ReadFromPhysicalMemoryEx, StartPCSound, StopPCSound, UnMapPhysicalMemory, WriteToPhysicalMemory, WriteToPhysicalMemoryEx.
    • Using Compressed Icons—To use a Windows Vista compliant icon (featuring very large icons or PNG compression), you must replace the resource compiler shipped with LabWindows/CVI with the one included in the Windows SDK released with Windows Vista. Install the SDK and copy the rc.exe and rcdll.dll files from C:\Program Files\Microsoft SDKs\Windows\v6.0\Bin to CVI85\sdk\bin.
    • Registering ActiveX Servers—When you build ActiveX servers in LabWindows/CVI 8.1.1 and later on Windows Vista and XP, the ActiveX servers are registered in your user profile. This registration is not visible to other users on your system. On previous versions of Windows, ActiveX servers are registered for all users. When you register these servers outside the LabWindows/CVI environment, they are always registered for all users; this option requires administrator privileges on Vista.
    • Registering LabWindows/CVI as an ActiveX Server—Installing LabWindows/CVI registers it for all users. Launching LabWindows/CVI registers LabWindows/CVI as an ActiveX server. LabWindows/CVI is registered in your user profile on all versions of Windows.
    • Creating and Deleting Network Variables and Processes—You may notice that about 50 bytes of memory are lost when you create and delete a network variable or process.
    • Setting the Compatibility Mode for Real-Time DLLs—When you create a DLL to run on a real-time target, you must use the Visual C/C++ compatibility mode. The Borland C/C++ compatibility mode is not supported for real-time DLLs.
    • Using the LabWindows/CVI Conversion Wizard in Visual Studio .NET 2005—Microsoft Visual Studio 2005 removed support for the single-threaded version of its C library. Therefore, you must configure your project's linker settings to ignore directives to use the single-threaded C library. In Visual Studio, select Project» Properties and expand the properties tree to the Configuration Properties»Linker»Input item. Add libc to the Ignore Specific Library option. Refer to the I Receive Linker Errors When Using LabWindows/CVI-Generated Static Libraries and Object Files in Microsoft Visual Studio 2005 KnowlegeBase article for more information.
    • Running the LabWindows/CVI Project and Conversion Wizards in Visual Studio .NET 2003—If you use the LabWindows/CVI Project and Conversion Wizards in Visual Studio .NET 2003 and try to build a project that was created by one of these wizards, you will receive linker errors. With LabWindows/CVI 8.5 and later, the LabWindows/CVI libraries can be installed to various locations. The LabWindows/CVI wizards are not aware of these changes and therefore cannot find the needed libraries. These linker errors will only occur if you are using the LabWindows/CVI wizards in Visual Studio .NET 2003. Refer to National Instruments KnowledgeBase Article 4BIHC800 for steps to work around this issue.
    • Updating an Existing Distribution—The LabWindows/CVI distribution creation feature does not provide the option to include .obj files for both compatible compilers. If you convert an existing distribution that has this option enabled, LabWindows/CVI includes the .obj files only for the current compatible compiler in the updated distribution.
    • Using the NI Instrument I/O Assistant—The Instrument I/O Assistant 2.0 generates LabWindows/CVI code that is not backward compatible with code that previous versions of the Instrument I/O Assistant generated. If you run code generated with the Instrument I/O Assistant 2.0 with an existing application, the code in that application might not compile.
    • Making Backup .uir Files—If you have been using LabWindows/CVI 8.1.1 or earlier, make backup copies of your .uir files. Once you save .uir files in LabWindows/CVI 8.5, the .uir files are no longer compatible with versions 8.1.1 or earlier. You cannot load .uir files that you have saved in LabWindows/CVI 8.5 in LabWindows/CVI 8.1.1 or earlier.
      You can save .uir files you create or load in LabWindows/CVI 8.5 in LabWindows/CVI 7.1 or LabWindows/CVI 8.0/8.1 format. Select File»Save .uir As and specify the version in the Save as type option. If you save a user interface with features that were added in later versions of LabWindows/CVI, those features are removed when you save the file in 7.1 or 8.0/8.1 format.
    • Using Microsoft Excel as an ActiveX Control—If you develop an application that uses Excel as an ActiveX control on a LabWindows/CVI user interface panel, make sure that a separate instance of Excel is not running simultaneously. Otherwise, programmatic calls to the Excel control might not work as expected after the separate Excel application terminates.
    • Navigating the Tools Library and Toolkit Topics in the LabWindows/CVI Help—If you click a link from a topic in the Tools Library or a toolkit section of the LabWindows/CVI Help or from the toolslib function panel help, you cannot use the Back button in the help viewer toolbar to return to the original topic.
    • Using the Advanced Analysis Library—Upgrading to LabWindows/CVI 8.5 and later may cause the Advanced Analysis or Analysis Library to produce numerical differences in floating point results and different results for exceptional inputs, such as positive or negative infinity and NaN. These differences may occur because the underlying C Analysis library has been recompiled in LabWindows/CVI 8.5 to take advantage of new processors and operating systems.
        In LabWindows/CVI 7.1 and earlier, CxSVD has the following requirement: If numberOfRows (n) < numberOfColumns (m), you must allocate m*m*sizeof(ComplexNum) bytes of memory to the input matrix and the U orthogonal matrix. LabWindows/CVI 8.x no longer has this requirement.
      • CxTrace—CxTrace accepts only a square matrix. In LabWindows/CVI 7.1 and earlier, the function requires both the number of rows and the number of columns as input parameters. In LabWindows/CVI 8.x and later, matrixSize specifies both the number of rows and the number of columns. The numberOfColumns parameter in LabWindows/CVI 7.1 and earlier is a reserved parameter in LabWindows/CVI 8.x. This parameter is not referenced in the function.
    The following items are the IDs and titles of the bugs fixed between LabWindows/CVI 8.1.1 and LabWindows/CVI 8.5. For a list of bug fixes in previous releases, refer to ni.com.
    User Interface
    IDFixed IssueHas Run-Time Impact?
    94478Control dimming is too restrictiveYes
    73500Invalid control ID error message when creating a table and modifying the properties of a columnNo
    73494Creating a custom control that uses a control in a tab panel as a template can cause a crashNo
    72314Custom controls based on a canvas do not draw correctly in the Operate mode of the User Interface EditorNo
    72268Add attribute, ATTR_SHOW_CHART_DIVISION_LABELS, to center mininum and maximum x-axis markersYes
    71108Cannot load .tui saved in LabWindows/CVI 8.1.1 and earlier that contains a numeric control that can include a color rampNo
    70369GetTableCellFromValue function cannot search non-64 bit integral valuesYes
    69453Calling the GetCtrlMenuAttribute function with the ATTR_ITEM_NAME attribute can cause a crashYes
    69269Cannot reset plot data when graph is hidden or is being resizedYes
    69068Font sizes inside a table cell do not grow proportionally at the exact same rate of the cellYes
    68139Incorrect plotting behavior when other controls overlap the strip chart's graph areaYes
    72710FileSelectPopup function returns wrong path on Windows VistaYes
    59859Changing the digital graph x-axis offset or gain causes the Edit Digital Graph dialog box to remain on the screenNo
    73345Cannot change the value of ATTR_TRACE_YAXIS from VAL_RIGHT_YAXIS to VAL_LEFT_YAXISNo
    99084Calling the PlotPackedDigitalLines function repeatedly causes memory leakYes
    99422Possible crash when using any data type other than integer with PlotDigitalLines, PlotDigitalLinesMultiBus, and PlotPackedDigitalLines and specifying a large number of values to plotYes
    72819When debugging a project in Classic View, opening a released .uir window does not show the <> menuNo
    70532Cannot convert an input control to a numeric control on a function panelNo
    69412Library menu is missing when Memory Display window is activeNo
    67751Generate Function Tree command deletes the contents of the original .h file and creates an empty .fp file if the source .h and output .h are sameNo
    94987Compiling a file in debug configuration can, in very rare instances, cause a crashNo
    96086Source code collapsible regions are not properly recalculated after a callback is regeneratedNo
    96206LabWindows/CVI can crash when you delete source code and then click a collapsible region button without moving the mouseNo
    96313LabWindows/CVI can crash after you remove source code lines and then move the mouse below the last line of code, if collapsible regions are enabledNo
    99057LabWindows/CVI can crash when you resume execution after running function panels with global variables, while program execution is suspendedNo
    Compiler
    60502__FUNCTION__ macro has been partially deprecatedNo
    73064Overflow problem in calculating the number and position of ticks on a slideYes
    Debugging
    71530Cannot edit unsigned variables in any format except ASCII format in the Variables windowNo
    Performance
    71310CNVWrite is slower in LabWindows/CVI 8.5 compared to LabWindows/CVI 8.1.1Yes
    69213The LocalizeMenuBar function causes memory usage increaseNo
    63965LabWindows/CVI takes an abnormally long time to run a project on the Windows 2000 Service Pack 4Yes
    57143TDMS channels limited to 4 billion valuesYes
    Stand-Alone Applications and Distributions
    60554Cannot convert distribution created in LabWindows/CVI 6.0No
    Help
    59986Incorrect directory locations for project and file templates; missing documentation about [CVISHAREDDIR] and [CVIPUBDOCSDIR] as installation locations in the Edit Installer dialog box and about
    %CVISHAREDDIR% and %CVIPUBDOCSDIR% as special variables available for build steps
    No
    60365Description of the help file template parameter [[FILEBASENAME]] is incorrectNo
    Miscellaneous
    72127Unusual behavior after installation of LabWindows/CVI, such as installer errors due to missing NI Activation Wizard or application errors due to missing run-time DLLsNo
    69204The WordRpt_SetMargins function is missing from wordreport.hNo
    68512The GUI Localization Utility does not work for the right y-axis of a strip chartYes
    68468UI to Code Converter does not generate correct code to show y-axis minor gridlinesYes
    60256Explicitly created variables with a backslash in their names cause the CNVGetVariables function to failYes
    60256LabWindows/CVI ActiveX server crashes on termination when used from LabVIEWYes
    © 1993–2008 National Instruments Corporation. All rights reserved.
    CVI, National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. For a listing of the copyrights, conditions, and disclaimers regarding components used in USI (Xerces C++, HDF5, Citadel 5, b64 library, and Stingray), refer to the USICopyrights.chm.
    GMT+8, 2025-12-8 07:58
