查看: 2290|回复: 0
[LabWindows] LabWindows/CVI 2009 SP1 Full Win32Eng LabWindows/CVI2009SP1完整版下载
    昨天 07:57
  • 签到天数: 3837 天
    连续签到: 30 天
    发表于 2020-12-9 23:21:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    自2009版LabWindows开始,NI仅提供完整版和运行版,不再提供基本版。
    2009SP1,提供了EXE和ZIP两个版本:
    .exe
    文件大小: 356176480 字节 (339.68 MB)
    修改日期: 2010-07-01 07:07
    MD5: cfccef8ecc30ab658db61ae2a9ba635e
    SHA1: ea230d8916eeeefe39edba12737f256d9e959cba
    SHA256: 351a97f6565ef692dee4ebb3606b65c5a2585b49a3740c0667e16d38f37ee01b
    CRC32: c8541924
    zip
    文件大小: 355953560 字节 (339.46 MB)
    修改日期: 2019-06-25 02:59
    MD5: b956b99a52694faf8e3931d84ef2930c(官方正确)
    SHA1: 988fd3be35c2cc44bae0d26913a19e98c8462e0b
    SHA256: 688dd91714b2e04eb4d62b95d11b1b10a23a7a1cf1377631b5189a6fc2c40951
    CRC32: 39c92411
    百度和NI官方下载地址:
    CVI2009SP1.txt (1.06 KB, 下载次数: 1, 售价: 15 圆)
    LabWindows/CVI for Windows 7/Vista/XP/2000, Version 2009 Service Pack 1Readme File
    This file contains installation information, programming considerations, and changes that are too recent to be included in the LabWindows/CVI Help. Refer to the LabWindows/CVI Release Notes for more information about new features.
    Contents
    Minimum System Requirements
    Installing LabWindows/CVI
    Activating LabWindows/CVI
    After Installation
    Upgrading from LabWindows/CVI 9.0
    Upgrading from LabWindows/CVI 8.5 or earlier
    To run LabWindows/CVI 2009 SP1, you must have the following items:
    • Personal computer using a Pentium 1GHz or higher microprocessor
    • Microsoft operating systems:
      • Windows XP (32-bit)
      • Windows 2000 Service Pack 3 or later
      Note  LabWindows/CVI 2009 is the last major release to support Windows 2000.
    • Minimum of 128 MB of RAM, 512 MB recommended
    • 1.1 GB free hard disk space for full installation, which includes the Interface to Win32 Application Programmatic Interface
      Note  Installing the Documentation from MSDN Library requires additional disk space.
    • Microsoft-compatible mouse
    National Instruments recommends that you install the complete LabWindows/CVI program to take full advantage of all LabWindows/CVI 2009 SP1 functionality. If you choose to install with options, select the options you want and follow the on-screen directions. If necessary, you can run the setup program again to install or remove additional files.
    Before Installation
    • If you install the LabWindows/CVI Real-Time Module and device drivers with LabWindows/CVI 2009 SP1, you must install these products in the following order:
      • LabWindows/CVI 2009 SP1
      • LabWindows/CVI 2009 Real-Time Module
      • Device driver software, using NI Device Drivers media
        The LabWindows/CVI package includes the device driver software on a DVD. If you require device driver software on CDs, refer to the National Instruments Web site at ni.com/info and enter the info code drivercd.
      If you are installing the LabWindows/CVI Real-Time Module, do not install the device driver software when you are prompted to do so during the LabWindows/CVI 2009 SP1 installation. Instead, install the device driver software when you are prompted during the LabWindows/CVI Real-Time Module installation.
    • When you install LabWindows/CVI, your user account must have administrator privileges.
    • You must explicitly select the Interface to Win32 API feature of the LabWindows/CVI installer to install the complete Interface to Win32 API.
      The Interface to Win32 API is based on the Windows Server 2003 R2 Platform SDK. The Windows Server 2003 R2 Platform SDK was released in March 2006 and does not include tools or functionality added in later versions of the SDK, such as support for functionality specific to Windows Vista.
      Note  The complete Interface to Win32 API is available with the LabWindows/CVI Full Development System. Some Win32 API header and import library files are included when you install the LabWindows/CVI Base package.
    • The LabWindows/CVI installation includes the LabWindows/CVI 2009 SP1 Run-Time Engine. This version replaces any previous version of the LabWindows/CVI Run-Time Engine. After you install LabWindows/CVI 2009 SP1, executables and DLLs created with previous versions of LabWindows/CVI automatically use the new LabWindows/CVI 2009 SP1 Run-Time Engine.
      To restore the previous Run-Time Engine, uninstall LabWindows/CVI 2009 SP1 and any previous versions of LabWindows/CVI on the computer. Then reinstall the LabWindows/CVI version you want to use, along with any additional National Instruments software you might have installed.
    • The IVI Installer Creator and IVI Specific Driver Test Suite items are selected by default in the installer feature tree only if the IVI Compliance Package is installed. You can select these items if the IVI Compliance Package is not installed, but you must then install the IVI Compliance Package, which you can download from ni.com.
    • You can install the Visual Studio 2005 Wizards and Visual Studio 2008 Wizards features only if you have installed Visual Studio 2005 and Visual Studio 2008, respectively.
    Running the Installation
    The LabWindows/CVI Platform DVD includes LabWindows/CVI and the following modules and toolkits.
    Modules
    • Real-Time Module
    • Vision Development Module
    Toolkits
    • Execution Profiler Toolkit
    • PID Toolkit
    • Real-Time Execution Trace Toolkit
    • Signal Processing Toolkit
    • SQL Toolkit
    Note  The LabWindows/CVI Platform DVD also includes the Documentation from MSDN Library.
    If you purchased any of these modules or toolkits, you can install them using the LabWindows/CVI Platform DVD. If you want to evaluate any of these modules or toolkits before purchasing them, you can install these add-ons from the LabWindows/CVI Platform DVD and try them for free for 30 days. Refer to each toolkit or module Readme for more information about installing with media other than the LabWindows/CVI Platform DVD.
    Complete the following steps to install LabWindows/CVI 2009 SP1:
    Note  If you already have LabWindows/CVI 9.x.x or earlier installed on your computer, be sure to install version 2009 SP1 in a different directory. If you have LabWindows/CVI 2009 installed on your computer, the LabWindows/CVI installer replaces LabWindows/CVI 2009 with LabWindows/CVI 2009 SP1. If you want to install to an existing directory, uninstall the other version before installing LabWindows/CVI 2009 SP1.
    • Insert the LabWindows/CVI media into the disk drive. If the media does not run automatically, open Windows Explorer, right-click the disk drive icon, and select AutoPlay.
    • On installation startup, the National Instruments LabWindows/CVI 2009 screen appears. Click Install LabWindows/CVI, Modules, and Toolkits.
    • In the Product List panel, select all the products you want to install. Select Install to install products using default options. Selecting Install with customization opens additional dialog boxes that require your input.
    • In the Product Information panel, determine whether to allow the installer to contact National Instruments to search for new notifications, such as critical updates, on the products you are installing. The checkbox is enabled by default.
    • In the User Information panel, enter your name and organization.
    • Enter the serial number, from the Certificate of Ownership card in the software kit, in the appropriate field for each product you install. LabWindows/CVI uses this serial number when you run the NI Activation Wizard. Leave the Serial Number field blank to evaluate the product.
      Note  To activate a National Instruments product after you evaluate it, refer to the Activation Instructions.
    Note  If you selected Device Drivers in the Product List, after installing LabWindows/CVI and any selected modules and toolkits, the LabWindows/CVI installer prompts you to insert the National Instruments Device Drivers DVD. Follow the instructions on the screen to install the device drivers.
    You can activate licenses you have purchased for LabWindows/CVI, modules, and toolkits during installation. If you do not activate a valid license for LabWindows/CVI or any modules and toolkits that you install, the unlicensed product operates in evaluation mode. After you install the product, the evaluation begins the first time you launch the product and lasts 30 consecutive days. When the evaluation period expires, you must activate a valid license to continue using the product.
    You can activate LabWindows/CVI, modules, or toolkits in the following ways:
    • During installation, as described in the Installation Instructions.
    • After installation, by enabling the Run License Manager to activate the product(s) checkbox on the Installation Summary panel of the LabWindows/CVI Platform DVD installer.
    • After you launch LabWindows/CVI for the first time with any product in evaluation mode, click the Activate Products button in the LabWindows/CVI Message dialog box.
    • Select Help»Activate LabWindows/CVI while LabWindows/CVI is running in evaluation mode or select Start»All Programs»National Instruments»NI License Manager to launch the NI License Manager.
    If you do not activate LabWindows/CVI or any modules and toolkits during installation, LabWindows/CVI prompts you to activate when you launch LabWindows/CVI. After you activate the licenses for all LabWindows/CVI products you installed, you no longer see this prompt. Once you choose your activation method and launch the NI Activation Wizard, complete the following steps to activate LabWindows/CVI and any modules or toolkits:
    • Select the Automatically activate through a secure Internet connection option and click Next.
      Your computer must be connected to the Internet for this option to work.
    • Enter the serial numbers for the products you want to activate. Click Next.
    • Fill in the necessary information and click Next.
    • Check the option and enter an email address if you would like to receive a confirmation email of your activation and click Next.
    • After a brief moment, a message appears, indicating whether LabWindows/CVI has been activated. Click Next.
    • When you successfully activate LabWindows/CVI and any modules or toolkits, click Finish. LabWindows/CVI displays a window indicating when your license expires.
    For more information about activation, refer to the LabWindows/CVI Release Notes.
    After Installation
    • Installing LabWindows/CVI in a New Directory—If you installed driver or toolkit software for LabWindows/CVI 8.1.1 or earlier and you install LabWindows/CVI 2009 SP1 in a new directory, you must uninstall and reinstall the LabWindows/CVI portion of the driver or toolkit software.
    • Using Example Programs—You can find example programs in the following location on Windows 7/Vista: \Users\Public\Documents\National Instruments\CVI2009\samples. On Windows 2000/XP, example programs are located in the following location: \Documents and Settings\All Users\Documents\National Instruments\CVI2009\samples.
    • Working with Project and File Templates—Save user-defined project and file templates in the LabWindows/CVI public documents directory (\Documents and Settings\All Users\Documents\National Instruments\CVI on Windows XP/2000 and \Users\Public\Documents\National Instruments\CVI on Windows 7/Vista). LabWindows/CVI 8.5 and later does not search previous locations, \Documents and Settings\All Users\Application Data\CVI and \Documents and Settings\\Application Data\CVI, for project and file templates.
    • Borland is no longer supported as a compatible compiler or as a third-party compiler in LabWindows/CVI.
    • Starting with the 2009 version of LabWindows/CVI, major versions align with the year in which they release. For example, this version of LabWindows/CVI is called LabWindows/CVI 2009 SP1. You can find installed files in the CVI2009 folder in the various locations where LabWindows/CVI installs files. The registry keys corresponding to this version of LabWindows/CVI are located in CVI\9.1 in the registry.
    • The NI Distributed System Manager replaces the NI Variable Manager. Use the System Manager to create and monitor network variables, processes, and I/O servers. For more information about the System Manager, refer to the NI Distributed System Manager Help, which you can access from the System Manager.
    • The Translate LW DOS Program option is no longer available.
    • The LabWindows/CVI compiler now defines the NDEBUG macro for release configuration builds.
    • LabWindows/CVI no longer adds _dbg suffix to the base name of the debug target of a project.
    • The data type of the targetThreadId parameter of the PostDeferredCallToThread and PostDeferredCallToThreadAndWait functions has been changed from unsigned long to unsigned int.
    • toolbox.h now includes some LabWindows/CVI headers that must be included after including windows.h. Therefore, if your code includes toolbox.h before including windows.h, reverse the order of these includes.
    • Network variable processes that begin with NI_ are disallowed. The CNVNewProcess function returns an error if the process name you specify begins with NI_.
    • The following macros have been renamed:
      LibraryPrevious Macro NameNew Macro Name
      WordReport.fp Instrument DriverNONEWR_NONE
      Analysis LibrarySORT_ASCENDINGANALYSIS_SORT_ASCENDING
      Analysis LibrarySORT_DESCENDINGANALYSIS_SORT_DESCENDING
    • The enum value CVIConst_CVI_FPVERSION_90 has been changed to CVIConst_CVI_FPVERSION_85 for the fpVersion parameter of the FPGenCreateFunctionTree function of the LabWindows/CVI ActiveX Server Interface Library.
    • The modini utility and related source code as well as the modreg source code are deprecated and no longer installed with LabWindows/CVI.
    • The LabWindows/CVI Quick Reference card is no longer published and is not installed with LabWindows/CVI.
    • The option to create Microsoft Windows WinHelp files (.hlp) from LabWindows/CVI, Generate»Documentation»Windows Help, is no longer available.
    • Microsoft Windows 7 Support—National Instruments is committed to maintaining compatibility with Microsoft Windows technology changes. While most NI products work with Windows 7, NI has become aware of some compatibility issues regarding Windows 7. To learn more about Windows 7 and NI products, visit ni.com/info and enter the Info Code windows7.
    • Uninstalling LabWindows/CVI 2009 SP1 Causes Issues with Measurement Studio and DIAdem—If you uninstall LabWindows/CVI 2009 SP1 from a computer that also has Measurement Studio 8.6.1 or earlier or DIAdem 11.1 or earlier installed, Measurement Studio and DIAdem will be unable to perform advanced analysis operations. To resolve this problem, uninstall Measurement Studio or DIAdem and then reinstall it.
    • Linking Import Libraries for .NET—LabWindows/CVI cannot link in the import library for a .NET mixed mode DLL.
    • Selecting Files Using Libraries Shortcut—In Windows 7, the Libraries shortcut item in file dialog boxes does not work correctly.
    • Zooming Graph Axis—Zooming a graph axis can skew a plot when the magnification becomes too large.
    • Resizing Slide Controls—Numeric markers do not always adjust correctly to the resizing of a slide control.
    • Setting Inc/Dec Arrow Width—ATTR_INCDEC_WIDTH has no effect if the inc/dec arrows are not visible.
    • Using Perforce with LabWindows/CVI—LabWindows/CVI crashes when using the Perforce 2009.1 source code control plug-in.
    • Specifying ATTR_MOVABLE Attribute—ATTR_MOVABLE does not work in Windows 7 with Aero enabled.
    • Displaying Popups—Second popup can appear behind another popup if the application is not in the foreground when the second popup is displayed.
    • Displaying Panels and Windows in Windows 7—LabWindows/CVI panels and windows do not support Aero Shake.
    • Availability of Example Programs for Base Package—Examples that only work in FDS are listed in Example Finder when Base version is activated.
    • Displaying PNG Images—PNG images with alpha-channel transparency lose their transparency when displayed on transparent classic-style picture controls.
    • Numerical Differences in Analysis Function Results—LabWindows/CVI 2009 uses the latest version of the Intel® Math Kernel Library (MKL). Some of the functions in the Intel MKL return different results compared to previous versions of MKL due to optimization, causing slight numerical differences between results from Vector and Matrix Algebra, Statistics, and Curve Fitting functions in LabWindows/CVI 2009 and previous versions of LabWindows/CVI.
    • Error When Building a LabWindows/CVI Project in Visual Studio 2005—If you create a project in Visual Studio 2005 that uses LabWindows/CVI libraries, you will see the following error: fatal error LNK1103: debugging information corrupt; recompile module. To address this issue, install the hotfix available from Microsoft.
    • Launching Examples from the LabWindows/CVI Help on 64-bit OSes—If you launch the LabWindows/CVI Help from the Start menu or from the LabWindows/CVI Welcome Page, the Open example buttons in function reference topics do not work correctly. The Open example buttons work correctly if you launch the LabWindows/CVI Help from the Help menu and in function panel help.
    • Flushing Internal Buffers in a Network Variable Write Operation—Starting with LabWindows/CVI 8.5.1, the Network Variable Library flushes all internal buffers in a write operation, which improves network variable performance.
      Flushing on write may cause lower throughput in some high bandwidth conditions, in which case you can set CNVFlushOnWriteAttribute to 0 (FALSE). In high bandwidth conditions, National Instruments recommends using the CNVBufferedWriter connection.
    • Flushing Internal Buffers in a Network Variable Read Operation—During a read operation, the Network Variable Library flushes all network variable connections in your program, including data in writer connections, for better performance.
    • Debugging Executables on Windows Vista—On Windows Vista, executables that contain setup, install, or update as part of their name automatically require administrator privileges. If you run these executables as stand-alone from a user-level account, Windows will prompt you for an administrator password. However, LabWindows/CVI cannot debug these applications from a user-level account. When you try to run them, LabWindows/CVI displays a Could not run executable notification. NI recommends that you rename your executable so that it does not contain those words in its name, or that you embed a manifest into the application that marks the application as being Vista-aware. You can embed a manifest using the Target Settings dialog box.
    • Using Compressed Icons—To use an icon featuring PNG compression, you must replace the resource compiler shipped with LabWindows/CVI with the one included in the Windows SDK released with Windows Vista. Install the SDK and copy the rc.exe and rcdll.dll files from C:\Program Files\Microsoft SDKs\Windows\v6.0\Bin to CVIversion\sdk\bin.
    • Performing DAQmx USB Buffered Operations on Windows Vista—On Windows Vista x64 Edition, running a program that uses NI-DAQmx 8.5 and terminating the program while it is performing DAQmx USB buffered operations can cause the machine to reboot or to display a Windows kernel bugcheck.
      The following may cause a process to terminate unexpectedly:
      • Selecting the End Process option in the Task Manager to kill the process.
      • Using a utility such as pskill to request process termination.
      • Shutting down the computer from the command line using shutdown -r -t 0 while the task is still running.
      • The process encountering an access violation, breakpoint, or other unhandled exception.
      • Attempting to log off, restart, or shutdown and clicking Cancel when the process prompts you to quit or cancel.
      • Choosing to stop the process from the LabWindows/CVI debugger while it is running or suspended.
    • Using Functions Requiring the Low-Level Driver—The LabWindows/CVI low-level driver is not supported on Windows Vista x64 Edition. The following functions are affected: inp, inpd, inpw, MapPhysicalMemory, outp, outpd, outpw, ReadFromPhysicalMemory, ReadFromPhysicalMemoryEx, StartPCSound, StopPCSound, UnMapPhysicalMemory, WriteToPhysicalMemory, WriteToPhysicalMemoryEx.
    • Registering ActiveX Servers—When you build ActiveX servers in LabWindows/CVI 8.1.1 and later on Windows Vista and XP, the ActiveX servers are registered in your user profile. This registration is not visible to other users on your system. On previous versions of Windows, ActiveX servers are registered for all users. When you register these servers outside the LabWindows/CVI environment, they are always registered for all users; this option requires administrator privileges on Windows Vista.
    • Registering LabWindows/CVI as an ActiveX Server—Installing LabWindows/CVI registers it for all users. Launching LabWindows/CVI registers LabWindows/CVI as an ActiveX server. LabWindows/CVI is registered in your user profile on all versions of Windows.
    • Creating and Deleting Network Variables and Processes—You may notice that about 50 bytes of memory are lost when you create and delete a network variable or process.
    • Using the LabWindows/CVI Conversion Wizard in Microsoft Visual Studio 2005 or Microsoft Visual Studio 2008—Microsoft Visual Studio 2005 and later do not support the single-threaded version of the Visual Studio C library. Therefore, you must configure your project's linker settings to ignore directives to use the single-threaded C library. In Visual Studio, select Project» Properties and expand the properties tree to the Configuration Properties»Linker»Input item. Add libc to the Ignore Specific Library option. Refer to the I Receive Linker Errors When Using LabWindows/CVI-Generated Static Libraries and Object Files in Microsoft Visual Studio 2005 KnowlegeBase article for more information.
    • Using the NI Instrument I/O Assistant—The Instrument I/O Assistant 2.0 generates LabWindows/CVI code that is not backward compatible with code that previous versions of the Instrument I/O Assistant generated. If you run code generated with the Instrument I/O Assistant 2.0 with an existing application, the code in that application might not compile.
    • Making Backup .uir Files—Make backup copies of your .uir files if you have been using previous versions of LabWindows/CVI. Once you save .uir files in LabWindows/CVI 2009 SP1, the .uir files are no longer compatible with versions 8.1.1 or earlier. You cannot load .uir files that you have saved in LabWindows/CVI 2009 SP1 in LabWindows/CVI 8.1.1 or earlier.
      You can save .uir files you create or load in LabWindows/CVI 2009 SP1 in earlier formats. Select File»Save .uir As and specify the format in the Save as type option. If you save a user interface with features that were added in later versions of LabWindows/CVI, those features are removed when you save the file in earlier formats.
    • Using Microsoft Excel as an ActiveX Control—If you develop an application that uses Excel as an ActiveX control on a LabWindows/CVI user interface panel, make sure that a separate instance of Excel is not running simultaneously. Otherwise, programmatic calls to the Excel control might not work as expected after the separate Excel application terminates.
    • Navigating the Tools Library and Toolkit Topics in the LabWindows/CVI Help—If you click a link from a topic in the Tools Library or a toolkit section of the LabWindows/CVI Help or from the toolslib function panel help, you cannot use the Back button in the help viewer toolbar to return to the original topic.
    • Using the Advanced Analysis Library—Upgrading to LabWindows/CVI 8.5 and later may cause the Advanced Analysis or Analysis Library to produce numerical differences in floating point results and different results for exceptional inputs, such as positive or negative infinity and NaN. These differences may occur because the underlying C Analysis library has been recompiled in LabWindows/CVI 8.5 to take advantage of new processors and operating systems.
        In LabWindows/CVI 7.1 and earlier, CxSVD has the following requirement: If numberOfRows (n) < numberOfColumns (m), you must allocate m*m*sizeof(ComplexNum) bytes of memory to the input matrix and the U orthogonal matrix. LabWindows/CVI 8.x and later no longer has this requirement.
      • CxTrace—CxTrace accepts only a square matrix. In LabWindows/CVI 7.1 and earlier, the function requires both the number of rows and the number of columns as input parameters. In LabWindows/CVI 8.x and later, matrixSize specifies both the number of rows and the number of columns. The numberOfColumns parameter in LabWindows/CVI 7.1 and earlier is a reserved parameter in LabWindows/CVI 8.x and later. This parameter is not referenced in the function.
    • Help File Font Size—Starting with LabWindows/CVI 2009, the LabWindows/CVI Help includes a Font button that you can use to increase or decrease the font size in the help file. The Font button might not update the font size in help files that merge into the LabWindows/CVI Help.
      In addition, the smallest font size setting of the Font button is the standard font size for National Instruments help files. The text size settings in Internet Explorer might cause the font to appear larger than typical National Instruments help files. If you resize the font, the help file retains the font size the next time you open the product help.
    The following items are the IDs and titles of the bugs fixed between LabWindows/CVI 2009 and LabWindows/CVI 2009 SP1. For a list of bug fixes in previous releases, refer to ni.com.
    IDFixed IssueHas Run-Time Impact?
    196251The Attribute Browser allows invalid characters and constant names longer than 10 characters for panels.No
    230084Progress bar in environment does not auto-fill.No
    198333The DLL Import Library Choices dialog box shown after selecting Options»Generate DLL Import Library results in the error Invalid Control ID.No
    198322The Attribute Browser allows you to edit read-only .uir files.No
    199243LabWindows/CVI displays innocuous error message after clicking on a panel title bar in the Edit Panel dialog boxNo
    198624Options»Generate DLL Import Library fails for 64-bit DLLs.No
    201769Help»Win32 API results in an error message after installing the Documentation from MSDN Library.No
    199755The build step variable %CVIBUILDCONFIG% does not support 64-bit configurations.No
    201054When the Attribute Browser is empty, toggling Find/Filter results in the error A custom control callback raised an exception.No
    208315Collapsible region markers may not update correctly as you scroll through a source file.No
    208352In the Edit Text Message dialog box, inserting a new line by pressing does not update the control.No
    226445Row and column inheritance of table controls does not work in the User Interface Editor.No
    236861Function panel for CNVSetArrayDataValue has incorrect prototype.No
    196251The Attribute Browser allows panel names longer than 10 characters.No
    208388Error messages may display when connecting with Windows Remote Desktop to a remote machine running LabWindows/CVI.No
    172157Diffing two files can cause window contents to draw in the wrong window.No
    Performance
    200777Multibyte characters on a .uir file may cause the LabWindows/CVI environment to hang.No
    232735Small timeouts in RS-232 write operations can cause the application to hang.Yes
    218499Calling GetTCPPeerName with an invalid handle can cause the application to hang.Yes
    201259Calling RegisterWinMsgCallback and UnRegisterWinMsgCallback from different threads may result in a crash.Yes
    203396LabWindows/CVI may crash if compiling a project that includes header files from earlier versions of LabWindows/CVI.No
    202181Memory corruption may occur in programs that duplicate graph controls.Yes
    200341A hang can occur if a panel is displayed from a thread other than the main thread and the main thread does not process events.Yes
    User Interface
    197797The strip chart cannot plot more than INT_MAX points.Yes
    235344The right Y axis name of a graph does not adjust correctly when the graph is resized.Yes
    Debugging/Compiler
    206299Running instrument driver function panels may result in a link error when using a 64-bit configuration.No
    223736Debugger may invalidate stored return values of gmtime and asctime.No
    201360Incorrect usage of designated initializers (C99) may result in a hang in the LabWindows/CVI environment during compilation.No
    196430Large static arrays declared in a block scope can cause a stack overflow if Detect uninitialized local variables at run time is selected.Yes
    Stand-Alone Applications and Distributions
    201771Distributions specifying a minimum .NET version of 3.0 or later do not build.No
    203306Some .cds files created in versions of LabWindows/CVI prior to LabWindows/CVI 2009 may not work in LabWindows/CVI 2009.No
    202378LabWindows/CVI cannot load .cds files specifying Windows 7 as the minimum operating system.No
    218345Missing dependency DLL error messages reported when debugging or deploying an RT program.Yes
    ActiveX
    212718Applications with ActiveX controls may hang if the active panel is changed from a non-UI thread.Yes
    216830Loading a panel with an ActiveX control in a thread other than the main thread will fail.Yes
    222668An internal error when loading a panel with ActiveX controls can cause a crash.Yes
    Miscellaneous
    192713LabWindows/CVI returns error -6604 when calling TDMS_ConvertFileFormat.Yes
    225480InetPing returns error if address does not exist.Yes
    216631Hidden files cannot be opened for writing.Yes
    201130Calling OpenComConfig with an input queue size greater than 40960 bytes results in unexpected behavior on Windows.Yes
    200251Paths with the separator '/' are not accepted by LabWindows/CVI ActiveX automation functions.Yes
    201013OpenComConfig does not return an error if the configuration parameters are invalid.Yes
    237190Variable argument parameters are documented as void * in the LabWindows/CVI Help.No
    200677Path control autocompletion may interfere with the text a user enters.Yes
    © 1993–2010 National Instruments Corporation. All rights reserved.
    For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in LabWindows/CVI, refer to the Copyright topic of the LabWindows/CVI Help.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2026-3-27 07:57
