查看: 3063|回复: 0
[LabWindows] LabWindows/CVI 2012 SP1 Runtime Win32Eng LabWindows/CVI2012SP1运行版下载
    4 小时前
  • 签到天数: 3810 天
    发表于 2020-12-9 23:46:48 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    自2009版LabWindows开始,NI仅提供完整版和运行版,不再提供基本版。
    2012SP1RT
    文件大小: 227503569 字节 (216.96 MB)
    修改日期: 2019-06-25 03:00
    MD5: 71e61cd0492aafc26e20957c1da59d91(官方正确)
    SHA1: 8347b31991506c1ca8f3574726a9aed003cff6e4
    SHA256: 27c564ca2869ab259bf333d6e9140193c051ad693e5b56a5c49919065873cd48
    CRC32: b03a5793
    百度和NI官方下载地址:
    CVI2012SP1RT.txt (636 Bytes, 下载次数: 1, 售价: 5 圆)
    LabWindows/CVI for Windows, Version 2012 Service Pack 1Readme File
    This file contains installation information, programming considerations, and changes that are too recent to be included in the LabWindows/CVI Help for LabWindows/CVI 2012 Service Pack 1. Refer to the LabWindows/CVI Release Notes for more information about new features.
    Caution  Installing LabWindows/CVI 2012 SP1 replaces any previous version of the LabWindows/CVI Run-Time Engine with the LabWindows/CVI 2012 SP1 Run-Time Engine. To restore the previous Run-Time Engine, uninstall LabWindows/CVI 2012 SP1 and any previous versions of LabWindows/CVI on the computer. Then reinstall the LabWindows/CVI version you want to use.
    Contents
    Activating LabWindows/CVI
    After Installation
    Upgrading from LabWindows/CVI 2010 or Earlier
    Upgrading from LabWindows/CVI 2009 or Earlier
    Upgrading from LabWindows/CVI 9.0 or Earlier
    Upgrading from LabWindows/CVI 8.5 or Earlier
    To run LabWindows/CVI 2012 SP1, you must have the following:
    • Personal computer using a Pentium 4/M or equivalent microprocessor
    • Microsoft operating systems:
      • Windows 7 (32-bit and 64-bit), including Starter Edition
      • Windows Vista Service Pack 1 (32-bit and 64-bit)
      • Windows XP Service Pack 3
      • Windows Server 2008 R2 Service Pack 1 (64-bit)
      • Windows Server 2003 R2 Service Pack 2 (32-bit)
      Note LabWindows/CVI supports only R2 editions of Windows Server
    • Minimum of 256 MB of RAM, 1 GB recommended
    • 1.4 GB free hard disk space for full installation, which includes the Interface to Win32 Application Programmatic Interface (API); additional space needed for National Instruments Device Drivers and for the Microsoft .NET Framework 4.0
    • Microsoft-compatible mouse
    National Instruments recommends that you install the complete LabWindows/CVI program to take full advantage of all LabWindows/CVI 2012 SP1 functionality. If you choose to install with options, select the options you want and follow the on-screen directions. If necessary, you can run the setup program again to install or remove additional files.
    The LabWindows/CVI Platform DVD includes LabWindows/CVI and the following modules and toolkits.
    Modules
    • Real-Time Module
    • Vision Development Module
    Toolkits
    • Real-Time Execution Trace Toolkit
    • SQL Toolkit
    • Signal Processing Toolkit
    • PID Toolkit
    • Execution Profiler Toolkit
    • ECU Measurement and Calibration Toolkit
    • Automotive Diagnostic Command Set
    If you purchased any of these modules or toolkits, you can install them using the LabWindows/CVI Platform DVD. If you want to evaluate any of these modules or toolkits before purchasing them, you can install these add-ons from the LabWindows/CVI Platform DVD and try them for 45 days. After an initial 7 day period, you can register on ni.com for access to the remainder of the evaluation period.
    NoteThe Execution Profiler Toolkit does not require a separate license if you have a LabWindows/CVI Full Development System license. If you have the LabWindows/CVI Base Package, you can install the Execution Profiler Toolkit for evaluation.
    Installation Considerations
    • When installing LabWindows/CVI, the LabWindows/CVI Real-Time Module, and NI Device Drivers, install device drivers after the LabWindows/CVI Real-Time Module. If you install all of these products at the same time using the LabWindows/CVI Platform DVD, the products are installed in the correct order. If you install the LabWindows/CVI Real-Time Module on a computer that already has device drivers installed, reinstall the device driver software to ensure that real-time support is installed for the device drivers you selected.
    • The complete Interface to Win32 API is available with the LabWindows/CVI Full Development System. Some Win32 API header and import library files are included when you install the LabWindows/CVI Base Package.
    • The LabWindows/CVI installation includes the LabWindows/CVI 2012 SP1 Run-Time Engine. This version replaces any previous version of the LabWindows/CVI Run-Time Engine. After you install LabWindows/CVI 2012 SP1, executables and DLLs created with previous versions of LabWindows/CVI automatically use the new LabWindows/CVI 2012 SP1 Run-Time Engine.
    • The IVI Installer Creator and IVI Specific Driver Test Suite items are selected by default in the installer feature tree only if the IVI Compliance Package is installed. You can select these items if the IVI Compliance Package is not installed, but you must then install the IVI Compliance Package, which you can download from ni.com. The IVI Compliance Package is also available on the NI Device Drivers media.
    • You can install the Visual Studio Wizards feature only if you have installed the version of Visual Studio corresponding to the Visual Studio Wizard you select.
    Running the Installation
    Complete the following steps to install LabWindows/CVI:
    NoteIf you have LabWindows/CVI 2012 installed on your computer, the LabWindows/CVI installer replaces LabWindows/CVI 2012 with LabWindows/CVI 2012 SP1. If you want to install to an existing directory, uninstall the other version before installing LabWindows/CVI 2012 SP1.
    You must have administrator privileges to install LabWindows/CVI.
    • Insert the LabWindows/CVI media into the disk drive. If the media does not run automatically, open Windows Explorer, right-click the disk drive icon, and select AutoPlay.
    • On installation startup, the National Instruments LabWindows/CVI 2012 screen appears. Click Install LabWindows/CVI, Modules, and Toolkits.
      NoteIf you have a serial number for the product you want to install, enter the number during installation when you are prompted. You also can activate the product after installation. For more information about finding serial numbers, refer to ni.com/info and enter SerialNumbers_en as the Info Code.
      Each product on the LabWindows/CVI Platform DVD has a different serial number, with the possible exception of the LabWindows/CVI Execution Profiler Toolkit.
    • If you selected Device Drivers in the Product List, the LabWindows/CVI installer prompts you to insert the National Instruments Device Drivers DVD after you install LabWindows/CVI and any selected modules and toolkits. Follow the instructions on the screen to install the device drivers.
    • To activate a National Instruments product, refer to the Activating LabWindows/CVI section.
    Updates and Notifications
    National Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates.
    National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications.
    You can activate LabWindows/CVI during or after installation. To activate during installation, enter a serial number when you are prompted by the installer. If you do not activate during installation, you can launch the NI Activation Wizard by selecting Activate Products in the License Status dialog box, which displays when you launch LabWindows/CVI for the first time.
    For more information about activation, refer to the Activating Your Software topic in the LabWindows/CVI Help.
    NoteIf you are unable to activate LabWindows/CVI, refer to the web page at ni.com/activate.
    After Installation
    • Installing LabWindows/CVI in a New Directory—If you installed driver or toolkit software for LabWindows/CVI 8.1.1 or earlier and you install LabWindows/CVI 2012 SP1 in a new directory, you must uninstall and reinstall the LabWindows/CVI portion of the driver or toolkit software.
    • Using Example Programs—You can find example programs in the following location on Windows 8/7/Vista/Server 2008: \Users\Public\Documents\National Instruments\CVI2012\samples. On Windows XP/Server 2003, example programs are located in the following location: \Documents and Settings\All Users\Documents\National Instruments\CVI2012\samples.
    • Working with Project and File Templates—Save user-defined project and file templates in the LabWindows/CVI public documents directory (\Users\Public\Documents\National Instruments\CVI on Windows 8/7/Vista/Server 2008 and \Documents and Settings\All Users\Documents\National Instruments\CVI on Windows XP/Server 2003). LabWindows/CVI 8.5 and later does not search previous locations, \Documents and Settings\All Users\Application Data\CVI and \Documents and Settings\\Application Data\CVI, for project and file templates.
    • Making Backup .uir Files—Make backup copies of your .uir files if you have been using previous versions of LabWindows/CVI. Once you save .uir files in LabWindows/CVI 2012, the .uir files are no longer compatible with versions 8.1.1 or earlier. You cannot load .uir files that you have saved in LabWindows/CVI 2012 in LabWindows/CVI 8.1.1 or earlier.
      You can save .uir files you create or load in LabWindows/CVI 2012 in earlier formats. Select File»Save .uir As and specify the format in the Save as type option. If you save a user interface with features that were added in later versions of LabWindows/CVI, those features are removed when you save the file in earlier formats.
    • The Physical Memory Access functions, located in the Utility Library, are deprecated. Refer to KB 5QCCQSQW for more information.
    • If your program includes any Port IO functions, located in the Utility Library, the program will require administrator privileges to run. Refer to KB 5Q5FO1QW for more information.
    • The LabWindows/CVI low-level support driver can be loaded only by applications running with administrator privileges on 32-bit systems. Refer to KB 5Q5FJ4QW for more information.
    • You can no longer create a reduced-size distribution that includes the low-level support driver. If your application uses the low-level support driver, you must include the full LabWindows/CVI Run-Time Engine in your installer. To include the full run-time engine in your installer, complete the following:
      • Select the NI LabWindows/CVI Shared Run-Time Engine item in the Drivers & Components tab of the Edit Installer dialog box.
      • Ensure that you deselect the Install the LabWindows/CVI Shared Run-Time Engine in the application directory option in the Advanced tab of the Edit Installer dialog box.
      Refer to KB 5R6A4SQW for more information.
    • The GetFontTypefaceName function, when used on VAL_DIALOG_FONT or VAL_DIALOG_META_FONT, now returns the actual typeface of the dialog font on your system, rather than the substitute for that font that Windows uses.
    • LabWindows/CVI 2012 supports the Perforce SCC Plug-in (P4SCC) 2006.1 and later.
    • For projects you save in LabWindows/CVI 2012, LabWindows/CVI attempts to resolve paths that were previously saved as absolute paths to be relative to the project. You can override this behavior by specifying the following options in the .prj file:
      For a target file, specify the following in the [Create Executable] section of the .prj file:
      Executable File_Configuration Force Path Absolute = True
      where _Configuration is the configuration of your target, such as Debug, Release, or Debug64.
      For a file in the project list, specify the following in the [File nnnn] section of the .prj file, where nnnn is the index of the file in the project list:
      Path Force Path Absolute = True
    • You can call .NET Library functions from multiple threads simultaneously without getting blocked.
    • Previous versions of LabWindows/CVI did not recognize numbers entered in scientific notation for numeric controls of type int64 or unsigned int64. Starting with LabWindows/CVI 2010 SP1, you can enter numbers in scientific notation. When you enter a number in scientific notation into numeric controls of type int64 or unsigned int64, LabWindows/CVI converts the number to a double and then to a 64-bit integer. This conversion may cause a loss of precision after 15 decimal digits.
    • LabWindows/CVI 2010 SP1 includes the GaussHypergeometric function, which you should use instead of the GaussHG function.
    • Build Options and Target Settings dialog box options apply per configuration. The options on these dialog boxes are no longer global as in previous releases.
    • National Instruments no longer supports Windows 2000.
    • The minimum operating system version for distributions is Windows XP. If you open an existing distribution that specifies Windows 2000 as the minimum operating system, LabWindows/CVI updates the minimum operating system to Windows XP.
    • If you install the Full Development System, the Interface to Win32 Application Programmatic Interface (API) is installed by default.
    • The glaux.lib import library is deprecated and is no longer included with LabWindows/CVI. The glaux.prj sample program is no longer installed.
    • The Save changes before debugging option in the Environment dialog box is now a global option. In previous releases, this option was workspace-specific.
    • The Save changes before compiling option in the Environment dialog box is enabled by default. This global option allows LabWindows/CVI to save all modified files before compiling and debugging.
    • LabWindows/CVI no longer installs the Documentation from MSDN Library. National Instruments recommends that you view the latest version of this documentation at www.msdn.com. For more information, visit ni.com.
    • The LabWindows/CVI Help includes a Font button that you can use to increase or decrease the font size in the help file. The Font button might not update the font size in help files that merge into the LabWindows/CVI Help.
      In addition, the smallest font size setting of the Font button is the standard font size for National Instruments help files. The text size settings in Internet Explorer might cause the font to appear larger than typical National Instruments help files. If you resize the font, the help file retains the font size the next time you open the product help.
    • Borland is no longer supported as a compatible compiler or as a third-party compiler in LabWindows/CVI.
    • Starting with the 2009 version of LabWindows/CVI, major versions align with the year in which they release. For example, this version of LabWindows/CVI is called LabWindows/CVI 2012. You can find installed files in the CVI2012 folder in the various locations where LabWindows/CVI installs files. The registry keys corresponding to this version of LabWindows/CVI are located in CVI\12.0 in the registry.
    • The NI Distributed System Manager replaces the NI Variable Manager. Use the System Manager to create and monitor network variables, processes, and I/O servers. For more information about the System Manager, refer to the NI Distributed System Manager Help, which you can access from the System Manager.
    • The Translate LW DOS Program option is no longer available.
    • The LabWindows/CVI compiler now defines the NDEBUG macro for release configuration builds.
    • LabWindows/CVI no longer adds _dbg suffix to the base name of the debug target of a project.
    • The data type of the targetThreadId parameter of the PostDeferredCallToThread and PostDeferredCallToThreadAndWait functions has been changed from unsigned long to unsigned int.
    • toolbox.h now includes some LabWindows/CVI headers that must be included after including windows.h. Therefore, if your code includes toolbox.h before including windows.h, reverse the order of these includes.
    • Network variable processes that begin with NI_ are disallowed. The CNVNewProcess function returns an error if the process name you specify begins with NI_.
    • The following macros have been renamed:
      LibraryPrevious Macro NameNew Macro Name
      WordReport.fp Instrument DriverNONEWR_NONE
      Analysis LibrarySORT_ASCENDINGANALYSIS_SORT_ASCENDING
      Analysis LibrarySORT_DESCENDINGANALYSIS_SORT_DESCENDING
    • Upgrading to LabWindows/CVI 8.5 and later may cause the Advanced Analysis or Analysis Library to produce numerical differences in floating point results and different results for exceptional inputs, such as positive or negative infinity and NaN. These differences may occur because the underlying C Analysis library has been recompiled in LabWindows/CVI 8.5 to take advantage of new processors and operating systems.
    • The enum value CVIConst_CVI_FPVERSION_90 has been changed to CVIConst_CVI_FPVERSION_85 for the fpVersion parameter of the FPGenCreateFunctionTree function of the LabWindows/CVI ActiveX Server Interface Library.
    • The modini utility and related source code as well as the modreg source code are deprecated and no longer installed with LabWindows/CVI.
    • The LabWindows/CVI Quick Reference card is no longer published and is not installed with LabWindows/CVI.
    • The option to create Microsoft Windows WinHelp files (.hlp) from LabWindows/CVI, Generate»Documentation»Windows Help, is no longer available.
    • The Network Variable Library flushes all internal buffers in a write operation, which improves network variable performance.
      Flushing on write may cause lower throughput in some high bandwidth conditions, in which case you can set CNVFlushOnWriteAttribute to 0 (FALSE). In high bandwidth conditions, National Instruments recommends using the CNVBufferedWriter connection.
    • During a read operation, the Network Variable Library flushes all network variable connections in your program, including data in writer connections, for better performance.
    • Registering ActiveX Servers—When you build ActiveX servers in LabWindows/CVI 8.1.1 and later on Windows XP and later, the ActiveX servers are registered in your user profile. This registration is not visible to other users on your system. On versions of Windows prior to Windows XP, ActiveX servers are registered for all users. When you register these servers outside the LabWindows/CVI environment, they are always registered for all users; this option requires administrator privileges on Windows Vista and later.
        In LabWindows/CVI 7.1 and earlier, CxSVD has the following requirement: If numberOfRows (n) < numberOfColumns (m), you must allocate m*m*sizeof(ComplexNum) bytes of memory to the input matrix and the U orthogonal matrix. LabWindows/CVI 8.x and later no longer has this requirement.
      • CxTrace—CxTrace accepts only a square matrix. In LabWindows/CVI 7.1 and earlier, the function requires both the number of rows and the number of columns as input parameters. In LabWindows/CVI 8.x and later, matrixSize specifies both the number of rows and the number of columns. The numberOfColumns parameter in LabWindows/CVI 7.1 and earlier is a reserved parameter in LabWindows/CVI 8.x and later. This parameter is not referenced in the function.
    This version of LabWindows/CVI has the following known issues. For additional known issues, refer to ni.com.
    • Selecting Values in IviFgen Class Driver—In the IviFgen FP file, the Attribute ID and Attribute Value controls in the Get/Set/CheckAttributeViInt64 functions display an empty field instead of a list of attributes and values. For more information, refer to KnowledgeBase 5WOA752F: Issue Setting IviFgen Attribute ID Using Get/Set/CheckAttributeViInt64 Functions.
    • Error When Building a LabWindows/CVI Project in Visual Studio 2005—If you create a project in Visual Studio 2005 that uses LabWindows/CVI libraries, you will see the following error: fatal error LNK1103: debugging information corrupt; recompile module. To address this issue, install the hotfix available from Microsoft.
    • Debugging Executables on Windows—On Windows Vista and later, executables that contain setup, install, or update as part of their name automatically require administrator privileges. If you run these executables as stand-alone from a user-level account, Windows will prompt you for an administrator password. However, LabWindows/CVI cannot debug these applications from a user-level account. When you try to run them, LabWindows/CVI displays a Could not run executable notification. NI recommends that you rename your executable so that it does not contain those words in its name, or that you embed a manifest into the application that marks the application as being Vista-aware. You can embed a manifest using the Target Settings dialog box.
    • Using the LabWindows/CVI Conversion Wizard in Microsoft Visual Studio—Microsoft Visual Studio 2005 and later do not support the single-threaded version of the Visual Studio C library. Therefore, you must configure your project's linker settings to ignore directives to use the single-threaded C library. In Visual Studio, select Project» Properties and expand the properties tree to the Configuration Properties»Linker»Input item. Add libc to the Ignore Specific Library option. Refer to the I Receive Linker Errors When Using LabWindows/CVI-Generated Static Libraries and Object Files in Microsoft Visual Studio 2005 KnowledgeBase article for more information.
    You can access the software and documentation bug fix list on ni.com. Refer to the LabWindows/CVI Bug Fix Information web page for an up-to-date list of bug fixes in LabWindows/CVI 2012 SP1.
    Using NI Launcher
    Note  Unlike previous versions of Microsoft Windows, MAX does not appear as a desktop shortcut. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    Important Information
    © 1993–2013 National Instruments. All rights reserved.
    GMT+8, 2026-2-27 13:32
