查看: 3606|回复: 1
[LV工具模块] NI ECU Measurement and Calibration Toolkit 20.6 Win32/64Eng NI电子控制单元测量和校准工具包ECUMC20.6下载
    发表于 2020-12-11 23:26:57 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    ECU测量和校准工具包
    ECU测量和校准(ECUMC)工具包用于为电子控制单元(ECU)设计和验证提供测量和校准。
    ECU测量和校准工具包是LabVIEW、LabWindows/CVI和Microsoft C/C ++编程环境的软件附件。该软件支持通用测量和校准协议(Universal Measurement and Calibration Protocol,XCP)及CAN校准协议(CAN Calibration Protocol,CCP),提供了许多高级且易用的函数。这些协议可让用户可根据ASAM (.A2L)数据库文件的定义,读写内部ECU变量及特性。通过(.A2L)数据库文件,工具包自动应用所有换算信息并以工程单位返回数据,便于简单地分析、演示及记录。此外,该工具包还提供了常见应用的示例,例如使用一维到三维用户界面来测量ECU变量或控制ECU特性。LabWindows标志经Microsoft公司授权使用。Windows是Microsoft公司在美国和其他国家的注册商标。
    20.6
    文件大小: 1086724096 字节 (1.01 GB)
    修改日期: 2020-12-09 08:07
    MD5: 8b7c30249598c99d5b30482c6e284d0b(官方正确)
    SHA1: c1c0c855f7d886878ea2ad74c55f0d7b563dbc7e
    SHA256: 7a52a04ef4e61a7dff47d0bcc22739f8715d912cb8439eda7efb974a8958a01f
    CRC32: 2c30fd1b
    ECUMC20.6.txt (642 Bytes, 下载次数: 3, 售价: 10 圆)
    ECU Measurement and Calibration Toolkit 20.6 Readme
    October 2020
    This file contains information about the ECU Measurement and Calibration Toolkit software.
    ECU Simulator
    XCP/CCP Custom Device for NI VeriStand
    Using LabVIEW Real-Time
    Using NI-XNET with the ECU Measurement and Calibration Toolkit
    Additional Programming Topics and Known Issues
    The ECU Measurement and Calibration Toolkit provides full-featured APIs, plus tools for viewing ASAM A2L database files and analyzing CCP and XCP communication. The ECU Measurement and Calibration APIs enable you to develop applications that are customized to your test and simulation requirements.
    ECU Measurement and Calibration Toolkit 20.6 supports the following operating systems:
    • Windows Server 2008 R2 SP11 (64-bit, not supported on Server Core Role)
    Note  In 2016, NI dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. ECU Measurement and Calibration Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use ECU Measurement and Calibration Toolkit to an unsupported OS. Additionally, after installing this version of ECU Measurement and Calibration Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    ECUMC Toolkit Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    ECU Measurement and Calibration Toolkit will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, please visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, please visit ni.com/r/b7g5wi.
    This version of the ECU Measurement and Calibration Toolkit supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by ECU Measurement and Calibration Toolkit 20.6
    LabVIEW2017 SP1, 2018 SP1, 2019 SP1, and 2020 SP1
    LabVIEW Real-Time Module2017, 2018 SP1, 2019, and 2020
    LabWindows™/CVI™2015 and later
    NI VeriStand2017, 2018 SP1, 2019 R3, and 2020 R4
    Microsoft Visual C/C++2008 and later
    Note  ECU Measurement and Calibration Toolkit software does not support LabWindows™/CVI™ Real-Time Module.
    If you are using the ECU Measurement and Calibration .NET Class Library, .NET Framework 4.0 (minimum) is required. The ECU Measurement and Calibration .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to NI .NET Support.
    NI installs ECU Measurement and Calibration Toolkit using NI Package Manager. If you do not already have NI software installed, ECU Measurement and Calibration Toolkit installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • If applicable, install an application development environment (ADE), such as LabVIEW, LabWindows/CVI, or Microsoft Visual Studio.
    • MSVC and LabWindows/CVI users should always install the MSVC Support feature. This feature installs the CCP and XCP Demo ECUs, which may be helpful if you are running ECU MC MSVC and LabWindows/CVI examples.
    New FeaturesNew Features Compared to ECU Measurement and Calibration Toolkit 20.0
    The ECU Measurement and Calibration Toolkit 20.6 release adds the following features:
    • Added support for XCP protocol on the XNET IP Stack in NI-XNET.
    • Added support for LabVIEW 2020 SP1.
    • Added support for LabWindows/CVI 2020.
    • Added support for VeriStand 2020 R3.
    New Features Compared to ECU Measurement and Calibration Toolkit 19.5
    The ECU Measurement and Calibration Toolkit 20.0 release adds the following features:
    • Added support for LabVIEW 2020.
    • Added support for VeriStand 2020.
    New Features Compared to ECU Measurement and Calibration Toolkit 19.0
    The ECU Measurement and Calibration Toolkit 19.5 release adds the following features:
    • Added support for LabVIEW 2019 SP1.
    • Added support for VeriStand 2019.
    • Added support for PXIe-8522 4-port, 1000BASE-T1 Automotive Ethernet Interface.
    • Added support for PXIe-8523 4-port, 100/1000BASE-T1 Automotive Ethernet Interface.
    New Features Compared to ECU Measurement and Calibration Toolkit 18.5
    The ECU Measurement and Calibration Toolkit 19.0 release adds the following features:
    • Added support for LabVIEW 2019.
    • Added support for LabVIEW Linux PXI RT.
    • Added support for LabWindows™/CVI™ 2019.
    • Added the ability to select non-primary NICs.
    • Added support for XCPplus protocol.
    • Added support for the PXIe-8521 4-port, 100BASE-T1 PXI Automotive Ethernet Interface Module.
    • Added support for installation through NI Package Manager.
    • Removed support for LabVIEW 2015.
    • Removed support for LabWindows™/CVI™ 2012 and 2013 (without SP1).
    • Removed support for VeriStand 2015.
    • Removed support for NI-CAN 15.0.
    • Removed support for NI-XNET 15.0.
    New Features Compared to ECU Measurement and Calibration Toolkit 18.0
    The ECU Measurement and Calibration Toolkit 18.5 release adds the following features:
    • Added support for LabVIEW 2018 SP1.
    • Added support for NI VeriStand 2018 and 2018 SP1.
    • Added support for ECU Determined CAN I/O Mode​. The CAN I/O Mode can be set to "ECU Determined" to use XCP ECUs with CAN 2.0 or CAN FD.
    • Added support for Selectable Timing Source for XCP​. This allows synchronization of time with either the ECU, CAN (DAQ), or host.
    • Added support for 64-bit integer. The 64-bit integer characteristic and measurement can be handled without precision loss.
    • Added support for String characteristics. Improves the handling of ASCII characteristics.
    • Added IP Source Port property. The new property XCP IP Source Port enables defining the source port (XCP master port) when Ethernet protocol is used. API only, not supported in NI VeriStand.
    This version of the ECU Measurement and Calibration Toolkit software supports the following software and hardware:
    • NI-CAN software version 16.0 or later
    • NI-CAN hardware supported by NI-CAN 16.0
    • NI-XNET software version 16.0 or later
    • NI-XNET CAN hardware supported by NI-XNET 16.0 and later3
    • NI-XNET Automotive Ethernet hardware supported by NI-XNET 19.0 and later
    • CompactRIO and R-Series hardware using NI 9852/9853 two-port CAN modules for NI CompactRIO (we recommend using NI 986x on NI CompactRIO instead of NI 985x)
    3 You can address NI-XNET Automotive Ethernet devices using their assigned IP addresses. To use a specific interface name (e.g., ENET1) together with a custom IP configuration, you can use an XNET IP Stack from ECUMC. The IP Stack feature requires NI-XNET 20.1 or later.
    Note  ECU Measurement and Calibration Toolkit software supports only NI Automotive Ethernet and CAN hardware products. For information about software for Automotive Ethernet and CAN hardware products from other vendors, refer to the documentation you received with those products.
    ECU Simulator
    The ECU Measurement and Calibration Toolkit software simulates two types of ECUs. All ECU Measurement and Calibration Toolkit examples are preconfigured to communicate with the ECUMC Demo ECU XCP simulation using the ASAM 2MC XcpECU.a2l file.
    Most of the examples can be used with the ECUMC Demo ECU CCP simulation. In that case, please, use the CCPECU.A2L file and the related protocol token "CCP:CANx".
    LabVIEW users can find the ECU simulators, seedkey DLLs, and corresponding A2L files at \\examples\ECUMC. Please, use the "XCPECU.llb\ECUMC Demo ECU XCP.vi" or "CCPECU.llb\ECUMC Demo ECU CCP.vi".
    Microsoft Visual C/C++ and LabWindows/CVI users can find the ECUMC Demo ECU simulators (only 32-bit), seedkey DLLs, and corresponding A2L files at
    • "\ECU Measurement and Calibration Toolkit\ECUMC Demo ECU XCP", or
    • "\ECU Measurement and Calibration Toolkit\ECUMC Demo ECU CCP".
    LabWindows/CVI users may refer to copies of the A2L files and seedkey DLLs provided within the CVI examples folder.
    Refer to the XCP/CCP Custom Device online help for information about using the NI XCP/CCP Custom Device with VeriStand.
    Upgrade Note: If you are upgrading your XCP/CCP Custom Device from the already-installed NI Developer Zone download, you need to clear the XCP/CCP controls from the NI VeriStand project temporary screen files directory. VeriStand projects created with an older VeriStand version must be converted to the new version by loading the project in System Explorer and saving it. When loading an older project into a newer VeriStand revision, a message shows up informing about missing Driver VI files. This message can be ignored and skipped.
    Upgrading Existing VeriStand System Definitions from a Previous Custom Device Version: You must migrate system definitions created with an earlier version of the XCP/CCP custom device to the current version before you can use them. Therefore, open and save the system definition file in the System Explorer.
    The CCP/XCP on CAN communication introduces higher busloads on the CAN network: If you are using CCP or XCP on CAN, the NI VeriStand Custom Device can add flexible configurations for reading and writing Characteristics and Measurements from the ECU. It is allowed running multiple Characteristic as well as Measurement read or write tasks in parallel. If you set up such a complex system, every task introduces some amount of busload onto the CAN network, because those CCP/XCP commands are based on a handshake protocol. If you run the CCP/XCP on CAN a protocol to its limits, the introduced busload on the CAN network increases significantly, and the ECU may not respond in the predefined time anymore. The reason is that there may not be enough free network bandwidth. In such cases, we recommended analyzing the CAN busload on the CAN network and trying to keep CAN traffic below values of 60% to 70%, to keep the network in an operable state. A typical indicator of running into such CCP/XCP on CAN protocol limits is a timeout error when executing a Characteristic/Measurement read or write operation. Therefore, we recommend checking the XCP/CCP Custom Device error status variable, whether the error 0xFFFB67FE "A timeout occurred waiting for a response from the ECU" occurs.
    Using LabVIEW Real-Time (RT)
    To use the ECU Measurement and Calibration Toolkit on a LabVIEW RT system, you must download your ASAM 2MC database (*.A2L) file to the RT target. The LabVIEW Real-Time Engine running on a PXI or CompactRIO system supports a File Transfer Protocol (FTP) server. You can access the LabVIEW RT target FTP server using any standard FTP utility for transferring files to and from the hard drive. For further information about how to download your A2L file to the RT target, refer to LabVIEW Real-Time (RT) Configuration in the ECU Measurement and Calibration Toolkit Help.
    If you are using NI hardware that is supported by NI-XNET, it is recommended that you use NI-XNET 19.5 or later with this version of ECU Measurement and Calibration Toolkit.
    CAN FD support with the ECU Measurement and Calibration Toolkit
    CAN FD features are only supported with NI-XNET version 17.0.1 or later.
    NI does not recommend cRIO-901x and cRIO-902x targets for CAN FD.
    Custom baud rate for CAN in NI VeriStand is only supported with NI-XNET version 18.0 or later.
    ECU Measurement and Calibration Toolkit 18.5 supports CCP Version 2.1.
    ECU Measurement and Calibration Toolkit 18.5 does support symbolic conversion tables for reading only. Refer to mcDoubleToText for further information.
    NI-I/O Trace monitors function calls to the ECU Measurement and Calibration Toolkit API. This tool helps in debugging programming problems in the application. To launch this tool, open Tools in MAX, and select NI-I/O Trace. If more than one NI driver is installed on your computer, you can specify which APIs to trace at any time. By default, all installed APIs are enabled. To select the APIs to trace, select Tools»Options, select the View Selections tab, and select the APIs under Installed API Choices.
    The following LabVIEW example VIs do not run under LabVIEW Real-Time and LabVIEW Base Development System:
    • Edit a characteristic.vi
    • Measurement and Calibration Application.vi
    To make these examples run, remove the subVI call from 3DDisplayWrapper.vi in MCCharacteristicsEditors.llb.
    If you are using an NI USB-8473 or NI USB-8473s, the ECU Measurement and Calibration Toolkit is based internally on the NI-CAN Frame API. For this reason, the following properties are not available for the GetProperty function:
    • CRO Task (mcPropCRODAQ_DTO_Task)
    • DTO Task (mcPropDAQ_DTO_Task)
    • SamplesPending (mcPropDAQ_SamplesPending)
    The LabVIEW project examples for CompactRIO and R-Series are configured for use with NI 985x C-Series only.
    The ECU Measurement and Calibration ECU Simulators (ECU MC Demo ECU XCP or CCP) are not supported under CompactRIO.
    The Basic Examples and some advanced examples are not supported under cRIO using XCP/TCP and XCP/UDP. To use these examples, you need to modify the communication parameters such as the IP Address.
    The behavior of mcDAQListInitialize has changed. It now returns an error (NoMoreDAQLists) if the requested DAQ list cannot be assigned. Prior to this change, ECU MC attempted to automatically assign a different DAQ list, but the new DAQ list might have different properties than the requested one and thus cause undesired behavior.
    Property DAQ:XCP:Meas Split Allowed was moved to ECU:XCP:Meas Split Allowed in the Set Property and Get Property VIs. Existing VIs that use this property will continue to work without any changes.
    XCP supports only DAQ that has a CAN identifier of DTO_ID.
    The following ASAM MCD-2MC (A2L) database features are not supported:
    • Formulas in ASAM MCD-2MC version 1.6 or later. Often used formulas such as linear scaling are not affected.
    • MATRIX_DIM keyword defining multidimensional measurements.
    • MATRIX_DIM keyword defining characteristics with more than 2 dimensions.
    • MATRIX_DIM keyword in ASAM MCD-2MC version 1.7 or later.
    You can access the software and documentation known issues list online. Visit ECUMC Known Issues for an up-to-date list of known issues.
    You can access the ECU Measurement and Calibration Toolkit 20.6 bug fix list online at ECUMC 20.6 Bug Fixes. This list describes a subset of issues fixed in this release. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    Refer to the ECU Measurement and Calibration Toolkit Help, accessible from \Users\Public\Documents\National Instruments\ECU Measurement and Calibration Toolkit\Documentation, for information about the ECU Measurement and Calibration Toolkit.
    The help includes an introduction to the CAN Calibration Protocol (CCP) and Measurement and Calibration Protocol (XCP). It also explains how to get started with application development and includes a complete reference for all ECU Measurement and Calibration Toolkit functions.
    You can automate the installation of most NI products using commandline arguments to suppress some or all of the installer user interface and dialog boxes.
    © 2009–2020 National Instruments. All rights reserved.
    377542F-01
    发表于 2022-3-8 20:22:07 | 显示全部楼层 来自:江苏省徐州市 联通
    GMT+8, 2025-12-8 07:35
