查看: 8000|回复: 2
[NI驱动程序] NI Vision Acquisition Software 20.6 Win32/64Eng 视觉采集软件VAS20.6 适用LabVIEW2020SP1/VDM2020SP1
    发表于 2020-12-14 23:40:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    视觉采集软件属于驱动程序软件,用于采集、显示和保存各类相机的图像。NI视觉采集软件(VAS)使您能够采集、显示和保存各种行业标准相机(包括Gige Vision、USB3 Vision和Camera Link)的图像。您还可以使用此软件轻松地控制NI视觉硬件上的数字I/O。借助一套易于使用的函数和示例程序,您可以使用LabVIEW、LabVIEW NXG和C/C ++快速创建应用程序。VAS视觉采集软件不同于VA视觉助手(Vision Assistant),视觉助手是VDM视觉开发包中的辅助工具,没有单独的安装包,安装VDM时可选择视觉助手安装。
    视觉采集软件20.6
    发布日期:
    20-12-7
    包含的版本:
    20.6.0
    Windows 10 (32- and 64-bit)
    Windows 10 IoT Enterprise LTSB 2016 (64-bit)3
    Windows 8.1 (32- and 64-bit)1
    Windows 7 SP1 (32- and 64-bit)2
    Windows Embedded Standard 7 SP1 (32- and 64-bit)2,3
    Windows Server 2016 (64-bit)1
    Windows Server 2012 R2 (64-bit)1
    Windows Server 2008 R2 SP1 (64-bit)2
    语言:
    英文
    离线安装版校验和(安装完成请做校验和,以确定下载正确性,如下载不正确可能无法安装):
    文件大小: 4493787136 字节 (4.19 GB)
    修改日期: 2020-12-08 08:08
    MD5: bde8a461170d5fab7e3afab82169e5a6(官方正确)
    SHA1: a3d83da43af4a76c2c288154673410532cddb797
    SHA256: d27bc438b8d650ca5cc3c85bd0d0074bada19b1df2ed2a4bff0c07be9630ab96
    CRC32: 82a7cf87
    下载地址:
    百度网盘下载(百度网盘非会员限速,可以使用一些破解器下载以提高下载速度):
    离线安装版本:
    请注册视觉论坛会员登录后购买附件下载查看
    NI离线安装版本(如果网络不受限制,建议使用NI的离线地址下载,速度较快;但是如果网络受限,则可能无法下载完成;地址亦或失效):
    VAS20.6.txt (653 Bytes, 下载次数: 74, 售价: 10 圆)
    NI Vision Acquisition Software 20.6 Readme
    December 2020
    This file contains important information about NI Vision Acquisition Software, including installation instructions, new features, fixed issues, and known issues.
    Vision Standards Support
    Deprecated Features
    Updates and Improvements
    Configuring NI-IMAQ
    Configuring NI-IMAQdx
    Documentation and Examples
    NI Vision Acquisition Software Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    LabVIEW NXG Considerations
    NI Vision Acquisition Software (VAS) allows you to acquire, display, and save images; control digital I/O on NI image acquisition devices; and configure your driver software and hardware.
    For information about licensing NI Vision software, visit ni.com/info and enter the Info Code LicenseVision. Refer to the NI Vision website at ni.com/vision for the latest information about NI Vision Acquisition Software.
    NI Vision Acquisition Software includes the following drivers:
    • NI-IMAQ is driver software for Camera Link cameras.
    • NI-IMAQdx is driver software for the following device types:
      • Camera Link cameras in Windows using supported frame grabbers:
        • PCIe-1427
        • PCIe-1433
        • PCIe-1437
        • PXIe-1435
      • ISC-178x smart cameras
      • GigE Vision-compliant cameras
      • USB3 Vision-compliant cameras
      • DirectShow-compatible cameras (Windows), UVC-compliant webcams (Linux RT)
    • NI-IMAQ I/O Driver Software that helps you program reconfigurable frame grabbers with LabVIEW FPGA and helps you program DIO without LabVIEW FPGA for Compact Vision Systems, Industrial Controllers, and other PCIe-based devices using the Vision RIO API.
      • Reconfigurable Frame Grabbers (requires LabVIEW FPGA):
        • PCIe-1473
        • PCIe-1477
        • NI 1483 FlexRIO Adapter Module
      • Devices supporting the Vision RIO API:
        • CVS-1458
        • CVS-1458RT
        • CVS-1459
        • CVS-1459RT
        • IC-3120
        • IC-3121
        • IC-3171
        • IC-3172
        • IC-3173
        • PCIe-8237
        • PXIe-8246
      • Note: LabVIEW FPGA can optionally be used to reconfigure the FPGA on Vision RIO devices, but only DIO functions are available for external connections.
    • Note: New versions of Vision Acquisition Software no longer support the following hardware:
      • NI 17xx and NI 177x Smart Cameras
      • NI EVS-1463, -1463RT, -1464, and -1464RT Embedded Vision Systems
      • NI CVS-1454, -1455, -1456, and -1457RT Compact Vision Systems
      • Analog cameras
      • Parallel digital cameras
      • Basler and Axis IP cameras
    • Note: New versions of Vision Acquisition Software no longer support the following real-time operating systems:
      • VxWorks
      • Phar Lap ETS (with the exception of NI 1483 modules, and GigE Vision-compliant cameras on PXI systems via the NI-IMAQdx driver)
    Additional Driver Software
    Some hardware requires driver software in addition to Vision Acquisition Software drivers. Refer to the NI website at ni.com/drivers for information about these drivers.
    • The NI PCIe-1473R and NI PCIe-1473R-LX110 require NI FlexRIO software to access the DRAM resources in a LabVIEW FPGA project.
    • The NI 1483 FlexRIO Adapter Module requires NI FlexRIO software.
    • The IC-312x and IC-317x industrial controllers require NI Industrial Controller Device Drivers to access FPGA resources and to discover remote real-time targets in NI Meaurement & Automation Explorer (MAX).
    The development computer must meet the following requirements to run NI Vision Acquisition Software:
    Processor
    Pentium 4 1 GHz or equivalent
    Memory
    512 MB RAM
    Display
    Minimum Recommended
    Free Hard Disk Space
    4.8 GB
    NI-IMAQ
    3.1 GB
    NI-IMAQdx
    4.1 GB
    NI-IMAQ I/O
    3.7 GB
    Operating System
    • Windows 10 (32- and 64-bit)
    • Windows 10 IoT Enterprise LTSB 2016 (64-bit)3
    • Windows 8.1 (32- and 64-bit)1
    • Windows 7 SP1 (32- and 64-bit)2
    • Windows Embedded Standard 7 SP1 (32- and 64-bit)2,3
    • Windows Server 2016 (64-bit)1
    Note  NI Vision Acquisition Software August 2016 dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI Vision Acquisition Software August 2016 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI Vision Acquisition Software August 2016 or later to an unsupported OS. Additionally, after installing NI Vision Acquisition Software August 2016 or later, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 or KB3125574 for more information about how to install these updates.
    3Only supported as pre-installed on NI hardware.
    The following table lists the NI application software versions, including service packs, supported by NI Vision Acquisition Software. The installer specifically allows side-by-side installations of NI Vision Acquisition Software for each of the supported versions of LabVIEW, enabling you to use NI Vision Acquisition Software with multiple versions of LabVIEW. NI recommends that you install LabVIEW, LabVIEW Real-Time, and any other supported development environment before installing NI Vision Acquisition Software.
    NI Application SoftwareVersions Supported by NI Vision Acquisition Software
    NI LabVIEW
    2017, 2018, 2019, 2020
    NI LabVIEW Real-Time Module
    NI LabVIEW FPGA Module
    NI LabVIEW NXG
    5.1
    NI LabWindows™/CVI™
    2015, 2017, 20191
    NI Vision Development Module
    7.1 or later
    NI Vision Builder for Automated Inspection
    2.5 or later
    1 NI-IMAQ I/O is not supported in NI LabWindows™/CVI™.
    NI Vision Acquisition Software .NET Support
    NI Vision Acquisition Software February 2014 was the last version to release updated support for the .NET Framework 2.0, .NET Framework 3.5, and .NET language integration into Visual Studio 2005 and Visual Studio 2008. Visual Studio 2010 and later are not supported.
    Development and runtime support for .NET driver features are no longer included as of NI Vision Acquisition Software 19.0 and later
    The following table lists the machine vision and imaging standards supported by NI Vision Acquisition Software.
    Machine Vision or Imaging StandardVersion Supported by NI Vision Acquisition Software
    Camera Link®
    2.1
    GenICam™
    3.1
    GigE Vision®
    2.0 (select features)
    USB3 Vision®
    1.0.1
    This release of NI Vision Acquisition Software includes the following new features.
    NI-IMAQ 20.6
    • Added support for LabVIEW 2020
    NI-IMAQdx 20.6
    • Added support for LabVIEW NXG 5.1
      • For information about VAS support in LabVIEW NXG, visit ni.com/info and enter the Info Code VisionNXGGuide.
    • Added support for GigE Vision cameras, USB3 Vision cameras, and USB webcams on PXI systems running Linux RT.
    • Added support for PXIe-8246 frame grabbers
    NI-IMAQ I/O 20.6
    Deprecated Features
    • NI-IMAQ 20.6
      • Removed support for LabVIEW 2016
    • NI-IMAQdx 20.6
      • Removed support for LabVIEW NXG 4.0, 5.0
      • Removed support for IIDC/DCAM-compliant IEEE 1394 cameras
      • Removed support for PCI/PXI/PCIe-825x frame grabbers
    • NI-IMAQ I/O 20.6
      • Removed support for PCI-8254 and PCIe-8255 frame grabbers
    Refer to the NI Website for an up-to-date list of all bug fixes in this release.
    You can access the software and documentation known issues list online. Refer to the NI Web site for an up-to-date list of known issues in NI Vision Acquisition Software.
    The following list contains potential high severity issues that you may want to review before using this product. Refer to the previous link to determine if any known issues have been resolved in a subsequent update.
    • Installing or reinstalling certain drivers, including NI-IMAQdx or Vision RIO support, on top of previous installations on a Linux Real-Time target can put the target in an unreachable state unless you force it into safe mode using the reset button or manually reassociate driver dependencies on the target. To avoid this issue, format the target prior to installing or reinstalling software, or only perform reinstallations using a Recommended Software Set. To learn more about this issue and additional recovery options, visit ni.com/info and enter the Info Code nikalEmbeddedReinstall.
    Complete the following steps to install NI Vision Acquisition Software.
    Note: You must have administrator access to install NI Vision Acquisition Software.
    • Insert the NI Vision Acquisition Software installation media.
    NI-IMAQ and NI-IMAQdx integrate with NI Measurement & Automation Explorer (MAX), the NI utility for configuring and testing your measurement and automation system. The NI MAX icon appears on your desktop after you install NI Vision Acquisition Software.
    Configuring NI-IMAQ
    Complete the following steps to install an image acquisition device and configure NI-IMAQ.
    • Run NI MAX.
      • Double-click the NI MAX icon on the desktop. You can use NI MAX to modify camera properties. Once you have saved these properties, they become the default settings for all NI-IMAQ applications.
      • Expand Devices and Interfaces to display a list of the image acquisition devices installed on your computer.
    Note: Refer to the right side of the MAX user interface, which displays context-sensitive help, for information about configuring image acquisition devices with NI MAX.
    Configuring a Remote PXI/Compact PCIe Image Acquisition Device
    Beginning with Vision Acquisition Software 19.0, NI-IMAQ Real-Time is not included for installation. However, you can still interact with remote real-time targets that have been set up using previous versions of NI-IMAQ and are running currently supported versions of LabVIEW Real-Time.
    Note: Install NI-IMAQ and the LabVIEW Real-Time Module on the remote system before you install and configure the image acquisition device. Follow the steps in the NI MAX help window to install software.
    • Launch NI MAX.
    • Expand NI-IMAQ Devices.
    Refer to the Measurement & Automation Explorer Help for NI-IMAQ for information about configuring specific NI image acquisition devices. You can access this help file from the NI MAX Help menu by selecting Help»Help Topics»NI Vision»NI-IMAQ.
    Complete the following steps to configure NI-IMAQdx.
    If you are using a USB webcam or other DirectShow-compatible camera, ensure that the camera driver is installed and functioning. For specific information about drivers and camera compatibility, consult your camera manufacturer documentation.
    Instructions for configuring an USB3 Vision, GigE Vision, or IP camera are included in the Measurement & Automation Explorer Help for NI-IMAQdx. You can access this help file from the MAX Help menu by selecting Help»Help Topics»NI Vision»NI-IMAQdx.
    • Install the NIC.
    • Choose Browse my computer for driver software.
    • Browse to the driver location. The newest driver version is installed to \NI-IMAQdx\Staging\NI GigE Vision.
    • Click Next.
    • Click Close.
    NI-IMAQdx will work with any standard gigabit Ethernet NIC. To use NI-IMAQdx with a standard gigabit Ethernet NIC, complete the following steps.
    Complete the following steps to configure NI-IMAQdx for Windows.
    • Connect the camera.
    • Run NI MAX.
      • Double-click the NI MAX icon on your desktop. You can use NI MAX to modify camera attributes. After you have saved these attributes, they become the default settings for all NI-IMAQdx or NI Vision applications.
      • For USB3 Vision cameras, NI-IMAQdx may not be associated with the camera if a third-party driver is installed. If this is the case, change the associated driver by right-clicking the camera and selecting Driver»NI-IMAQdx.
    Configuring NI-IMAQdx for the LabVIEW Real-Time Module
    If you are using a Windows development machine, the LabVIEW Real-Time Module, and an RT target, complete the following steps to install and configure NI-IMAQdx.
    • Run NI MAX.
      • Configure your network settings. Refer to the Remote Systems Help in NI MAX (Help»Help Topics»Remote Systems) for instructions about configuring network settings.
    • Install NI-IMAQdx on the Real-Time target, using one of the following options:
      • Recommended Software Set on supported Smart Cameras, Compact Vision Systems, CompactRIO controllers, NI Industrial Controllers, and FlexRIO controllers
        • Click Add/Remove Software on the NI MAX toolbar to launch the LabVIEW Real-Time Software Wizard.
        • Select Vision Software, NI CompactRIO, NI Industrial Controller, or FlexRIO under the version of the LabVIEW Real-Time Module you are using.
        • Click Next.
        • Select any additional add-ons you would like to install to the target machine. For some real-time targets, such as CompactRIO controllers, NI-IMAQdx or supported camera types will appear as an add-on.
        • Click Next to begin downloading the software to the target machine. When NI MAX has finished downloading the software, it restarts the remote device.
        • Click Finish.
      • Custom installation
        • If you are given a choice of Recommended Software Sets, choose custom software installation and click Next to proceed with a custom installation.
        • Select NI-IMAQdx, as well as any additional software you would like to install on the target machine.
        • Click Finish.
    • Press to refresh the NI MAX configuration tree. Your camera should be listed in the Remote Systems list.
    Documentation and examples are installed onto your hard drive with NI Vision Acquisition Software. To view the documentation, select Start»All Programs»National Instruments»Vision»Documentation and then select the driver documentation. Some application-specific documents are installed to the application help folder, as listed in the following sections.
    Refer to the NI Product Manuals Library at ni.com/manuals for the most recent versions of product documentation.
    NI Vision Acquisition Software Documentation for NI MAX
    • You can access the Measurement & Automation Explorer Help for NI-IMAQ and the Measurement & Automation Explorer Help for NI-IMAQdx from the NI MAX Help menu by selecting Help»Help Topics»NI Vision. These documents are installed to \MAX\Help.
    NI Vision Acquisition Software Documentation for LabVIEW
    • You can access the NI-IMAQ VI Reference Help, NI-IMAQdx VI Reference Help, and NI Vision-RIO VI Reference Help from the LabVIEW Help menu.
    • NI Example Finder—Illustrates common applications you can create with NI Vision Acquisition Software. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help. Vision Acquisition Software examples for LabVIEW are installed to \examples\Vision Acquisition, where is the location LabVIEW is installed.
    NI Vision Acquisition Software Documentation for LabWindows/CVI
    • NI-IMAQ Function Reference Help—Contains reference information about NI-IMAQ functions for LabWindows/CVI.
    • NI-IMAQdx Function Reference Help—Contains reference information about NI-IMAQdx functions for LabWindows/CVI.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each function to access help for that function, control, function class, and function library. The niimaq.fp, NIIMAQdx.fp, and imaqio.fp function panels are installed to \CVI\Bin.
    • Example programs are installed to
      • C:\Users\Public\Documents\National Instruments\CVIversion\samples
    NI Vision Acquisition Software for Eclipse and other Text-based Development Environments
    • Getting Started with C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition with the NI Vision Development Module and NI-IMAQdx—Describes how to use the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition to develop an example C application using the NI Vision Development Module API and/or NI-IMAQdx, and deploy it on a Linux remote target. This tutorial outlines the basic steps required to build and deploy an example application. This document is installed to \Vision\Help.
    • To view text-based example programs, select Start»All Programs»National Instruments»Vision»Examples, and then select the driver you want to see examples for. You can also navigate to \Public\Public Documents\National Instruments.
    In LabVIEW NXG, NI-IMAQdx supports only the following:
    • Camera Link cameras used with supported frame grabbers
    For advanced camera configuration or renaming support, use NI MAX.
    Installing NI-IMAQdx for LabVIEW NXG
    LabVIEW NXG is installed using NI Package Manager. Complete the following steps to install NI-IMAQdx for LabVIEW NXG.
    • Visit ni.com/info and enter the Info Code NXGDownload to access the LabVIEW NXG download page.
    • Click Download LabVIEW NXG.
    • NI Package Manager installs, then automatically opens an installation window.
    • Select LabVIEW NXG 5.1 and NI-IMAQdx 20.6.
    • Complete the installer instructions to download LabVIEW NXG and NI-IMAQdx support for LabVIEW NXG.
    NI Vision Acquisition Software will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    LabWindows/CVIcvi_lifecycle
    © 2020 National Instruments. All rights reserved.
    375130R-01
  • 签到天数: 1 天
    发表于 2021-4-3 19:31:31 | 显示全部楼层 来自:湖南省长沙市 移动
    发表于 2025-1-20 10:18:29 | 显示全部楼层 来自:江苏省苏州市 电信
    GMT+8, 2025-12-8 00:24
