查看: 5322|回复: 0
[LV工具模块] LabVIEW Modulation Toolkit 16.0 Win32/64Eng LabVIEW调制工具包16.0
    前天 16:03
    发表于 2020-12-15 23:22:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW Modulation Toolkit 16.0 Win32/64Eng LabVIEW调制工具包2016
    LabVIEW调制工具包
    LabVIEW调制工具包为LabVIEW提供了调制信号生成和分析功能,适用于研究、设计、原型,验证和测试应用。
    LabVIEW调制工具包是LabVIEW的一个软件附件,提供了用于生成、分析、处理和可视化模拟和数字调制信号的功能和工具。该工具包可让您使用各种调制方案(包括AM、FM、PM、ASK、FSK、MSK、PSK和QAM)对信号进行调制和解调。使用LabVIEW调制工具包,您可以执行信道编码、交织编码和均衡等等高级信号处理,也可以测量频率误差、误差矢量幅度(EVM)和误码率(BER)等参数,以验证信号质量。使用LabVIEW调制工具包,您还可以应用常见的信号减损,并通过星座图、眼图和网格图等可视化工具查看信号。
    Win32/64Eng
    16.0
    文件大小: 609250896 字节 (581.03 MB)
    修改日期: 2016-07-06 19:45
    MD5: 877259c0b16deb74c47bf9ab4535af19
    SHA1: 2fe79095edc7070252ba0ac2bb19cbb427715006
    SHA256: aabeff2e6ce91c1e578ce9eeed0abf438d7a127779f912bc116ccd7a21ebab2f
    CRC32: 45be5807
    Modulation16.txt (573 Bytes, 下载次数: 2, 售价: 10 圆)
    NI LabVIEW Modulation Toolkit 16.0 Readme
    June 2016
    Thank you for using the NI LabVIEW Modulation Toolkit (MT). This file contains important information about the NI LabVIEW Modulation Toolkit and is organized into the following sections:
    Accessing VIs and Functions
    Toolkit Version Naming Changes
    Uninstalling/Modifying NI LabVIEW Modulation Toolkit
    NI LabVIEW Modulation Toolkit 16.0 adds support for LabVIEW 2016 (32- and 64-bit)
    NI LabVIEW Modulation Toolkit 15.0 includes the following new features:
    • Support for QAM 512, 1024, 2048, 4096
    NI LabVIEW Modulation Toolkit 4.4 includes the following new features:
    • Support for LabVIEW 2013 and LabVIEW 2014 (32- and 64-bit)
    • Support for Offset EVM measurement for OQPSK
    • Support for EVM normalization for QAM
    • Support for quadrature skew measurement for OQPSK
    NI LabVIEW Modulation Toolkit 4.3.4 adds support for LabVIEW 2012 (32- and 64-bit).
    Supported HardwareVector Signal Generators
    • NI PXI-5670
    • NI PXI-5671
    • NI PXIe-5672
    • NI PXIe-5673
    • NI PXIe-5673E
    Device-specific information about these modules is included in the NI RF Signal Generators Help.
    Arbitrary Waveform Generators
    • NI PXIe-5442
    • NI PXIe-5450
    • NI PXIe-5451
    Vector Signal Analyzers
    • NI PXI-5660
    • NI PXI-5661
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    Digitizers
    • NI PXI-5621
    • NI PXI-5620
    • NI PXI-5122
    • NI PXI-5124
    • NI PCI-5122
    • NI PCI-5124
    • NI PXI-5922
    • NI PXI-5142
    • NI PXIe-5122
    • NI PXIe-5622
    NI LabVIEW Modulation Toolkit 16.0 supports the following operating systems:
    Note  NI LabVIEW Modulation Toolkit 16.0 and later does not support Windows Server non-R2 editions.
    NI LabVIEW Modulation Toolkit 16.0 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum Requirements
    • Processor—Intel Core i3 or equivalent
    • RAM—2 GB
    • If your application runs on an RT target, NI recommends that you have at least 128 MB of RAM
    Recommended System
    • Processor—Intel Core i5 or equivalent
    • RAM—4 GB
    Note   Instrument drivers are not required for NI LabVIEW Modulation Toolkit operation in simulation mode. However, the toolkit installs examples for the supported drivers if they are present on the system. Refer to the Supported Drivers section of this document for more information.
    Note  You should install ADEs, such as NI LabVIEW before installing NI LabVIEW Modulation Toolkit. To add support for ADEs installed after installing NI LabVIEW Modulation Toolkit, modify your NI LabVIEW Modulation Toolkit installation or launch the NI LabVIEW Modulation Toolkit installer again.
    • NI LabVIEW 2013 SP1, 2014 SP1, 2015 SP1, or 2016
    • NI LabVIEW Real-Time Module 2013 SP1, 2014 SP1, 2015 SP1, or 2016
      • (32-bit) Program Files\National Instruments
      • (64-bit) Program Files (x86)\National Instruments
      • \LabVIEW
    ItemInstalled Location
    VIs\vi.lib\addons\Modulation
    Examples\examples\Modulation
    Documentation for NI LabVIEW Modulation Toolkit 16.0 is located at Start»All Programs»National Instruments»Modulation Toolkit»Modulation Toolkit Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI LabVIEW Modulation Toolkit HelpHTML/Windows HelpContains primary help content for NI LabVIEW Modulation Toolkit products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI LabVIEW Modulation Toolkit
    • A complete reference for all NI LabVIEW Modulation Toolkit programming VIs
    NI LabVIEW Modulation Toolkit ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI LabVIEW Modulation Toolkit palette VIs are available from the Functions»RF Communications»Modulation palette.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI LabVIEW Modulation Toolkit examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–RFSG and NI LabVIEW Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Toolkit and Modules»Modulation or by directory structure at Modulation.
    • Click the Search tab to search all installed examples by keyword. For example, search for "Modulation" to locate all NI LabVIEW Modulation Toolkit examples.
    You can also access all the installed NI LabVIEW Modulation Toolkit examples for LabVIEW at Start»All Programs»National Instruments»Modulation Toolkit»Modulation Toolkit Examples.
    Examples also are available online that demonstrate integrating NI RF signal generators with NI RF signal analyzers and NI toolkit software including the NI LabVIEW Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    NI LabVIEW Modulation Toolkit 16.0 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI LabVIEW Modulation Toolkit drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI LabVIEW Modulation Toolkit 16.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI LabVIEW Modulation Toolkit 16.0 to an unsupported OS. Additionally, after installing NI LabVIEW Modulation Toolkit 16.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI LabVIEW Modulation Toolkit versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the toolkit was released and the most recent software version the toolkit was designed to work with. Toolkit versions now start with a two-digit year indicator: <;ProductName>. For example, NI LabVIEW Modulation Toolkit 16.0 is the version released with LabVIEW 2016. The last version released under the old numbering scheme is NI LabVIEW Modulation Toolkit 4.4. The first version released under the new numbering scheme is NI LabVIEW Modulation Toolkit 15.0.
    • Select NI LabVIEW Modulation Toolkit 16.0 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    You can access the software and documentation known issues list online. Refer to the NI LabVIEW Modulation Toolkit 16.0 Known Issues at ni.com for an up-to-date list of known issues in NI LabVIEW Modulation Toolkit 16.0.
    The following items are the IDs and titles of a subset of issues fixed in the NI LabVIEW Modulation Toolkit. This is not an exhaustive list of issues fixed in the current version of the NI LabVIEW Modulation Toolkit. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI LabVIEW Modulation Toolkit 15.0 from NI LabVIEW Modulation Toolkit 4.4.
    521869Fixed an issue where the MT examples for NI-Scope had an NI-RFSA dependency.
    525695Fixed an issue where OQPSK intermittently reported NaN as the result for the I/Q Gain Imbalance and the Quadrature Skew measurements.
    508707Fixed an issue where intermittent loss of samples occurred during continuous digital demodulation.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.4 from NI LabVIEW Modulation Toolkit 4.3.4.
    389508Fixed DWarn 0x262C7578.
    402017Fixed an issue where MSK demodulation returned a high EVM.
    462305Fixed an issue where MSK recovered an incorrect constellation when the pulse shaping filter was set to None.
    362507Fixed an issue where installing MT 4.3.3 did not install the digital modulation related files on LabVIEW 2012.
    404991Fixed an issue where controls could not be created for the Modulation Toolkit classes.
    415930Fixed an issue where the OQPSK demodulation did not lock to the constellation consistently.
    426459Fixed an issue where EVM variations were observed in 8-PSK and 16-PSK demodulation.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.3.4 from NI LabVIEW Modulation Toolkit 4.3.3.
    362507Fixed an issue where installing NI LabVIEW Modulation Toolkit 4.3.3 did not install Digital Modulation Toolkit VIs on LabVIEW 2012.
    374121Fixed an issue where NI LabVIEW Modulation Toolkit did not install on LabVIEW 2012.
    404822Fixed an issue where multiple shortcuts to documents were present in the Start Menu folder for the NI LabVIEW Modulation Toolkit.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.3.3 from NI LabVIEW Modulation Toolkit 4.3.2.
    322185Fixed an issue where some files were missing in the Modulation Toolkit after upgrading LabVIEW and reinstalling the toolkit for the upgraded version.
    320449Fixed an issue where the NI License Manager was unable to check out the Modulation Toolkit license from certain packages in a volume license file.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.3.2 from NI LabVIEW Modulation Toolkit 4.3.1.
    294171Fixed an issue where an error message about conflicts between different dir.mnu is displayed when opening a VI from a LabVIEW project that has Modulation Toolkit dependencies.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.3.1 from NI LabVIEW Modulation Toolkit 4.3.
    294170Fixed an issue where LabVIEW projects that have Modulation Toolkit dependencies take a long time to load.
    294916Fixed an issue where an error message is displayed while compiling a project that refers to mod_Symbols to Bits.vi.
    298309Fixed an issue where the analog modulation VIs are not installed on upgrading from MT 4.1 to 4.3.1.
    293100Fixed an issue where the Modulation Toolkit does not install properly on LabVIEW versions after 2010 SP1.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.3 from NI LabVIEW Modulation Toolkit 4.2.1.
    147127Fixed an issue where the offsets seem to be off by one sample in the MT Phase Noise example.
    176993Fixed an issue where the sideband rejection in AM-SSB is correlated to the sample rate of the message signal, and cannot be reduced below a certain dB level.
    223422Fixed an issue where the Gaussian pulse does not integrate to unity.
    233207Fixed an issue in FSK modulation, where the pulse shape filter ramp up that needs to be deleted must be equal to the length of the filter.
    239324Fixed an issue where the search (+/- % of Fsampl) parameter of the pilot extraction filter cluster is used incorrectly during AM-SSB and AM-VSB demodulation.
    244292Fixed an issue where the constellation trace shows ghost points when a BPSK symbol is defined in PSK simulation.
    © 2002–2016 National Instruments. All rights reserved.
    375435B-01
    GMT+8, 2026-2-25 01:06
