查看: 2960|回复: 0
[NI软件产品] NI Bluetooth Toolkit 18.0 Win32/64Eng NI蓝牙测试工具包18.0下载
    4 小时前
  • 签到天数: 3539 天
    连续签到: 9 天
    发表于 2020-12-16 23:23:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Bluetooth测试工具包
    Bluetooth测试工具包为蓝牙基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)测试应用提供信号生成和分析功能。
    Bluetooth测试工具包是一款专用软件,旨在扩展NI RF的功能,使其具备经典蓝牙和低功率(LE)蓝牙信号生成和分析能力。该软件可以通过调制准确度、载波频率漂移、发射功率(TXP)等符合标准的物理层测量,分析蓝牙信号(最高可支持蓝牙5.2)基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)信号。借助Bluetooth测试工具包,您可通过交互式软面板快速轻松地执行和调试测量,创建和回放开放的未锁定波形,并利用更高性能的API更快速完成自动化测试。此外,Bluetooth测试工具包可以通过内置的直接测试模式(DTM)命令来控制待测设备。Bluetooth 为Bluetooth SIG公司的注册商标。
    Win32/64Eng
    18.0
    文件大小: 839667120 字节 (800.77 MB)
    修改日期: 2019-01-18 00:01
    MD5: 52010beeb61314190fafae8d6fd437f7(官方正确)
    SHA1: 3f2a3dd8962bc09fbf53246e5e2febf5adacc2a3
    SHA256: 6aad11205813727edeb9433dd5180cba4617f08182b2e364dc02dd17de84a6c6
    CRC32: 7d4281ac
    BT18.txt (566 Bytes, 下载次数: 0, 售价: 10 元)
    NI Bluetooth Analysis Toolkit 18.0 Readme
    January 2019
    This file contains important information about the NI Bluetooth Analysis Toolkit 18.0 and is organized into the following sections:
    Accessing VIs and Functions
    Product Version Naming Changes
    NI Bluetooth Analysis Toolkit 18.0 includes the following new features:
    • Support for LabVIEW 2018 (32-bit and 64-bit)
    NI Bluetooth Analysis Toolkit 17.0 includes the following new features:
    • Support for Bluetooth LE Standard v5.0
    NI Bluetooth Analysis Toolkit 16.0 includes the following new features:
    • Support for Bluetooth LE Standard v5.0 (draft version)
    • Support for LE enhanced direct test Mode commands
    • Support for de-whitening in LE
    • Support for preamble-based burst synchronization for LE
    • Support for whole packet frequency deviation trace as part of carrier frequency offset measurement
    • Support for whole packet bit trace for LE as part of PER
    • NI PXIe-5663E
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5668R
    • NI PXIe-5840
    • NI PXIe-5820
    Note  Device-specific information about these modules is included in the NI Digital Waveform Generator/Analyzer Help.
    NI Bluetooth Analysis Toolkit 18.0 supports the following operating systems:
    • Windows Embedded Standard 7 SP12 (32-bit and 64-bit)
    Note   NI Bluetooth Analysis Toolkit 18.0 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • NI-RFSA 2.9.1 or later
    • NI LabVIEW Modulation Toolkit 4.3.4 or later
    Note  You should install ADEs, such as NI LabVIEW or NI LabWindows™/CVI™, before installing NI Bluetooth Analysis Toolkit 18.0. To add support for ADEs installed after installing NI Bluetooth Analysis Toolkit 18.0, modify your NI Bluetooth Analysis Toolkit 18.0 installation or launch the NI Bluetooth Analysis Toolkit 18.0 installer again.
    • NI LabVIEW 2013 SP1 f6 patch, 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, 2016, 2017, or 2018
    • LabWindows/CVI 8.5.1 or later
    ItemInstalled Location
    Analysis Interactive Example\Bluetooth Toolkit\niBTA_Interactive_example.exe
    DLL (32-bit OS/64-bit OS , 64-bit support)\system32\
    DLL (64-bit OS , 32-bit support)\systemWOW64\
    VIs\vi.lib\RF Toolkits\BT
    Examples\examples\RF Toolkits\BT
    LabWindows/CVI
    Header Files\Shared\CVI\Include
    Static Libraries\Shared\CVI\bin\msvc
    .lfp/.sub Files\Shared\CVI\bin
    Examples\CVI\samples\Bluetooth
    C
    Header Files\Shared\ExternalCompilerSupport\C\include
    Import Library\Shared\ExternalCompilerSupport\C\lib32\msvc
    Examples\Bluetooth Toolkit\examples\C\Analysis
    Select Start»All Programs»National Instruments»NI-Bluetooth Analysis Toolkit»Bluetooth Analysis Interactive Example to launch the Analysis Interactive Example.
    Documentation for NI Bluetooth Analysis Toolkit 18.0 is located at Start»All Programs»National Instruments»NI Bluetooth Analysis Toolkit»Bluetooth Analysis Toolkit Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI Bluetooth Analysis Toolkit HelpHTML/Windows HelpContains information about NI Bluetooth Analysis Toolkit products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI Bluetooth Analysis Toolkit
    • A complete reference for all NI Bluetooth Analysis Toolkit programming functions
    NI Bluetooth Analysis Toolkit ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI Bluetooth Analysis palette VIs are available from the Functions»RF Communications»Bluetooth»Analysis palette.
    NI Bluetooth Analysis functions are available in LabWindows/CVI from the Library menu.
    You can access all the installed NI Bluetooth Analysis Toolkit examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI Bluetooth Analysis Toolkit»Bluetooth Analysis Toolkit Examples.
    Examples also are available online that demonstrate integrating NI RF signal generators with NI RF signal analyzers and NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    NI Bluetooth Analysis Toolkit 18.0 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI Bluetooth Analysis Toolkit support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI Bluetooth Analysis Toolkit 18.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI Bluetooth Analysis Toolkit 18.0 to an unsupported OS. Additionally, after installing NI Bluetooth Analysis Toolkit 18.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI Bluetooth Analysis Toolkit versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the toolkit was released and the most recent software version the toolkit was designed to work with. Toolkit versions now start with a two-digit year indicator: . For example, NI Bluetooth Analysis Toolkit 18.0 is the version released with LabVIEW 2018. The last version released under the old numbering scheme is NI Bluetooth Analysis Toolkit 1.2. The first version released under the new numbering scheme is NI Bluetooth Analysis Toolkit 14.0.
    The following item is a behavior change in Bluetooth Toolkit 17.0 from Bluetooth Toolkit 16.0.
    • The computations of DF1 and CFO results for LE-LR-125k packets are modified as per the final test specification.
    No known issues.
    The following items are changes in Bluetooth Toolkit 18.0 from Bluetooth Toolkit 17.0.
    Bug IDFixed Issue
    688934Fixed an issue where the estimated I and Q DC Offset results under the DEVM measurement were incorrect.
    651369Fixed an issue where an error was reported due to the runtime dependency on niScope_64.dll.
    693593Fixed an issue where de-whitening for Long Range packets was not as per the Bluetooth standard.
    The following items are changes in Bluetooth Toolkit 17.0 from Bluetooth Toolkit 16.0.
    Bug IDFixed Issue
    641142Fixed an issue where the results of Maximum Carrier Drift (Hz) properties of CFO and DF2 measurements had a wrong sign.
    The following items are changes in Bluetooth Toolkit 16.0 from Bluetooth Toolkit 15.0.
    Bug IDFixed Issue
    558416Fixed an issue where the behavior of burst synchronization type Preamble was similar to None for LE.
    584720Fixed an issue where the CFO calculation in the LE-Enhanced packets did not match the Bluetooth LE 2 Mbps Test Cases (draft version).
    The following items are changes in Bluetooth Toolkit 15.0 from Bluetooth Toolkit 14.5.
    Bug IDFixed Issue
    542999Fixed an issue where the average DF2avg and max/min DF2max computation did not match the Bluetooth Radio Frequency TSS and TP Specification 1.2/2.0/2.0 + EDR/2.1/2.1+EDR/4.0 standards.
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8.1. For more information about NI support for Windows 10, visit ni.com/windows10.
    © 2011–2019 National Instruments. All rights reserved.
    375225E-01
    NI Bluetooth Generation Toolkit 18.0 Readme
    January 2019
    This file contains important information about the NI Bluetooth Generation Toolkit 18.0 and is organized into the following sections:
    NI Bluetooth Generation Toolkit 18.0 includes the following new features:
    • Support for Bluetooth LE Standard v5.1
    NI Bluetooth Generation Toolkit 17.0 includes the following new features:
    NI Bluetooth Generation Toolkit 16.0 includes the following new features:
    • Support for disabling the LE PDU header
    • Support for LE enhanced direct test mode commands
    • Support for whitening in LE
    • Support for Dirty TX test with stable modulation index
    • Support for modulation index configuration
    • Support for oversampling factor configuration
    • Support for ramp time and settling time configuration
    • NI PXIe-5673E
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    • NI PXIe-5820
    NI Bluetooth Generation Toolkit 17.0 supports the following operating systems:
    Note   NI Bluetooth Generation Toolkit 18.0 does not support Windows Server non-R2 editions.
    • NI-RFSG 1.9.7 or later
    Note  You should install ADEs, such as NI LabVIEW or NI LabWindows™/CVI™, before installing NI Bluetooth Generation Toolkit 18.0. To add support for ADEs installed after installing NI Bluetooth Generation Toolkit 18.0, modify your NI Bluetooth Generation Toolkit 18.0 installation or launch the NI Bluetooth Generation Toolkit 18.0 installer again.
    Generation Interactive Example\Bluetooth Toolkit\niBTG_Interactive_Example.exe
    LabWindows/CVI
    C
    Examples\Bluetooth Toolkit\examples\C\Generation
    Select Start»All Programs»National Instruments»NI-BT Generation Toolkit»Bluetooth Generation Interactive Example to launch the Generation Interactive Example.
    Documentation for NI Bluetooth Generation Toolkit 18.0 is located at Start»All Programs»National Instruments»NI Bluetooth Generation Toolkit»Bluetooth Generation Toolkit Documentation. The documentation set is composed of the following documents.
    NI Bluetooth Generation Toolkit HelpHTML/Windows HelpContains information about NI Bluetooth Generation Toolkit. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI Bluetooth Generation Toolkit
    • A complete reference for all NI Bluetooth Generation Toolkit programming functions
    NI Bluetooth Generation Toolkit ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI Bluetooth Generation palette VIs are available from the Functions»RF Communications»Bluetooth»Generation palette.
    NI Bluetooth Generation functions are available in LabWindows/CVI from the Instrument menu.
    You can access all the installed NI Bluetooth Generation Toolkit examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI Bluetooth Generation Toolkit»Bluetooth Generation Toolkit Examples.
    NI Bluetooth Generation Toolkit 18.0 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI Bluetooth Generation Toolkit drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI Bluetooth Generation Toolkit 18.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI Bluetooth Generation Toolkit 18.0 to an unsupported OS. Additionally, after installing NI Bluetooth Generation Toolkit 18.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI Bluetooth Generation Toolkit versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the toolkit was released and the most recent software version the toolkit was designed to work with. Toolkit versions now start with a two-digit year indicator: . For example, NI Bluetooth Generation Toolkit 18.0 is the version released with LabVIEW 2015. The last version released under the old numbering scheme is NI Bluetooth Generation Toolkit 18.0. The first version released under the new numbering scheme is NI Bluetooth Generation Toolkit 14.0.
    The following item is a behavior change in Bluetooth Toolkit 18.0 from Bluetooth Toolkit 17.0.
    • Headroom is applied after applying impairments.
    No known issues.
    Bug IDFixed Issue
    693593Fixed an issue where whitening for Long Range packets was not as per the Bluetooth standard.
    696528Fixed an issue where the pattern type input was not used for continuous carrier mode.
    Bug IDFixed Issue
    557693Fixed an issue where the LE Preamble was not generated based on the LSB of LE access address.
    370079Fixed an issue where settling time and ramp time of the waveforms did not match the Bluetooth Radio Frequency TSS and TP Specification 1.2/2.0/2.0 + EDR/2.1/2.1+EDR/3.0/3.0+HS and Bluetooth Test Specification 4.0/4.2.0/4.2.2.
    549638Fixed an issue where the AWGN applied on the generated signal was wrong.
    584734Fixed an issue where the packet interval for LE-TP-EXT, LE-Enhanced packets did not match the Bluetooth Core Specification v4.0/4.2 and the Bluetooth LE 2 Mbps Standard (draft version).
    601300Fixed an issue where the seed for LE PN9 sequence was not reset between different runs.
    607860Fixed an issue where the dirty transmitter modulating signal was not synchronized with the packets.
    375224E-01
    GMT+8, 2025-5-14 12:25
