查看: 4363|回复: 0
[NI软件产品] NI Bluetooth Toolkit 19.1 Win32/64Eng NI蓝牙测试工具包19.1下载
    58 秒前
  • 签到天数: 3763 天
    连续签到: 14 天
    发表于 2020-12-16 23:28:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Bluetooth测试工具包
    Bluetooth测试工具包为蓝牙基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)测试应用提供信号生成和分析功能。
    Bluetooth测试工具包是一款专用软件,旨在扩展NI RF的功能,使其具备经典蓝牙和低功率(LE)蓝牙信号生成和分析能力。该软件可以通过调制准确度、载波频率漂移、发射功率(TXP)等符合标准的物理层测量,分析蓝牙信号(最高可支持蓝牙5.2)基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)信号。借助Bluetooth测试工具包,您可通过交互式软面板快速轻松地执行和调试测量,创建和回放开放的未锁定波形,并利用更高性能的API更快速完成自动化测试。此外,Bluetooth测试工具包可以通过内置的直接测试模式(DTM)命令来控制待测设备。Bluetooth 为Bluetooth SIG公司的注册商标。
    Win32/64Eng
    19.1
    文件大小: 1238573056 字节 (1.15 GB)
    修改日期: 2019-10-18 19:11
    MD5: 50f2cb13bf42b28bdbd36c2a066dc86c
    SHA1: 9b930ac8b43d9106381c041a957321990a75ec01
    SHA256: 5d72f8915e5bfc7577843120586d46e4b21be7e1bc07ad4c37127a76ac720213
    CRC32: c6fd263b
    BT19.1.txt (611 Bytes, 下载次数: 0, 售价: 10 圆)
    Bluetooth Toolkit 19.1 Readme
    October 2019
    This file contains important information about the Bluetooth Toolkit, including system requirements and installation instructions.
    Bluetooth Toolkit Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    Bluetooth Toolkit enables you to generate and analyze Bluetooth BDR, EDR, 4.0 LE, 4.2 LE, 5.0 LE (2 Mbps and long range) signals. The toolkit also supports generation of Bluetooth 5.1 signals. Helps in characterising the performance of Bluetooth design with powerful interactive examples.
    New Features New Features in Bluetooth Generation New Features in Bluetooth Analysis
    The following table shows the hardware models supported in Bluetooth Toolkit:
    Hardware ProductHardware Model
    Vector Signal AnalyzerPXIe-5663/5663E
    PXIe-5665
    PXIe-5668R
    Vector Signal TransceiverPXIe-5820
    PXIe-5840
    PXIe-5841
    PXIe-5644R
    PXIe-5645R
    PXIe-5646R
    Vector Signal GeneratorPXIe-5673/5673E
    Bluetooth Toolkit has the following requirements:
    • 1 GHz or faster 64-bit (x64) Processor or equivalent
    • At least 2 GB of disk space
    • At least 2 GB RAM
    • NI-RFSA 15.0 or later
    • NI-RFSG 15.0 or later
    Bluetooth Toolkit 19.1 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, Bluetooth Toolkit dropped support for all 32-bit Windows operating systems. Bluetooth Toolkit will not install or run on an unsupported OS. Refer to Bluetooth Toolkit Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Bluetooth Toolkit 19.0 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by Bluetooth Toolkit
    LabVIEW2016, 2017 SP1, 2018 SP1, or 2019
    LabWindows™/CVI™2013 SP2 and later
    NI installs Bluetooth Toolkit using NI Package Manager. If you do not already have NI software installed, Bluetooth Toolkit installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Accessing the APILabVIEW
    Bluetooth Toolkit VIs are available in LabVIEW from the Functions » RF Communications » Bluetooth palette.
    LabWindows/CVI
    Bluetooth Toolkit functions are available in LabWindows/CVI from the Library menu.
    Interactive Example
    To launch the Bluetooth Interactive Example, navigate to the following locations:
    Bluetooth Analysis Interactive Example
    • Start » All Programs » National Instruments » Bluetooth Analysis » Bluetooth Analysis Interactive Example
    Bluetooth Generation Interactive Example
    • Start » All Programs » National Instruments» Bluetooth Generation» Bluetooth Generation Interactive Example .
    The documentation set is composed of the following documents.
    DocumentFormatDescriptionPath
    Bluetooth Analysis Toolkit HelpHTML/Windows HelpInformation about Bluetooth Analysis. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to Bluetooth Analysis
    • A complete reference for all Bluetooth Analysis programming functions and VIs
    Start»All Programs»National Instruments»Bluetooth Analysis»Bluetooth Analysis Toolkit Documentation
    Bluetooth Generation Toolkit HelpHTML/Windows HelpInformation about Bluetooth Generation. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to Bluetooth Generation
    • A complete reference for all Bluetooth Generation programming functions and VIs
    Start»All Programs»National Instruments»Bluetooth Generation»Bluetooth Generation Toolkit Documentation
    Bluetooth Toolkit ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.Start»All Programs»National Instruments»Bluetooth»Bluetooth Toolkit Readme
    For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals .
    To access all the installed Bluetooth Toolkit examples for LabVIEW and LabWindows/CVI, navigate to the following locations:
    • Start » All Programs » National Instruments » Bluetooth Analysis Toolkit » Bluetooth Analysis Toolkit Examples
    • Start » All Programs » National Instruments » Bluetooth Generation Toolkit » Bluetooth Generation Toolkit Examples
    Behavior Changes Behavior Changes in Bluetooth Generation Behavior Changes in Bluetooth Analysis
    You can access the software and documentation known issues list online. Refer to the NI Bluetooth Toolkit Known Issues for an up-to-date list of known issues.
    Bug Fixes Bug Fixes in Bluetooth Generation Bug Fixes in Bluetooth Analysis
    • For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer .
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer .
    • To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer .
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10 .
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8 .
    Bluetooth Toolkit will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport .
    LabWindows/CVIcvi_lifecycle
    For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents .
    378073B-01
    GMT+8, 2026-1-5 10:27
