查看: 2937|回复: 0
[NI软件产品] NI Bluetooth Toolkit 20.0 Win32/64Eng NI蓝牙测试工具包20.0下载
  • 签到天数: 3539 天
    连续签到: 9 天
    发表于 2020-12-16 23:30:18 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Bluetooth测试工具包
    Bluetooth测试工具包为蓝牙基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)测试应用提供信号生成和分析功能。
    Bluetooth测试工具包是一款专用软件,旨在扩展NI RF的功能,使其具备经典蓝牙和低功率(LE)蓝牙信号生成和分析能力。该软件可以通过调制准确度、载波频率漂移、发射功率(TXP)等符合标准的物理层测量,分析蓝牙信号(最高可支持蓝牙5.2)基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)信号。借助Bluetooth测试工具包,您可通过交互式软面板快速轻松地执行和调试测量,创建和回放开放的未锁定波形,并利用更高性能的API更快速完成自动化测试。此外,Bluetooth测试工具包可以通过内置的直接测试模式(DTM)命令来控制待测设备。Bluetooth 为Bluetooth SIG公司的注册商标。
    Win32/64Eng
    20.0
    文件大小: 1227345920 字节 (1.14 GB)
    修改日期: 2020-05-15 14:31
    MD5: f735c83ec0a389cb66714d05f4da3366(官方正确)
    SHA1: e2df95064789e8e020b80283af9adacedbd8238e
    SHA256: 5159680646445af916d24f90601767c9ff2960bb96818ce9be9eb6f0784c06ea
    CRC32: 51b6f791
    BT20.txt (653 Bytes, 下载次数: 0, 售价: 10 元)
    NI Bluetooth Toolkit 20.0 Readme
    May 2020
    This file contains important information about the NI Bluetooth Toolkit, including system requirements, and installation instructions.
    NI Bluetooth Toolkit Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    NI Bluetooth Toolkit enables you to generate and analyze Bluetooth BDR, EDR, 4.0 LE, 4.2 LE, 5.0 LE (2 Mbps and long range) signals. The toolkit also supports generation of Bluetooth 5.1 signals. Helps in characterising the performance of Bluetooth design with powerful interactive examples.
    New Features New Features in Bluetooth Generation New Features in Bluetooth Analysis
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    • PXIe-5841 with PXIe-5655
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    Vector Signal Generator
    • PXIe-5673
    • PXIe-5673E
    NI Bluetooth Toolkit has the following requirements:
    • 1 GHz or faster 64-bit (x64) Processor or equivalent
    • At least 2 GB of disk space
    • At least 2 GB RAM
    • NI-RFSA 15.0 or later
    • NI-RFSG 15.0 or later
    NI Bluetooth Toolkit 20.0 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, NI Bluetooth Toolkit dropped support for all 32-bit Windows operating systems. NI Bluetooth Toolkit will not install or run on an unsupported OS. Refer to NI Bluetooth Toolkit Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, NI Bluetooth Toolkit dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use NI Bluetooth Toolkit 20.0 to an unsupported OS. Additionally, after installing NI Bluetooth Toolkit 20.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note   Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/r/PAESupport.
    NI Bluetooth Toolkit 20.0 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by NI Bluetooth Toolkit
    LabVIEW2017 SP1, 2018 SP1, 2019 SP1, or 2020
    LabWindows™/CVI™2013 SP2 and later
    NI installs NI Bluetooth Toolkit using NI Package Manager. If you do not already have NI software installed, NI Bluetooth Toolkit installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate NI Bluetooth Toolkit. For more information on NI Bluetooth Toolkit activation, refer to National Instruments Software Activation .
    Accessing the APILabVIEW
    NI Bluetooth Toolkit VIs are available in LabVIEW from the Functions » RF Communications » Bluetooth palette.
    LabWindows/CVI
    NI Bluetooth Toolkit functions are available in LabWindows/CVI from the Library menu.
    Interactive Example
    To launch the Bluetooth Interactive Example, navigate to the following locations:
    Bluetooth Analysis Interactive Example
    • Start » All Programs » National Instruments » Bluetooth Analysis » Bluetooth Analysis Interactive Example
    Bluetooth Generation Interactive Example
    • Start » All Programs » National Instruments» Bluetooth Generation» Bluetooth Generation Interactive Example
    The documentation set is composed of the following documents.
    DocumentFormatDescriptionPath
    NI Bluetooth Analysis Toolkit HelpHTML/Windows HelpInformation about Bluetooth Analysis. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to Bluetooth Analysis
    • A complete reference for all Bluetooth Analysis programming functions and VIs
    Start»All Programs»National Instruments»Bluetooth Analysis»Bluetooth Analysis Toolkit Documentation
    NI Bluetooth Generation Toolkit HelpHTML/Windows HelpInformation about Bluetooth Generation. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to Bluetooth Generation
    • A complete reference for all Bluetooth Generation programming functions and VIs
    Start»All Programs»National Instruments»Bluetooth Generation»Bluetooth Generation Toolkit Documentation
    NI Bluetooth Toolkit ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.Start»All Programs»National Instruments»Bluetooth»NI Bluetooth Toolkit Readme
    To access all the installed NI Bluetooth Toolkit examples for LabVIEW and LabWindows/CVI, navigate to the following locations:
    • Start » All Programs » National Instruments » Bluetooth Analysis Toolkit » Bluetooth Analysis Toolkit Examples
    • Start » All Programs » National Instruments » Bluetooth Generation Toolkit » Bluetooth Generation Toolkit Examples
    Behavior Changes Behavior Changes in Bluetooth Generation Behavior Changes in Bluetooth Analysis
    You can access the software and documentation known issues list online. Refer to the NI Bluetooth Toolkit Known Issues for an up-to-date list of known issues.
    Bug Fixes Bug Fixes in Bluetooth Generation Bug Fixes in Bluetooth Analysis
    NI Bluetooth Toolkit will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2009–2020 National Instruments. All rights reserved.
    378073C-01
    GMT+8, 2025-5-14 13:04
