查看: 2719|回复: 0
[NI驱动程序] NI-VirtualBench Software 15.1 Win32/64 中文/德语/日语/法语/英文/韩语 NI虚拟工作台软件15.1版下载
    昨天 10:50
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2020-12-19 00:01:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    VirtualBench软件
    VirtualBench软件为VirtualBench多功能一体式仪器提供支持。
    VirtualBench软件是一个驱动软件,包含一个Windows应用程序,可以让用户通过集成的视图来查看VirtualBench多功能一体式仪器中所有五种仪器的数据。该软件还为LabVIEW和C提供API支持,并提供随附范例和详细的帮助文件。VirtualBench Software Windows应用程序包含工作流功能,例如仪器配置导入和导出以及数据捕获。此外,这一Windows应用程序还提供数字荧光密度图、XY模式和免持智能捕获等高级功能。
    15.1
    文件大小: 217260872 字节 (207.20 MB)
    修改日期: 2015-12-24 05:50
    MD5: ac1a71abef314251052477f1e7921faf(官方正确)
    SHA1: be596e2e6f7443f3014c1f15951d01308b776a5e
    SHA256: 91d0ea4bf78a3b01be395b742c8125765fb78b523fddae3da02dbd772e7954af
    CRC32: ea845a47
    NIVB15.1.txt (645 Bytes, 下载次数: 0, 售价: 10 元)
    NI VirtualBench 15.1 Readme
    October 2015
    This file contains important information about VirtualBench 15.1, including any system requirements and supported devices for the application and the driver software. VirtualBench 15.1 adds support for the VB-8034.
    Driver Version Naming Changes
    Devices Supported in VirtualBench
    Using NI Software with Microsoft Windows 8.x
    VirtualBench supports the following operating systems:
    • Windows Vista, Service Pack (SP) 1 or greater (32-bit and 64-bit)
    • Windows XP, SP3 or greater
    • Windows Server 2008 R2, SP1 or greater (64-bit)
    • Windows Server 2012 R2
    The following table lists the NI application software versions, including service packs, supported by VirtualBench.
    NI Application SoftwareVersions Supported by VirtualBench
    2013, 2014, 2015
    The following table lists the programming languages and Microsoft Visual Studio versions supported by this version of VirtualBench.
    Programming LanguageVisual Studio Versions Supported by VirtualBench
    ANSI C
    2003, 2005, 2008, 2010, and 2012
    VirtualBench versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, VirtualBench 15.0 is the version released with LabVIEW 2015. The last version released under the old numbering scheme is VirtualBench 1.2. The first version released under the new numbering scheme is VirtualBench 15.0.
    The following devices are supported in VirtualBench:
    • NI VB-8012
    • NI VB-8034
    When you install NI software on Microsoft Windows 8.x, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Finding All Programs
    VirtualBench Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of VirtualBench that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2014–2015 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents.
    374955D-01
    GMT+8, 2025-7-26 05:52
