查看: 3438|回复: 0
[NI驱动程序] NI-VRTS 1.5 Driver Win64多国语言 NI-VRTS车辆雷达测试系统1.5版驱动下载
    昨天 09:54
  • 签到天数: 3808 天
    发表于 2020-12-19 23:16:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-VRTS
    NI-VRTS为客户使用车辆雷达测试系统(VRTS)提供支持。
    NI-VRTS是一款NI仪器驱动程序,可帮助您创建从独立障碍物模拟器到全功能硬件在环(HIL)仿真系统等不同规模的软件应用程序。此驱动程序提供一系列操作、属性和示例,可模拟最多四个障碍物。此外,NI-VRTS可以通过测试辐射方向图、等效同位素辐射功率(EIRP)、噪声、频谱占用率、波束宽度和线性调频分析来帮助您评估雷达设备。
    Win64,中文, 德语, 日语, 法语, 英文, 韩语
    1.5
    文件大小: 491250092 字节 (468.49 MB)
    修改日期: 2019-01-16 04:45
    MD5: 715378ec174673b8ddef7cc653eff42d
    SHA1: fd1aed83ed2f07321476aac39e8a52f4ba6e89ca
    SHA256: 2f80b7aebb6feed04d79ee517e9cd403f4bc134c034e47de3df3c2233acf4e81
    CRC32: 1ad65b09
    NI-VRTS1.5.0.txt (628 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-VRTS 1.5 Readme
    December 2018
    This file contains important information about the NI-VRTS, including supported hardware, installation instructions, and new features.
    New FeaturesNI-VRTS 1.5 includes the following new features:
    • Support for the mmRH-3609, a monostatic mmWave radio head.
    • Center frequency configurable across the full range of the mmWave radio head (76-81 GHz).1
    • Ability to enable or disable the alignment laser.
    • Ability to call the Close VI without powering down the mmWave radio head.
    • Exportable module calibration constants.
    • Ability to read module temperatures.
    • Input validation when configuring obstacles.
    1By default, the mmWave radio head is calibrated for center frequency of 76.5 GHz. Contact NI for alternative calibrations.
    The following list details the hardware models supported in NI-VRTS 1.5.
    • Variable Delay Generator for PXI (VDG)
      • NI-5692
    • PXI Vector Signal Transceiver (VST)
      • PXIe-5840
    • mmWave Radio Head
      • mmRH-3608
      • mmRH-3609
    NI-VRTS 1.5 has the following requirements:
    • 4 GB RAM
    NI-VRTS 1.5 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    NI-VRTS 1.5 supports the following application software versions, including service packs. You should install LabVIEW before installing NI-VRTS. To add support for application software installed after installing NI-VRTS, modify your NI-VRTS installation or launch the NI-VRTS installer again.
    Versions Supported by NI-VRTS
    LabVIEW2015 SP1, 2016
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2015 SP1 and LabVIEW 2016.
    NI-VRTS palette VIs are available in the following palette location.
    User Libraries»NI-VRTS
    Installation InstructionsInstalling Dependencies
    • Ensure that you have installed the latest version of NI Package Manager.
      • To access the download page for NI Package Manager, go to ni.com/info and enter info code NIPMDownload.
      • Double click the package file to open NI Package Manager.
      • Follow the instructions in the installation prompts.
    • Install the required drivers.
      • Go to ni.com/downloads.
      • Click NI Drivers.
      • Search the NI Driver Downloads page for the instrument drivers in the following table and install the indicated versions.
        Driver Name
        Version
        NI-RFSA16.0
        NI-RFSG16.0
    • Install the required software products.
      • Click NI Software Products.
      • Search the NI Software Product Downloads page for the software in the following table and install the indicated versions.
        Driver Name
        Version
        NI-RFmx SpecAn2.3
        NI-RFmx DeMod2.3
    Installing NI-VRTS
    • Ensure that you have installed all previously described dependencies.
    • If you installed a beta version of NI-VRTS 1.5, remove it before proceeding.
    • Install NI-VRTS 1.5 using NI Package Manager.
    You can access the software and documentation known issues list online. Refer to the NI-VRTS 1.5 Known Issues at ni.com/info and enter the Info Code s8fp4w for an up-to-date list of known issues in NI-VRTS 1.5.
    The following items are changes in NI-VRTS 1.5.
    ID
    Fixed Issue
    65191Fixed an issue that misapplied delays and gains to VDGs in multi-object configurations.
    NI-VRTS ships with the following examples that can be found at \user.lib\NI-VRTS\API\Examples:
    • NI-VRTS - Obstacle Simulation.vi demonstrates obstacle simulation.
    • NI-VRTS - Obstacle Simulation and OBW Measurement.vi demonstrates how to simulate obstacles and carry out occupied bandwidth measurement on the RADAR sensor.
    • NI-VRTS - Obstacle Simulation and FM Demod Measurement.vi demonstrates how to simulate obstacles and carry out FM demodulation on the RADAR sensor signal.
    • NI-VRTS - Obstacle Simulation and TxP Measurement.vi demonstrates obstacle simulation and performs a transmit power measurement on the RADAR sensor signal.
    © 2018 National Instruments. All rights reserved.
    377823A-01
    GMT+8, 2026-2-26 01:43
