查看: 3116|回复: 0
[NI驱动程序] NI IVI Compliance Package 2.1.1 Win32Eng NI IVI合规软件包ICP2.1.1下载
    昨天 10:50
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2020-12-21 23:14:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    IVI合规软件包
    Win32Eng
    2.1.1
    文件大小: 56031949 字节 (53.44 MB)
    修改日期: 2019-06-25 02:45
    MD5: 43153365e74b680416375d27a567f702
    SHA1: c072fe1247c7d8e11e0f2a31e9d000b59e3fa608
    SHA256: e4c042577063e37594962e5ba0e12aecab177020eaa6726866c516a9abf1a333
    CRC32: 2d586f47
    ICP2.1.1.txt (547 Bytes, 下载次数: 0, 售价: 10 元)
    IVI Compliance Package 2.1.1Documentation File(c) Copyright 1999-2004 National Instruments Corporation.All rights reserved.Product and company names listed are trademarks or trade names of their respective companies.Introduction------------The IVI Compliance Package 2.1.1 is an update release of the IVI Compliance Package 2.1. As this release includes fixes to minor bugs and the latest version of the IVI Shared Components, you can refer to the IVI Compliance Package 2.0 Release Notes for more information about this product.For more information about the following topics, refer to IVI Compliance Package Release Notes:                * Detailed upgrade instructions        * IVI Shared Components overview and major structural changes to IVI products        * Class Drivers API changes        * New installation directoriesWarning: The IVI Configuration Store file format now requires that all names be case-sensitive.  If you use logical names, driver session names, or virtual names in your program, make sure that the name you use matches the name defined in the IVI Configuration Store file exactly, without any variations in the case of the characters in the name.Availability------------- IVI Compliance Package 2.1.1 is included on the: National Instruments Device Drivers CD and is distributed from the web as a stand-alone version.- To install the stand-alone, web-only IVI Compliance Package 2.1.1 version, perform the following steps:        1. Download the IVI Compliance Package 2.1.1 self-extracting archive from http://www.ni.com/downloads by navigating through the Drivers and Updates link.        2. Start the installation by double clicking on the self-extracting archive.         3. Click OK to begin installation.        4. Follow the directions that appear on screen.Minimum System Requirements---------------------------- To use IVI Compliance Package 2.1.1 for Windows, you must have the following minimum system requirements:        * Windows XP/2000/NT 4.0/ME/98        * Windows NT 4.0 users only: Windows Service Pack 6        * Internet Explorer 4.0.1        * Windows 98 users only: DCOM 98.        * PC using at least a 200 MHz Pentium class or higher microprocessor        * 64 MB of RAM        * 150 MB of free hard disk space- You need to install Internet Explorer 4.0.1 or later before installing IVI Compliance Package 2.1.1. If you use a Windows operating system and do not have Internet Explorer 4.0.1 or later installed, an error occurs during installation.  If you are unwilling to upgrade to Internet Explorer 4.0.1 or later in order to install IVI Compliance Package 2.1.1, there is an alternative installer package that waives this requirement but still gives you the necessary IVI components needed to run specific IVI drivers. You can obtain this alternative package (NI IVI Engine Package) by contacting National Instruments. The NI IVI Engine Package does not install the IVI Shared Components. Using the NI IVI Engine package makes your system non compliant with IVI specifications. National Instruments does not offer configuration and class driver support with the NI IVI Engine Package.Known Incompatibilities------------------------ There are no known incompatibilities with upgrading from the IVI Compliance Package 2.0 or 2.1 to the IVI Compliance Package 2.1.1.- NI Calibration Executive version 2.1 is not compatible with IVI Compliance Package 2.1.1. If you use NI Calibration Executive version 2.1, you should not upgrade to IVI Compliance Package 2.1.1. - NI Switch Executive version 1.0 is not compatible with IVI Compliance Package 2.1.1. If you use NI Switch Executive version 1.0, you should not upgrade to IVI Compliance Package 2.1.1. - If you already have IVI Driver Toolset 1.1 installed, you must uninstall IVI Driver Toolset 1.1 before installing IVI Compliance Package 2.1.1. By uninstalling IVI Driver Toolset 1.1, you are uninstalling class simulation drivers, Soft Front Panels and NI-SPY. IVI Compliance Package 2.1.1 does not restore these components to your system.  There are no known incompatibilities with the IVI Driver Toolset 2.0 and the IVI Compliance Package 2.1.1.Installation------------Before installing IVI Compliance Package 2.1.1, consider the following issues:- If you plan to use IVI Compliance Package 2.1.1 with LabVIEW, LabWindows/CVI and\or Measurement Studio, make sure that you have already installed LabVIEW version 7.0 or greater, LabWindows/CVI version 6.0 or greater and\or Measurement Studio version 6.0 or greater.- National Instruments recommends that you close all other applications before you install IVI Compliance Package 2.1.1.Installed Components--------------------IVI Compliance Package 2.1.1 installs the following components:        IVI Class Drivers        IVI Class Driver CVI Support                                                IVI Class Driver C++ Wrappers for Measurement Studio        IVI Class Driver Wrappers for LabVIEW 7.0 and 7.1        IVI Class Driver Examples for CVI and LabVIEW and Measurement Studio        INI to XML Converter        IVI Shared Components version 1.1.2        Measurement & Automation Explorer 3.0 (MAX) plug-in for IVI configurationNote: The IVI Compliance Package 2.1.1 stand-alone, web-only distribution does not install NI-Spy or MAX. You can install NI-Spy and MAX using several other National Instruments products, including the NI Device Driver CD.Uninstall Considerations------------------------If you want to uninstall the IVI Compliance Package 2.1.1:        1. Select Start»Settings»Control Panel»Add/Remove Programs.        2. Select National Instruments Software and click Remove.        3. Select IVI Compliance Package 2.1.1 and click Uninstall.        4. Visit www.ivifoundation.org to download the IVI Foundation IVI Shared Component Cleanup Utility.        5. Run the IVI Foundation IVI Shared Component Cleanup Utility.Note: After you uninstall IVI Compliance Package 2.1.1, IVI Shared Components remains on your system. You must run the IVI Foundation IVI Shared Component Cleanup Utility to remove the IVI Shared Components. The IVI Shared Components are not uninstalled by the Windows uninstallation utility.Note: If you installed IVI Compliance Package 2.1.1 as part of another distribution that depends on the presence of IVI Compliance Package 2.1.1, you cannot uninstall IVI Compliance Package 2.1.1 without uninstalling the dependent product.Known Issues------------- The following IVI products are incompatible with IVI Compliance Package 2.1.1:         * IVI Driver Toolset (IDT) 1.1        * Basic IVI Class Drivers (BICD) version 2.4 and previous        * IVI Engine 1.83 and previousDo not install the above products after installing IVI Compliance Package 2.1.1. These older IVI products are also included as part of other National Instruments software products, such as the products listed below:        * LabVIEW 6.1 and previous        * TestStand 2.0        * Measurement Studio 6.0 and previous        * NI-Scope 2.1.4 and previous        * NI-DMM 2.0.1 and previous        * NI-Switch 1.6.1 and previous        * NI-Fgen 1.6 and previousIf there is an upgrade for these products, it is recommended that you upgrade to the latest version (such as NI-DMM 2.2 and NI-SWITCH 2.1). Otherwise, when installing any of the above products (after installing IVI Compliance Package 2.1.1), you must disable any visible IVI related features in the feature selection tree. If there are not any visible IVI features in the feature selection tree, you must repair IVI Compliance Package 2.1.1 installation by doing the following:         1. Select Start»Settings»Control Panel»Add/Remove Programs.        2. Select National Instruments Software and click Change.        3. Select IVI Compliance Package 2.1.1 and click Repair.- LabVIEW users:  Downcasting from a class driver to a specific driver using property nodes may return an error in the following cases:         * when using a combination of specific driver VIs and specific driver property nodes        * when using a specific driver property node with inherent properties  The suggested workaround is to either        * not use specific driver property nodes, or         * use specific driver property nodes but without any inherent properties and not in the conjunction with specific driver VIs.- A VI that makes calls to an IVI Class Driver and an IVI specific driver in parallel by branching off of the same instrument handle will result in an 'IVI_ERROR_NOT_INITIALIZED' being returned from the call to the class driver.- Measurement Studio and LabWindows/CVI users: The IVI class driver examples use a default logical name that might differ in case from the logical names in the Configuration Store. If you try to run the examples with the default logical names, the examples might not run successfully. However, you can choose to provide a logical name yourself rather than use the default logical name. The name you provide must match the logical name in the Configuration Store exactly, including the character case.  Logical names stored in the Configuration Store can be accessed and modified in MAX.- Measurement Studio 6.0 users: If you install Measurement Studio 6.0 after installing IVI Compliance Package 2.1.1, then the old IVI class examples install and these do not compile. You must run "Modify" on the IVI Compliance Package 2.1.1 installer and enable the "CVI Support" feature to get the new examples. In some cases where either you have edited some of the example files or other old IVI files are still found on the system, running the "Modify" does not update the files. In this case, you must also run "Repair" on the IVI Compliance Package 2.1.1 installer after running the "Modify" to get the correct files.- Measurement Studio 6.0 users: If you install the following products in the order specified below:                 1- NI-SWITCH 1.6.1 and previous        2- IVI Compliance Package 2.1.1        3- Measurement Studio 6.0you might encounter an error message about the IVI MAX provider during installation of Measurement Studio 6.0. You can click "OK" on the error dialog. Clicking “OK” continues normal installation. This error does not affect your software products and your software products will continue to run normally.- National Instruments IVI libraries, tools, and utilities only support single-byte character strings. You cannot use multi-byte characters, such as those commonly used in Chinese, Japanese, and Korean operating systems. Only single byte characters, such as ASCII characters, may be passed to IVI function calls, used to set directory paths, and used to create entries in the MAX IVI Configuration Utility.- If you use NI-Switch 1.61 or earlier, initializing NI-Switch sessions with independent topologies causes a runtime error.  If you use independent topologies, you should upgrade to NI Switch 2.0 or later.- Installing TestStand 2.0.1 Session Manager over IVI Compliance Package 2.1.1 Session Manager breaks TS201 IVI Step Types. This break causes the IVI logical names to not show up in the IVI Step Type in TestStand. Instead, an "invalid logical name" error appears. However, IVI devices continue to function in LabVIEW. To fix this issue, repair the Session manager part from the IVI Compliance Package 2.1.1 distribution.- IVI help in MAX requires Internet Explorer 5.0 or higher. Without IE 5.0 or higher, IVI category help and the dynamic item help does not show up in MAX.- Using IVI Class Drivers and NI-DMM 2.1 with NI Spy running can cause LabVIEW or CVI to crash.  You should upgrade to the latest version of NI-DMM.
    GMT+8, 2025-7-26 05:55
