查看: 2838|回复: 0
[NI驱动程序] NI IVI Compliance Package 3.2 Win32Eng NI IVI合规软件包ICP3.2下载
    昨天 10:50
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2020-12-21 23:30:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    IVI合规软件包
    Win32Eng
    3.2
    文件大小: 65833410 字节 (62.78 MB)
    修改日期: 2019-06-25 02:45
    MD5: 9e2794ebd5e9f47e42367a01ff14194f
    SHA1: d038be2c2bd6f27db56009bec5fe6449c2c5cc53
    SHA256: 20817425ad9791f98ec8f743b8bb2614df6bd75a4e036a7f5ba0594a74b2b5d8
    CRC32: 6def62a6
    ICP3.2.txt (569 Bytes, 下载次数: 0, 售价: 10 元)
    NI IVI Compliance Package 3.2Documentation File
    © Copyright 1999–2007. National Instruments Corporation. All rights reserved.
    CVI™, IVI™, LabVIEW™, Measurement Studio™, National Instruments™, NI™, ni.com™, NI-DMM™, NI-FGEN™, and TestStand™ are trademarks of National Instruments Corporation. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    Introduction
    IVI Compliance Package (ICP) 3.2 is an update release of IVI Compliance Package 3.1. This release includes the following new features and bug fixes:
    • Inclusion of the latest version of IVI Shared Components 1.5.0 (CAR 499AF2WZ)
    • Addition of help links from all IVI class driver propreties (CAR 4B38J900)
    • Inclusion of IVI-COM adapters in the IVI Compliance Package distribution (CAR 4BA9O4WZ)
    • Inclusion of a spec file for automated installations (CAR 4AJDPDHS)
    • Other installer updates (CARs 484H9F00, 446A4HHS)
    Note: IVI Compliance Package 3.2 includes IVI-COM adapters which enable users to use IVI-C and IVI-COM specific drivers interchangeably in the same application. For more information on IVI-COM adapters, refer to the IVI-C Class Driver Support for IVI-COM Specific Drivers document.
    Note: IVI Compliance Package 3.2 supports only 32-bit applications on 64-bit Windows Vista. For more information on using National Instruments products with Windows Vista, visit ni.com/vista.
    Note: Installation directory for LabWindows/CVI IVI Class examples and IVI Class Simulation drivers has been changed. The new installation directory is \Documents\National Instruments\CVI\Samples\IVI directory.
    Refer to the IVI Compliance Package Release Notes, Version 3.0, for general information about this product.
    • Windows 2000 Service Pack 4
    • Windows XP
    • Windows Vista x86
    • Windows Vista x64
    Availability/Installation
    IVI Compliance Package is included in the National Instruments Device Drivers CD Set. A stand-alone version is available on ni.com.
    Before installing IVI Compliance Package 3.2, consider the following issues:
    • If you plan to use IVI Compliance Package 3.2 with LabVIEW, LabWindows™/CVI™, and/or Measurement Studio, make sure that you have already installed LabVIEW version 7.1 or later, LabWindows/CVI version 7.0 or later, and/or Measurement Studio version 6.0 or later.
    • For compatibility reasons, the IVI Compliance Package 3.2 installation process enables write permissions for the Program Files\IVI directory on Windows Vista systems.
    • National Instruments recommends that you close all other applications before you install IVI Compliance Package 3.2.
    To install the stand-alone, Web-only IVI Compliance Package 3.2 version, complete the following steps:
    • Download the IVI Compliance Package 3.2 self-extracting archive from http://www.ni.com/downloads by navigating through the Drivers and Updates link.
    • Double-click the self-extracting archive to launch the installer.
    Known Incompatibilities
    • There are no known incompatibilities with upgrading from previous IVI Compliance Package versions to IVI Compliance Package 3.2.
    • NI-Spy version 2.2 and earlier is not compatible with IVI Compliance Package 3.2. If you use NI-Spy version 2.2 or earlier, do not upgrade to IVI Compliance Package 3.2.
    • NI TestStand version 2.0.1 is not compatible with IVI Compliance Package 3.2. If you use NI TestStand version 2.0.1 and want to install IVI Compliance Package for the first time, do not upgrade to IVI Compliance Package 3.2, because it does not include support for NI TestStand version 2.0.1. Versions of IVI Compliance Package prior to version 3.1 can be installed instead. Please refer to the Installing the IVI Compliance Package 3.2 or later With TestStand 2.0.1 document for details.
    • As of IVI Compliance Package 3.1, the IVI Compliance Package distribution no longer includes LabWindows/CVI 6.0 support. Please refer to the Using LabWindows/CVI 6.0 With ICP 3.1 document for details.
    Installed Components
    IVI Compliance Package 3.2 installs the following components:
    • IVI class drivers
    • IVI class driver C++ wrappers for Measurement Studio (Windows 2000 and XP only)
    • IVI class driver wrappers for LabVIEW 7.1, 8.0, 8.2, and 8.5
    • IVI-COM adapters
    • IVI Shared Components, version 1.5.0
    • IVI configuration plug-in for Measurement & Automation Explorer (MAX) 4.2.1 and later
    • Online help
    Note: The IVI Compliance Package 3.2 stand-alone, web-only distribution does not install NI-Spy or MAX. You can install NI-Spy and MAX using several other National Instruments products, including the NI Device Drivers CD Set.
    Note: You must have MAX 4.2.1 or later installed to use the IVI Configuration utility in MAX.
    Note: As of IVI Compliance Package 2.5, the IVI Class Driver files are no longer installed in the VXIPNP directory. These files will continue to be installed in the IVI directory.
    Note: IVI class simulation drivers and IVI Soft Front Panels used to be distributed with the IVI Driver Toolset. Since the IVI Driver Toolset has been discontinued, the IVI class simulation drivers are now distributed with the IVI Compliance Package 2.5 and later. The IVI Soft Front Panels are available upon request to instrument.drivers@ni.com.
    Note: As of IVI Compliance Package 3.0, the LabWindows/CVI Instrument Driver Developers Guide (iddg.pdf) is no longer installed with ICP. This file gets installed with LabWindows/CVI. When you upgrade to ICP 3.2, the file will be removed from your system. To replace the file, run the LabWindows/CVI installation in the Repair mode.
    Uninstall Considerations
    Complete the following steps to uninstall IVI Compliance Package 3.2:
    • Select Start»Settings»Control Panel»Add or Remove Programs.
    • Select NI IVI Compliance Package 3.2 and click Remove.
    Note: After you uninstall IVI Compliance Package 3.2, the IVI Shared Components remain on the system. Complete the following steps to uninstall the IVI Shared Components:
    • Select IVI Shared Components and click Change/Remove.
    Note: If you installed IVI Compliance Package 3.2 as part of another distribution that depends on IVI Compliance Package 3.2, you cannot uninstall IVI Compliance Package 3.2 without uninstalling the dependent product.
    • LabVIEW users: Downcasting from a class driver to a specific driver using property nodes may return an error in the following cases:
      • You use a combination of specific driver VIs and specific driver property nodes.
      • You use a specific driver property node with inherent properties.
      Use one of the following workarounds to avoid this error:
      • Do not use specific driver property nodes.
      • Use specific driver property nodes but without any inherent properties and not in the conjunction with specific driver VIs.
    • LabVIEW users: A VI that makes calls to an IVI class driver and an IVI specific driver in parallel by branching off of the same instrument handle will result in an IVI_ERROR_NOT_INITIALIZED error being returned from the call to the class driver.
    • IVI help in MAX requires Internet Explorer 5.0 or higher. Without Internet Explorer 5.0 or higher, IVI category help and the dynamic item help does not appear in MAX.
    GMT+8, 2025-7-26 06:00
