查看: 3666|回复: 0
[NI驱动程序] NI IVI Compliance Package 4.0 Win32/64Eng NI IVI合规软件包ICP4.0下载
    昨天 10:50
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2020-12-21 23:34:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    IVI合规软件包
    Win32/64Eng
    4.0
    文件大小: 84375253 字节 (80.47 MB)
    修改日期: 2019-06-25 02:45
    MD5: 195534270d0c3a27707599d1b7b8a557
    SHA1: 7edf84db0924cd839074e13dd5dc8f62b93ea1b0
    SHA256: 4b628e96fe9f430c1f09e74096c4790c491579876af4463e8a15ff56aabf62a5
    CRC32: 2e0836c9
    ICP4.0.txt (576 Bytes, 下载次数: 0, 售价: 10 元)
    NI IVI Compliance Package 4.0.0Documentation File
    © Copyright 1999–2009. National Instruments Corporation. All rights reserved.
    LabWindows/CVI™, IVI™, LabVIEW™, Measurement Studio™, National Instruments™, NI™, ni.com™, NI-DMM™, NI-FGEN™, and TestStand™ are trademarks of National Instruments Corporation. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    Introduction
    IVI Compliance Package (ICP) 4.0 is an update release of IVI Compliance Package 3.3. This release includes the following new features and bug fixes:
    • Supports using NI Modular Instruments drivers in Native 64-bit applications on 64-bit Windows Vista. For more information on using National Instruments products with Windows Vista, visit ni.com/vista.
    • Includes of the latest version of IVI Shared Components 2.0.0 (CAR 166704)
    • Adds new functions and reorganizes the IVI Engine fp file (CAR 120845)
    • MAX Provider improvements:
      • Adds 64-bit module path (CAR 125061)
      • Supports AssemblyQualifiedClassName (CAR 130023)
      • Updates MAX to handle qualified physical names (CAR 131237)
    • Class Driver Examples:
      • Adds CVI IVI class driver examples for IviSpecAn, IviPwrMeter, and IviRFSigGen (CAR 131088)
      • Adds Example Finder support for CVI IVI class examples (CAR 92728)
      • Adds IviScope Continuous Acquisition example to LabVIEW (CAR 104764)
    Refer to the IVI Compliance Package Release Notes, Version 3.0, for general information about this product.
    • Windows 2000 Service Pack 4
    • Windows XP
    • Windows Vista x86
    • Windows Vista x64
    Availability/Installation
    IVI Compliance Package is included in the National Instruments Device Drivers CD Set. A stand-alone version is available on ni.com.
    Before installing IVI Compliance Package 4.0, consider the following issues:
    • If you plan to use IVI Compliance Package 4.0 with LabVIEW, LabWindows/CVI, and/or Measurement Studio, make sure that you have already installed LabVIEW version 8.2 or later, LabWindows/CVI version 7.0 or later, and/or Measurement Studio version 6.0 or later.
    • For compatibility reasons, the IVI Compliance Package 4.0 installation process enables write permissions for the IVI Standard Root directories (defaults: Program Files\IVI Foundation\IVI and Program Files(x86)\IVI Foundation\IVI) on Windows Vista systems.
    • National Instruments recommends that you close all other applications before you install IVI Compliance Package 4.0.
    To install the stand-alone, Web-only IVI Compliance Package 4.0 version, complete the following steps:
    • Download the IVI Compliance Package 4.0 self-extracting archive from http://www.ni.com/downloads by navigating through the Drivers and Updates link.
    • Double-click the self-extracting archive to launch the installer.
    Known Incompatibilities
    • There are no known incompatibilities with upgrading from previous IVI Compliance Package versions to IVI Compliance Package 4.0.
    • NI-Spy version 2.2 and earlier is not compatible with IVI Compliance Package 4.0. If you use NI-Spy version 2.2 or earlier, do not upgrade to IVI Compliance Package 4.0.
    • As of IVI Compliance Package 3.1, the IVI Compliance Package distribution no longer includes LabWindows/CVI 6.0 support. Please refer to the Using LabWindows/CVI 6.0 With ICP 3.1 document for details.
    Installed Components
    IVI Compliance Package 4.0 installs the following components:
    • IVI class simulation drivers (32-bit only)
    • IVI class driver C++ wrappers for Measurement Studio (Windows 2000 and XP only)
    • IVI class drivers
    • IVI class driver wrappers for LabVIEW 8.2, 8.5, 8.6, and 2009
    • IVI Shared Components, version 2.0.0
    • IVI configuration plug-in for Measurement & Automation Explorer (MAX) 4.2.1 and later
    • Online help
    Note: The IVI Compliance Package 4.0 stand-alone, web-only distribution does not install NI-Spy or MAX. You can install NI-Spy and MAX using several other National Instruments products, including the NI Device Drivers CD Set.
    Note: You must have MAX 4.2.1 or later installed to use the IVI Configuration utility in MAX.
    Note: Installation directory for LabWindows/CVI IVI Class examples and IVI Class Simulation drivers has been changed. The new installation directory is \Documents\National Instruments\CVI\Samples\IVI directory.
    Note: IVI Compliance Package 4.0 includes IVI-COM adapters which enable users to use IVI-C and IVI-COM specific drivers interchangeably in the same 32-bit application. For more information on IVI-COM adapters, refer to the IVI-C Class Driver Support for IVI-COM Specific Drivers document.
    Note: As of IVI Compliance Package 3.0, the LabWindows/CVI Instrument Driver Developers Guide (iddg.pdf) is no longer installed with ICP. This file gets installed with LabWindows/CVI. When you upgrade to ICP 4.0, the file will be removed from your system. To replace the file, run the LabWindows/CVI installation in the Repair mode.
    Uninstall Considerations
    Complete the following steps to uninstall IVI Compliance Package 4.0:
    • Select Start»Settings»Control Panel»Add or Remove Programs.
    • Select NI IVI Compliance Package 4.0 and click Remove.
    Note: After you uninstall IVI Compliance Package 4.0, the IVI Shared Components remain on the system. Complete the following steps to uninstall the IVI Shared Components:
    • Select IVI Shared Components and click Change/Remove.
    Note: If you installed IVI Compliance Package 4.0 as part of another distribution that depends on IVI Compliance Package 4.0, you cannot uninstall IVI Compliance Package 4.0 without uninstalling the dependent product.
    • If IVI Shared Components 2.0.0 is already installed when the ICP 4.0 installer is run, the IVI Shared Components feature(s) in the feature tree will not be displayed.
    • LabVIEW users: A VI that makes calls to an IVI class driver and an IVI specific driver in parallel by branching off of the same instrument handle will result in an IVI_ERROR_NOT_INITIALIZED error being returned from the call to the class driver.
    • IVI help in MAX requires Internet Explorer 5.0 or higher. Without Internet Explorer 5.0 or higher, IVI category help and the dynamic item help does not appear in MAX.
    GMT+8, 2025-7-26 06:00
