查看: 2695|回复: 0
[NI驱动程序] NI IVI Compliance Package 4.4 Win32/64Eng NI IVI合规软件包ICP4.4下载
    昨天 10:50
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2020-12-21 23:41:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    IVI合规软件包
    Win32/64Eng
    4.4
    文件大小: 158776692 字节 (151.42 MB)
    修改日期: 2019-06-25 02:45
    MD5: 32fca9244ba776971e5377921bdd72de
    SHA1: 527d3632a96844998e1c42d5248662ce9028ed4d
    SHA256: 13d8993bd1eb000d9136954578c19cc9086da6222966f957cd0ddfbc868f0a26
    CRC32: 8e8f9b4a
    ICP4.4.txt (586 Bytes, 下载次数: 0, 售价: 10 元)
    NI IVI Compliance Package 4.4.0Readme File
    IVI Compliance Package (ICP) 4.4 is an update release of IVI Compliance Package 4.3. This release includes the following new features and bug fixes:
    • Adds support for the IviACPwr class (CARs 254373, 25374, 256322)
    • Adds IVI-COM adapter support for the IviACPwr class (CAR 254370)
    • Includes IVI Shared Components 2.2.1 (CAR 254400)
    • Supports NI Update Service 2.0 (CAR 91206)
    Refer to the IVI Compliance Package Release Notes, Version 4.4, for general information about this product.
    Contents
    Availablility/Installation
    Known Incompatibilities
    Installed Components
    Uninstall Considerations
    • Windows 7 (32-bit or 64-bit), including Starter Edition (32-bit)
    • Windows Vista (32-bit or 64-bit)
    • Windows XP Service Pack 2 or later
    Availability/Installation
    IVI Compliance Package is included in the National Instruments Device Drivers media. A stand-alone version is available on ni.com.
    Before installing IVI Compliance Package 4.4, consider the following issues:
    • If you plan to use IVI Compliance Package 4.4 with LabVIEW, and/or LabWindows/CVI, make sure that you have already installed LabVIEW version 8.6 or later, and/or LabWindows/CVI version 7.0 or later.
    • For compatibility reasons, the IVI Compliance Package 4.4 installation process enables write permissions for the IVI Standard Root directories (defaults: Program Files\IVI Foundation\IVI and Program Files(x86)\IVI Foundation\IVI) on Windows Vista and Windows 7 systems.
    • National Instruments recommends that you close all other applications before you install IVI Compliance Package 4.4.
    To install the stand-alone, Web-only IVI Compliance Package 4.4 version, complete the following steps:
    • Download the IVI Compliance Package 4.4 self-extracting archive from http://www.ni.com/downloads by navigating through the Drivers and Updates link.
    • Double-click the self-extracting archive to launch the installer.
    • As of IVI Compliance Package 3.1, the IVI Compliance Package distribution no longer includes LabWindows/CVI 6.0 support. Please refer to the Using LabWindows/CVI 6.0 With ICP 3.1 document for details.
    • The IVI Specific Driver Test Suite in LabWindows/CVI 2009 requires ICP 4.1 or later.
    • The IVI Specific Driver Test Suite in LabWindows/CVI 2010 SP1 or later requires ICP 4.4.
    IVI Compliance Package 4.4 installs the following components:
    • IVI class drivers
    • IVI class driver wrappers for LabVIEW 8.6, 2009, 2010, and 2011
    • IVI Shared Components, version 2.2.1
    • IVI configuration plug-in for Measurement & Automation Explorer (MAX) 4.2.1 and later
    • Online help
    Note: The IVI Compliance Package 4.4 stand-alone, web-only distribution does not install NI I/O Trace (formerly known as NI-Spy) or MAX. You can install NI I/O Trace and MAX using several other National Instruments products, including the NI Device Drivers media.
    Note: You must have MAX 4.2.1 or later installed to use the IVI Configuration utility in MAX.
    Note: The installation directory for LabWindows/CVI IVI Class examples and IVI Class Simulation drivers has been changed. The new installation directory is \Documents\National Instruments\CVI\Samples\IVI directory.
    Note: IVI Compliance Package 4.4 includes IVI-COM adapters which enable users to use IVI-C and IVI-COM specific drivers interchangeably in the same 32-bit application. For more information on IVI-COM adapters, refer to the IVI-C Class Driver Support for IVI-COM Specific Drivers document.
    Complete the following steps to uninstall IVI Compliance Package 4.4:
    • Select Start»Settings»Control Panel»Add or Remove Programs.
    • Select NI IVI Compliance Package 4.4 and click Remove.
    Note: After you uninstall IVI Compliance Package 4.4, the IVI Shared Components remain on the system. Complete the following steps to uninstall the IVI Shared Components:
    • Select IVI Shared Components and click Change/Remove.
    Note: If you installed IVI Compliance Package 4.4 as part of another distribution that depends on IVI Compliance Package 4.4, you cannot uninstall IVI Compliance Package 4.4 without uninstalling the dependent product.
    • When installing a user-built distribution configured for distribution media smaller than 200MB that includes a Modular Instruments Run-Time distribution, an installation error might occur. Please refer to KnowledgeBase 5CT96RW1: NI IVI Engine Installation Failure When Included in User-built Distribution for more information.
    • If IVI Shared Components 2.2.1 or later is already installed when the ICP 4.4 installer is run, the IVI Shared Components feature(s) in the feature tree will not be displayed.
    • Because it has a ViInt64 attribute, the IviDigitizer Class Driver function panel file is in the CVI 8.5 format, which is incompatible with LabWindows/CVI versions prior to 8.5. Due to a known issue in LabWindows/CVI 8.5, the Get/Set/Check Attribute function panels do not display the enumerated values in the "Attribute Value" field when the FP format is 8.5. To enter a value manually, you may press "Ctrl+T". Because of this known issue, CVI 9.0.1 or later is recommended for use with the IviDigitizer FP file.
    • NI-Spy is now known as NI I/O Trace. Images in the National Instruments IVI Driver Help continue to reflect the NI-Spy name. However, the general functionality depicted in the images remains the same.
    Important Information
    © Copyright 1999–2011. National Instruments Corporation. All rights reserved.
    CVI™, IVI™, LabVIEW™, Measurement Studio™, National Instruments™, NI™, ni.com™, NI-DMM™, NI-FGEN™, and TestStand™ are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. The mark LabWindows is used under a license from Microsoft Corporation. Windows is a registered trademark of Microsoft Corporation in the United States and other countries. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    GMT+8, 2025-7-26 06:00
