查看: 4004|回复: 0
[NI驱动程序] NI IVI Compliance Package 4.6.1 Win32/64Eng NI IVI合规软件包ICP4.6.1下载
    昨天 10:50
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2020-12-21 23:47:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    IVI合规软件包
    Win32/64Eng
    4.6.1
    文件大小: 180993197 字节 (172.61 MB)
    修改日期: 2019-06-25 02:45
    MD5: 65830830d2e240aa9f54a22977bf06d0
    SHA1: 582bba675c354953f60f3874927d4edc44a20e1b
    SHA256: 461f2fb1a6e23d5d22eb8e32a5244e0f41dd83ab60755679be20fa3565427333
    CRC32: 9be4d72b
    ICP4.6.1.txt (594 Bytes, 下载次数: 0, 售价: 10 元)
    NI IVI Compliance Package 4.6.0Readme File
    IVI Compliance Package (ICP) 4.6 is an update release of IVI Compliance Package 4.5. This release includes the following new features and bug fixes:
    • Compliance with the new Windows 8 start screen (CAR 382391)
    • Update the base value of attribute IDs in IVI Header (CAR 361820)
    • IVI Measurement and Automation Explorer (MAX) Provider improvements (CARs 389480, 400051, 398939)
    • IVI Logical Name control performance improvement (CAR 355983)
    • IVI Portable Configuration improvement (CAR 355749)
    Refer to the IVI Compliance Package Release Notes, Version 4.6, for general information about this product.
    Contents
    Availability/Installation
    Known Incompatibilities
    Installed Components
    Uninstall Considerations
    • Windows 8 (32-bit or 64-bit)
    • Windows 7 (32-bit or 64-bit), including Starter Edition (32-bit)
    • Windows Vista (32-bit or 64-bit)
    • Windows XP Service Pack 3 or later
    IVI Compliance Package is included in the National Instruments Device Drivers media. A stand-alone version is available on ni.com.
    Before installing IVI Compliance Package 4.6, consider the following issues:
    • If you plan to use IVI Compliance Package 4.6 with LabVIEW, and/or LabWindows/CVI, make sure that you have already installed LabVIEW version 2010 or later, and/or LabWindows/CVI version 7.1 or later.
    • For compatibility reasons, the IVI Compliance Package 4.6 installation process enables write permissions for the IVI Standard Root directories (defaults: Program Files\IVI Foundation\IVI and Program Files(x86)\IVI Foundation\IVI) on Windows Vista, Windows 7 and Windows 8 systems.
    • National Instruments recommends that you close all other applications before you install IVI Compliance Package 4.6.
    To install the stand-alone, Web-only IVI Compliance Package 4.6 version, complete the following steps:
    • Download the IVI Compliance Package 4.6 self-extracting archive from http://www.ni.com/downloads by navigating through the Drivers and Updates link.
    • Double-click the self-extracting archive to launch the installer.
    • As of IVI Compliance Package 3.1, the IVI Compliance Package distribution no longer includes LabWindows/CVI 6.0 support. Please refer to the Using LabWindows/CVI 6.0 With ICP 3.1 document for details.
    • The IVI Specific Driver Test Suite in LabWindows/CVI 2009 requires ICP 4.1 or later.
    • The IVI Specific Driver Test Suite in LabWindows/CVI 2010 SP1 or later requires ICP 4.5 or later.
    IVI Compliance Package 4.6 installs the following components:
    • IVI class drivers
    • IVI class driver wrappers for LabVIEW 2010, 2011, 2012 and 2013
    • IVI Shared Components, version 2.2.1
    • IVI configuration plug-in for Measurement & Automation Explorer (MAX) 4.7.0 and later
    • Online help
    Note: The IVI Compliance Package 4.6 stand-alone, web-only distribution does not install NI I/O Trace (formerly known as NI-Spy) or MAX. You can install NI I/O Trace and MAX using several other National Instruments products, including the NI Device Drivers media.
    Note: You must have MAX 4.7.0 or later installed to use the IVI Configuration utility in MAX.
    Note: The installation directory for LabWindows/CVI IVI Class examples and IVI Class Simulation drivers has been changed. The new installation directory is \Documents\National Instruments\CVI\Samples\IVI directory.
    Note: IVI Compliance Package 4.6 includes IVI-COM adapters which enable users to use IVI-C and IVI-COM specific drivers interchangeably in the same 32-bit application. For more information on IVI-COM adapters, refer to the IVI-C Class Driver Support for IVI-COM Specific Drivers document.
    Note: IVI Compliance Package 4.5 and later installs alternate FP and SUB files for the IviFgen class driver in order to support setting 64-bit integer attributes. For more information, refer to KnowledgeBase 5WOA752F: Issue Setting IviFgen Attribute ID Using Get/Set/CheckAttributeViInt64 Functions.
    Complete the following steps to uninstall IVI Compliance Package 4.6:
    • Select Start»Settings»Control Panel»Add or Remove Programs.
    • Select NI IVI Compliance Package 4.6 and click Remove.
    Note: After you uninstall IVI Compliance Package 4.6, the IVI Shared Components remain on the system. Complete the following steps to uninstall the IVI Shared Components:
    • Select IVI Shared Components and click Change/Remove.
    Note: If you installed IVI Compliance Package 4.6 as part of another distribution that depends on IVI Compliance Package 4.6, you cannot uninstall IVI Compliance Package 4.6 without uninstalling the dependent product.
    • When installing a user-built distribution configured for distribution media smaller than 200MB that includes a Modular Instruments Run-Time distribution, an installation error might occur. Please refer to KnowledgeBase 5CT96RW1: NI IVI Engine Installation Failure When Included in User-built Distribution for more information.
    • If IVI Shared Components 2.2.1 or later is already installed when the ICP 4.6 installer is run, the IVI Shared Components feature(s) in the feature tree will not be displayed.
    • Because it has a ViInt64 attribute, the IviDigitizer Class Driver function panel file is in the CVI 8.5 format, which is incompatible with LabWindows/CVI versions prior to 8.5. Due to a known issue in LabWindows/CVI 8.5, the Get/Set/Check Attribute function panels do not display the enumerated values in the "Attribute Value" field when the FP format is 8.5. To enter a value manually, you may press "Ctrl+T". Because of this known issue, CVI 9.0.1 or later is recommended for use with the IviDigitizer FP file.
    • In the IviFgen FP file, the Attribute ID and Attribute Value controls in the Get/Set/CheckAttributeViInt64 function display an empty field instead of a list of attributes and values. For more information, refer to KnowledgeBase 5WOA752F: Issue Setting IviFgen Attribute ID Using Get/Set/CheckAttributeViInt64 Functions.
    • In the IVI Configuration Utility in MAX, the DAQmx devices (both simulated devices and real devices) will appear in the Resource Descriptor list in the Hardware Assets table only if you have DAQmx 9.2 or later installed.
    • NI-Spy is now known as NI I/O Trace. Images in the National Instruments IVI Driver Help continue to reflect the NI-Spy name. However, the general functionality depicted in the images remains the same.
    Important Information
    © Copyright 1999–2013. National Instruments Corporation. All rights reserved.
    CVI™, IVI™, LabVIEW™, Measurement Studio™, National Instruments™, NI™, ni.com™, NI-DMM™, NI-FGEN™, and TestStand™ are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. The mark LabWindows is used under a license from Microsoft Corporation. Windows is a registered trademark of Microsoft Corporation in the United States and other countries. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    GMT+8, 2025-7-26 05:52
