查看: 3114|回复: 0
[NI驱动程序] NI IVI Compliance Package 15.0 Win32/64Eng NI IVI合规软件包ICP15.0下载
    昨天 10:50
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2020-12-21 23:51:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    IVI合规软件包
    Win32/64Eng
    15.0
    文件大小: 196805446 字节 (187.69 MB)
    修改日期: 2019-06-25 02:45
    MD5: c6c80d836b678e6042a0be7fef42e22c
    SHA1: 51fb5b73f9138532065c46c7025c1cda31582084
    SHA256: 45af3c31151db13a026b97e79884704b751ab30778dd88ccc03e2283967be292
    CRC32: 12888217
    ICP15.0.txt (601 Bytes, 下载次数: 0, 售价: 10 元)
    NI IVI Compliance Package 15.0 Readme
    2015
    Version 15.0
    August 2015
    This file contains important information about the IVI Compliance Package, including installation instructions, new features, a partial list of bugs fixed for the IVI Compliance Package 15.0, and known issues.
    Uninstall Considerations
    New Features and Bug Fixes
    Driver Version Naming Changes
    Known Incompatibilities
    How to Use NI Software with Microsoft Windows 8.0/8.1.x
    IVI Compliance Package (ICP) 15.0 is an update release of IVI Compliance Package 14.0. IVI Compliance Package 15.0 installs the following components:
    • IVI class drivers
    • IVI class driver wrappers for LabVIEW 2012, 2013, 2014 and 2015
    • IVI Shared Components, version 2.3.0
    • IVI configuration plug-in for Measurement & Automation Explorer (MAX) 4.7.0 and later
    • Online help
    IVI Compliance Package has the following requirements:
    • Windows 8.0/8.1 (32-bit or 64-bit)
    • Windows 7 (32-bit or 64-bit), including Starter Edition (32-bit)
    • Windows Vista (32-bit or 64-bit)
    • Windows XP Service Pack 3 or later
    Note  IVI Compliance Package supports only R2 editions for Windows Server.
    The following table lists the NI application software versions, including service packs, supported by IVI Compliance Package. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    NI Application SoftwareVersions Supported by IVI Compliance Package
    NI LabVIEWLabVIEW version 2012 or later
    NI LabWindows™/CVI™LabWindows/CVI version 7.1 or later
    IVI Compliance Package is included in the National Instruments Device Drivers media. A stand-alone version is available on ni.com.
    Before installing IVI Compliance Package 15.0, consider the following issues:
    • For compatibility reasons, the IVI Compliance Package 15.0 installation process enables write permissions for the IVI Standard Root directories (defaults: Program Files\IVI Foundation\IVI and Program Files(x86)\IVI Foundation\IVI) on Windows Vista, Windows 7 and Windows 8.0/8.1 systems.
    • National Instruments recommends that you close all other applications before you install IVI Compliance Package 15.0.
    To install the stand-alone, Web-only IVI Compliance Package 15.0 version, complete the following steps:
    • Download the IVI Compliance Package 15.0 self-extracting archive from http://www.ni.com/downloads by navigating through the Drivers and Updates link.
    • Double-click the self-extracting archive to launch the installer.
    Notes:
    • The IVI Compliance Package 15.0 stand-alone, web-only distribution does not install NI I/O Trace (formerly known as NI-Spy) or MAX. You can install NI I/O Trace and MAX using several other National Instruments products, including the NI Device Drivers media.
    • You must have MAX 4.7.0 or later installed to use the IVI Configuration utility in MAX.
    • The installation directory for LabWindows/CVI IVI Class examples and IVI Class Simulation drivers has been changed. The new installation directory is \Documents\National Instruments\CVI\Samples\IVI directory.
    • IVI Compliance Package 3.2 and later includes IVI-COM adapters, which enable users to use IVI-C and IVI-COM specific drivers interchangeably in the same 32-bit application. For more information on IVI-COM adapters, refer to the IVI-C Class Driver Support for IVI-COM Specific Drivers document.
    • IVI Compliance Package 4.5 and later installs alternate FP and SUB files for the IviFgen class driver in order to support setting 64-bit integer attributes. For more information, refer to KnowledgeBase 5WOA752F: Issue Setting IviFgen Attribute ID Using Get/Set/CheckAttributeViInt64 Functions.
    • If you use IVI Compliance Package 4.5 or later to build a driver, it will work on a system that has IVI Compliance Package 2.5 or later. In addition, all specific drivers on IDNet have been rebuilt with IVI Compliance Package 4.6.1.
    Complete the following steps to uninstall IVI Compliance Package 15.0:
    • From the Control Panel, select Uninstall a Program.
    • Select NI IVI Compliance Package 15.0 and click Remove.
    Note: After you uninstall IVI Compliance Package 15.0, the IVI Shared Components remain on the system. To remove the remaining components, right-click IVI Shared Components 2.3.0 and select Uninstall/Change.
    Note: If you installed IVI Compliance Package 15.0 as part of another distribution that depends on IVI Compliance Package 15.0, you cannot uninstall IVI Compliance Package 15.0 without uninstalling the dependent product.
    This release includes the following new features and bug fixes:
    • Updated IviFgen Class Driver FP interface format (CAR 341802)
    • IVI Measurement and Automation Explorer (MAX) Provider improvements (CARs 475366, 494720, 509808, 510037)
    • IVI-COM Adapter improvement (CAR 482527)
    Refer to the IVI Compliance Package Release Notes, Version 15.0, for general information about this product.
    IVI Compliance Package versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, IVI Compliance Package 15.0 is the version released with LabVIEW 2015. The last version released under the old numbering scheme is IVI Compliance Package 4.6.1. The first version released under the new numbering scheme is IVI Compliance Package 15.0.
    • When installing a user-built distribution configured for distribution media smaller than 200MB that includes a Modular Instruments Run-Time distribution, an installation error might occur. Please refer to KnowledgeBase 5CT96RW1: NI IVI Engine Installation Failure When Included in User-built Distribution for more information.
    • If IVI Shared Components 2.3.0 or later is already installed when the ICP 15.0 installer is run, the IVI Shared Components feature(s) in the feature tree will not be displayed.
    • Because it has a ViInt64 attribute, the IviDigitizer Class Driver function panel file is in the CVI 8.5 format, which is incompatible with LabWindows/CVI versions prior to 8.5. Due to a known issue in LabWindows/CVI 8.5, the Get/Set/Check Attribute function panels do not display the enumerated values in the "Attribute Value" field when the FP format is 8.5. To enter a value manually, you may press "Ctrl+T". Because of this known issue, CVI 9.0.1 or later is recommended for use with the IviDigitizer FP file.
    • In the IVI Configuration Utility in MAX, the DAQmx devices (both simulated devices and real devices) will appear in the Resource Descriptor list in the Hardware Assets table only if you have DAQmx 9.2 or later installed.
    • NI-Spy is now known as NI I/O Trace. Images in the National Instruments IVI Driver Help continue to reflect the NI-Spy name. However, the general functionality depicted in the images remains the same.
    • The IVI Specific Driver Test Suite in LabWindows/CVI 2009 requires ICP 4.1 or later.
    • The IVI Specific Driver Test Suite in LabWindows/CVI 2010 SP1 or later requires ICP 4.5 or later.
    When you install National Instruments software on Microsoft Windows 8.0/8.1.x, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Note  NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.0/8.1.x. You can launch NI MAX either from the Apps view or from within NI Launcher.
    Windows 8.0/8.1.x DesktopDesktop TaskbarRight-click application and select Pin to Taskbar
    Windows 8.0/8.1.x DesktopStart screenRight-click application and select Pin to Start
    Windows 8.0/8.1.x Start screenDesktop TaskbarRight-click application and select Pin to taskbar from the menu bar on the bottom of the screen
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.0/8.1) or click the down arrow on the bottom left of the screen (Windows 8.1).
    For more information about NI support for Windows 8.0/8.1.x, visit ni.com/windows8.
    NI IVI Compliance Package Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments IVI Compliance Package will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of IVI Compliance Package that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 1999–2015 National Instruments. All rights reserved.
    GMT+8, 2025-7-26 05:55
