查看: 3818|回复: 0
[NI驱动程序] NI IVI Compliance Package 16.0.1 Win32/64Eng NI IVI合规软件包ICP16.0.1下载
    昨天 08:55
  • 签到天数: 3849 天
    连续签到: 42 天
    发表于 2020-12-21 23:53:58 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    IVI合规软件包
    Win32/64Eng
    16.0.1
    文件大小: 202434279 字节 (193.06 MB)
    修改日期: 2019-06-25 02:45
    MD5: caf88212a1ca8f35dfba74e8b5a3abb5
    SHA1: ef385c8d29d2193606fdba8a8751605e69f62fef
    SHA256: 16759e81f48b68e3a2235313b1e045837da3d38f373480057cf7edb74651870e
    CRC32: 060daf5b
    ICP16.0.1.txt (611 Bytes, 下载次数: 0, 售价: 10 圆)
    NI IVI Compliance Package 16.0.1 Readme
    August 2016
    This file contains important information about the IVI Compliance Package (ICP), including installation instructions, new features, a partial list of bugs fixed for ICP 16.0.1, and known issues.
    Installed Components
    Uninstall Considerations
    New Features and Bug Fixes
    Driver Version Naming Changes
    Known Incompatibilities
    NI Software Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 R2
    Depending on the software support you select when you install ICP 16.0.1, the installation includes one or more of the following components:
    • IVI class drivers
    • IVI class driver wrappers for LabVIEW 2013, 2014, 2015 and 2016
    • IVI Shared Components 2.4.1
    • IVI configuration plug-in for Measurement & Automation Explorer (MAX) 4.7 and later
    • Documentation
    ICP has the following requirements:
    • Windows 10 (32-bit or 64-bit)
    • Windows 8.1 Update 1 (32-bit or 64-bit)
    • Windows 7 SP1 (32-bit or 64-bit), including Starter Edition (32-bit)
    Note  ICP supports only R2 editions for Windows Server.
    The following table lists the NI application software versions, including service packs, supported by ICP.
    NI Application SoftwareVersions Supported by IVI Compliance Package
    NI LabVIEWLabVIEW version 2013 or later
    NI LabWindows™/CVI™LabWindows/CVI version 7.1 or later
    ICP is included in the National Instruments Device Drivers media. A stand-alone web distribution version is available on ni.com/downloads.
    Before installing ICP 16.0.1, consider the following issues:
    • For compatibility reasons, ICP 16.0.1 installation process enables write permissions for the IVI Standard Root directories (defaults: Program Files\IVI Foundation\IVI and Program Files(x86)\IVI Foundation\IVI) on Windows 7 Service Pack 1, and Windows 8.1 systems.
    • National Instruments recommends that you close all other applications before you install ICP 16.0.1.
    To install the stand-alone, web-only ICP, complete the following steps:
    • Download ICP 16.0.1 self-extracting archive file from http://www.ni.com/downloads by navigating through the Drivers and Updates link.
    • Double-click the self-extracting archive file to launch the installer.
    Notes:
    • ICP 16.0.1 stand-alone, web-only distribution does not install NI I/O Trace (formerly known as NI-Spy) or MAX. You can install NI I/O Trace and MAX using several other National Instruments products, including the NI Device Drivers media.
    • The installation directory for LabWindows/CVI IVI Class examples and IVI Class Simulation drivers has been changed. The new installation directory is \Documents\National Instruments\CVI\Samples\IVI directory.
    • ICP 3.2 and later versions include IVI-COM adapters, which enable users to use IVI-C and IVI-COM specific drivers interchangeably in the same 32-bit application. For more information on IVI-COM adapters, refer to the IVI-C Class Driver Support for IVI-COM Specific Drivers document.
    • ICP 4.5 and later versions install alternate FP and SUB files for the IviFgen class driver in order to support setting 64-bit integer attributes. For more information, refer to KnowledgeBase 5WOA752F: Issue Setting IviFgen Attribute ID Using Get/Set/CheckAttributeViInt64 Functions.
    • If you use ICP 4.5 or later to build a driver, it will work on a system that has ICP 2.5 or later. In addition, all specific drivers on IDNet have been rebuilt with ICP 4.6.1.
    Complete the following steps to uninstall ICP 16.0.1:
    • From the Control Panel, select Uninstall a Program.
    • Select NI IVI Compliance Package 16.0.1.
    • Click Remove.
    Note: After you uninstall ICP 16.0.1, the IVI Shared Components remain on the system. To remove the remaining components, right-click IVI Shared Components 2.4.1 and select Uninstall/Change.
    Note: If you installed ICP 16.0.1 as part of another distribution that depends on ICP 16.0.1, you cannot uninstall ICP 16.0.1 without uninstalling the dependent product.
    This release includes the following new features and bug fixes:
    • Add functions Ivi_AttributeIsAvailable and Ivi_SessionIsAvailable (CAR 569968)
    • Decoupling VISA header from IVI header (CAR 530691)
    • IVI MAX Provider improvements for 64-bit MI Soft Front Panel (CAR 575894)
    • IVI-COM Adapter IviFgen 5.2 support (CAR 315782)
    Refer to the IVI Compliance Package Release Notes, Version 16.0.1, for general information about this product.
    IVI Compliance Package (ICP) versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, ICP 16.0.1 is the version released with LabVIEW 2016. The last version released under the old numbering scheme is ICP 4.6.1. The first version released under the new numbering scheme is ICP 14.0.
    • When installing a user-built distribution configured for distribution media smaller than 200MB that includes a Modular Instruments Run-Time distribution, an installation error might occur. Please refer to KnowledgeBase 5CT96RW1: NI IVI Engine Installation Failure When Included in User-Built Distribution for more information.
    • If IVI Shared Components 2.4.1 or later is already installed when the ICP 16.0.1 installer is run, the IVI Shared Components feature(s) in the feature tree will not be displayed.
    • Because it has a ViInt64 attribute, the IviDigitizer Class Driver function panel file is in the CVI 8.5 format, which is incompatible with LabWindows/CVI versions prior to 8.5. Due to a known issue in LabWindows/CVI 8.5, the Get/Set/Check Attribute function panels do not display the enumerated values in the "Attribute Value" field when the FP format is 8.5. To enter a value manually, you may press "Ctrl+T". Because of this known issue, CVI 9.0.1 or later is recommended for use with the IviDigitizer FP file.
    • In the IVI Configuration Utility in MAX, the NI-DAQ™mx devices (both simulated devices and physical devices) will appear in the Resource Descriptor list in the Hardware Assets table only if you have NI-DAQ™mx 9.2 or later installed.
    • NI-Spy is now known as NI I/O Trace. Images in the National Instruments IVI Driver Help continue to reflect the NI-Spy name. However, the general functionality depicted in the images remains the same.
    • The IVI Specific Driver Test Suite in LabWindows/CVI 2009 requires ICP 4.1 or later.
    • The IVI Specific Driver Test Suite in LabWindows/CVI 2010 SP1 or later requires ICP 4.5 or later.
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10,  ni.com/windows10.
    Using NI Launcher
    Note  NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.1. You can launch NI MAX either from the Apps view or from within NI Launcher.
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.1) or click the down arrow on the bottom left of the screen (Windows 8.1).
    NI IVI Compliance Package Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 R2 in 2016
    National Instruments IVI Compliance Package (ICP) will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 R2 as of July 1, 2016. Versions of ICP that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003 R2. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 1999–2016 National Instruments. All rights reserved.
    GMT+8, 2026-4-8 07:47
