查看: 5005|回复: 0
[NI驱动程序] NI IVI Compliance Package 19.5 Win32/64Eng NI IVI合规软件包ICP19.5下载
    昨天 10:50
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2020-12-22 00:01:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    IVI合规软件包
    Win32/64Eng
    19.5
    文件大小: 583573504 字节 (556.54 MB)
    修改日期: 2019-10-25 22:28
    MD5: 2d5f34cf1f64f0d64576e9d8ba53e429
    SHA1: c81ead5d2f871d9b378731b9dbd3c2c64d4c3009
    SHA256: c073e6207720fbd4864eca79d02b0da9654d53c5fcecec562dbca12ff3811faf
    CRC32: e57d34f9
    ICP19.5.txt (657 Bytes, 下载次数: 1, 售价: 10 元)
    NI IVI Compliance Package 20.0 Readme
    May 2020
    This file contains important information about the IVI Compliance Package (ICP), including installation instructions, new features, a partial list of bugs fixed for ICP 20.0, and known issues.
    About IVI Compliance Package
    Installed Components
    Uninstall Considerations
    LabWindows/CVI Version Support
    New Features and Bug Fixes
    Known Incompatibilities
    ICP Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    The IVI Compliance Package is a software package that contains the IVI class drivers and support libraries necessary to develop and use applications that leverage IVI instrument interchangeability. The IVI Compliance Package also is based on and is compliant with the latest version of the instrument programming specifications defined by the IVI Foundation. You can use the IVI class drivers in the IVI Compliance Package with IVI specific drivers.
    IVI class drivers implement functions and attributes for controlling an instrument within a specified class, as defined by the IVI Foundation. The IVI Compliance Package provides IVI class drivers for the following specifications:
    • IviACPwr
    • IviCounter
    • IviDCPwr
    • IviDigitizer
    • IviDmm
    • IviDownconverter
    • IviFgen
    • IviPwrMeter
    • IviRFSigGen
    • IviScope
    • IviSpecAn
    • IviSwtch
    • IviUpconverter
    IVI specific drivers are drivers for the most popular instruments from all of the currently defined IVI Foundation classes and from the largest instrument manufacturers including National Instruments, Keysight Technologies, and Tektronix. You can create IVI specific drivers yourself, or download them from ni.com/idnet.
    Depending on the software support you select when you install ICP 20.0, the installation includes one or more of the following components:
    • IVI class drivers
    • IVI class driver wrappers for LabVIEW 2017, 2018, 2019, and 2020
    • IVI class driver wrappers for LabVIEW NXG 5.0
    • IVI.NET adapters
    • IVI Shared Components 2.6.1
    • IVI.NET Shared Components 1.4.1
    • IVI configuration plug-in for Measurement & Automation Explorer (MAX) 4.7 and later
    • Documentation
    ICP has the following requirements:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  Refer to ICP Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  In 2016, ICP dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. ICP 20.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use ICP 20.0 to an unsupported OS. Additionally, after installing ICP 20.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    ICP supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by ICP
    LabVIEW2017, 2018, 2019, 2020, and NXG 5.0
    NI LabWindows™/CVI™7.1, 8.0, 8.5, 9.0, 2009, 2010, 2012, 2013, 2015, 2017, 2019
    Note:  National Instruments recommends that you close all other applications before you install ICP 20.0. You must have at least 260 MB of free space available to install this product.
    Installing ICP for LabVIEW and LabWindows/CVI
    NI automates ICP installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    A stand-alone web distribution version is also available from ni.com/downloads.
    To install the stand-alone, web-only version of ICP, complete the following steps:
    • Download the ICP 20.0 self-extracting archive file from http://www.ni.com/downloads/drivers/ by searching for IVI Compliance Package.
    • Double-click the self-extracting archive file to launch the installer.
    Installing ICP for LabVIEW NXG
    You can install ICP at the same time that you install LabVIEW NXG. In Package Manager, select LabVIEW NXG and Drivers. Then select IVI Compliance Package from the list of drivers available to install.
    Installation Notes
    • The ICP 20.0 stand-alone, web-only distribution does not install NI I/O Trace (formerly known as NI-Spy) or MAX. You can install NI I/O Trace and MAX using several other National Instruments products, including the NI Device Drivers media.
    • The installation directory for LabWindows/CVI IVI Class examples and IVI Class Simulation drivers has been changed. The new installation directory is \Documents\National Instruments\CVI\Samples\IVI directory.
    • ICP 3.2 and later include IVI-COM adapters, which enable users to use IVI-C and IVI-COM specific drivers interchangeably in the same 32-bit application. For more information on IVI-COM adapters, refer to the IVI-C Class Driver Support for IVI-COM Specific Drivers document.
    • ICP 19.0 and later includes IVI.NET adapters, which enable users to use IVI-C and IVI.NET specific drivers interchangeably in the same application.
    • ICP 4.5 and later installs alternate FP and SUB files for the IviFgen class driver in order to support setting 64-bit integer attributes. For more information, refer to KnowledgeBase 5WOA752F: Issue Setting IviFgen Attribute ID Using Get/Set/CheckAttributeViInt64 Functions.
    After you uninstall ICP 20.0, the IVI Shared Components remain on the system. To remove the remaining components, right-click IVI Shared Components 2.6.1 and select Uninstall/Change.
    If you installed ICP 20.0 as part of another distribution that depends on ICP 20.0, you cannot uninstall ICP 20.0 without uninstalling the dependent product.
    This release includes the following new features and bug fixes:
    • Support for LabVIEW 2020 and LabVIEW NXG 5.0
    • Minor bug fixes
    • NI-Spy is now known as NI I/O Trace. Images in the National Instruments IVI Driver Help continue to reflect the NI-Spy name. However, the general functionality depicted in the images remains the same.
    • To build the IVI Class Simulation drivers using LabWindows/CVI 2015 or later, make sure to include the htmlhelp.lib and BufferOverflowU.lib files from the Windows SDK version 8.1.
    • In ICP 19.5 and IVI Shared Components 2.6 or later, the installers no longer unlock the IVI Foundation directory. Therefore, you no longer can modify the files installed under the IVI Foundation directory.
    The following sections detail considerations for using LabVIEW NXG with ICP 20.0.
    • System requirements: Only 64-bit (x64) processors are supported.
    • Operating system: Only 64-bit operating systems are supported. Refer to the Supported Operating Systems section for more information.
    LabVIEW NXG Help
    View context help in LabVIEW NXG by pressing and hovering over an object.
    Search for items using the search bar in the upper right corner of the LabVIEW NXG window. You can also view context help for the search results.
    LabVIEW NXG Examples
    ICP will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 1999–2019 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help>>;Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents.
    376942E-01
    GMT+8, 2025-7-26 05:54
