查看: 2562|回复: 0
[NI软件套件] LabVIEW 2013 Fall Student Suite Win32Eng LabVIEW2013秋季学生版套件英文版
    8 小时前
  • 签到天数: 3527 天
    连续签到: 15 天
    发表于 2020-12-23 23:37:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW学生软件套件
    LabVIEW学生软件套件包括LabVIEW学生版、Circuit Design Suite以及六个软件附件(Control Design and Simulation Module、Digital Filter Design Toolkit、Modulation Toolkit、MathScript RT Module、Vision Builder for Automated Inspection、Vision Development Module)。
    LabVIEW学生软件套件是一个针对院校和工程应用的软件套件。该套件提供了LabVIEW学生版、Circuit Design Suite以及六个软件附件(Control Design and Simulation Module、Digital Filter Design Toolkit、Modulation Toolkit、MathScript RT Module、Vision Builder for Automated Inspection、Vision Development Module),其中包括调制、测量、检查和开发功能。
    2013Fall
    ENG
    文件大小: 5383369865 字节 (5.01 GB)
    修改日期: 2013-08-27 05:13
    MD5: 70f88cd37a82f824f7e8925c482b72be(官方正确)
    SHA1: a459b37730049d3a0e91cd9292ec40d74b75fa65
    SHA256: b8a504e0ccc0b04f7a9a72428ca2dbe926c257915df9d2e56dba96695e4a795f
    CRC32: edb26761
    LVStudent2013FallEng.txt (605 Bytes, 下载次数: 0, 售价: 30 元)
    NI Student Edition DVD Readme
    This file contains important information about the NI Student Edition software and is organized into the following sections:
    Installing, Evaluating, and Activating NI Student Edition Software
    OS X Support for NI Driver and Application Software
    64-bit Versions of NI LabVIEW and NI Vision
    LabVIEW MathScript RT Module for OS X or Linux
    NI Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    Readmes for Products on the NI Student Edition DVD
    Install modules and toolkits from the NI Student Edition DVD to ensure compatibility with the version of LabVIEW included in this release.
    Complete the following steps to install products on the NI Student Edition DVD:
    • Insert the NI Student Edition DVD.
    • Select the products you want to install. Select Install to minimize your interaction during installation.
    • Enter the serial number or leave the field blank for a temporary trial. Locate the serial number on the Certificate of Ownership, the product packing slip, or the shipping label, depending on your purchase.
    • Begin installation and follow the instructions on your screen.
    • Activate when prompted.
    Save the media in order to modify or repair your installation, or to distribute NI software with your custom-built installers.
    Refer to the NI Student Edition printed documentation for additional activation instructions and a complete list of modules and toolkits available.
    Back to Top
    Some NI software and driver products do not currently support OS X 10.7, and will not install and/or function on machines running this operating system. For more information on this issue, go to ni.com/info and enter the Info Code NIMacLion. For information on LabVIEW OS X support, refer to the LabVIEW Readme. To access the LabVIEW Readme, go to ni.com/info and enter the Info Code lv2013rm
    Back to Top
    64-bit versions of NI LabVIEW and NI Vision software are available for download or upon request. To request copies of these software packages, visit ni.com/info and enter the Info Code lv64bit.
    Back to Top
    To request a version that runs on OS X or Linux, visit ni.com/info and enter the Info Code ASLMathScript.
    Back to Top
    Back to Top
    Using NI Launcher
    Note  Unlike previous versions of Microsoft Windows, MAX does not appear as a desktop shortcut. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    Back to Top
    National Instruments will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of most products that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI LabWindows/CVIcvi_lifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Back to Top
    Refer to the following readmes for information about each product on the NI Student Edition DVD, including installation, activation, known issues, and bug fixes. For information about NI Device Drivers, refer to the readme on the NI Device Drivers media or visit ni.com/info and enter the Info Code driverAug2013.
    • LabVIEW Development System
    • LabVIEW Control Design Assistant
    • LabVIEW Control Design and Simulation Module
    • LabVIEW MathScript RT Module
    • LabVIEW LEGO® MINDSTORMS® NXT Module
    • NI Vision Development Module
    • LabVIEW Digital Filter Design Toolkit
    • LabVIEW Modulation Toolkit
    • LabVIEW System Identification Toolkit
    • NI SignalExpress
    • Vision Builder for Automated Inspection
    • NI Circuit Design Suite
    Back to Top
    Important Information
    © 2008–2013 National Instruments. All rights reserved.
    GMT+8, 2025-4-28 16:51
