查看: 4851|回复: 0
[NI驱动程序] LabVIEW Instrument Design Libraries for High-Speed Serial Instruments 18.0 Win32Eng LabVIEW高速串行仪器设计库18.0
    8 小时前
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2020-12-28 00:25:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW Instrument Design Libraries for High-Speed Serial Instruments软件可帮助您为PXI高速串行仪器创建应用程序。
    LabVIEW Instrument Design Libraries for High-Speed Serial Instruments是LabVIEW的一个驱动软件,用于创建和开发高速串行应用程序。该软件用作为用户和供应商代码之间的接口,适用于主机和FPGA,并可实现仪器常见的功能。LabVIEW Instrument Design Libraries for High-Speed Serial Instruments软件还可帮助您将项目导出到Vivado设计套件中。
    Win32Eng
    18.0
    文件大小: 1378684808 字节 (1.28 GB)
    修改日期: 2018-07-03 23:35
    MD5: e608004690e7f21faa42dbad2c0f7ae0(官方正确)
    SHA1: fced6d45a4243cb6c050d486ef8a58ad57038d2d
    SHA256: b8e36873a9330ea96feffa4eb2b71633badb5049bad3555a457b1468c109d088
    CRC32: 02e91756
    LVIDLHSSI18.0.txt (686 Bytes, 下载次数: 0, 售价: 10 圆)
    NI LabVIEW 2018 Instrument Design Libraries for High Speed Serial Instruments 18.0 Readme
    June 2018
    Thank you for using NI LabVIEW 2018 Instrument Design Libraries for High-Speed Serial Instruments 18.0. This file contains important information about NI LabVIEW 2018 Instrument Design Libraries for High-Speed Serial Instruments 18.0 and is organized into the following sections.
    Sample Projects
    Driver Version Naming Changes
    Installing NI LabVIEW 2018 Instrument Design Libraries for High-Speed Serial Instruments 18.0
    Known Issues and Bug Fixes
    How to Use NI Software with Microsoft Windows 8.1
    NI LabVIEW 2018 Instrument Design Libraries for High-Speed Serial Instruments 18.0 allows you to develop high-speed serial applications for use with the PXIe-6591R, PXIe-6592R, and PXIe-7902 high-speed serial modules.
    NI LabVIEW 2018 Instrument Design Libraries for High-Speed Serial Instruments 18.0 includes the following new features.
    • Support for LabVIEW 2018
    • Support for LabVIEW 2018 64-bit (previous versions supported development only in LabVIEW 32-bit)
    NI LabVIEW 2017 Instrument Design Libraries for High-Speed Serial Instruments 17.0 includes the following new features.
    • Support for LabVIEW 2017
    • Support for exporting projects to Vivado Design Suite
    NI LabVIEW 2016 Instrument Design Libraries for High-Speed Serial Instruments 16.1 includes the following new features.
    • Support for the PXIe-7902 module
    • 1 Gigabit Ethernet sample project
    NI LabVIEW 2016 Instrument Design Libraries for High-Speed Serial Instruments 16.0 includes the following new features.
    • Support for LabVIEW 2016
    NI LabVIEW 2018 Instrument Design Libraries for High-Speed Serial Instruments 18.0 supports the following hardware devices:
    • PXIe-6591R
    • PXIe-6592R
    • PXIe-7902
    Note: The following system requirements apply to NI LabVIEW 2018 Instrument Design Libraries for High-Speed Serial Instruments 18.0 software only. LabVIEW FPGA has separate system requirements. Refer to the LabVIEW Readme for these system requirements.
    NI LabVIEW 2018 Instrument Design Libraries for High-Speed Serial Instruments 18.0 supports the following operating systems:
    Operating System64-bit32-bit
    Windows 10
    Windows 8.1
    Windows 7 Professional
    Windows Server 2012 R2
    Windows Server 2008 R2
    Note: NI LabVIEW 2018 Instrument Design Libraries for High-Speed Serial Instruments 18.0 does not support Windows Server non-R2 editions.
    Minimum System Requirements
    • RAM—2 GB
    • Windows 10/8.1/7 or Windows Server 2008/2012 with all available critical updates and service packs
    The following table lists the NI application software versions, including service packs, supported by NI LabVIEW 2018 Instrument Design Libraries for High-Speed Serial Instruments 18.0.
    NI Application SoftwareVersions Supported by NI LabVIEW 2018 Instrument Design Libraries for High-Speed Serial Instruments 18.0
    NI LabVIEWLabVIEW 2018 32-bit, LabVIEW 2018 64-bit
    LabVIEW FPGALabVIEW FPGA 32-bit, LabVIEW FPGA 64-bit
    LabVIEW Real-TimeLabVIEW Real-Time 2018
    The product documentation is available at ni.com/manuals and from Start»All Programs»National Instruments»High Speed Serial Instruments»High Speed Serial Instruments Documentation.
    To view these documents, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    The documentation set is composed of the following documents:
    DocumentDescription
    NI High Speed Serial Instruments HelpContains information about high-speed serial instrument device support. This book also provides instructions for using LabVIEW and the LabVIEW FPGA Module with high-speed serial modules.
    High Speed Serial Instruments User ManualContains information about how to develop applications for your high-speed serial modules.
    Getting started guide for your deviceContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your high-speed serial module.
    Specifications document for your deviceLists technical specifications for your high-speed serial module.
    NI LabVIEW 2018 Instrument Design Libraries for High-Speed Serial Instruments 18.0 Readme (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Sample Projects
    In LabVIEW, you can use the NI Example Finder to search or browse examples. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs and their descriptions:
    • Click the Browse tab to locate modulation examples by task.
    • Click the Search tab to search all installed examples by keyword.
    Examples also are available online that demonstrate applications using high-speed serial instruments. Refer to ni.com/examples for these examples and for more information.
    NI LabVIEW 2018 Instrument Design Libraries for High-Speed Serial Instruments 18.0 versions are aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions start with a two-digit year indicator: <;ProductName>. For example, NI LabVIEW 2016 Instrument Design Libraries 16.0 is the version released with LabVIEW 2016.
    Complete the following steps to install NI LabVIEW 2018 Instrument Design Libraries for High-Speed Serial Instruments 18.0.
    • Install LabVIEW. Refer to the LabVIEW Installation Guide for installation instructions for LabVIEW and system requirements for the LabVIEW software. Refer to the LabVIEW Upgrade Notes for additional information about upgrading to the most recent version of LabVIEW for Windows.
      • Documentation for LabVIEW is available at ni.com/manuals and from Start»All Programs»National Instruments»LabVIEW»LabVIEW Manuals.
    • Install the LabVIEW FPGA Module. Refer to the LabVIEW FPGA Module Release and Upgrade Notes for installation instructions and information about getting started with the LabVIEW FPGA Module.
      • Documentation for the LabVIEW FPGA Module is available at ni.com/manuals and from Start»All Programs»National Instruments»LabVIEW»LabVIEW Manuals.
    • Install the NI LabVIEW 2018 Instrument Design Libraries for High-Speed Serial Instruments 18.0 driver.
      • Documentation for the NI LabVIEW 2018 Instrument Design Libraries for High-Speed Serial Instruments 18.0 driver is available at ni.com/manuals and by selecting Start»All Programs»National Instruments»High-Speed Serial Instruments»High-Speed Serial Instruments Documentation.
    Note The niSi53xxClockConfig.dll file included as part of the NI LabVIEW Instrument Design Libraries for High-Speed Serial Instruments software may be used only in the use of the NI LabVIEW Instrument Design Libraries for High-Speed Serial Instruments software with the Silicon Labs device in the PXIe-6591R, PXIe-6592R, and PXIe-7902 products.
    You can access the bug fixes and software and documentation known issues lists online at ni.com/info by entering Info Code exty47.
    When you install National Instruments software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Note  NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.1. You can launch NI MAX either from the Apps view or from within NI Launcher.
    Windows 8.1 DesktopDesktop TaskbarRight-click application and select Pin to Taskbar.
    Windows 8.1 DesktopStart screenRight-click application and select Pin to Start.
    Windows 8.1 Start screenDesktop TaskbarRight-click application and select Pin to taskbar from the menu bar on the bottom of the screen.
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and click the down arrow on the bottom left of the screen.
    ©2008–2018 National Instruments. All rights reserved.
    374806F-01
    GMT+8, 2025-12-12 16:16
