查看: 3390|回复: 0
[NI驱动程序] NI ELVISmx 4.5 Driver Win32Eng NI ELVISmx设备驱动软件4.5下载
    11 小时前
    发表于 2020-12-29 23:19:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI ELVISmx
    NI-ELVISmx为使用NI ELVIS II和NI ELVIS II +以及myDAQ学生数据采集设备的客户提供支持。
    NI-ELVISmx是支持NI ELVIS II、NI ELVIS II +和myDAQ设备的驱动软件。NI-ELVISmx包括NI ELVISmx Instrument Launcher、LabVIEW Express VI和编程NI ELVIS II/II+硬件的SignalExpress步骤。
    Win32Eng
    4.5
    文件大小: 1340465672 字节 (1.25 GB)
    修改日期: 2013-08-27 05:12
    版本: 1.5.0.2712
    MD5: 9c20045cf563054a3bc55bd9e6f6109d(官方正确)
    SHA1: 945aba1ef567f4dd0c3995576f34b1de5afb2464
    SHA256: c3e5c67c8981941519e23aa7060bc829e82fafb90ae1ef8de2c2330a5901775d
    CRC32: 2e13e142
    ELVISmx4.5.0.txt (618 Bytes, 下载次数: 0, 售价: 10 圆)
    NI ELVISmx 4.5 Readme
    June 2013
    This file contains important information about the NI ELVISmx software and is organized into the following sections:
    Operating System Support
    Software Requirements
    What's New
    Using the Instruments in Manual Mode (NI ELVIS II Series Only)
    Fixed Issues
    NI ELVISmx Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    The NI ELVISmx driver provides driver support for NI ELVIS II series and NI myDAQ hardware. Refer to ni.com/downloads for the latest information about the NI ELVISmx driver.
    For more information on how to get started with NI ELVIS II series, visit ni.com/nielvis. Visit ni.com/mydaq for materials related to NI myDAQ.
    Note:  NI ELVISmx driver software does not support Legacy NI ELVIS workstations. National Instruments recommends NI ELVIS II/II+ programmed with NI ELVISmx driver software for new applications. Refer to ni.com/downloads for the NI ELVIS Software driver for Legacy ELVIS workstations.
    The following operating systems are supported in NI ELVISmx 4.5:
    • Windows 8 (32-bit and 64-bit)*
    • Windows 7 (32-bit and 64-bit)*
    • Windows Vista Business edition, Service Pack (SP) 1 or greater (32-bit and 64-bit)*
    • Windows XP, SP3 or greater
    • Windows Server 2008, including R2, SP1 or greater (64-bit, not supported on Server Core Role)*
    * NI ELVISmx is not supported in LabVIEW (64-bit). To use LabVIEW with NI ELVISmx on a Windows 8/7/Vista (64-bit) operating system, you must have LabVIEW (32-bit) installed.
    Back to Top
    You must have NI-DAQmx 9.7.5 or later installed to use NI ELVISmx 4.5. NI ELVISmx 4.5 installs NI-DAQmx 9.7.5 by default. NI ELVISmx 4.5 is used with LabVIEW 2010 or later. If you are using NI SignalExpress, you must use version 2011 or later. If you are using NI Multisim, you must use version 12.0 or later.
    Note: Because several of the NI ELVISmx instruments run the device at maximum speed, NI ELVIS II Series and NI myDAQ devices must be used with Hi-Speed USB interfaces.
    Back to Top
    What's New
    NI ELVISmx 4.5 includes support for LabVIEW 2013.
    Back to Top
    The Variable Power Supplies and Function Generator can be set to Manual mode or Software mode by using their associated Soft Front Panel Instruments, Express VIs, or SignalExpress Steps. In Manual mode, the knobs on the NI ELVIS II Series Workstation control the instrument outputs.
    Back to Top
    The following list describes the documentation that installs with NI ELVISmx:
    • Where to Start with NI ELVIS II Series—This document includes important installation and configuration instructions you should read before using the NI ELVISmx software and NI ELVIS II Series hardware.
    • NI Educational Laboratory Virtual Instrumentation Suite II Series (NI ELVIS II Series) User Manual—This user manual provides more detailed information about the NI ELVIS II Series hardware, including specifications and safety information.
    • NI ELVIS II Series Specifications—This document lists the hardware specifications for the NI ELVIS II series devices.
    • NI myDAQ User Guide and Specifications—This user guide provides more detailed information about the NI myDAQ hardware, including specifications and safety information.
    • NI ELVISmx Help—This help file provides information about the soft front panel (SFP) instruments and the LabVIEW Express VIs that you may need while using the software.
    • SignalExpress Help—This help file contains instructions for designing measurement projects using the NI ELVISmx steps in SignalExpress.
    • Using NI ELVISmx Instruments in NI Multisim—This help file explains how to use NI ELVISmx instruments in NI Multisim to simulate data, acquire data from hardware, and compare simulated and acquired data.
    To download the latest NI ELVISmx documentation, refer to ni.com/manuals.
    Back to Top
    Fixed Issues
    The following issues were fixed in this release of NI ELVISmx driver software.
    CAR IDSummary
    107798When the Function Generator SFP is in Manual Mode, the instrument disables controls that are not available on the NI ELVIS II workstation.
    373017The Bode Analyzer SFP always measures 5 Steps (per decade), regardless of what the user selects on the Steps (per decade) control.
    410171Impedance Analyzer SFP and Express VI are presenting incorrect phase measurement results.
    Back to Top
    • When using NI ELVISmx SFPs, controls can disable/enable incorrectly and/or contain incorrect values when an invalid device is selected. A device becomes invalid when it is disconnected from the PC while the SFP Device control drop-down dialog is open. If the disconnected device is selected from the drop-down control and then reconnected, the SFP controls may not update correctly. Selecting the device again from the SFP Device control corrects the issue.
    • Scope Zoom has been hidden. You can enable it using the steps outlined in the KB document, KB 4T5GG7HF: How Do I Display the Zoom Controls on the NI ELVISmx Scope Soft Front Panel?. To access this document, go to ni.com/info and enter the Info Code exh3ma.
    • The NI ELVIS II Series device must be plugged into the system and powered on before launching the NI ELVISmx Express VIs and SignalExpress steps in order for it to be recognized by the software. If the device is plugged in after the software is launched, close the software application and relaunch it.
    • Some NI ELVISmx instruments are not supported by NI myDAQ. For more information on NI ELVISmx instrument support, refer to the NI ELVISmx Help.
    • When running the NI ELVISmx Express VIs continuously in a loop, wire the Stop input of the Express VI to the Stop control of the loop for optimal performance.
    • In SignalExpress, if you drag NI ELVISmx steps data into the SignalExpress Data view, the graph axes always default to voltage versus time. If you want to change these defaults (for instance, to current versus voltage), you must manually change the labels on the graph.
    Back to Top
    Back to Top
    Using NI Launcher
    Finding All Programs
    Back to Top
    National Instruments ELVISmx will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI ELVISmx that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI LabWindows/CVIcvi_lifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Back to Top
    Important Information
    © 2003–2013 National Instruments. All rights reserved.
    GMT+8, 2025-12-8 20:46
