查看: 2906|回复: 0
[NI驱动程序] NI FlexRIO Adapter Module Support 2.0 Driver Win32Eng NI FlexRIO适配器模块支持驱动软件2.0下载
    10 小时前
    发表于 2020-12-30 23:17:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI FlexRIO适配器模块支持
    NI FlexRIO Adapter Module Support为FlexRIO适配器模块提供LabVIEW支持。
    NI FlexRIO Adapter Module Support是一款驱动软件,可支持并访问FlexRIO适配器模块的I/O,包括数字化仪、收发仪、信号发生器、射频和DIO适配器模块。该软件还提供示例来帮助用户开始使用各种FlexRIO适配器模块。必须安装NI-FlexRIO才可使用该软件。
    Win32Eng
    2.0
    文件大小: 112408809 字节 (107.20 MB)
    修改日期: 2010-09-03 22:10
    MD5: 58a5114a8f34f83ee33b3c624bdced9f(官方正确)
    SHA1: 3b9b3cf4dbf77505c5e093ed7a9e45349fa2c7fa
    SHA256: d32be531b47bb1b406a7fddb609c37843658f1f7d2e04cc5a6786b4dec02162b
    CRC32: 38a1a99c
    FlixeRIOAMS2.0.txt (614 Bytes, 下载次数: 0, 售价: 10 圆)
    NI FlexRIO™ Adapter Module Support Readme
    Version 2.0
    Thank you for using NI FlexRIO Adapter Module Support. This file contains important information about the NI FlexRIO Adapter Module Support software, and it is organized into the following sections:
    • New Features
    • Supported Hardware
    • Installing NI FlexRIO Adapter Module Support 2.0
    • Supported Platforms
    • Uninstalling/Modifying NI FlexRIO Adapter Module Support
    • Documentation
    NI FlexRIO Adapter Module Support 2.0 includes the following new features:
    • Support for LabVIEW 2010 (32-bit).
    NI FlexRIO Adapter Module Support software supports the following NI FlexRIO adapter modules:
    • NI 5751
    • NI 5752
    • NI 5761
    • NI 5781
    • NI 6581
    • NI 6583
    • NI 6584
    • NI 6585
    Installing NI FlexRIO Adapter Module Support 2.0 with LabVIEW 8.6 Examples
    Complete the following steps to install NI FlexRIO Adapter Module Support 2.0:
    • Install LabVIEW 8.6.1.
    • (Optional) Install LabVIEW Real-Time 8.6.1.
    • Install LabVIEW FPGA 8.6.1.
    • Install NI-RIO 3.5.
    • Install NI FlexRIO Adapter Module Support 2.0.
    Installing NI FlexRIO Adapter Module Support 2.0 with LabVIEW 2009 Examples
    • Install LabVIEW 2009.
    • (Optional) Install LabVIEW Real-Time 2009.
    • Install LabVIEW FPGA 2009.
    Installing NI FlexRIO Adapter Module Support 2.0 with LabVIEW 2010 Examples
    • Install LabVIEW 2010.
    • (Optional) Install LabVIEW Real-Time 2010.
    • Install LabVIEW FPGA 2010.
      Note: In the LabVIEW FPGA installation menu, you must also install the Compilation Tools for FPGA Devices other than Virtex-II to use these examples.
    Note: Visit ni.com/info and enter rdsoftwareversion as the Info Code for more information about which minimum software versions you need for your device.
    Supported Platforms
    NI FlexRIO Adapter Module Support 2.0 supports the following platforms:
    • Windows 7 Professional (32-bit and 64-bit)
    • Windows Vista Business (32-bit and 64-bit)
    • Windows XP Professional
    • Click Change/Remove.
    • Select NI FlexRIO Adapter Module Support 2.0 from the dialog box that appears.
    The product documentation is available at Start» Programs臧ational Instruments»NI-RIO»FlexRIO». Visit ni.com/manuals for the latest versions of product documentation.
    To view these documents, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    Refer to ni.com/flexrio for additional NI FlexRIO product support and information.
    Important Information
    © 2008–2010 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-12-8 19:54
